2012-04-21Prepare v2012.04v2012.04Wolfgang Denk
Also tiny style cleanup to tools/patman/README Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-04-21net: ll_temac: drop obsolete "NAMESIZE" defineStephan Linz
... after commit "net/miiphy/serial: drop duplicate NAMESIZE define" (sha1:f6add13) was applied. The building of the new LL TEMAC network driver fails with error below: xilinx_ll_temac.c: In function 'xilinx_ll_temac_initialize': xilinx_ll_temac.c:301: error: 'NAMESIZE' undeclared (first use in this function) xilinx_ll_temac.c:301: error: (Each undeclared identifier is reported only once xilinx_ll_temac.c:301: error: for each function it appears in.) Signed-off-by: Stephan Linz <linz@li-pro.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-04-21Add 'patman' patch generation, checking and submission scriptSimon Glass
What is this? ============= This tool is a Python script which: - Creates patch directly from your branch - Cleans them up by removing unwanted tags - Inserts a cover letter with change lists - Runs the patches through checkpatch.pl and its own checks - Optionally emails them out to selected people It is intended to automate patch creation and make it a less error-prone process. It is useful for U-Boot and Linux work so far, since it uses the checkpatch.pl script. It is configured almost entirely by tags it finds in your commits. This means that you can work on a number of different branches at once, and keep the settings with each branch rather than having to git format-patch, git send-email, etc. with the correct parameters each time. So for example if you put: in one of your commits, the series will be sent there. See the README file for full details. END Signed-off-by: Simon Glass <sjg@chromium.org>
2012-04-21eb_cpux9k2: add USB host support to boardJens Scharsig
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2012-04-21mmc: Fix warning if CONFIG_MMC_TRACE is enabledDirk Behme
Fix the warning mmc.c: In function 'mmc_send_cmd': mmc.c:87: warning: assignment from incompatible pointer type in case CONFIG_MMC_TRACE is enabled. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Andy Fleming <afleming@freescale.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2012-04-21ehci-omap: fix for enabling the correct usb portJeroen Hofstee
This is just a patch for the problem reported here: http://lists.denx.de/pipermail/u-boot/2012-February/117580.html originally reported by Igor. "Looks like this is copy paste error from my side,(for port2/3 it should have been bypass for port2/3 rather its port1 set in bypass mode)" I only submit the patch since it is missing in 2012.04-rc3 while the twister board depends on it. Maybe it is already somewhere in the reposistory, but I cannot find it. note: the twister boards still needs an additional `usb reset`, don't know why. U-Boot 2012.04-rc3-dirty (Apr 19 2012 - 21:38:38) AM35XX-GP ES1.0, CPU-OPP2, L3-165MHz, Max CPU Clock 600 Mhz TAM3517 TWISTER Board + LPDDR/NAND I2C: ready DRAM: 256 MiB NAND: 512 MiB MMC: OMAP SD/MMC: 0 In: serial Out: serial Err: serial Die ID #746c0000000000000155dc1405011024 Net: DaVinci-EMAC, smc911x-0 Hit any key to stop autoboot: 0 twister => usb start (Re)start USB... USB: Register 1313 NbrPorts 3 USB EHCI 1.00 scanning bus for devices... 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found twister => usb reset (Re)start USB... USB: Register 1313 NbrPorts 3 USB EHCI 1.00 scanning bus for devices... 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found twister => usb reset (Re)start USB... USB: Register 1313 NbrPorts 3 USB EHCI 1.00 scanning bus for devices... 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found twister => usb reset (Re)start USB... USB: Register 1313 NbrPorts 3 USB EHCI 1.00 scanning bus for devices... 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Govindraj.R <govindraj.raja <at> ti.com> Acked-by: Tom Rini <trini@ti.com>
2012-04-21fdt: avoid bad MAKEALL statusWolfgang Denk
Current versions of dtc always print a message like DTC: dts->dtb on file "dt.dtb.tmp" which cannot even be suppressed with "-qqq". To avoid incorrect MAKEALL status, we manually filter out this message. This is a bit complicated, as we have to make sure to set a correct return code. Also, get rid of the temp file: dtc accepts "-" for stdin. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2012-04-21fdt: fix out of tree builds with DT supportWolfgang Denk
Fix: FATAL ERROR: Couldn't open "../arch/arm/dts/tegra20.dtsi": No such file or directory Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2012-04-21GCC4.6: Squash warnings in onenand_base.cWolfgang Denk
Fix gcc 4.6 build warnings: onenand_base.c: In function 'onenand_probe': onenand_base.c:2577:6: warning: variable 'maf_id' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2012-04-18Prepare v2012.04-rc3v2012.04-rc3Wolfgang Denk
2012-04-18Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
* 'master' of git://git.denx.de/u-boot-sh: sh: ecovec: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT sh: Fix rsk7264 pin setup for on-board ethernet
