This function is called from esdhc_send_cmd so we need it available to
everyone.
Fix:
undefined reference to `spi_flash_free'
undefined reference to `spi_flash_probe'
CC: Stefan Roese <sr@denx.de>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
1. Add USDHC, I2C, UART, 74LV, USB, QSPI support.
2. Support SPL
3. CONFIG_MX6UL_14X14_EVK_EMMC_REWORK is introduced, this board default
supports sd for usdhc2, but can do hardware rework to make usdhc2 support
emmc.
Boot Log:
U-Boot SPL 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59)
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59 +0800)
CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C)CPU: Thermal invalid data, fuse: 0x0
- invalid sensor device
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C: ready
DRAM: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
i.MX6UL's DRAM space starts from 0x80000000, same to i.MX6SX, so use
same address with i.MX6SX.
1. Define two structures mx6ul_iomux_ddr_regs and mx6ul_iomux_grp_regs.
2. Add a new function mx6ul_dram_iocfg to configure dram io.
3. Refactor MMDC1 macro, discard "#ifdef CONFIG_MX6SX". Since
only mmdc0 channel exists on i.MX6SX/UL, redefine MMDC1 macro support
runtime check, but not hardcoding #ifdef macros.
4. Introduce mx6ul-ddr.h, which includes the register address for DRAM
IO configuration.
DRAM space starts from 0x80000000 for i.MX6UL, so need to
fix LOADADDR, SYS_TEXT_BASE.
i.MX6UL does not have GPIO6/7, so do not include them for i.MX6UL.
PAD_CTL_SPEED_LOW for i.MX6SX/UL is (0 << 6)
Signed-off-by: Ye.Li <B37916@freescale.com>
1.Update WDOG settings.
2.No need to gate/ungate all PFDs for i.MX6UL.
i.MX6UL features an Cortex-A7 core, it does not have PL310 as other i.MX6
chips. To Cortex-A7 core, If D-Cache is enabled, L2 Cache is enabled.
There is on specific switch for on/off L2 Cache, so default select
SYS_L2CACHE_OFF.
1. Add enet, uart, i2c, ipg clock support for i.MX6UL.
2. Correct get_periph_clk, it should account for
MXC_CCM_CBCDR_PERIPH_CLK2_PODF_MASK.
3. Refactor get_mmdc_ch0_clk to make all i.MX6 share one function,
but not use 'ifdef'.
4. Use CONFIG_FSL_QSPI for enable_qspi_clk, but not #ifdef CONFIG_MX6SX.
5. Use CONFIG_PCIE_IMX for pcie clock settings, use CONFIG_CMD_SATA for
sata clock settings. In this way, we not need "#if defined(CONFIG_MX6Q)
|| defined....", only need one CONFIG_PCIE_IMX in header file.
Since i.MX6UL use A7 core, but not A9 core, we do not need
the erratas for i.MX6UL.
Add i.MX6UL GPT timer support.
Since i.MX6UL's cache line size is 64bytes, need to
define the macro CONFIG_SYS_CACHELINE_SIZE to 64 for i.MX6UL.
1. Update imx register base address for i.MX6UL.
2. Remove duplicated MXS_APBH/GPMI/BCH_BASE.
3. Remove #ifdef for register addresses that equal to
"AIPS2_OFF_BASE_ADDR + 0x34000" for different chips.
4. According fuse map, complete fuse_bank4_regs.
5. Move AIPS3_ARB_BASE_ADDR and AIPS3_ARB_END_ADDR out of #ifdef CONFIG_MX6SX,
because we can use runtime check
Add i.MX6UL pins IOMUX file which defines the IOMUX settings for choose.
Add MXC_CPU_MX6UL for i.MX6UL CPU type which is got at runtime from
DIGPROG register. But the value has been occupied by MXC_CPU_MX6D which
is not real id from DIGPROG register, so change i.MX6D to value 0x67 which
was not occupied.
Add kconfig options for various SPI flashes and use them in cm-fx6 defconfig.
Cc: Jagan Teki <jteki@openedev.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
With recent additions to USB Kconfig the number of USB options had grown
large enough to warrant a separate menu for USB.
Add a Kconfig menu for USB.
Add Kconfig options for USB keyboard and use them for cm-fx6.
Add USB_EHCI_MX6 option to menuconfig and use it when migrating cm-fx6 usb
config to defconfig.
CPU_V7 is already selected by ARCH_MX6, so no point in selecting it again
by boards that depend on ARCH_MX6.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
cm-fx6 is an MX6 based board, and the menuconfig hierarchy should
reflect that. Make TARGET_CM_FX6 dependant on ARCH_MX6.
Move CONFIG_CMD_* options that can be selected in menuconfig to cm-fx6
defconfig.
Refactor display code to only setup hdmi if do_enable_hdmi() is invoked.
Add support for selecting display preset using the environment variable
"displaytype". This is a preparation for future merging of compulab
omap3_display.c display selection code with the cm-fx6 display selection code.
The "panel" environment variable is retained for backwards compatibility.
Implement a cm-fx6 specific board_video_skip() to provide the option to not
initialize the display.
The new function does not init display if the environment variable "panel" is
not defined, or if it is set to an unsupported value.
