2015-09-07Prepare v2015.10-rc3v2015.10-rc3Tom Rini
2015-09-07Merge git://git.denx.de/u-boot-usbTom Rini
2015-09-07Merge git://git.denx.de/u-boot-socfpgaTom Rini
2015-09-07usb: ehci: remember init modeStephen Warren
When an EHCI device is registered in device mode, the HW isn't actually initialized at all, and hence isn't left in a running state. Consequently, when the device is deregistered, ehci_shutdown() will fail, since the HW bits it expects to see set in response to its shutdown requests will not be sent, and the message "EHCI failed to shut down host controller." will be printed. Fix ehci-hcd.c to remember whether the device was registered in host or device mode, and only call ehci_shutdown() for host mode registrations. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-09-07dfu: tftp: Kconfig: Enable DFU_TFTP support on the am335x_boneblack_defconfigLukasz Majewski
This commit enables support for DFU_TFTP on the am335x bone black device. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: tftp: Kconfig: Add Kconfig entry for dfu tftp featureLukasz Majewski
The dfu tftp feature can be now enabled via Kconfig. This commit provides necessary code for it. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: command: Extend "dfu" command to handle receiving data via TFTPLukasz Majewski
The "dfu" command has been extended to support transfers via TFTP protocol. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07update: tftp: dfu: Extend update_tftp() function to support DFULukasz Majewski
This code allows using DFU defined mediums for storing data received via TFTP protocol. It reuses and preserves functionality of legacy code at common/update.c. The update_tftp() function now accepts parameters - namely medium device name and its number (e.g. mmc 1). Without this information passed old behavior is preserved. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: tftp: update: Add dfu_write_from_mem_addr() functionLukasz Majewski
This function allows writing via DFU data stored from fixed buffer address (like e.g. loadaddr env variable). Such predefined buffers are used in the update_tftp() code. In fact this function is a wrapper on the dfu_write() and dfu_flush(). Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: tftp: update: Provide tftp support for the DFU subsystemLukasz Majewski
This commit adds initial support for using tftp for downloading and upgrading firmware on the device. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07tftp: update: Allow some parts of the code to be reused when ↵Lukasz Majewski
CONFIG_SYS_NO_FLASH is set Up till now it was impossible to use code from update.c when system was not equipped with raw FLASH memory. Such behavior prevented DFU from reusing this code. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-09-07net: tftp: Move tftp.h file from ./net to ./include/netLukasz Majewski
This change gives the ability to reuse the <tftp.h> header file by other subsystems (like e.g. dfu). Without this change compilation error emerges for the legacy update.c file. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07doc: dfu: tftp: README entry for TFTP extension of DFULukasz Majewski
Documentation file for DFU extension. With this functionality it is now possible to transfer FIT images with firmware updates via TFTP and use DFU backend for storing them. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07h2200: Fix build errorKishon Vijay Abraham I
Commit <8bfc288c3955> ("usb: gadget: ether: Perform board initialization from ethernet gadget driver") added board_usb_init and board_usb_cleanup in ethernet gadget driver. But h2200 board didn't have board_usb_init and board_usb_cleanup implementations. This introduced the following build errors +drivers/usb/gadget/built-in.o: In function `usb_eth_halt': +drivers/usb/gadget/ether.c:2498: undefined reference to `board_usb_cleanup' +drivers/usb/gadget/built-in.o: In function `usb_eth_init': +drivers/usb/gadget/ether.c:2316: undefined reference to `board_usb_init' Fix it here by adding empty board_usb_init and board_usb_cleanup functions in h2200.c. Fixes: <8bfc288c3955> ("usb: gadget: ether: Perform board initialization from ethernet gadget driver") Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-09-07dfu: Delete superfluous initialization of the dfu_buf_size static variableLukasz Majewski
After extension of the dfu_get_buf() to also setup (implicitly) the dfu_buf_size variable it is not needed to set dfu_buf_size to CONFIG_SYS_DFU_DATA_BUF_SIZE. This variable is set in the dfu_get_buf() by not only considering CONFIG_SYS_DFU_DATA_BUF but more importantly the "dfu_bufsiz" env variable. Therefore, dfu_get_buf() should be used for initialization. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-09-07dfu:tests: Modify dfu_gadget_test.sh to accept USB device vendor:product IDLukasz Majewski
