path: root/Makefile
2013-11-25Prepare v2014.01-rc1v2014.01-rc1Tom Rini
2013-11-25Makefile: move some libraries to lib/MakefileMasahiro Yamada
2013-11-25Makefile: descend into subdirectories only when CONFIG_API is definedMasahiro Yamada
All objects under api/ and examples/api/ directories are selected by CONFIG_API. So we can move CONFIG_API switch to the top Makefile. In order to use CONFIG_API, the definition of SUBDIR_EXAMPLES-y must be moved after "sinlude $(obj)include/autoconf.mk". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25tools: updater: Remove remainders of dead boardMasahiro Yamada
tools/updater needs board/MAI/AmigaOneG3SE board for compiling. But AmigaOneG3SE board was already deleted by Commit 953b7e6. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17Makefile: move fs/fat/ entry to drivers/MakefileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-11-17powerpc: mpc824x: Do not create a symbolic link to bedbug_603e.cMasahiro Yamada
2013-11-17powerpc: mpc83xx: Do not create a symbolic link to ddr-gen2.cMasahiro Yamada
2013-11-17Makefile: delete unused linesMasahiro Yamada
2013-11-17Makefile: refactor a littleMasahiro Yamada
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2013-11-17drivers/net/npe: descend only when CONFIG_IXP4XX_NPE=yMasahiro Yamada
CONFIG_IXP4XX_NPE is defined only for CPU ixp. It is not necessary to filter by CPU ixp. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17drivers/net/fm: descend only when CONFIG_FMAN_ENET=yMasahiro Yamada
CONFIG_FMAN_ENET is defined only for CPU mpc85xx. We do not need to filter by CPU mpc85xx. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17drivers/qe: move the entry to drivers/MakefileMasahiro Yamada
2013-11-17powerpc: move mpc8xxx entry under arch/powerpc/cpu/Masahiro Yamada
2013-11-17Makefile: merge $(LIBBOARD) into $(LIBS)Masahiro Yamada
We do not need to handle $(LIBBOARD) and $(LIBS) separately. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17lib: descend into sub directories only when it is necessaryMasahiro Yamada
2013-11-06Makfile: fix a rule to build u-boot.sbMasahiro Yamada
2013-11-01Makefile: convert makefiles to Kbuild style and delete grep switchMasahiro Yamada
We have converted all makefiles needed to build $(LIBS). Until this commit we used to grep switch so that U-Boot style and Kbuild style makefiles coexist. But we do not need any more. Goint forward, use always Kbuild style Makefile when adding a new Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-01dts, api, test: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-31ARM: s5pc, exynos: move Samsung ARM SoC specific code under arch/arm/Masahiro Yamada
This patch moves S5PC, EXYNOS specific directory entries from the toplevel Makefile to arch/arm/cpu/armv7/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2013-10-31ARM: omap: move OMAP specific code under arch/arm/Masahiro Yamada
This patch moves OMAP specific directory entries from the toplevel Makefile and spl/Makefile to arch/arm/cpu/armv7/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2013-10-31ARM: tegra: move Tegra specific code under arch/arm/Masahiro Yamada
This patch moves Tegra specific directory entries from the toplevel Makefile and spl/Makefile to arch/arm/cpu/*/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <TWarren@nvidia.com>
2013-10-31fs: move some file system to fs/MakefileMasahiro Yamada
This commit moves some subdirectories of fs from the toplevel Makefile to fs/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-10-31drivers: move some drivers to drivers/MakefileMasahiro Yamada
This commit moves some drivers subdirectory entry from the toplevel Makefile to drivers/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31ARM: imx-common: convert makefiles to Kbuild styleMasahiro Yamada
Multiple targets are included in arch/arm/imx-common/Makefile In order to refactor it, we need to tweak Makefile and spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31Makefile: prepare for using Kbuild-style MakefileMasahiro Yamada
Every makefile in sub directories has common lines at the top and the bottom. This commit pushes the common parts into script/Makefile.build. Going forward sub-makefiles only need to describe this part: COBJS := ... COBJS += ... SOBJS := ... But using obj-y is preferable to prepare for switching to Kbuild. The conventional (non-Kbuild) Makefile style is still supported. This is achieved by greping the Makefile before entering into it. U-Boot conventional sub makefiles always include some other makefiles. So the build system searches a line beginning with "include" keyword in the makefile in order to distinguish which style it is. If the Makefile include a "include" line, we assume it is a conventional U-Boot style. Otherwise, it is treated as a Kbuild-style makefile. With this tweak, we can switch sub-makefiles from U-Boot style to Kbuild style little by little. obj-y := foo/ syntax (descending into the sub directory) is not supportd yet. It will be implemented in the upcomming commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2013-10-16powerpc/tool/pbl: fix pbl image compiling processShaohui Xie
