path: root/MAKEALL
2011-12-10ARM: convert "omap730p2" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Dave Peverley <dpeverley@mpc-data.co.uk> Acked-by: Tom Rini <trini@ti.com>
2011-12-10ARM: convert "omap16xx" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kshitij Gupta <kshitij@ti.com> Acked-by: Tom Rini <trini@ti.com>
2011-12-10ARM: convert "apollon" board to use boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-12-09MIPS: MAKEALL: fix lists for MIPSel and MIPS boardsDaniel Schwierzeck
Build dbau1550_el only in LIST_au1xx0_el and LIST_mips_el. Also remove obsolete lists for mips5kc. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Thomas Lange <thomas@corelatus.se>
2011-12-06MAKEALL: Add -l option to only list build targetsMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de>
2011-11-29MAKEALL: drop obsolete mx31pdk_nand targetStefano Babic
The mx31pdk can boot only from NAND and the target was already updated in boards.cfg. mx31pdk_nand is obsolete and is dropped. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-22adp-ag101: add board adp-ag101 supportMacpaul Lin
Add evaluation board "adp-ag101" configuration file adp-ag101.h. Add adp-ag101.c board config and related settings. Add board adp-ag101 into boards.cfg Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-19ColdFire: Move boards with simple _config rules to boards.cfgstany MARCEL
Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
2011-10-12MIPS: Jz4740: Add qi_lb60 board supportXiangfu Liu
Add support for the qi_lb60 (a.k.a QI Ben NanoNote) clamshell device from Qi hardware: http://en.qi-hardware.com/wiki/Ben_NanoNote http://en.qi-hardware.com/wiki/Main_Page http://en.wikipedia.org/wiki/Qi_hardware This Jz4740-based clamshell device does not use NOR flash to boot. The initial bring-up assumes that U-Boot is directly loaded into SDRAM using USB boot tool, and starts from 0x80100000. About USB boot tool ------------------- Jz4740 is one of the XBurst processors with USB boot functionality supported. The CPU can boot from a small ROM in the LSI, initialize CPU and USB module, then wait for USB commands from the USB host. We can send 8 KB binary data to the CPU cache using USB boot tool. USB boot tool is available to the public at Ingenic website. Also there is an alternative Debian package named xburst-tools. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Acked-by: Daniel <zpxu@ingenic.cn> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-10-05MAKEALL: rename coldfire list to m68k to match archMike Frysinger
The m68k tree is the only one where `./MAKEALL <arch>` does not work. So rename the existing coldfire list in the MAKEALL script to m68k, and add an alias from coldfire to m68k. This makes scripting around MAKEALL easier. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-10MAKEALL: drop boards listed in boards.cfgWolfgang Denk
Pick them up automatically using $(boards_by_arch ...) Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-10MAKEALL: drop non-existent "versatile" configurationWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-09-07ARM: remove broken "modnet50" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Thomas Elste <info@elste.org>
2011-09-07ARM: remove broken "lpc2292sodimm" board.Wolfgang Denk
2011-09-07ARM: remove broken "impa7" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marius Gröger <mag@sysgo.de>
2011-09-07ARM: remove broken "evb4510" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Curt Brune <curt@cucy.com>
2011-09-07ARM: remove broken "ep7312" board.Wolfgang Denk
2011-09-07ARM: remove broken "SMN42" board.Wolfgang Denk
2011-09-04ARM: remove broken "voiceblue" boardWolfgang Denk
2011-09-04ARM: remove broken "smdk2400" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Gary Jennejohn <garyj@denx.de>
2011-09-04ARM: remove broken "sbc2410x" boardWolfgang Denk
2011-09-04ARM: remove broken "netstar" boardWolfgang Denk
2011-09-04ARM: remove broken "mx1fs2" boardWolfgang Denk
2011-09-04ARM: remove broken "lpd7a40x" boardsWolfgang Denk
Remove lpd7a400 and lpd7a404 boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-04ARM: remove broken "edb93xx" boardsWolfgang Denk
Remove edb9301, edb9302, edb9302a, edb9307, edb9307a, edb9312, edb9315 and edb9315a boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-04ARM: remove broken "B2" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2011-09-04ARM: remove broken "armadillo" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Rowel Atienza <rowel@diwalabs.com>
