[trini Don't remove some copyrights by accident]
The file header indicated that this file was GPL-2.0+, but actually
the code was derived from (Marvell based) Linux source code which is
only GPL-2.0. Fix this.
Cc: Stefan Roese <sr@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This commit adapts the files that were derived from PIBS (PowerPC
Initialization and Boot Software) codeto using SPDX License
Identifiers.
So far, SPDX has not assigned an official License ID for the PIBS
license yet, so this should be considered preliminary.
Note that the following files contained incorrect license information:
arch/powerpc/cpu/ppc4xx/4xx_uart.c
arch/powerpc/cpu/ppc4xx/start.S
arch/powerpc/include/asm/ppc440.h
These files included, in addition to the GPL-2.0 / ibm-pibs dual
license as inherited from PIBS, a GPL-2.0+ license header which was
obviously incorrect. This has been removed.
Licenses/README
Unlike the other patches in this series so far, this commit fixes a
ambiguity in the license terms for some OMAP files: the code was
originally derived from the Linux kernel sources, where it was clearly
marked as GPL-2.0 (i. e. without the "or later" part), but the U-Boot
version had a GPL-2.0+ file header added, apparently without
permission / relicensing from the original authors of the code.
Insert a GPL-2.0 SPDX-License-Identifier to fix this.
cc: Tom Rix <Tom.Rix@windriver.com>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Acked-by: Tom Rini <trini@ti.com>
1. Reformat tx/rx descriptor as an uniform struct.
2. Replace uint32_t[2] with uint64_t for descriptor control.
Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com>
CC: Joe Hershberger <joe.hershberger@gmail.com>
The __* keywords are reserved. On FreeBSD __unused evaluates
to the attribute unused, causing a compilation failure.
Just use unused instead.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
cc: joe.hershberger@gmail.com
This patch adds support for Realtek PHY modules RTL8211DN and
RTL8211E (variants: RTL8211E-VB-CG, RTL8211E-VL-CG, RTL8211EG-VB-CG),
which can be found on Freescale's T1040RDB boards.
To make the driver more generic across 8211 family, a generic name 8211x
is added for macros and function names.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Acked-by: York Sun <yorksun@freescale.com>
This patch adds support for the SMSC9500 with product id 0x9900 which is
equipped in the "EXSYS USB 2.0" etherner USB adapter.
Tested on omap3_beagle.
Use ARRAY_SIZE instead of having similar implementation in each drivers.
The NUMELEMS defined in drivers/net/npe/include/IxOsalTypes.h is not used
at all, so this patch removes it instead of converting it to use ARRAY_SIZE.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Cc: Ben Warren <biggerbadderben@gmail.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Cc: York Sun <yorksun@freescale.com>
LAN8710/8720 are 10/100 Mbps PHYs, so fix the '.features' field.
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Use default_serial_puts() instead of its own implementation.
Acked-by: Michal Simek <monstr@monstr.eu>
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Up to this point some PHY initialization was done from the FPGA
and some from u-boot.
From now all initialization is done from u-boot.
To keep this maintainable a PHY setup machine was implemented that can
execute commands from initialization arrays.
Add a new iocon flavor with a second communiction port per channel.
Add a new iocon flavor with fiber instead of copper connectivity.
Fixup an easy conflict over adding the clk_get prototype and USB_OTG
defines for am33xx having moved.
arch/arm/include/asm/arch-am33xx/hardware.h
Reviewed-by: Thierry Reding <thierry.reding@gmail.com>
Commit 669dfc2e adds libfdt_env.h to HOSTCPPFLAGS. It causes stdio.h
to be included before _GNU_SOURCE is defined in C files. On some old hosts
some prototypes are protected by #ifdef __USE_GNU, which is set when
_GNU_SOURCE is defined.
Signed-off-by: York Sun <yorksun@freescale.com>
The timestamp is shown in fit_print_contents() but for some reason not
in fit_image_print(). This seems to be an oversight, since it is the latter
which is used by bootm.
Add timestamp printing in this case.
(There is code duplication in these two function, for looking at in a future
patch).
This function is only defined if CONFIG_SILENT_CONSOLE is set and
CONFIG_SILENT_U_BOOT_ONLY is not set, the call to it should be based
on the same conditions.
