using UBI and DM together leads in compiler error, as
both define a "struct device", so rename "struct device"
in include/dm/device.h to "struct udevice", as we use
linux code (MTD/UBI/UBIFS some USB code,...) and cannot
change the linux "struct device"
Make the common eeprom library available for any I2C driver.
Signed-off-by: Ilya Ledvich <ilya@compulab.co.il>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Add environment partition runtime detection callback.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
cm-t54 Eth MAC address is stored in onboard EEPROM.
Add EEPROM support and setup stored Eth MAC address.
If EEPROM does not contain a valid MAC, then generate it from the
processor ID code (reference code is taken from OMAP5 uEvm board file).
Modify Device Tree blob MAC address field with retrieved data.
Add cm-t54 board directory, config file. Enable build.
Basic support includes:
Serial console
SD/MMC
eMMC
USB
Ethernet
As revision code 1 is for silicon revision 2.0, it is easily confused with
silicon revision 1.0.
Device type report also reworked in same style.
Signed-off-by: Sergey Alyoshin <alyoshin.s@gmail.com>
Last section of DMM is used for trapping tiler unmapped sections.
Corresponding trap_size should be deducted from total SDRAM size
only if trap section is overlapping with available SDRAM
based on DMM sections. Fixing the same.
Cc: Tom Rini <trini@ti.com>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Roger Meier <r.meier@siemens.com>
Tested-by: Samuel Egli <samuel.egli@siemens.com>
This adds the Gumstix DuoVero machine [1]. This is a OMAP4430-based
computer-on-module (COM aka SOM) that can be mounted on various
expansion boards with different peripherals.
[1] https://store.gumstix.com/index.php/category/43/
Signed-off-by: Ash Charles <ash@gumstix.com>
[trini: Rename gpmc_enable_gpmc_cs_config to gpmc_enable_gpmc_net_config]
The omap_hw_init_context function (and assorted helpers) is the same for
all OMAP-derived parts as when CHSETTINGS are used, that's the same and
our DDR base is also always the same. In order to make this common we
simply need to update the names of the define for DDR address space
which is also common.
Cc: Sricharan R. <r.sricharan@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Add default eeprom address setting.
Efuse register addresses are wrongly programmed.
Fixing the same.
Acked-by: Tom Rini <trini@ti.com>
DRA72 has 1GB connected to EMIF1 only. Updating the details.
And also enable WA for BUG0039 only if corresponding EMIF is present.
Adding the prcm, dplls, control module hooks for DRA72x.
TPS65917 is used in DRA722 evm. Update the address offsets accordingly.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Add silicon ID code for DRA722 silicon.
GPMC controller on TI's OMAP SoC is general purpose controller to interface
with different types of external devices like;
- parallel NOR flash
- parallel NAND flash
- OneNand flash
- SDR RAM
- Ethernet Devices like LAN9220
Though GPMC configurations may be different for each platform depending on
clock-frequency and external device interfacing with controller. But
initialization sequence remains common across all platfoms.
Thus this patch merges gpmc_init() scattered in different arch-xx/mem.c
files into single omap-common/mem-common.c
However, actual platforms specific register config values are still sourced
from corresponding platform specific headers like;
AM33xx: arch/arm/include/asm/arch-am33xx/mem.h
OMAP3: arch/arm/include/asm/arch-omap3/mem.h
OMAP4: arch/arm/include/asm/arch-omap4/mem.h
OMAP4: arch/arm/include/asm/arch-omap5/mem.h
Also, CONFIG_xx passed by board-profile decide config for which set of macros
need to be used for initialization
CONFIG_NAND: initialize GPMC for NAND device
CONFIG_NOR: initialize GPMC for NOR device
CONFIG_ONENAND: initialize GPMC for ONENAND device
Signed-off-by: Pekon Gupta <pekon@ti.com>
[trini: define GPMC_SIZE_256M for omap3]
In case of multilib-enabled toolchains if default architecture differ from
the one examples are being built for linker will fail to link example object
files with libgcc of another (non-compatible) architecture.
Interesting enough for years in main Makefile we used CFLAGS/c_flags for this
but not for examples.
So fixing it now.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Wolfgang Denx <wd@denx.de>
Acked-by: WOlfgang Denk <wd@denx.de>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Entry for dfu subsystem have been added to doc/git-mailrc file
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
This is currently the only x86 board.
This patch moves platform specific information for GPMC and ELM controller
into separate header files, so that any derivative devices do not mess other
header files.
Platform specific information added into arch-xx/../hardware.h
- CPU related platform specific details like base-address of GPMC and ELM
Platform specific information added into arch-xx/../mem.h
- Generic configs for GPMC and ELM initialization.
- Hardware parameters or constrains specific to GPMC and ELM IP like;
number of max number of chip-selects available
header files.
Clean-up the board configuration file for the Gumstix Overo board by
including common omap3 definitions from ti_omap3_common.h as suggested
here [1].
[1] http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/185960
Signed-off-by: Ash Charles <ashcharles@gmail.com>
include/configs/omap3_overo.h
Update the board configuration for Gumstix Overo. In particular,
add support for zImage and DTB files on boot.