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03MAKEALL ARMv7: Use boards.cfgDirk Behme
Use the boards from boards.cfg for building ./MAKEALL ARMV7. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2011-08-03MAKEALL: remove AT91 boards that are in boards.cfgReinhard Meyer
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03MAKEALL: remove obsolete at91rm9200 socAndreas Bießmann
Since complete at91rm9200 SoC device was droped (due to replacement with common at91 code) this parameter can safely be removed. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-07-26MAKEALL: add -h/--help optionsMike Frysinger
Convert all the comments at the top of the file into help text for people to easily get at with standard -h/--help options. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-07-04arm/km: add support for portl2 boardValentin Longchamp
This adds support for the keymile Kirkwood BEC portl2 board. This board relies on the km_arm (km_kirkwood) BEC. The egiga driver is configured for a 100M full-duplex, A/N off connnection to the backplane. This board has always ethernet present, because it is connected to the marvell switch similar to mgcoge3un. The reset_phy functionality is also the same to mgcoge3un. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: replace suenx targets with km_kirkwoodHolger Brunck
suen3 and suen8 were in first HW version quite different, but now they are from a u-boot point of view similar. So these two boards can use the same header file. Other keymile boards differ only in the usage of the PCI interface. Therefore a target km_kirkwood_pci was introduced. All targets use the same header file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-06-30nios2: move generic config to boards.cfgMike Frysinger
I can't build test this, but just looking at the config files written and it seems OK ... Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-21cpuat91: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-06-21cpu9260/9G20: fix board supportEric Benard
2011-05-11Add definitions for OpenRD-Client and OpenRD-UltimateClint Adams
Signed-off-by: Clint Adams <clint@debian.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Julian Pidancet <julian.pidancet@citrix.com>
2011-04-27ARMV7: OMAP3: Add support for Comelit DIG297 boardLuca Ceresoli
Board support for the DIG297 board manufactured by Comelit Group SpA. It is a custom board based on the BeagleBoard <http://beagleboard.org/> by Texas Instruments. The board support is based on the BeagleBoard implementation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ARMV7: AM3517/05: Add support for CraneBoard.Srinath
It is a low cost reference design based on Sitara AM3517 SoC from Texas Instruments Please refer to <www.craneboard.org> for more details. Signed-off-by: Srinath <srinath@mistralsolutions.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-13x86: Rename i386 to x86Graeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-02MIPS: Purple: Remove Purple supportDaniel Schwierzeck
The Purple SoC and eval board are not actively maintained since years. This patch removes the support completely as aggreed with Wolfgang Denk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2010-12-16Armada100: Add Board Support for Marvell Aspenite-DBPrafulla Wadaskar
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with * Processor upto 1.2GHz * Parallel 1Gb x8 DDR2-1066 MHz * 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR * Footprints for eMMC/eSD NAND & MMC x8 card * 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket * SEAF memory board, subset of PISMO2 With Peripherals: * 4.3” WVGA 24-bit LCD * Audio codecs (AC97 & I2S), TSI * VGA camera * Video in via 3 RCA jacks, and HDMI type C out * Marvell 88W8688 802.11bg/BT module * GPS RF IC * Dual analog mics & speakers, headset jack, LED, ambient light sensor * USB2.0 HS host (A), OTG (micro AB) * FE PHY, PCIE Mini Card slot * GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality The patch is tested for boot from DRAM using XDB Signed-off-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-12-07MAKEALL: fix AT91Andreas Bießmann
* add boards_by_soc() * remove boards already in boards.cfg from LIST_AT91 Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