2012-04-18sh: ecovec: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INITNobuhiro Iwamatsu
When calling board_late_init, we need to define CONFIG_BOARD_LATE_INIT. The latest ecovec config defines BOARD_LATE_INIT, board_late_init is not called. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-04-18sh: Fix rsk7264 pin setup for on-board ethernetPhil Edworthy
This sets up the external ethernet IRQ pin. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-04-17i.MX6: arm2: Add AXI cache and Qos settingDirk Behme
Do the same AXI cache and Qos settings done already in the SabreLite imximage.cfg for the ARM2 board, too. It fixes a display flash issue caused by low priority of the display IDMA channel. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Jason Chen <b02280@freescale.com> CC: Jason Liu <r64343@freescale.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <festevam@gmail.com> Acked-by: Jason Liu <r64343@freescale.com>
2012-04-16Prepare v2012.04-rc2; minor Coding Style cleanupv2012.04-rc2Wolfgang Denk
2012-04-16Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM926EJS: Fix cache.c to comply with checkpatch.pl ARM926EJS: Make asm routines volatile in cache ops MX35: mx35pdk: wrong board revision ARM1136: MX35: Make asm routines volatile in cache ops ARM: add u-boot.imx as target for i.MX SOCs M28: Pull out CONFIG_APBH_DMA so it's always enabled DMA: Split the APBH DMA init into block and channel init imx: Return gpio_set_value in gpio_direction_output imx: Use GPIO_TO_PORT macro in the gpio driver instead of (gpio >> 5) imx: Add GPIO_TO_PORT macro in the mxc_gpio driver imx: Remove unneeded/repititive definitions from imx headers i.MX28: Allow coexistence of PIO and DMA mode for SD/MMC MX31: mx31pdk: drop enable_caches from board file i.MX28: Fix initial stack pointer position mx35: mx35pdk: fix when cache functions are linked mx35: flea3: fix when cache functions are linked ARM: 926ejs: use debug() for misaligned addresses ARM1136: add cache flush and invalidate operations mx6qsabrelite: Fix the serial console port mx6qsabrelite: Add boot switch setting information into the README i.MX6: mx6qsabrelite: add cache commands if cache is enabled i.MX6: implement enable_caches() i.MX6: define CACHELINE_SIZE MX53: DDR: Fix ZQHWCTRL field TZQ_CS mx28evk: Add a README file mx28: Split the README into a common part and a m28 specific part tricorder: Load kernel from ubifs tricorder: Add UBIFS cm-t35: fix Ethernet reset timing hawkboard: Add CONFIG_SPL_LIBGENERIC_SUPPORT BeagleBoard: Remove userbutton command and use gpio command instead OMAP: Move omap1510inn to Unmaintained / Orphaned
2012-04-16ARM926EJS: Fix cache.c to comply with checkpatch.plMarek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-04-16ARM926EJS: Make asm routines volatile in cache opsMarek Vasut
We certainly don't want the compiler to reorganise the code for dcache flushing. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Stefano Babic <sbabic@denx.de>
2012-04-16MX35: mx35pdk: wrong board revisionStefano Babic
The board revision is detected accessing to the pmic, that is not available before relocation (I2C). This generates the following error: CPU: Freescale i.MX35 rev 2.0 at 532 MHz. Reset cause: WDOG <reg num> = 7 is invalid. Should be less than 0 Board: MX35 PDK 1.0 The revision number is wrong, as a default value is printed (tested on a mx35pdk Rev. 2.0). Move the output in the board_late_init(), when pmic can be accessed. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-04-16ARM1136: MX35: Make asm routines volatile in cache opsStefano Babic
As well as pushed for ARM926EJS, we certainly don't want the compiler to reorganise the code for dcache flushing Fix checkpatch warnings as well. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marex@denx.de> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-04-16ARM: add u-boot.imx as target for i.MX SOCsStefano Babic
Freescale SOCs require an header to u-boot.bin The patch adds u-boot.imx to the default targets if the imx file is set (IMX_CONFIG). Signed-off-by: Stefano Babic <sbabic@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> CC: Loïc Minier <loic.minier@linaro.org> CC: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Tested-by: Dirk Behme <dirk.behme@googlemail.com>
2012-04-16M28: Pull out CONFIG_APBH_DMA so it's always enabledMarek Vasut
The ABPH DMA is now used also by the SD card. Therefore it has to be enabled even if NAND is disabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16DMA: Split the APBH DMA init into block and channel initMarek Vasut
This fixes the issue where mxs_dma_init() was called either twice or never, without introducing any new init hooks. The idea is to allow each and every device using the APBH DMA block to configure and request only the channels it uses, instead of making it call init for all the channels as is now. The common DMA block init part, which only configures the block, is then called from CPUs arch_cpu_init() call. NOTE: This patch depends on: http://patchwork.ozlabs.org/patch/150957/ Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16imx: Return gpio_set_value in gpio_direction_outputVikram Narayanan
