2015-02-17Prepare v2015.04-rc2v2015.04-rc2Tom Rini
2015-02-17Revert "sunxi: configs/sunxi-common.h: Enable CONFIG_CMD_PART"Tom Rini
This reverts commit bd2a4888b123713adec271d6c8040ca9f609aa2f which was an older version of af21f2f which is what we actually want in. Signed-off-by: Tom Rini <trini@ti.com>
2015-02-17add example for file on VFAT filesystem usageWaldemar Brodkorb
For example on a raspberry pi the u-boot environment can be saved in a file on the first VFAT partition. This example illustrates how to use it with fw_printenv/fw_setenv. Signed-off-by: Waldemar Brodkorb <wbx@openadk.org>
2015-02-17Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-02-16ARM: lpc3250: config: add generic board supportVladimir Zapolskiy
The only LPC3250 board works fine with enabled generic board support, add CONFIG_SYS_GENERIC_BOARD right into the arch config header. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-02-16KM/IVM: remove ivm_read_eeprom(void)Valentin Longchamp
This is not used anymore since the procedure was split into a simple read function and a later alaysis. The ivm_read_eeprom name is now used for the previous ivm_simple_read_eeprom function. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-1682xx/km82xx: read the IVM eeprom earlierValentin Longchamp
This allows to define the ethaddr env variable according to the the IVM content by reading the IVM in misc_init_r. Later, when HUSH is available the content read earlier is analyzed to populate some non env variables. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-1683xx/km83xx: read the IVM eeprom earlierValentin Longchamp
2015-02-1685xx/kmp204x: read the IVM eeprom earlierValentin Longchamp
2015-02-16kirkwood/km_arm: read the IVM eeprom earlierValentin Longchamp
2015-02-16KM/IVM: split the IVM reading and parsing in 2 partsValentin Longchamp
This allows to first read the IVM content (earlier in the boot sequence) and define the ethaddr env variable thanks to the ivm_read_eepromi(). Later, the IVM content can be parsed and used to define some hush variables, when the hush subsystem is available thanks to ivm_analyze_eeprom(). To avoid the HW read to happen twice, the buffer passed to ivm_read_eeprom() has to be reused by ivm_analyze_eeprom (and thus allocated before calling ivm_read_eeprom()). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-16spl, spl_nor: fix compiler warningHeiko Schocher
executing "tools/buildman/buildman mpc5xx" drops this warning: common/spl/spl_nor.c: In function 'spl_nor_load_image': common/spl/spl_nor.c:26:10: warning: assignment discards 'const' qualifier from pointer target type [enabled by default] fix this. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-02-16.travis.yml: remove 824x buildsHeiko Schocher
remove powerpc 824x build, as this architecture not longer exists. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-02-16PCI: add 64-bit prefetchable memory supportDavid Feng
PCI specification allow prefetchable memory to be 32-bit or 64-bit. PCI express specification states that all memmory bars for prefetchable memory must be implemented as 64-bit. They all require that 64 bit prefetchble memory are suported especially when u-boot is ported to more and more 64bit processors. Signed-off-by: David Feng <fenghua@phytium.com.cn> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-16sunxi: Support the FEL boot mode in the regular u-boot buildSiarhei Siamashka
So that the CONFIG_SPL_FEL option is not needed anymore. And the regular SPL binary, generated by the default u-boot build, is now also bootable over USB in the FEL mode. The SPL still can boot from the SD card too. A bunch of system registers need to be saved/restored in order to ensure that the IRQ handler still works in the BROM FEL code after getting control back from the SPL. This is done in the sunxi code instead of abusing ifdefs in 'start.S'. The decision whether to load the main u-boot binary from the SD card or return to the FEL code in the BROM is done at runtime. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [hdegoede@redhat.com: Since we now restore various regs before returning to the FEL BROM code we can drop the sunxi specific #ifdefs in start.S] Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16sunxi: Normalise FEL supportSimon Glass
Make sunxi's FEL code fit with the normal U-Boot boot sequence instead of creating its own. There are some #ifdefs required in start.S. Future work will hopefully remove these. This series is available at u-boot-dm, branch sunxi-working. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16arm: spl: Provide for a board-specific loaderSimon Glass
Some boards have a special way of loading U-Boot that does not fit with the existing SPL code. For example sunxi uses an 'FEL' mode where U-Boot is loaded over USB. Add a CONFIG option and boot mode for this. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16arm: Allow lr to be saved by board codeSimon Glass
