The SPDX tag conversion ate part of this file, put things back to the
way they should be.
The use of 'bool' data types in globally used header files cases build
errors like this:
In file included from arch/blackfin/include/asm/blackfin.h:13:0,
from include/common.h:92,
from cmd_test.c:17:
arch/blackfin/include/asm/blackfin_local.h:54:1: error: unknown type name 'bool'
Use plain 'int' instead to avoid such kind of trouble.
Some board have multiple configurations.
For example, the board "m54455evb" has many configurations:
M54455EVB, M54455EVB_a66, M54455EVB_i66, M54455EVB_intel, ...
When we modify board-related files, we need to test
all configurations based on such a board.
In such a case, the new option -b is useful.
-I$(TOPDIR)/include is defined in the top config.mk.
All objects under api/ and examples/api/ directories are selected
by CONFIG_API.
So we can move CONFIG_API switch to the top Makefile.
In order to use CONFIG_API, the definition of SUBDIR_EXAMPLES-y
must be moved after "sinlude $(obj)include/autoconf.mk".
The directory tools/ is always built before common/.
So when envcrc tool is necessary in common/Makefile,
it already exists.
HOSTCFLAGS is meaningless because no host programs
are compiled there.
by CONFIG_API.
Commit 69434e4c deleted spieval board support
but it missed to clean up include/configs/spieval.h file.
We have a generic rule to generate .o file from *.S
in $(TOPDIR)/config.mk.
tools/updater needs board/MAI/AmigaOneG3SE board
for compiling.
But AmigaOneG3SE board was already deleted
by Commit 953b7e6.
It looks like tools/imls/Makefile is invoked from nowhere.
And also it is broken.
Some GPIO connected LEDs have inverted polarity.
Introduce new config option: CONFIG_GPIO_LED_INVERTED_TABLE for the
specifying the inverted GPIO LEDs list and add support for this in the
gpio_led driver.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Tested-by: Ilya Ledvich <ilya@compulab.co.il>
Add a check for the gpio_request() function return value and do not try
to configure the GPIO if the gpio_request() call fails.
Also, print an error message indicating the gpio_request() has failed.
The CONFIG_GPIO_LED symbol does not have any documentation in the README
file. Document the CONFIG_GPIO_LED symbol.
In the case of not having CONFIG_CMD_HASH but having CONFIG_CMD_CRC32
enabled (and not CONFIG_CRC32_VERIFY), we end up in this part of the
code path on hash_command(). However, we will only have exactly 3 args
here, and 3 > 3 is false, and we will not try and store the hash at the
address given as arg #3. The next problem however is that we've been
moving argv around so the third value is now in argv[0] not argv[3].
Confirmed on AM335x Beaglebone White.
This chip is compatible with the existing driver, except that it uses
BAR2 instead of BAR1 for the I/O memory region. Using this patch I can
use the PCIe ethernet interface on the CompuLab Trimslice to boot from
the network.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Patch: 276477
Instead of directly calling the low-level invalidate_dcache_range() and
flush_cache() functions, provide thin wrappers that take into account
alignment requirements.
While at it, fix a case where the cache was flushed but should have been
invalidated, two cases where the buffer data was flushed instead of the
descriptor and a missing cache invalidation before reading the packet
data that the NIC just wrote to memory.
Patch: 276474
Added d-cache support for zynq_gem.c,
Observed a difference of +0.8 MiB/s when downloading
a file of size of 3007944Bytes.
With d-cache OFF:
Filename 'uImage'.
Load address: 0x800
Loading: #################################################################
1.3 MiB/s
done
Bytes transferred = 3007944 (2de5c8 hex)
With d-cache ON:
Filename 'uImage'.
Load address: 0x800
2.1 MiB/s
done
Changes on zynq_gem for d-cache support:
- Tx and Rx buffers are cache-aligned
- Updated logic for invalidating Rx buffers and flushing Tx buffers.
- Tx and Rx BD's are allocated from non-cacheable region.
(When BDs are cached, we don't see a consistent link)
- Use TX BD status intead of txsr status checks.