dfu-util allows filtering on USB device vendor:product ID by using the -d flag (-d 0451:d022). Such option is very handy when many DFU devices are connected to a single host PC. This commit allows testing when above situation emerges. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Lukasz Majewski <l.majewski@majess.pl> Test HW - AM335x Beagle Bone Black NOTE: Max size of file to transfer: 2MiB
2015-09-07usb: gadget: f_thor: Allocate request up to THOR_PACKET_SIZESiva Durga Prasad Paladugu
Allocate request up to THOR_PACKET_SIZE not the ep0->maxpacket as the descriptors data depend on the number of descriptors and this 64 bytes were not enough and the buffer might overflow which results in memalign failures later. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-09-07f_thor: Dont perform reset at the end of thorSiva Durga Prasad Paladugu
Dont perform reset at the end of thor download if configured to do reset off. Reset may not be required in all cases and hence provided an option to do so. The case would be to download the images to DDR instead of flash device. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-09-07implement Fastboot via USB OTG on bcm28155_ap boardsJiandong Zheng
Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2015-09-07arc: make AXS101 default platformAlexey Brodkin
This fixes building in automated flow that doesn't use defconfigs. See discussion on that topic here: http://patchwork.ozlabs.org/patch/502558/ See similar patches for other architectures/platforms here: [1] http://git.denx.de/?p=u-boot.git;a=commit;h=ff560a13056a565a4e9ce1761bd04276a3cace88 [2] http://git.denx.de/?p=u-boot.git;a=commit;h=589907e2c187ec69b351c38ccda36730d25ab5d6 And while at it add missing shell prompt to axs103. Cc: Tom Rini <trini@konsulko.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-09-04net: altera_tse: Zap unused variableMarek Vasut
Zap variable which is set but never used. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2015-09-04arm: socfpga: Add support for the Terasic DE-0 Atlas boardDinh Nguyen
Add support for the Terasic DE0-Nano/Atlas-SoC Kit, which is a CycloneV based board. The board can boot from SD/MMC. Ethernet is also supported. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-09-04arm: socfpga: Add support for DENX MCV SoM and MCVEVK boardMarek Vasut
Add support for DENX MCV SoM, which is CycloneV based and the associated DENX MCVEVK baseboard. The board can boot from eMMC. Ethernet and USB is supported. Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-04arm: socfpga: Add support for Terasic SoCkit boardMarek Vasut
Add support for Terasic SoCkit, which is CycloneV based board. The board can boot either from SD/MMC or QSPI. Ethernet is also supported. Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-04arm: socfpga: Do not call board_init_r() from board_init_f()Marek Vasut
Instead of calling board_init_r() directly from board_init_f(), just return from board_init_f(). This will make the code continue executing in crt0.S _main(), from which the board_init_r() is called. This patch aligns the SoCFPGA SPL with the correct SPL design as well as reduces the stack utilisation slightly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-09-04arm: socfpga: Zap OF_CONTROL checks, it's always enabledMarek Vasut
The CONFIG_OF_CONTROL and CONFIG_SPL_OF_CONTROL is always enabled on Altera SoCFPGA, remove the unnecessary checks. Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-04arm: socfpga: Always enable OF_CONTROL and SPL_OF_CONTROLMarek Vasut
The SoCFPGA probes mostly from OF and the OF is mandatory both in U-Boot itself and U-Boot SPL. Enable it by default. Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-04arm: socfpga: Assure ISWGRP 0 and 1 are initedMarek Vasut
This fix makes sure that the ISWGRP0 and ISWGRP1 registers are correctly inited. In case those registers are not initialized, it is not possible to access the registers synthesised in the FPGA through the bridges. Any such access produces data abort. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-09-04mmc: dw_mmc: Probe the MMC from OFMarek Vasut
Rework the driver to probe the MMC controller from Device Tree and make it mandatory. There is no longer support for probing from the ancient qts-generated header files. This patch now also removes previous temporary workaround. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@konsulko.com>
2015-09-03doc: document the fdtdir PXE commandStefan Brüns
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2015-09-03doc: Fix inconsistent filename in PXE config exampleStefan Brüns
The default config includes base.menu, not linux.list Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2015-09-03Merge git://git.denx.de/u-boot-rockchipTom Rini