Add EEPROM ID switches for Alto35, Arbor43C, Stagecoach, Thumbo, and
Turtlecore Gumstix Overo expansion boards.
Gumstix Overo COMs with board revision 0x4 use a different Wifi and
Bluetooth module: Wi2Wi's W2CBW0015. No other code changes are required
in u-boot---just handling of this particular board revision.
Patch f33b9bd3
[arm: omap3: Enable clocks for peripherals only if they are used]
breaks SPL booting on Overo. Since some gpio inputs are
read to detect the board revision. But with this patch above, the
clocks to the GPIO subsystems are not enabled per default any more.
The GPIO banks need to be configured specifically now.
The linux kernel is at nand0,3 using the current layout, but is best
accessed through the partition label "linux". Since CONFIG_CMD_MTDPARTS is
defined the CONFIG_JFFS2 settings are unreferenced; use "setenv partition
rootfs" to set the default mtd partition for jffs2.
Signed-off-by: Peter A. Bigot <pab@pabigot.com>
Tested-by: Ash Charles <ash@gumstix.com>
Linux kernel at version 3.5 is about 3.5 MiB; test kernels for 3.10 exceed 4
MiB. Prepare for future upgrades by increasing the NAND partition now.
The NAND linux partition format default was changed from jffs2 to ubi in
254973e6df0e48f1a72b67905185c774dcd9f394 but the corresponding commands were
not enabled.
Adapted from d70f5480 described below.
commit d70f54808dfa83b574e1239c3eccbcf3317343e1
Author: Javier Martinez Canillas <javier@dowhile0.org>
Date: Mon Jan 7 03:51:20 2013 +0000
omap4: allow the use of a plain text env file instead boot scripts
For production systems it is better to use script images since
they are protected by checksums and carry valuable information like
name and timestamp. Also, you can't validate the content passed to
env import.
But for development, it is easier to use the env import command and
plain text files instead of script-images.
Since both OMAP4 supported boards (Panda and TI SDP4430) are used
primarily for development, this patch allows U-Boot to load env var
from a text file in case that an boot.scr script-image is not present.
The variable uenvcmd (if existent) will be executed (using run) after
uEnv.txt was loaded. If uenvcmd doesn't exist the default boot sequence
will be started.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Acked-by: Nishanth Menon <nm@ti.com>
In 7168977 we made calls to check_and_invalidate_dcache_range()
conditional on !CONFIG_SYS_FSL_ESDHC_USE_PIO. Only define this function
in this case as well.
The implementation of mmc_select_hwpart() was cribbed from do_mmcops().
Update do_mmcops() to call mmc_select_hwpart() to avoid duplication.
<panto> Manual patch update due to patch order.
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
This enables specifying which eMMC HW partition to target for any U-Boot
command that uses the generic get_partition() function to parse its
command-line arguments.
Some device types (e.g. eMMC) have hardware-level partitions (for eMMC,
separate boot and user data partitions). This change allows the user to
specify the HW partition they wish to access when passing a device ID to
U-Boot Commands such as part, ls, load, ums, etc.
The syntax allows an optional ".$hwpartid" to be appended to the device
name string for those commands.
Existing syntax, for MMC device 0, default HW partition ID, SW partition
ID 1:
ls mmc 0:1 /
New syntax, for MMC device 0, HW partition ID 1 (boot0), SW partition
ID 2:
ls mmc 0.1:2 /
For my purposes, this is most useful for the ums (USB mass storage
gadget) command, but there's no reason not to allow the new syntax
globally.
This patch adds the core support infra-structure. The next patch will
provide the implementation for MMC.
All the sub-commands start with the main command name, but it was
missing from one of the help texts.
<panto> typos fix.
This sub-command adds support for the RPMB partition of an eMMC:
* mmc rpmb key <address of the authentication key>
Programs the authentication key in the eMMC This key can not
be overwritten.
* mmc rpmb read <address> <block> <#count> [address of key]
Reads <#count> blocks of 256 bytes in the RPMB partition
beginning at block number <block>. If the optionnal
address of the authentication key is provided, the
Message Authentication Code (MAC) is verified on each
block.
* mmc rpmb write <address> <block> <#count> <address of key>
Writes <#count> blocks of 256 bytes in the RPMB partition
beginning at block number <block>. The datas are signed
with the key provided.
* mmc rpmb counter
Returns the 'Write counter' of the RPMB partition.
The sub-command is conditional on compilation flag CONFIG_SUPPORT_EMMC_RPMB
Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
CC: Wolfgang Denk <wd@denx.de>
User's confirmation is asked in different commands. This commit adds a
function for such confirmation.
This patch adds functions for read, write and authentication
key programming for the Replay Protected Memory Block partition
in the eMMC.
MMC switch command for unsupported feature (e.g. bus width) sets a switch
error bit in card status. This bit should be checked, and, if it's set,
no access with new controller settings should be performed.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
mmc_init() doesn't call get_timer() anymore if MMC is already
initialized.
<panto> Minor formatting fix.
Signed-off-by: Mateusz Zalega <m.zalega@samsung.com>
Since B&R boards uses only MMC-Controller #1, it only
wastes time if we initialize #0 first to see that there is nothing.
Cc: <trini@ti.com>
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