Signed-off-by: Srikanth Thokala <sthokal@xilinx.com>
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Signed-off-by: David Dueck <davidcdueck@googlemail.com>
The current code incorrectly detects gigabit capabilities for some
100Mbit/s phys. (lan8720a)
When an unprogrammed EEPROM is attached to a dm9000, the dm9000 will
come up with a invalid MAC address of ff:ff:ff:ff:ff:ff. Add code that
gets enabled if CONFIG_RANDOM_MACADDR is enabled that generates a random
(and valid) locally administered MAC address that allows the system to
network boot until a real MAC address can be configured.
Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
The e1000 driver expects to always have some kind of non-volatile memory
attached directly to the ethernet controller chip. This means that I would
have to add an additional separate flash chip to my custom board just to
store essentially the MAC address. Since I don't want to do that, this patch
introduces a new config option CONFIG_E1000_NO_NVM. If defined it disables
all accesses to the NVM. I have tested the patch with a 82574 controller.
Signed-off-by: Rojhalat Ibrahim <imr@rtschenk.de>
NetServerEther was not being cleared in the tftp server code, so the
destination MAC address would be whatever the last destination MAC
address was.
Scenario:
U-Boot:
dhcp
tftpsrv
Host:
Send device WRQ
Device:
Responds with ACK to dhcp server mac address with
host ip address
By clearing NetServerEther, we force a lookup of the host MAC address
to go with the associated host IP.
The masks were ignoring the last 4 bits which didn't allow detection differences
between the ar8031 and ar8035.
Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com>
Patch: 288018
The both AR8031 and AR8035 belong to Atheros 803x serial PHY.
So the phy id mask of AR8031 is the same to the phy id mask
of AR8035. The right mask value is 0x4fffff.
This patch has been tested on the P1010 and P1023.
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Patch: 287748
Fix the 32-bit memory access that is not "endianess safe",
i.e. not giving the desired byte layout for LE cpus:
tempval = *((uint *) (tmpbuf + 4)), where 'char tmpbuf[]'.
Free the stack from rendundant local vars:
tmpbuf[] and i.
Use a portable type (u32) for the 32bit tsec register value
holder: tempval.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
Use cross arch portable u32 instead of uint for the
tsec registers. Remove the typedefs for the register
struct definitions in the process. Fix long lines.
Currently, the buffer descriptor (BD) fields cannot be
correctly accessed by a little endian processor. This
patch fixes the issue by making the access of BDs to be
portable among different cpu architectures.
Use portable data types for the Rx/Tx buffer descriptor
fields. Use portable I/O accessors to insure that the
big endian BDs are correctly accessed by little endian
cpus too, and to insure proper sync with the H/W.
Removed the redundant RTXBD "volatile" type, as proper
synchronization around BD data accesses is provided by
the I/O accessors now.
The "sparse" tool was also used to verify the correctness
of these changes.
Cc: Scott Wood <scottwood@freescale.com>
Fix bufPtr and the rxIdx/ txIdx occurrences to
solve the related checkpatch warnings for the
coming patches.
Add the __iomem address space marker for the tsec pointers
to struct tsec_mii_mng memory mapped register regions.
This solves the sparse warnings for mixig normal pointers with
__iomem pointers for tsec. E.g.:
fsl_mdio.c:34:19: warning: incorrect type in argument 1 (different
address spaces)
fsl_mdio.c:34:19: expected unsigned int volatile [noderef]
<asn:2>*addr
fsl_mdio.c:34:19: got unsigned int *<noident>
tsec.c:91:35: warning: incorrect type in argument 1 (different address
spaces)
tsec.c:91:35: expected struct tsec_mii_mng *phyregs
tsec.c:91:35: got struct tsec_mii_mng [noderef] <asn:2>*phyregs_sgmii
tsec.c:680:19: warning: incorrect type in assignment (different address
spaces)
tsec.c:680:19: expected struct tsec_mii_mng *regs
tsec.c:680:19: got struct tsec_mii_mng [noderef] <asn:2>*<noident>
Remove tsec_t typedef. Define macros as getters of
tsec and mdio register memory regions, for consistent
initialization of various 'regs' fields and also to
manage overly long initialization lines.
