Messages to afleming@freescale.com now bounce, and should be
directed to my personal address at afleming@gmail.com
Signed-off-by: Andy Fleming <afleming@gmail.com>
The _config part is gone for sure, the _defconfig target could at least
work. I have not verified this for all targets though.
It's easier to Cc Masahiro on Kconfig-related changes with a git-mailrc
alias.
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Reflect the latest build system to doc/README.SPL.
This document is too old and useless.
if status register do never set MXC_CSPICTRL_TC, spi_xchg_single
endless loops. Add a timeout here to prevent endless hang.
Cc: Dirk Behme <dirk.behme@gmail.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This parameter should also be supported.
Tested-by: Ajay Kumar <ajaykumar.rs@samsung.com>
The SPI transaction delay is supposed to be measured from the end of one
transaction to the start of the next. The code does not work that way, so
fix it.
An incorrect message version is passed to the EC in some cases and the
parameters of one function are switched.
Fix these problems.
It's usually a common pattern to free() the memory that we allocated.
Implement this here to stop leaking memory.
Cc: Michal Simek <michal.simek@xilinx.com>
Add support for re-relocation malloc() in arm's start-up code.
At present arm defines CONFIG_SYS_GENERIC_GLOBAL_DATA, meaning that
the global_data pointer is set up in board_init_f(). However it is
actually set up before this, it just isn't zeroed.
If we zero the global data before calling board_init_f() then we
don't need to define CONFIG_SYS_GENERIC_GLOBAL_DATA.
Make this change (on arm32 only) to simplify the init process. I
don't have the ability to test aarch64 yet.
Acked-by: Tom Rini <trini@ti.com>
This patch configures the qrio to trigger a core reset on
a CPU reset request.
Signed-off-by: Rainer Boschung <rainer.boschung@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Reviewed-by: York Sun <yorksun@freescale.com>
To acheive this, the qrio_uprstreq() function that sets the UPRSTREQN
flag in the qrio RESCNF reg is added.
Check the core timer status register (TSR) for watchdog reset,
and and set the QRIO's reset reason flag REASON1[0] accordingly.
This allows the appliction SW to identify the cpu watchdog as a
reset reason, by setting the REASON1[0] flag in the QRIO.
To achieve this, the qrio_cpuwd_flag() function that sets the CPU watchdog
flag in the REASON1 reg is added.
The booting of the board is now protected by the CPU watchdog.
A failure during the boot phase will end up in board reset.
When CONFIG_WATCHDOG is defined the board initialization just performs
a WATCHDOG_RESET, an initialization of the watchdog is not done.
This has been modified fot the MPC85xx, the board initialization calls
its watchdog initialitzation allowing for full watchdog configuration
very early in the boot phase.
Function to inititialize the cpu watchdog added.
[York Sun: Add prototype in watchdog.h]
For e500mc cores the watchdog timer period has to be set by means of a
6bit value, that defines the bit of the timebase counter used to signal
a watchdog timer exception on its 0 to 1 transition.
The macro used to set the watchdog period TCR_WP, was redefined for e500mc
to support 6 WP setting.
The parameter (x) given to the macro specifies the prescaling factor of
the time base clock (fTB):
watchdog_period = 1/fTB * 2^x
TCR watchdog bit are overwritten when dec interrupt is enabled.
This has been fixed with this patch.
Add callback with __weak annotation to allow setup of environment
partition number in runtime from a board file.
Propagate mmc_switch_part() return value into init_mmc_for_env() instead
of -1 in case of failure.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Add missing mmc_get_env_addr() prototype in environment.h
If the MCI IP version >= 0x300, it supports hight speed mode
option, this patch enable it.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Add configuration register definition, this register only
exists on MCI IP version >= 0x300.
The mode register is different between MCI IP version.
So, according to MCI IP version to set the mode register.