2015-09-02rockchip: Put README image creation commands on one lineSimon Glass
It is easier to paste these into the command line if they are a single common. Use line continuation instead of separate lines. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Update todo in README.rockchipSjoerd Simons
MMC support works now, so it can be dropped from the todo Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Drop first 32kb of zeros from the rkSD image typeSjoerd Simons
Instead of creating a rockchip SPL SD card image with 32KB of zeros which can be written to the start of an SD card, create the images with only the useful data that should be written to an offset of 32KB on the SD card. The first 32 kilobytes aren't needed for bootup and only serve as convenient way of accidentally obliterating your partition table. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02arm: Turn of d-cache before i-cacheSjoerd Simons
Booting the kernel fails on RK3288 (and probably other rockchip SoCs) when the i-cache is disabled/flushed before d-cache. I have not investigated whether this is due to U-Boot hanging or whether it's very early in the linux boot, but following the approach of the various rockchip U-Boot forks (first disable d-cache then i-cache) makes things work. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add config_distro_bootcmd supportSjoerd Simons
Now that MMC works in U-Boot add config distro command support to start Linux in a standard fashion. One oddity here is that linux fails to load when the fdt is relocated to above 512MB, so set fdt_high to make sure it's loaded below that. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Turn off CONFIG_SPL_LED for fireflySjoerd Simons
With LED support enabled the SPL easily goes over the size limit (e.g. with both Debians gcc 4.9 and 5.2 cross-compilers). Turn off LED support in the SPL to reduce the size just enough for those compilers. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Tweaked commit subject to remove _SUPPORT Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Disable sdio mmc slot on rk3288-fireflySjoerd Simons
U-Boot can't use the sdio card so turn it of to prevent things getting confused/struck when trying to use the card as storage. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02mmc: Probe DM based mmc devices in u-bootSjoerd Simons
During mmc initialize probe all devices with the MMC Uclass if build with CONFIG_DM_MMC Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02doc: Fix reference to Rock pro when Rock 2 is meantSjoerd Simons
The Radxa Rock pro board is rk3188 based and thus won't work with U-Boot built for RK3288. Change the documentation to refer to the intended board, the Radxa Rock 2, which is an RK3288-based design very similar to the firefly Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add a simple READMESimon Glass
Add a few notes on how to try out the Rockchip support so far. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add basic support for jerrySimon Glass
This builds and displays an SPL message, but does not function beyond that. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add basic support for firefly-rk3288Simon Glass
The Firefly RK3288 is a suitable target board for initial mainline Rockchip support. It includes a good set of peripherals, a recent SoC and it is readily available. This adds only some basic files required to allow the baord to display a serial message in SPL and hang. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add SPI driverSimon Glass
Add a SPI driver for the Rockchip RK3288, using driver model. It should work for other Rockchip SoCs also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add I2C driverSimon Glass
Add an I2C driver for the Rockchip RK3288, using driver model. It should work for other Rockchip SoCs also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add core SoC start-up codeSimon Glass
Add code for starting up U-Boot SPL and U-Boot proper. This is generic and makes use of devices provided by the board- or SoC-specific code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add an MMC driverSimon Glass
Add an MMC driver which supports RK3288, but may also support other SoCs. It uses the Designware MMC device. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: rk3288: Add SDRAM initSimon Glass
Add code to set up the SDRAM in SPL, ready for loading U-Boot. This uses device tree for configuration so should be able to support other RAM configurations. It may be possible to generalise the code to support other SoCs at some point. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: rk3288: Add pinctrl driverSimon Glass
Add a driver which supports pin multiplexing setup for the most commonly used peripherals. Signed-off-by: Simon Glass <sjg@chromium.org>