Use the __iomem address space marker to address sparse
warnings in tsec.c where IO accessors are used, like:
tsec.c:394:19: warning: incorrect type in argument 1 (different
address spaces)
tsec.c:394:19: expected unsigned int volatile [noderef]
<asn:2>*addr
tsec.c:394:19: got unsigned int *<noident>
with __iomem pointers for tsec.
Access to privlist[1] (hardcoded referece to the 2nd tsec's
priv area) is neither correct nor does it make sense in the
current context. Each tsec dev has access to its own priv
instance only, and hence to its own set of group address
registers (GADDR) to filter multicast addresses.
This fix leads to removal of the unused (faulty) privlist[]
and related global static vars. Note that mcast() can be
called only after eth_device allocation and init, and hence
after priv area allocation, so dev->priv is correctly
initialized upon mcast() call.
Patch: 278990
There are several implementation issues for tsec_mcast_addr()
addressed by this patch:
* unmanaged, not portable r/w access to registers; fixed with
setbits_be32()/ clrbits_be32()
* use of volatile pointers
* unnecessary forced cast to u8 for the ether_crc() result
* removed redundant parens
* corrected some comment slips
Patch: 279000
This fixes the following compiler warnings when activating
CONFIG_MCAST_TFTP:
tsec.c: In function 'tsec_mcast_addr':
tsec.c:130:2: warning: passing argument 2 of 'ether_crc' makes pointer
from integer without a cast [enabled by default]
In file included from /work/u-boot-net/include/common.h:874:0,
from tsec.c:15:
/work/u-boot-net/include/net.h:189:5: note: expected 'const unsigned
char *' but argument is of type 'u8'
tsec.c: In function 'tsec_initialize':
tsec.c:646:13: warning: assignment from incompatible pointer type
eth.c: In function 'eth_mcast_join':
eth.c:358:2: warning: passing argument 2 of 'eth_current->mcast' makes
integer from pointer without a cast [enabled by default]
eth.c:358:2: note: expected 'u32' but argument is of type 'u8 *'
In the eth_mcast_join() implementation, eth_current->mcast()
takes a u8 pointer to the multicast mac address and not a ip
address value as implied by its prototype.
Fix parameter type mismatch for tsec_macst_addr() (tsec.c):
ether_crc() takes a u8 pointer not a u8 value.
mcast() is given a u8 pointer to the multicats mac address.
Update parameter type for the rest of mcast() instances.
Patch: 278989
It's important that buffer descriptors are aligned in accordance to GMAC
data bus width (32/64/128-bit). It's safe to align to 128-bit (16-bytes)
for every bus width type.
If buffer descriptor is improperly aligned GMAC discards lower bits of
provided address and as a result reads from improper location that
doesn't match expected fields.
Commit ef76025a99247cdb8f927a2c9f15400678dfb599 "net: Multiple
updates/enhancements to designware.c" introduced another structure
member "link_printed" right before buffer descriptors while "padding"
member was left untouched. This together with alignment of structure
itself to 16-byte boundary forces buffer descriptoprs always to be
4-byte aligned that causes driver complete disfunction if GMAC bus width
is 64 or 128-bit.
Proposed change makes sure all buffer descriptors are 16-byte (128-bit)
aligned.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Patch: 277902
"bus mode" register contains lots of fields and some of them don't
expect to be written with 0 (zero). So since we're only interested in
resetting MAC (which is done with setting the least significant bit of
this register with "0") I believe it's better to modify only 1 bit of
the register.
Acked-by: Vipin Kumar <vipin.kumar@st.com>
Patch: 277864
R8A7791 has the same sh-ether IP core as other SH/rmobile.
This patch adds support of R8A7791.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Joe Hershberger <joe.hershberger@gmail.com>
AR8035 driver will be never applied because of wrong mask for
AR8031 driver. Fix this.
Reported-by: Pavel Nakonechny <pavel.nakonechny@skitlab.ru>
Cc: Andy Fleming <afleming@freescale.com>
Patch: 276944
This chip is compatible with other RTL8168 chips and can be found on the
NVIDIA Cardhu and Beaver boards.
Patch: 276475
