https://gitlab.denx.de/u-boot/custodians/u-boot-mips
- mtmips: network stability fixes for gardena-smart-gateway
The watchdog of mediatek chips is enabled by bootrom before u-boot is
running. Previously we choose to enable the wdt driver only to disable the
watchdog hardware.
Now wdt service is enabled by default. The function arch_misc_init which is
only used to disable wdt is no longer needed.
Reviewed-by: Ryder Lee <ryder.lee@mediatek.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
The initr_watchdog is currently placed before initr_serial. The
initr_watchdog calls printf and printf finally calls ops->putc of a serial
driver.
However, gd->cur_serial_dev points to a udevice allocated in board_f. The
gd->cur_serial_dev->driver->ops->putc points the the code region before
relocation.
Some serial drivers call WATCHDOG_RESET() in ops->putc. When DM is enabled
for watchdog, watchdog_reset() is called. watchdog_reset() calls get_timer
to get current timer.
On some platforms the timer driver is also a DM driver. initr_watchdog is
placed right after initr_dm, which means the timer driver hasn't been
initialized. So dm_timer_init() is called. To create a new udevice, calloc
is called.
However start from ops->putc, u-boot execution flow is redirected into the
memory region before relocation (board_f). In board_f, dlmalloc hasn't
been initialized. The call to calloc will fail, and this will cause DM to
print out an error message, and it will call printf again, causing
recursive error outputs.
This patch places initr_watchdog after initr_serial to solve this issue.
Cc: Stefan Roese <sr@denx.de>
Tested-by: Frank Wunderlich <frank-w@public-files.de>
Tested-by: Suniel Mahesh <sunil.m@techveda.org>
Fix booting for wandboard
https://gitlab.denx.de/u-boot/custodians/u-boot-video
- fix pwm backlight
One of the SD-CARD slots on the Wandboard Quad B1 is MMC 2. Enable it as a
boot device.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
- DWC and i.MX6 fixes
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
set_pwm() will always fail with -ENOSYS if pwm_ops set_invert() is
not implemented, leaving the backlight dark. Fix this by returning
no error if set_invert() is not implemented and no polarity change
is requested.
Fixes: 57e7775413 ("video: backlight: Parse PWM polarity cell")
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
- fix complation error for CONFIG_USB
- update RPi3 DTBs to v5.1-rc6 state
- add defconfig for RPi3 B+
- Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
With commit 06985289d452 ("watchdog: Implement generic watchdog_reset()
version") the init sequence has changed in arch_misc_init(), resulting
in a re-appearance of the d-cache issue on MT7688 boards (e.g. gardena).
When this happens, the first (or sometimes later ones as well) TFTP
command hangs and does not complete correctly. This leads to the
assumption that the d-cache is not in a clean state once the ethernet
driver is called (d-cache is used here for the buffers). The old work-
around with the cache flush somehow does not work any more now with
the new code change.
Unfortunately adding CONFIG_SYS_MALLOC_CLEAR_ON_INIT also did not fix
this issue. With v2019.07-rc3 it shows again. The time of accessing
the data seems to be very important here. It needs to be "very late"
in the boot process.
Testing has shown, that copying a 64KiB area in DDR at a very late
bootup time, directly before calling into the prompt, fixes this issue.
Flushing of the complete d-cache does not seem to necessary, as this
copy alone seems to fix this problem.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
dwc3-generic has been broken since MISC uclass has been modified to scan DT
sub-nodes after bind.
Fixing it by a using the no-op uclass.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This uclass is intended for devices that do not need any features from the
uclass, including binding children.
This will typically be used by devices that are used to bind child devices
but do not use dm_scan_fdt_dev() to do it. That is for example the case of
several USB wrappers that have 2 child devices (1 for device and 1 for
host) but bind only one at a any given time.
There is simply no reason to do that here.
The EHCI iMX6 driver is only partly converted to DT probing and
still uses a tremendous amount of hard-coded addresses. Worse,
the driver uses hard-coded SoC-model-specific base addresses, which
are derived from values protected by SoC-specific macros, hence the
driver is also compiled for a specific SoC model. Even worse, the
driver depends on specific sequential indexing of the controllers,
from which it derives offsets in the PHY and ANATOP register sets.
However, when the driver is probed from DT, the indexing is not
correct. In fact, each controller has index 0. This patch derives
the index for DT probing case from the controller base addresses,
which is not the way this should be done, however it is the least
intrusive approach, favorable this close to release.
The necessary steps to convert this driver fully to DT probing are
described inside the patch, however this should be done in the next
release and depends on iMX clock driver patches.
Cc: Abel Vesa <abel.vesa@nxp.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Ludwig Zenz <lzenz@dh-electronics.com>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Vagrant Cascadian <vagrant@debian.org>
Commit b238e4b00ced ("rockchip: Cleanup of make_fit_atf.py.") set
firmware = "atf_1";
loadables = "uboot","atf_1","atf_2";
Actually it should be:
firmware = "atf_1";
loadables = "uboot","atf_2","atf_3";
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Add missing mailing-list to the amlogic boards MAINTAINERS file.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- Wandboard
After the conversion to DM the U-Boot proper binary name
is 'u-boot-dtb.img', so adjust it accordingly.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
After the transition to DM, only the mx6dl/solo wandboard
is supported.
