2013-07-12Prepare v2013.07-rc3v2013.07-rc3Tom Rini
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-07-12bootm: Handle errors consistentlySimon Glass
A recent bootm fix left the error path incomplete. If CONFIG_TRACE is set it may still not be a supported command, so cover that with the unsupported subcommand print. Once we handle BOOTM_STATE_OS_GO, we can just move into the error handler itself, no need for a goto there. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Update slightly based on Simon's changes to also cover CONFIG_TRACE/BOOTM_STATE_FAKE_OS_GO] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12mtd: mxc_nand: Fix crash after MTD resyncMarek Vasut
The driver triggered a BUG() in nand_base.c:3214/nand_scan_tail() because the ecc.strength was not set in NAND_ECC_HW_SYNDROME ECC mode. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Benoit Thebaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-07-12common/image.c: Fix regression with ramdisk load/entry points in FITStefano Babic
A FIT image with a ramdisk that sets the entry or load points to 0x0 must be treated as meaning "leave in place" and NOT "relocate to 0x0". This regression was introduced in a51ec63. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12bootm: Correct the arguments for the ELF image loaderSimon Glass
The arguments were out of place since commit 983c72f, since this file was missed and not tested. Correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12bootm: Use selected configuration for ramdisk and fdtSimon Glass
If a specific configuraion is selected by the bootm command, e.g. with 'bootm 84000000#recoveryconf' we must honour this for not just the kernel, but also the ramdisk and FDT. In the conversion to using a common fit_image_load() function for loading images from FITs (commits a51ec63 and 53f375f) this feature was lost. Reinstate it by passing the selected configuration back from fit_image_load() to boot_get_kernel(), then use this configuration (which is stored in images->fit_uname_cfg) in both boot_get_ramdisk() and boot_get_fdt(). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12blackfin: x86: bootm: Handle PREP stage of bootmSimon Glass
The OS function is now always called with the PREP stage. Adjust the remaining bootm OS functions to deal with this correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12bootm: Remove extra OK messageSimon Glass
This is not needed as we already print 'OK' later in all cases. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12cmd_bootm.c: Re-order bootm_load_os return check for ELDK4.2Tom Rini
With ELDK4.2 we were getting a warning that load_end may be used uninitialized in calling lmb_reserve. This could not be the case, however. If we re-order the checks (and make them slightly clearer as well) the warning goes away. bootm_load_os may only return 0 on success, BOOTM_ERR_OVERLAP in a non-fatal overlap (already covered in comments) or a fatal BOOTM_ERR that is covered in the error handler. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-07-12mx53ard: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-12mx51evk: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-07-12wandboard: Change default environment to cope with OE changesOtavio Salvador
2013-07-12mx6slevk: Change default environment to cope with OE changesOtavio Salvador
2013-07-12mx6qsabrelite: Change default environment to cope with OE changesOtavio Salvador
2013-07-12mx53loco: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Jason Liu <r64343@freescale.com>
2013-07-12net: fec: Avoid MX28 bus sync issueMarek Vasut
The MX28 multi-layer AHB bus can be too slow and trigger the FEC DMA too early, before all the data hit the DRAM. This patch ensures the data are written in the RAM before the DMA starts. Please see the comment in the patch for full details. This patch was produced with an amazing help from Albert Aribaud, who pointed out it can possibly be such a bus synchronisation issue. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com>
2013-07-12net: fec: Remove bogus flush_dcache_range() callMarek Vasut
Remove incorrectly called and duplicate flush_dcache_range() call from fec_mxc driver. The call is not needed, since the caches are already flushed in fec_tbd_init(), moreover the second argument should be the ending address, not size. Signed-off-by: Marek Vasut <marex@denx.de> Reported-by: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com>
2013-07-12m28evk: add trimffs to nand commandMarek Vasut
this is usefull when writing an UBI image which contains and UBIFS volume (check README.nand and UBI FAQ for more details) Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-07-11ARM: tegra: enable LCD panel on VentanaStephen Warren
Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: tegra: enable LCD panel on HarmonyStephen Warren
2013-07-11Tegra: Config: Enable Tegra30/Tegra114 USB functionJim Lin
Add USB EHCI, storage and network support. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: Tegra: USB: EHCI: Add support for Tegra30/Tegra114Jim Lin
Tegra30 and Tegra114 are compatible except PLL parameters. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: Tegra: FDT: Add USB EHCI function for T30/T114Jim Lin
Add DT node for USB EHCI function. Add support for T30-Cardhu, T30-Beaver, T114-Dalmore boards. Signed-off-by: Jim Lin <jilin@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-10Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-07-10usb: pxa27x_udc: fix compiler warningsMike Dunn
Newer gcc versions warn about unused variables. This patch corrects a few of those warnings that popped up in a build for the palmtreo680 board. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-07-10dfu: Update DFU's authorship historyŁukasz Majewski
The DFU's state machine original implementation author and copyright were missing. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