The link register value can be required on some boards (e.g. FEL mode on sunxi) so use a branch instruction to jump to save_boot_params() instead of a branch link. This requires a branch back to save_boot_params_ret so adjust the users to deal with this. For exynos just drop the function since it doesn't do anything. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16tools: mksunxiboot: Fix problems on big endian systemsSiarhei Siamashka
Now my PS3 can be also used to build u-boot for sunxi devices. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16sunxi: otg: Fix peripheral modeHans de Goede
Peripheral mode needs us to signal vusb high to the phy for it to work, just like the host mode does. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-16sunxi: dram: Un-inline dram helper functionsHans de Goede
Move the dram helper functions to a separate C file, rather then having them as inline helpers in dram.h. This saves 144 bytes in the .text segment for sun6i builds. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-16sunxi: video: Dynamically reserve framebuffer memoryHans de Goede
Only use CONFIG_SUNXI_MAX_FB_SIZE to reserve memory at the top when relocating u-boot, and calculate the actual amount of memory necessary when setting up the video-mode and use only that, freeing up some additional memory for use by the kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-16sunxi: video: Do not use CONFIG_SYS_MEM_TOP_HIDE for the framebufferHans de Goede
Do not use CONFIG_SYS_MEM_TOP_HIDE for the framebuffer, instead override board_get_usable_ram_top to make sure that u-boot is not relocated into the area where we want to use the framebuffer, and patch the devicetree from sunxi_simplefb_setup() to tell the kernel to not touch the framebuffer. This makes u-boot properly see the framebuffer as dram, and initalize the level 2 cache for it, fixing the very slow cfb scrolling problem. As an added bonus this stops us from reserving the framebuffer when simplefb is not used because an older kernel is booted, or hdp is used and no hdmi cable was plugged in, freeing up the memory for kernel use in these cases. Reported-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-16sunxi: MAINTAINERS: drop no longer existing felconfig-s from MAINTAINERSHans de Goede
2015-02-16sunxi: Ampe A76 supportPaul Kocialkowski
Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16config_distro_bootcmd.h: Enable CONFIG_CMD_PARTHans de Goede
The recent changes to config_distro_bootcmd.h require CONFIG_CMD_PART to be defined, as the default bootcmd now uses the "part" command. This fixes sunxi boards not booting with v2015.04-rc1. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2015-02-16image: Convert to use fdt_for_each_subnode macroAxel Lin
Use fdt_for_each_subnode macro to simplify the code a bit. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-16tools/imagetool: remove linker scriptAndreas Bießmann
Commit a93648d197df48fa46dd55f925ff70468bd81c71 introduced linker generated lists for imagetool which is the base for some host tools (mkimage, dumpimage, et al.). Unfortunately some host tool chains do not support the used type of linker scripts. Therefore this commit broke these host-tools for them, namely FreeBSD and Darwin (OS/X). This commit tries to fix this. In order to have a clean distinction between host and embedded code space we need to introduce our own linker generated list instead of re-using the available linker_lists.h provided functionality. So we copy the implementation used in linux kernel script/mod/file2alias.c which has the very same problem (cause it is a host tool). This code also comes with an abstraction for Mach-O binary format used in Darwin systems. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-02-16net: keystone_net: move serdes setup to initialization functionVitaly Andrianov
On Keystone2 devices serdes must be initialized before accessing MDIO bus. This commit moves the keystone2_net_serdes_setup() from keystone2_eth_open to keystone2_emac_initialize to meet that requirement. This also eliminates unnecessary serdes initializatin every time when the keystone2_eth_open is being called. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Nishanth Menon <nm@ti.com>
2015-02-16keystone2: ddr3: eliminate using global ddr3_size variableVitaly Andrianov
KS2 ddr3 initialization uses ddr3_size global variable before u-boot relocation. Even if the variable is not being used after relocation, writing to it corrupts relocation table. This patch removes the global ddr3_size variable and uses local one instead. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Tested-by: Nishanth Menon <nm@ti.com>
2015-02-16clock_am43xx:Set the MAC clock to /5 for OPP100Steve Kipisz