Add FIT image support so that all the wandboard variants
can be supported, like it was prior to the DM conversion.
Successfully booted Linux on mx6q/solo/qp wandboards.
Add a mmc0 alias so that U-Boot proper can associate mmc0
with the boot SD card.
Import wandboard devicetree files so that the mx6q and mx6qp
variants can be properly supported.
Udate the wandboard devicetree files with the ones
from kernel 5.1.9.
Place dtbs under SoC level rather than board level.
imx6q-novena.dtb and imx6dl-wandboard-revb1.dtb were
placed under the board config option, so move them
to SoC level.
This also aligns with the kernel dts Makefile format.
Keep dtb entries sorted to help adding new dtbs
in an organized form.
- fix for atf bl31_image_info pointer
- fix for rockpro64 vdd_log init
- fix for tinker-rk3288 SPL size too big
All the config for TPL has been update, we can enable the TPL.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
The raw u-boot.bin for tinker board has been about 450KB without
debug option, and 550KB with all debug on, and the default value is 200KB,
which is not enough for run raw u-boot.bin.
We need to update TEXT BASE for TPL/SPL/U-Boot;
SPL no need relocate STACK after enable TPL, so remove it;
Don't enable pinctrl names so that SPL can get pinctrl dts;
rockchip pinctrl driver has update to use dts, so we need
to add the pinctrl config in SPL for sdmmc.
Migrate all the "u-boot,dm-pre-reloc" tag from rk3288-tinker.dts
into rk3288-tinker-u-boot.dtsi.
When both board level and soc level '-u-boot.dtsi' files exist,
we need to include the soc level 'rk3288-u-boot.dtsi' manually.
Move all the tag "u-boot,dm-pre-reloc" from rk3288.dtsi
into rk3288-u-boot.dtsi.
TPL is at SRAM while other stage is at SDRAM, so it needs
separate STACK.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
More boards other than vyasa needs TPL, so enable the TPL configs
at chip level instead of board level.
Add missing regulator-init-microvolt property to vdd_log regulator.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
(Rebase on latest u-boot-rockchip master)
Change-Id: I13b24fb81e8ad269d7dbb0c7b67f5f4795d2e775
The pointer to struct atf_image_info in
bl31_params_mem.bl31_params.bl31_image_info is not initialized before
being dereferenced. This can cause U-Boot to crash right before jumping
to the BL31 ATF binary.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Fixes: bcc1726a7bdd ("spl: add support to booting with ATF")
There is a regression seen on Poplar platform, which doesn't even show
a U-Boot version banner on booting. It turns out that due to landing
of commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to
simple-bus driver"), we need to increase SYS_MALLOC_F_LEN from its
default size 0x400, as pre-relocation requires more memory there. Let's
increase SYS_MALLOC_F_LEN to 0x4000 to fix the regression.
Thanks to Andreas Färber <afaerber@suse.de> for reporting, and Bin Meng
<bmeng.cn@gmail.com> for trouble shooting.
Reported-by: Andreas Färber <afaerber@suse.de>
Tested-by: Andreas Färber <afaerber@suse.de>
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel
Second set of u-boot-atmel fixes for 2019.07 cycle
https://gitlab.denx.de/u-boot/custodians/u-boot-uniphier
UniPhier SoC updates for v2019.07
- Add SPI pin-mux data for pinctrl driver
- Remove unused code
- Trivial bug-fix and clean-up
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for v2019.07-rc5 (4)
The definition of an unimplemented function is corrected.
Move the sg_set_pinsel macro to arch/arm/mach-uniphier/arm32/debug_ll.S
since it is not used anywhere else.
Move the C functions sg_set_{pinsel,iectrl} to debug-uart.c since they
are not used anywhere else.
debug_uart_init() is called from spl_board_init(), which is only
compiled for SPL. For U-boot proper, _debug_uart_init() is unreachable,
so dropped by the dead code elimination.
Now that 64-bit SoCs of this SoC family no longer support SPL,
debug-uart-ld20.c is never compiled.
This file calls readl(), so needs to include <linux/io.h>.
Currently, it relies on someone else including it.
Commit e27d6c7d328c ("ARM: uniphier: simplify SoC ID get function")
accidentally removed the macros needed to compile debug_ll.S
Revive them.
Fixes: e27d6c7d328c ("ARM: uniphier: simplify SoC ID get function")
Add pin-mux settings for SPI controller.
Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com>
ConvertPointer() must be EFIAPI. The first parameter should be of type
efi_uint_t. Use the same parameter name as the UEFI specification.
Fixes for 2019.07
- menlo board
- allow SDB on Sabre
- HAB for mx6sl
- apalis board