2013-07-10cmd_bootm.c: Make bootz handle BOOTM_STATE_FINDOTHER itselfTom Rini
As a zImage does not have a U-Boot header, we cannot really do what BOOTM_STATE_FINDOTHER does, exactly. Break the ramdisk/fdt portions of bootm_find_other into bootm_find_ramdisk/fdt which can be called in both cases. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10cmd_bootm.c: Make bootz consume 'bootz' from argv, decrement argcTom Rini
Like 'bootm', 'bootz' needs to consume 'bootz' so that the rest of the state functions will work. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10bootm: Add the missing PREP stage to bootz and correct image handlingSimon Glass
In the recent bootm refactor, the PREP stage was missing in the bootz command. This causes unpredictable behaviour. The use of a local variable means that the reset of cmd_bootm.c does not in fact use the same image structure, so remove this. Also manually set the OS type to Linux, since this is the only possibility at present, and we need to select the right boot function. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10bootm: Clean up bootz_setup() functionSimon Glass
This function has no prototype in the headers and passes void * around, thus requiring several casts. Tidy this up. - Add new patch to clean up bootz_setup() function Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10bootm: Require boot function only if it is about to be usedSimon Glass
The original bootm code (before commit 35fc84f) did not check for a valid boot function in the subcommand case, which was incorrect. This check was introduced in all cases, but in fact we should only check for the function when we need it. Otherwise in some cases the check fires before the OS type is known. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10bootm: Disable interrupts only when loadingSimon Glass
With the move of the interrupt code to earlier in the sequence, we exposed a problem where the interrupts are disabled at each bootm stage. This is not correct - it should be done only once. Let's disable interrupts in the LOAD stage. Put the code in a function for clarity. Also, bootz lost its interrupt code altogether, so reinstate it. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2013-07-10EXYNOS: Resolve the i2c compilation errorAmar
This patch resolves the below mentioned compilation error of i2c driver for non-FDT case Compilation error: s3c24x0_i2c.c: In function 'board_i2c_init': s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use in this function) s3c24x0_i2c.c:544:18: note: each undeclared identifier is reported only once for each function it appears in s3c24x0_i2c.c:545:3: warning: implicit declaration of function Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-09arm: exynos: fix clock calculationMinkyu Kang
There are differnce with clock calcuation by cpu variations. This patch will fix it according to user manual. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
2013-07-08video: consolidate splash screen alignment codeAnatolij Gustschin
Code for checking "splashpos" environment variable is duplicated in drivers, move it to the common function. Call this function also in the bmp display command to consider "splashpos" settings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-07-05power:bat:trats: Break battery charging with ctrl+CŁukasz Majewski
Add support for disabling battery charging with ctrl+C keyboard combination pressed. Moreover the battery update is done more frequently. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05arm:trats: Increase malloc pool size (for DFU ext4 transfers)Łukasz Majewski
Commit: dfu: make data buffer size configurable SHA1: 89a72b2e0e141042c9109185e02d39b2107ffc62 replaced statically allocated buffers with one allocated with memalign. Malloc pool size of 1MiB was too small, since we needed bigger buffer to transfer for example uImage. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS4210: Configure GPIO for uartRajeshwari Shinde
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: LDS file move to commonRajeshwari Shinde
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused. It is renamed to exynos-uboot-spl.lds Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: Add API for power reset and exit wakeupRajeshwari Shinde
This patch adds APIs to get power reset status and exit the wakeup condition for both exynos5 and exynos4 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-04cmd_bootm.c: Correct check/return for unsupported sub-commandTom Rini
With the do_bootm_states re-organization, we have the call to any potential sub-commands in a single spot. If one fails, we can then stop right there and return to the caller. Prior to these calls we have already ensured that ret is zero so we will not be returning this error for some other case. Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-07-03cosmetic: README.SPL: fix a typoMasahiro Yamada
2013-07-03Makefile: fix readelf usageAndreas Bießmann
Some OS (like OS X) do not provide a generic readelf. We should enforce to use the toochain provided readelf instead, to do so use $(CROSS_COMPILE)readelf. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl> Tested-by: Lubomir Popov <lpopov@mm-sol.com>
2013-07-03tools/proftool: remove REG_NOERRORAndreas Bießmann
Remove non portable usage of REG_NOERROR. BSD (like OS X) variants of regex.h do not declare REG_NOERROR, even GNU regex(3) does not mention REG_NOERROR, just remove it. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-07-03lib/rsa/rsa-sig.c: compile on OS XAndreas Bießmann
Interfaces exposed by error.h seems not to be used in rsa-sig.c, remove it. This also fixes an compile error on OS X: ---8<--- u-boot/lib/rsa/rsa-sign.c:23:19: error: error.h: No such file or directory --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl> Tested-by: Lubomir Popov <lpopov@mm-sol.com>
