This makes sure we have inline functions such as inb/outb that
are used in these two files by including the arch-specific
<asm/io.h> header. However the ARM version does not provide the
accessors unless the config symbol __io is also defined so add
that in front of the include.
After this the bios emulator will compile on ARM systems.
The "mmc rescan" command takes no arguments. However, executing
"mmc rescan 1" succeeds, leading the user to believe that MMC device 1
has been rescanned. In fact, the "current" MMC device has been
rescanned, and the current device may well not be 1. Add error-checking
to the "mmc" command to explicitly reject any extra command-line
arguments so that it's more obvious when U-Boot isn't doing what the
user thought they asked it to.
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a,
which changed all occurrences of __bss__end__ into __bss_end,
left behind some untouched __bss_end__ occurrences in all 33
u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and
in board/mousse/u-boot.lds.rom. These are replaced here.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
start_sect is not aligned to a 4 byte boundary thus causing exceptions
on ARM platforms. Access this field via the get_unaligned_le32 macro.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
CONFIG_SYS_HZ must be 1000, and get_timer() must therefore return ms.
Document this.
README text provided by Tom Rini.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
It was noticed that when `make distclean' is run, the make process
terminates with error reporting something like:
rm: cannot remove '/tmp/foobar/': Is a directory
make: *** [clobber] Error 1
The problem is that the list of files targeted for removal includes a
directory in case CONFIG_SPL_TARGET is not set.
The fix has been tested as follows:
Ran several times the following sequence of commands:
CROSS_COMPILE=/usr/bin/arm-linux-gnueabi- make O=/tmp/foobar smdk5250_config
CROSS_COMPILE=/usr/bin/arm-linux-gnueabi- make O=/tmp/foobar distclean
it did not cause an error, it used to before this change.
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Most of the various environment functions create CONFIG_ENV_SIZE buffers on
the stack. At least on ARM and PPC which have 4KB stacks, this can overflow
the stack if we have large environment sizes. So move all the buffers off
the stack to static buffers.
Bash ver 3.x doesn't support the parameter expansion with case
substitution. Use tr instead.
Signed-off-by: York Sun <yorksun@freescale.com>
Acked-by: Allen Martin <amartin@nvidia.com>
This patch provides a support to build the user specified dts.
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
'bool' is defined in random places. This patch consolidates them into a
single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with
true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true.
Skip *.py, *.php, lib/* files.
After merging LCD patches for v2013.04 the bcm2835 video
driver building is broken due to removal of many global
variables. Fix the driver.
Cc: Stephen Warren <swarren@wwwdotorg.org>
drivers/video/Makefile
* default bootmenu entries:
attached kernel, internal eMMC memory, external SD card,
u-boot boot order
* in CONFIG_PREBOOT try load bootmenu.scr from first partition
of internal eMMC memory (also known as MyDocs) which (should)
overwrite default bootmenu entries
* when keyboard slide is closed boot first menu entry
* when keyborad slide is open show bootmenu
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
The "bootmenu" command uses U-Boot menu interfaces and provides
a simple mechanism for creating menus with several boot items.
When running this command the menu will be assembled as defined
by a set of environment variables which contain a title and
command key-value pairs. The "Up" and "Down" keys are used for
navigation through the items. Current active menu item is
highlighted and can be selected using the "Enter" key.
The command interprets and generates various ANSI escape
sequencies, so for proper menu rendering and item selection
the used terminal should support them.
[agust: various fixes and documentation updates]
Checking the default menu item and obtaining its data can
be useful in custom menu code. Export menu_default_choice()
function which serves this purpose.
Selecting menu items is currently done in menu_interactive_choice()
by reading the user input strings from standard input.
Extend menu_interactive_choice() to support user defined function
for selecting menu items. This function and its argument can be
specified when creating the menu.
drivers/spi/tegra20_sflash.c
include/fdtdec.h
lib/fdtdec.c
The _start symbol is already relocated, so do not add the relocation the second
time in c_runtime_cpu_setup.
This fixes e.g. the abort exception handling path, which ended in double fault
due to bad address in VBAR.