When EMAC is in the boot order, the boot ROM sets OPP50 and the MAC clock is set to /2. SPL needs to change it to /5 for Ethernet to generate the correct txclk. This patch sets it correctly. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
2015-02-16ARM: DRA7-evm: DDR3: Update leveling valuesLokesh Vutla
Update the software leveling parameters. This fixes the random crash seen on DRA7-evm. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-02-16ARM: DRA7: EMIF: Update SDRAM_REF_CTRL register valueLokesh Vutla
The value in SDRAM_REF_CTRL controls the delay time between the initial rising edge of DDR_RESETn to rising edge of DDR_CKE (JEDEC specs this as 500us). In order to achieve this, SDRAM_REF_CTRL should be written with a value corresponding to 500us delay before starting DDR initialization sequence, and configure proper value at the end of sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-02-16ARM: DRA72x: DDR3: Fix EMIF timings for 666MHz clockAngela Stegmaier
DDR3 timing and latency paramenters were not configured correctly for 666MHz. Fixing the timing and latency values according to Data sheet. This fixes the random crashes seen on DRA72-evm. Signed-off-by: Angela Stegmaier <angelabaker@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-02-16mtd, omap: fix case NAND_OMAP_GPMC_PREFETCH not definedEgli, Samuel
The patch c316f577b4b72d1a1aeb559e9b3fad20808f1ffd breaks siemens boards because prefetch mode is not enabled. I assume it breaks other boards as well that don't use prefetch. This patch sets read_buf to nand_read_buf if NAND_OMAP_GPMC_PREFETCH is not defined. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> CC: Daniel Mack <zonque@gmail.com> CC: Guido Martínez <guido@vanguardiasur.com.ar> CC: Tom Rini <trini@ti.com> CC: Heiko Schocher <hs@denx.de>
2015-02-16Merge git://git.denx.de/u-boot-marvellTom Rini
2015-02-16Merge branch 'sandbox' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-16lsxl: add a README fileMichael Walle
The README describes the recovery method which can be used if the NAS box is not reachable anymore. Addionally, it describes the different boot scripts. Signed-off-by: Michael Walle <michael@walle.cc>
2015-02-15sandbox: Adjust the order of the NO_SDL checkSimon Glass
An option is provided to avoid using SDL in U-Boot sandbox (and drop support for the LCD). However the check in the Makefile is too late and warnings are printed even if NO_SDL=y is given. Adjust the order to avoid this warning. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2015-02-15sandbox: Return '-c command' exit value as sandbox exit codeJoe Hershberger
When a command is passed into sandbox using the '-c' argument the command is run directly. This is most helpful when running tests (such as test-dm.sh). Previously the exit code was an unused enum. Change it to be the actual return code from the command so that the script calling sandbox can know if the command succeeded (tests passed). Also remove the now completely unused "exit_state" in sandbox. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-15buildman: allow multiple toolchains in a single pathAlbert ARIBAUD
When buildman scans a toolchain path, it stops at the first toolchain found. However, a single path can contains several toolchains, each with its own prefix. This patch lets buildman scan all toolchains in the path. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-15patman: Read in the git-mailrc alias fileSimon Glass
We should read this file to obtain a set of aliases. This reduces the need to create them in the ~/.patman file. This feature did exist in some version of patman, and is mentioned in the help but it did not find its way upstream. Reported-by: Graeme Russ <gruss@tss-engineering.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-15buildman: Fix incorrect arguemnt in GetUpstream()Simon Glass
This causes an error when trying to build a local branch which has a local branch as its upstream. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-13Merge git://git.denx.de/u-boot-samsungTom Rini
2015-02-13Merge git://git.denx.de/u-boot-dmTom Rini
2015-02-13Merge git://git.denx.de/u-boot-arcTom Rini
2015-02-13Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2015-02-13dm: mx6: sabre: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-13dm: stv0991: Move driver model CONFIGs to KconfigSimon Glass
2015-02-13Exynos: Clock: Cleanup soc_get_periph_rateAkshay Saraswat
Since we have src, div and pre-div mask bits defined corresponding to peripherals, calculation of clock specific to I2C appears redundant and confusing. Using clk_bit_info struct we can write calculations generic to all peripherals which makes code easy to understand and free from peripheral specific exceptions. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
