path: root/Documentation
2019-06-20doc: Remove duplicated documentation directoryBreno Matheus Lima
Commit ad7061ed742e ("doc: Move device tree bindings documentation to doc/device-tree-bindings") moved all device tree binding documentation to doc/device-tree-bindings directory. The current U-Boot project still have two documentation directories: - doc/ - Documentation/ Move all documentation and sphinx files to doc directory so all content can be in a common place. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-06-01net: eth-uclass: Support device tree MAC addressesThierry Reding
Add the standard Ethernet device tree bindings (imported from v5.0 of the Linux kernel) and implement support for reading the MAC address for Ethernet devices in the Ethernet uclass. If the "mac-address" property exists, the MAC address will be parsed from that. If that property does not exist, the "local-mac-address" property will be tried as fallback. MAC addresses from device tree take precedence over the ones stored in a network interface card's ROM. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2019-05-05Documentation: dts: Add pl310 cache controller dts documentationDinh Nguyen
Linux commit 8ecd7f5970c5 ("ARM: 8483/1: Documentation: l2c: Rename l2cc to l2c2x0") Linux docs: Documentation/devicetree/bindings/arm/l2c2x0.txt Copied from Linux kernel v5.0. "The documentation in the l2cc.txt is specific to the L2 cache controllers L2C210/L2C220/L2C310 (also known as PL210/PL220/PL310 and variants) and not generic as the file name implies. It's not valid for integrated L2 controllers as found in e.g. Cortex-A15/A7/A57/A53." Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2019-04-11fdtdec: Implement fdtdec_add_reserved_memory()Thierry Reding
This function can be used to add subnodes in the /reserved-memory node. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Thierry Reding <treding@nvidia.com>
2019-02-16efi_loader: documentation of image loaderHeinrich Schuchardt
- Add missing function descriptions. - Update existing function descriptions to match Sphinx style. - Add lib/efi_loader/efi_image_loader.c to the input files for Sphinx generated documentation. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-11-14misc: Add IHS FPGA driverMario Six
Add a driver for gdsys IHS (Integrated Hardware Systems) FPGAs, which supports initialization of the FPGA, as well as information gathering. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-11-14misc: Add gdsys_soc driverMario Six
This patch adds a driver for the bus associated with a IHS FPGA. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-29board: Add gazerbeam driverMario Six
Add a board driver for the upcoming gdsys Gazerbeam board. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-18misc: Add MPC83xx serdes driverMario Six
Add a driver to configure the SerDes (Serializer/Deserializer) lanes on the MPC83xx architecture. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18cpu: Add MPC83xx CPU driverMario Six
Add a CPU driver for the MPC83xx architecture. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18timer: Add MPC83xx timer driverMario Six
Add a timer driver for the MPC83xx architecture. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18clk: Add MPC83xx clock driverMario Six
Add a clock driver for the MPC83xx architecture. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18ram: Add driver for MPC83xxMario Six
Add a RAM driver for the MPC83xx architecture. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-11Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingTom Rini
2018-08-11Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2018-08-11misc: Add gdsys_ioep driverMario Six
Add driver for the IHS IO endpoint on IHS FPGAs. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-11axi: Add ihs_axi driverMario Six
Add a driver for the gdsys IHS AXI bus used on IHS FPGAs. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-10doc: add structure to Sphinx generated docsHeinrich Schuchardt
Create separate html pages for linker lists, the serial subsystem, and the EFI subsystem. Add a table of content. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-24doc: Move device tree bindings documentation to doc/device-tree-bindingsBreno Lima
Currently the U-Boot project contains 2 documentation directories: - doc/ - Documentation/ The Documentation directory only contains device tree bindings related content, so move the 3 files to doc/device-tree-bindings/. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-07-23doc: Replace DocBook with sphinx-based docsMario Six
The Linux kernel moved to sphinx-based documentation and got rid of the DocBook based documentation quite a while ago. Hence, the DocBook documentation for U-Boot should be converted as well. To achieve this, import the necessary files from Linux v4.17, and convert the current DocBook documentation (three files altogether) to sphinx/reStructuredText. For now, all old DocBook documentation was merged into a single handbook, tentatively named "U-Boot Hacker Manual". For some source files, the documentation style was changed to comply with kernel-doc; no functional changes were applied. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-05-18phy: add support for STM32 usb phy controllerPatrice Chotard
This patch adds phy tranceiver driver for STM32 USB PHY Controller (usbphyc) that provides dual port High-Speed phy for OTG (single port) and EHCI/OHCI host controller (two ports). One port of the phy is shared between the two USB controllers through a UTMI+ switch. Signed-off-by: Christophe Kerello <christophe.kerello@st.com> Signed-off-by: Amelie Delaunay <amelie.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-07-28phy: add a NO-OP phy driverJean-Jacques Hiblot
This driver is used to stub PHY operations in a driver (USB, SATA). This is useful when the 'client' driver (USB, SATA, ...) uses the PHY framework and there is no actual PHY harwdare to drive. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-07-12dt-bindings: Document the Broadcom STB wake-up timer nodeFlorian Fainelli
Document the binding for the Broadcom STB SoCs wake-up timer node allowing the system to generate alarms and exit low power states. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2005-08-19Fix erroneous commitWolfgang Denk
2005-08-19Fix MPC52xx watchdog driverWolfgang Denk
- make watchdog driver work on systems with an IPB clock frequency of 133 MHz (watchdog expired to fast there). - now all three watchdog chain entries could be used. - fix some typos. Patch by Martin Krause, 23 Jun 2005