To fix the clock divider calculation error when the controller
clock same as the operating frequency. This is known as bypass
mode. In this mode, the divider should be 0.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
Implement SD driver for the S3C24xx family. This implementation
is currently only capable of using the PIO transfers, DMA is not
supported.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Unify the register structure so they can be easily used across all
of S3C24xx lineup.
Seems like the controller doesn't support the flag. None of the hi-speed cards
I've tried could be read, while they successfully worked with the quirk enabled.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
This patch add Marvell kirkwood MVSDIO/MMC driver
and enable it for Sheevaplugs and OpenRD boards.
Signed-off-by: Gerald Kerma <drEagle@doukki.net>
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
CONFIG_${CPU} is defined by Kconfig.
CONFIG_${ARCH} is defined by Kconfig.
Use "make <board>_defconfig" instead of "make <board>_config".
Invoke tools/genboardscfg.py to generate boards.cfg when it is missing.
- Use "make <board>_defconfig" instead of "make <board>_config".
- Invoke tools/genboardscfg.py to generate boards.cfg when it is
missing.
- Show "Building ${BOARD_NAME} board..." message.
(Prior to Kconfig, instead, mkconfig script displayed
"Configuring for ${BOARD_NAME} board..." but it was removed.)
Without this message, we cannot know which board is currently
being built.
- Do not show "# configuration written to .config".
This message is useless and just annoying for MAKEALL.
The old configuration script is no longer necessary.
Nor is boards.cfg a primary database.
We can generate it with the genboardscfg.py tool
based on the latest Kconfig, defconfig and MAINTAINERS.
Now the primary data for each board is in Kconfig, defconfig and
MAINTAINERS.
It is true boards.cfg is needed for MAKEALL and buildman and might be
useful to brouse all the supported boards in a single database.
But it would be painful to maintain the boards.cfg in sync.
So, this is the solution.
Add a tool to generate the equivalent boards.cfg file based on
We can keep all the functions of MAKEALL and buildman with it.
The best thing would be to change MAKEALL and buildman for not
depending on boards.cfg in the future, but it would take some time.
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit enables Kconfig.
Going forward, we use Kconfig for the board configuration.
mkconfig will never be used. Nor will include/config.mk be generated.
Kconfig must be adjusted for U-Boot because our situation is
a little more complicated than Linux Kernel.
We have to generate multiple boot images (Normal, SPL, TPL)
from one source tree.
Each image needs its own configuration input.
Usage:
Run "make <board>_defconfig" to do the board configuration.
It will create the .config file and additionally spl/.config, tpl/.config
if SPL, TPL is enabled, respectively.
You can use "make config", "make menuconfig" etc. to create
a new .config or modify the existing one.
Use "make spl/config", "make spl/menuconfig" etc. for spl/.config
and do likewise for tpl/.config file.
The generic syntax of configuration targets for SPL, TPL is:
<target_image>/<config_command>
Here, <target_image> is either 'spl' or 'tpl'
<config_command> is 'config', 'menuconfig', 'xconfig', etc.
When the configuration is done, run "make".
(Or "make <board>_defconfig all" will do the configuration and build
in one time.)
For futher information of how Kconfig works in U-Boot,
please read the comment block of scripts/multiconfig.py.
By the way, there is another item worth remarking here:
coexistence of Kconfig and board herder files.
Prior to Kconfig, we used C headers to define a set of configs.
We expect a very long term to migrate from C headers to Kconfig.
Two different infractructure must coexist in the interim.
In our former configuration scheme, include/autoconf.mk was generated
for use in makefiles.
It is still generated under include/, spl/include/, tpl/include/ directory
for the Normal, SPL, TPL image, respectively.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
This commit adds more Kconfig files, which were written by hand.
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Import
- scripts/kconfig/*
- include/linux/kconfig.h
from Linux 3.16-rc7.
Change-Id: I8e72b942b8816726773d5407ce405d68a1594389
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Add back the maintainers entries for Altera's SOCFPGA platform.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