Signed-off-by: Vincent Stehlé <v-stehle@ti.com>
Reported-by: Lubomir Popov <lpopov@mm-sol.com>
The 'XN' execute never bit is set in the pagetables. This will
prevent speculative prefetches to non executable regions. But the
domain permissions are set as master in the DACR register.
So the pagetable attribute for 'XN' is not effective. Change the
permissions to client.
This fixes lot of speculative prefetch aborts seen on OMAP5
secure devices.
Signed-off-by: R Sricharan <r.sricharan@ti.com>
Tested-by: Vincent Stehle <v-stehle@ti.com>
Cc: Vincent Stehle <v-stehle@ti.com>
Cc: Tom Rini <trini@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Introduce a weak version of dram_bank_setup function
to allow a platform specific function.
This is used in the subsequent patch to setup dram region
without 'XN' attribute in order to enable the region
under client permissions.
We declare the set_section_dcache function globally in the cache header, for
later use by e.g. machine specific code.
Signed-off-by: Vincent Stehlé <v-stehle <at> ti.com>
Cc: Tom Rini <trini <at> ti.com>
As I am no longer working for Bluegiga I will pass apx4devkit maintenance
to Lauri.
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@iki.fi>
Acked-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
Signed-off-by: Steven Stallion <sstallion@gmail.com>
Reviewed-by: Tom Rini <trini@ti.com>
The ext4write command was taking the in-memory address and filename path
in reverse order from the rest of the filesystem read and write
commands. This corrects the order to be the same as fatload, etc.
usleep_range() is a Linux facility, ignore it when udelay()
is encountered.
Signed-off-by: Matt Porter <mporter@ti.com>
While the kernel mainly uses pr_debug(...), etc, for debug messages, we
use debug(...). Add this to the list of logFunctions so that they are
correctly checked (and not warned against) for long string literals.
This is not called outside of env_callback.c so mark static, remove from
<env_callback.h>
This allows:
MAKEALL -s tegra
to replace:
MAKEALL -s tegra20 -s tegra30 -s tegra114
The following also works:
MAKEALL -s tegra -s omap
Tested on my Dalmore E1611 board, eMMC and SD-Card work fine, can load
a kernel off of an SD card OK, card detect works, and the env is now
stored in eMMC (end of the 2nd 'boot' sector, same as Tegra20/30).
Signed-off-by: Tom Warren <twarren@nvidia.com>
T114 requires SD bus power-rail bringup for the SDIO card on SDMMC3.
SDIO1 (the SD-card slot on Dalmore) needs to have its pads setup
before the MMC driver is added.
Took these values directly from the kernel dts files.
Turn on SPI in dalmore config file
Signed-off-by: Allen Martin <amartin@nvidia.com>
Add driver for tegra114 SPI controller. This controller is not
compatible with either the tegra20 or tegra30 controllers, so it
requires a new driver.
Dalmore has a SPI flash part attached to controller 4, so enable
controller 4 and set to 25MHz.
Add nodes for t114 SPI controller hardware
Add node for apbdma controller hardware.
Add "nvidia,tegra114-spi" to represent t114 SPI controller hardware.
Add support for Winbond W25Q32DW 32Mbit part
Add a common interface to fdt based SPI drivers. Each driver is
represented by a table entry in fdt_spi_drivers[]. If there are
multiple SPI drivers in the table, the first driver to return success
from spi_init() will be registered as the SPI driver.
Make the tegra20 SPI driver similar to the tegra30 (and soon to be
tegra114) SPI drivers in preparation of common fdt SPI driver front
end.
Move register structs from headers into .c files and use common name.
This is in preparation of making common fdt front end for SPI
drivers.
Remove non fdt support from tegra20 and tegra30 SPI drivers in
preparation of new common fdt based SPI driver front end.
Rename tegra SPI drivers to tegra20_flash and tegra20_slink in
preparation for commonization and addition of tegra114_spi.
This feature was only used for tegra20 seaboard that had a pinmux
conflict on the SPI pins. These boards were never manufactured, so
remove this support to clean up SPI driver.