Previous process of compiling a PBL boot image is: 1: make <board_name_config> 2: make u-boot.pbl for example: make T4240QDS_SDCARD_config make u-boot.pbl Now the process is: 1: make <board_name> for example: make T4240QDS_SDCARD Also, updated README.pblimage. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2013-10-16Prepare v2013.10v2013.10Tom Rini
2013-10-14Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-10-02Prepare v2013.04-rc4v2013.10-rc4Tom Rini
2013-09-25drivers:power:max77693: add support for new multi function pmic max77693Piotr Wilczek
This patch add support for new multi function pmic max77693. The driver is split into three modules: pmic, muic and fuelgage. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-20Makefile: Do not show make debug messagesMasahiro Yamada
In commit 27af930, the top Makefile was adjusted to the new boards.cfg format. But at the same time, -d option was added. If you configure and make separately, for example like follows: make omap4_panda_config make CROSS_COMPILE=<your_compiler_prefix> it works fine as it did before. But if you do them in one time like follows: make omap4_panda CROSS_COMPILE=<your_compiler_prefix> The log is sprinkled with annoying make debug messages. This commit deletes -d option again. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Nishanth Menon <nm@ti.com>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-16Prepare v2013.10-rc3v2013.10-rc3Tom Rini
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-06Always build u-boot.img when using CONFIG_SPL_FRAMEWORKHenrik Nordström
Use of uImage formatted u-boot have long been preferred, and recent changes to better support Falcon mode on MMC now enforces it on MMC. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net>
2013-09-02Prepare v2013.10-rc2v2013.10-rc2Tom Rini
2013-08-27CONFIG: EXYNOS5: Replace misnomer SMDK5250 with EXYNOS5250 and update MakefilesChander Kashyap
Update the Makefiles so that all boards can use the same spl generation tool Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-21Makefile: Fix build in a separated directory treeYork Sun
Fix a bug introduced by commit 3aa29dee TPL : introduce the TPL based on the SPL Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-20TPL : introduce the TPL based on the SPLYing Zhang
Due to the nand SPL on some board(e.g. P1022DS)has a size limit, it can not be more than 4K. So, the SPL cannot initialize the DDR with the SPD code. This patch introduces TPL to enable a loader stub that is loaded by the code from the SPL. It initializes the DDR with the SPD or other operations. The TPL's size is sizeable, the maximum size is decided by the memory's size that TPL runs. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are three stage uboot images: * spl_boot, * tpl_boot, * final uboot image Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-19SPL: Makefile: Build a separate autoconf.mk for SPLJoel Fernandes
SPL defines CONFIG_SPL_BUILD but this does not percolate to the autoconf.mk Makefile. As a result the build breaks when CONFIG_SPL_BUILD is used in the board-specific include header file. With this, there is a possibility of having a CONFIG option defined in the header file but not defined in the Makefile causing all kinds of build failure and problems. It also messes things for up, for example, when one might want to undefine options to keep the SPL small and doesn't want to be stuck with the CONFIG options used for U-boot. Lastly, this also avoids defining special CONFIG_SPL_ variables for cases where some options are required in U-boot but not in SPL. We add a spl-autoconf.mk rule that is generated for SPL with the CONFIG_SPL_BUILD flag and conditionally include it for SPL builds. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-08-19Prepare v2013.10-rc1v2013.10-rc1Tom Rini
2013-08-18Merge branch 'master' of git://88.191.163.10/u-boot-armTom Rini
Fixup an easy conflict over adding the clk_get prototype and USB_OTG defines for am33xx having moved. Conflicts: arch/arm/include/asm/arch-am33xx/hardware.h Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15ARM: OMAP: Add CONFIG_OMAP_COMMONLokesh Vutla
Adding a new CONFIG_OMAP_COMMON which is included by all boards that needs to build cpu/armv7/omap-common folder. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-08-02Validate dtc is new enoughStephen Warren