Signed-off-by: Paul B. Henson <henson@acm.org>
At present the console for linux is silent if the U-Boot console is silent,
unless CONFIG_SILENT_U_BOOT_ONLY is set. I wonder if a better way would be
to have an environment variable to control this? Then we can control the
verbosity from scripts, and set the variable to 'no' for those boards that
want Linux to boot with console output.
If image name is longer than 32 bytes, then it will be truncated.
This will remove '\0' at the end of the line, so printf will
go out of string limit.
Signed-off-by: Taras Kondratiuk <taras@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
This is a trivial patch that just enables xmodem downloads using the existing
ymodem framework.
Signed-off-by: Angus Ainslie <angus@akkea.ca>
Signed-off-by: Antoine Tenart <atenart@adeneo-embedded.com>
[trini: Change to SPDX, fix a few compiler warnings, adapt to
CONFIG_OMAP_COMMON]
[trini: Fix warnings about vtp things in emif4.c, adapt AM43XX]
Rename some CONFIG_TI814X to a more generic CONFIG_TI81XX
[trini: Adapt for CONFIG_OMAP_COMMON changes, AM43XX]
add the am1808 based ipam390 board from Barix.
- 128MByte, DDR2, synchronous RAM 16bit databus to SDRAM
interface
- 128MByte, NAND Flash, 8bit databus to the NANDFlash
Interface
- Ethernet PHY Micrel KSZ8051R via RMII
- Console on UART 0
- booting fron nand flash
- spl falcon bootmode
in arch_cpu_init() uart2 is fix enabled, without reference the
setting from CONFIG_SYS_NS16550_COM1. Use the setting from
CONFIG_SYS_NS16550_COM1 for enabling the console.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
In case CONFIG_BOOTSTAGE is not defined, call from bootstage_mark_name()
show_boot_progress(), so get more BOOTSTAGE_ID* ids in show_boot_progress()
if CONFIG_BOOTSTAGE is not defined.
emac_pins_rmii pinmux
Add the generic "poke a GPIO" command, with the GPIO related defines.
Acked-by: Dan Murphy <dmurphy@ti.com>
Add the generic "poke the SPI bus" command, with the SPI related
defines.
Update omap5_common.h to use ti_armv7_common.h, and in turn update
dra7xx_evm.h and omap5_uevm.h slightly. The biggest changes here are
that IP blocks which exist on the platform, and had clocks enabled,
now have the drivers being built as well.
We create two new files, include/configs/ti_armv7_common.h for all of
the common IP blocks and related features / commands we share in
virtually all of our platforms. We then create
include/configs/ti_am335x_common.h for everything common to the am335x
SoC leaving just the board specific parts to
include/configs/ti_am335x_common.h.
Bring in the 'boot_fdt' environment variable that i.MX boards use to try
and load a device tree when booting.
With device trees, boards do not always set CONFIG_MACH_TYPE now, so we
must not rely on this define being set. The kernel uses ~0 to see if we
have a valid machine number or not, so set that as the default, invalid
machine, id and only fix if CONFIG_MACH_TYPE is set.
Tested-by: Heiko Schocher <hs@denx.de>
We defined PHYS_DRAM_1 to 0x80000000 (start of DRAM) and then used this
for CONFIG_SYS_SDRAM_BASE. But then we kept on referencing PHYS_DRAM_1
in other places. Change to directly setting CONFIG_SYS_DRAM_BASE and
then using that name in code.
IGEP boards now have Device Tree support in the mainline
kernel. To boot an IGEP board using a DT, a uEnv.txt plain
text file could be used to define a custom uenvcmd that will
be run by the default boot command.
It is more convenient to change the default boot command to
allow loading a FDT if it is stored in the boot dir of the
rootfs uSD/MMC partition.
If no FDT is found then the defaul command tries to boot a
zImage without a DT using legacy boot.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Able to load the kernel from some form of ext[234] or FAT. Also, with v3.9 and
later of the Linux Kernel, uImage isn't builtable anymore by default, so we
should switch to use the bootz command.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Commit "OMAP5: emif/ddr: Change emif settings as required for ES1.0 silicon"
(f40107345cbcd6e0d1747eda45e76c4e2a6df0db)
changed sequence to set final DDR PHY config register value at the beginning.
Looks like it was made by mistake and should be reverted.