Collateral changes:
- Don't use the global displays array (it's CONFIG_IMX_VIDEO_SKIP specific).
- Don't use detect_hdmi(), since env controlled init makes it unnecessary.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
U-Boot does not explicitly assign the display to an IPU interface. Instead, it
relies on the power-on default of DI0.
Since the kernel reassigns HDMI display to DI1, after a warm reset the HDMI
display no longer works in U-Boot.
Fix this by explicitly assigning HDMI to IPU1 DI0 in U-Boot.
1. Add DDR script for mx6qpsabreauto board.
2. On CPU3 board, enet RGMII tx clock is from internal PLL. Set the GPR5[9]
and init the enet pll output to 125Mhz.
3. On CPU3 board, SW1ABC=VDDSOC_IN, SW2=VDDARM_IN.
Build target: mx6qpsabreauto_config
Boot Log:
U-Boot 2015.07-rc2-00071-gfd985ff (Jun 29 2015 - 22:10:55 +0800)
CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C) at 34C
Reset cause: POR
Board: MX6Q-Sabreauto revA
I2C: ready
DRAM: 2 GiB
PMIC: PFUZE100 ID=0x10
Flash: 32 MiB
NAND: 0 MiB
MMC: FSL_SDHC: 0
No panel detected: default to HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Note:
In this patch, we still add a new config mx6qpsabreauto_config,
since SPL is not supported now, and IMX_CONFIG is needed at
build time, so add this config. Future, when SPL is converted,
this config can be removed.
Signed-off-by: Robin Gong <b38343@freescale.com>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Detect the SOC and board variant at runtime and change the dtb name,
but not hardcoding the fdt_file env variable.
Take the following patch as a reference.
Íd58699b157df75f1aa0b363ea9c21add21a0c
"mx6cuboxi: Load the correct 'fdtfile' variable"
The i.MX6DQP has a PRG module, need to enable its clock for using IPU.
Signed-off-by: Brown Oliver <B37094@freescale.com>
Since the i.MX6QP has fixed the issue in boot ROM, so remove the workaround
for i.MX6QP.
Since i.MX6QP changes some CCM registers, so modify the clocks settings to
follow the hardware changes.
In c files, use runtime check and discard #ifdef.
Add cpu type for i.MX6QP/DP.
This patch also fix is_mx6dqp(), since get_cpu_rev can return MXC_CPU_MX6QP
and MXC_CPU_MX6DP, we should use:
(is_cpu_type(MXC_CPU_MX6QP) || is_cpu_type(MXC_CPU_MX6DP)).
sw variable in checkboard function is storing vbank value
which can only take 3-bit value.
So check of sw value for if greater than 7 is redundant.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
eMMC has no CD and WP pins, it needs to add board-specific
board_mmc_getcd() and board_mmc_getwp() in SPL to support
eMMC boot without external SD card inserted.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Serdes Lanes availability on T4160 and T4080 are same, which serdes 2 & 3
support 8 Lanes, but serdes 1 & 4 support only 4 Lanes E/F/G/H, Lanes
A/B/C/D are not available, updated the serdes table accordingly with
some minor fix.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Add support for NOR flash and GPIO/I2C switch control on RevC.
- NOR support
- bank0/bank4 switch
- SD/eMMC switch
- board version
For running Chain of Trust when doing Secure Boot from NAND,
the Bootscript header and bootscript must be copied from NAND
to RAM(DDR).
The addresses and commands for the same have been defined.
Signed-off-by: Saksham Jain <saksham@freescale.com>
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com>
Secure Boot Target is added for NAND for P5020 and P5040.
The Secure boot target has already been added for P3041 by
enabling CONFIG_SYS_RAMBOOT and configuring CPC as SRAM.
The targets for P5020 and P5040 are added in the same manner.
Secure Boot Target is added for NAND for P3041.
For mpc85xx SoCs, the core begins execution from address 0xFFFFFFFC.
In case of secure boot, this default address maps to Boot ROM.
The Boot ROM code requires that the bootloader(U-boot) must lie
in 0 to 3.5G address space i.e. 0x0 - 0xDFFFFFFF.
In case of NAND Secure Boot, CONFIG_SYS_RAMBOOT is enabled and CPC is
configured as SRAM. U-Boot binary will be located on SRAM configured
at address 0xBFF00000.
In the U-Boot code, TLB entries are created to map the virtual address
0xFFF00000 to physical address 0xBFF00000 of CPC configured as SRAM.
Commit 488d19c (patman: add distutils based installer) has the side effect
of making patman run twice with each invocation. Fix this by checking for
'main program' invocation in patman.py. This is good practice in any case.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
Added routine mmu_set_region_dcache_behaviour() to set a
particular region as non cacheable.
Define dummy routine for mmu_set_region_dcache_behaviour()
to handle incase of dcache off.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
IFC nand ecc encode and decode mode are not correctly
set in CSOR register during nand initialization.Enable
ecc encode/decode in 4-bit mode
Signed-off-by: Jaiprakash Singh <b44839@freescale.com>
Correct the value CONFIG_USB_MAX_CONTROLLER_COUNT macro to 1
for p1025 as it has one USB controller
Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