Subsequent patches assume that dtc supports various recent features. These are available in dtc 1.4.0. Validate that dtc is at least that version. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-24Licenses: introduce SPDX Unique Lincense IdentifiersWolfgang Denk
Like many other projects, U-Boot has a tradition of including big blocks of License headers in all files. This not only blows up the source code with mostly redundant information, but also makes it very difficult to generate License Clearing Reports. An additional problem is that even the same lincenses are referred to by a number of slightly varying text blocks (full, abbreviated, different indentation, line wrapping and/or white space, with obsolete address information, ...) which makes automatic processing a nightmare. To make this easier, such license headers in the source files will be replaced with a single line reference to Unique Lincense Identifiers as defined by the Linux Foundation's SPDX project [1]. For example, in a source file the full "GPL v2.0 or later" header text will be replaced by a single line: SPDX-License-Identifier: GPL-2.0+ We use the SPDX Unique Lincense Identifiers here; these are available at [2]. Note: From the legal point of view, this patch is supposed to be only a change to the textual representation of the license information, but in no way any change to the actual license terms. With this patch applied, all files will still be licensed under the same terms they were before. Note 2: The apparent difference between the old "COPYING" and the new "Licenses/gpl-2.0.txt" only results from switching to the upstream version of the license which is differently formatted; there are not any actual changes to the content. Note 3: There are some recurring questions about linense issues, such as: - Is a "All Rights Reserved" clause a problem in GPL code? - Are files without any license header a problem? - Do we need license headers at all? The following excerpt from an e-mail by Daniel B. Ravicher should help with these: | Message-ID: <4ADF8CAA.5030808@softwarefreedom.org> | Date: Wed, 21 Oct 2009 18:35:22 -0400 | From: "Daniel B. Ravicher" <ravicher@softwarefreedom.org> | To: Wolfgang Denk <wd@denx.de> | Subject: Re: GPL and license cleanup questions | | Mr. Denk, | | Wolfgang Denk wrote: | > - There are a number of files which do not include any specific | > license information at all. Is it correct to assume that these files | > are automatically covered by the "GPL v2 or later" clause as | > specified by the COPYING file in the top level directory of the | > U-Boot source tree? | | That is a very fact specific analysis and could be different across the | various files. However, if the contributor could reasonably be expected | to have known that the project was licensed GPLv2 or later at the time | she made her contribution, then a reasonably implication is that she | consented to her contributions being distributed under those terms. | | > - Do such files need any clean up, for example should we add GPL | > headers to them, or is this not needed? | | If the project as a whole is licensed under clear terms, you need not | identify those same terms in each file, although there is no harm in | doing so. | | > - There are other files, which include both a GPL license header | > _plus_ some copyright note with an "All Rights Reserved" clause. It | > has been my understanding that this is a conflict, and me must ask | > the copyright holders to remove such "All Rights Reserved" clauses. | > But then, some people claim that "All Rights Reserved" is a no-op | > nowadays. License checking tools (like OSLC) seem to indicate this is | > a problem, but then we see quite a lot of "All rights reserved" in | > BSD-licensed files in gcc and glibc. So what is the correct way to | > deal with such files? | | It is not a conflict to grant a license and also reserve all rights, as | implicit in that language is that you are reserving all "other" rights | not granted in the license. Thus, a file with "Licensed under GPL, All | Rights Reserved" would mean that it is licensed under the GPL, but no | other rights are given to copy, modify or redistribute it. | | Warm regards, | --Dan | | Daniel B. Ravicher, Legal Director | Software Freedom Law Center (SFLC) and Moglen Ravicher LLC | 1995 Broadway, 17th Fl., New York, NY 10023 | (212) 461-1902 direct (212) 580-0800 main (212) 580-0898 fax | ravicher@softwarefreedom.org www.softwarefreedom.org [1] http://spdx.org/ [2] http://spdx.org/licenses/ Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-07-23Prepare v2013.07v2013.07Tom Rini
2013-07-12Prepare v2013.07-rc3v2013.07-rc3Tom Rini
