Seems 6ae6e160 broke creating images in certain cases, there
are two problems with that patch.
First is that the expression "!x == 4 || !x == 6" is ambiguous. The
intention here was "!(x == 4) || !(x == 6)" based on reading further in
the file, where this was borrowed from. This however is interpreted by
gcc as "(!x) == 4 || (!x) == 6" and always false. gcc-5.x will warn
about this case.
The second problem is that we do not want to test for the case of "(NOT x
is 4) OR (NOT x is 6)" but instead "(x is not equal to 4) AND (x is not
equal to 6)". This is because in those two cases we already execute the
code question in another part of the file. Rewrite the expression and
add parenthesis for clarity.
Cc: Philippe De Swert <philippedeswert@gmail.com>
[trini: Re-word Marek's explanation]
Now that we may compile (but not link) code calling fixup_cmdtable when
this is not set, we need to always have the declaration available. We
should also make sure that anyone calling the function includes
<command.h> as that's where the function declaration is.
This option is needed for all SoCs which have nodes on bus. Without
enabling this drivers are not found and probed.
Issue was found on Zynq MMC probe.
Enable this option by default.
Subcommands contain pointers to functions which are not updated when
MANUAL_RELOC is enabled. This patch fix it.
Acked-by: Heiko Schocher <hs@denx.de>
debug_uart.h is included twice.
Remove this c&p error from s5p driver.
Move driver to DM
Prepare for using DM.
Calculate the minimum sd clock based on max clock. This will
be done by add_sdhci() if we pass minimum clock as zero.
It also does based on SD host contoller version.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Remove unused macros when driver was moved to DM.
SPL DM MMC FAT requires more malloc space(3k fat buffers + dm)
that it is available now. Extend SPL malloc space.
Current OCM layout:
0xffff0000 - 0xfff2000 - Full malloc space
0xffff2000 - 0xffff300 - Stack location
0xfffff300 - CONFIG_SYS_MALLOC_F_LEN - Early malloc space
0xfffffd00 - sizeof(GD) - GD
0xfffffe00 - 0xffffffff - SoC specific boot code
The patch
"board_init: Change the logic to setup malloc_base"
(sha1: 9ac4fc82071ce346e3885118242ff45d22f69b82)
breaks SPL for Zynq because it puts early alloc area on the stack which
caused that stack was decreased by CONFIG_SYS_MALLOC_F_LEN (0x400)
and there was not enough space for regular stack.
This patch changes memory layout to better utilize the last 64k OCM
block.
0xffff0000 - 0xfff1000 - Full malloc space
0xffff1000 - 0xffff300 - Stack location
Tested-by: Moritz Fischer <moritz.fischer@ettus.com>
Remove configuration options from board file.
Enable to break waiting loop at any time.
Reviewed-by: Jagan Teki <jteki@openedev.com>
Do not set interface via configs. Read information from DT.
- Enable DM_ETH by default for Zynq and ZynqMP
- Remove board_eth_init code
- Change miiphy_read function to return value instead of error code
based on DM requirement
- Do not enable EMIO DT support by default
Sync it with write function.
This function was used for OF init before DM.
Remove this function as the part of move to DM.
Enable access to MDIO before zynq_gem_init is called.
It enables read information about phy earlier.
Check return value.
Move phy init code out of zynq_gem_init. DM drivers are normally calling
this code from probe function.
Resort code to use priv->phydev variable directly.
It will simplify move to DM.
Next step to move driver to driver model. Do not use eth_device
structure. Use private structure instead.
Add iobase to private structure to store gem iobase.
Pass regs instead of dev because this will be chagned by
driver model.
Add return value for phy detection algorithm to stop init function when
phy is not found.
CONFIG_API is causing compilation error when DM_ETH is enabled because
eth_get_dev() is not available.
Move PHYLIB from board config to defconfig
Enable driver model MMC support on SoCFPGA.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Convert the SoCFPGA shim for registering the DWMMC driver to DM.
This function triggers the registration of the dwmmc driver on SoCFPGA,
but this is not needed in case the driver is correctly probed from DT.
The SR1500 board is a CycloneV based board, similar to the EBV
SoCrates, equipped with the following devices:
- SPI NOR
- eMMC
- Ethernet
Cc: Pavel Machek <pavel@denx.de>
Acked-by: Pavel Machek <pavel@denx.de>
This patch removes unsued function usb_phy_reset, rather common function
dwc3_phy_reset is used.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@freescale.com>
As per dwc3 databook, delay is required before taking the core out of reset.
This delay is required so that the PHY are stable, and then we can take core
out of reset.
Reference is taken from linux dwc3 code, file: drivers/usb/dwc3/core.c.
Signed-off-by: Sriram Dash <sriram.dash@freescale.com>
This driver is meant to be used with any EHCI-compatible host
controller in case if there's no need for platform-specific
glue such as setup of controller or PHY's power mode via
GPIOs etc.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Stephen Warren <swarren@nvidia.com>
The DM entry should be unique, otherwise it will collide with other
drivers. Fix this by assigning the driver a more unique name than
usb_ehci.
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
The driver does "return 0" in function with void type.
Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Apply Erratum A007792 sw workaround for T4080
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
fix the following build warnings:
drivers/usb/dwc3/core.c: In function ‘dwc3_uboot_init’:
drivers/usb/dwc3/core.c:625:6: warning: ‘dev’ is used uninitialized in this function [-Wuninitialized]
mem = devm_kzalloc(dev, sizeof(*dwc) + DWC3_ALIGN_MASK, GFP_KERNEL);
drivers/usb/dwc3/dwc3-omap.c: In function ‘dwc3_omap_uboot_init’:
drivers/usb/dwc3/dwc3-omap.c:380:7: warning: ‘dev’ is used uninitialized in this function [-Wuninitialized]
omap = devm_kzalloc(dev, sizeof(*omap), GFP_KERNEL);
Signed-off-by: Felipe Balbi <balbi@ti.com>
Fix the following build break:
drivers/usb/host/xhci-omap.c:35:5: error: ‘board_usb_init’ aliased to external symbol ‘__board_usb_init’
int board_usb_init(int index, enum usb_init_type init)
Enable USB XHCI support for ZynqMP
Added USB XHCI driver support for zynqmp.
We now want to make sure that we have the platform data for NS16550 when
we do not have OF_CONTROL set.