Return gpio_set_value in gpio_direction_output. Earlier it returned 0 and ignored gpio_set_value's return value. Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-04-16imx: Use GPIO_TO_PORT macro in the gpio driver instead of (gpio >> 5)Vikram Narayanan
Use the defined GPIO_TO_PORT macro. Remove gpio >> 5 references. Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-04-16imx: Add GPIO_TO_PORT macro in the mxc_gpio driverVikram Narayanan
Add GPIO_TO_PORT macro in the mxc_gpio.c driver Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-04-16imx: Remove unneeded/repititive definitions from imx headersVikram Narayanan
Remove gpio related unused/repititive definitions from imx headers. Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-04-16i.MX28: Allow coexistence of PIO and DMA mode for SD/MMCMarek Vasut
This SD DMA function of i.MX28 is still apparently too experimental to be enabled by default in 2012.04 release. Enable this feature only if the user plans to tinker with DCache or explicitly enables it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16MX31: mx31pdk: drop enable_caches from board fileStefano Babic
enable_caches() is implemented now in cpu.c for ARM1136. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16i.MX28: Fix initial stack pointer positionMarek Vasut
The patch: m28evk: Use GENERATED_GBL_DATA_SIZE commit 1084606c972ea5f1d89f69bdbd978b867d0ee521 introduced usage of GENERATED_GBL_DATA_SIZE and calculation of initial stack pointer position defived from that. Due to a small typo, the SP position moved to 0x21f80, which is past the SRAM area. This didn't manifest on the real hardware as the SRAM repeats there (address bits in the CPU being ignored). Though this was caught in QEMU, where it crashed the emulator. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16mx35: mx35pdk: fix when cache functions are linkedStefano Babic
2012-04-16mx35: flea3: fix when cache functions are linkedStefano Babic
2012-04-16ARM: 926ejs: use debug() for misaligned addressesStefano Babic
Misaligned warnings are useful to debug faulty drivers. A misaligned warning is printed also when the driver is correct - use debug() instead of printf(). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Albert Aribaud <albert.u.boot@aribaud.net> CC: Mike Frysinger <vapier@gentoo.org> CC: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16ARM1136: add cache flush and invalidate operationsAnatolij Gustschin
Since commit 5c1ad3e6f8ae578bbe30e09652f1531e9bc22031 (net: fec_mxc: allow use with cache enabled) the FEC_MXC driver uses flush_dcache_range() and invalidate_dcache_range() functions. This driver is also configured for ARM1136 based 'flea3' and 'mx35pdk' boards which currently do not build as there are no ARM1136 specific flush_dcache_range() and invalidate_dcache_range() functions. Add various ARM1136 cache functions to fix building for 'flea3' and 'mx35pdk'. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16mx6qsabrelite: Fix the serial console portFabio Estevam
On mx6qsabrelite the console is ttymxc1. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16mx6qsabrelite: Add boot switch setting information into the READMEFabio Estevam
Add boot switch setting information into the README Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16i.MX6: mx6qsabrelite: add cache commands if cache is enabledEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16i.MX6: implement enable_caches()Eric Nelson
disabled by default until drivers are fixed Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16i.MX6: define CACHELINE_SIZEEric Nelson
2012-04-16MX53: DDR: Fix ZQHWCTRL field TZQ_CSTroy Kisky
Currently, board files are setting this field to 0x01 which the manual says is a reserved value. Change to use the default of 0x02 - 128 cycles. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16mx28evk: Add a README fileFabio Estevam
Add a README file for mx28evk board. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16mx28: Split the README into a common part and a m28 specific partFabio Estevam
Split the README into a common part and a m28 specific part. This will make things easier when adding new README files for other mx28 based boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16tricorder: Load kernel from ubifsBernhard Walle
Signed-off-by: Bernhard Walle <walle@corscience.de>
2012-04-16tricorder: Add UBIFSBernhard Walle
Since kernel should be in a ubifs partition, we need UBIFS. The greater malloc size is needed for UBIFS. Signed-off-by: Bernhard Walle <walle@corscience.de> Squashed two commits (UBIFS enabled and malloc size increased) into one. Signed-off-by: Thomas Weber <weber@corscience.de>
2012-04-16cm-t35: fix Ethernet reset timingIgor Grinberg
The reset_net_chip() function has wrong timings for the reset pulse. This appeared to work until: 0607e2b (ARMV7: OMAP: Write more than 1 byte at a time in i2c_write) Fix the Ethernet support by introducing right timings. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-04-16hawkboard: Add CONFIG_SPL_LIBGENERIC_SUPPORTTom Rini
With older toolchains we need CONFIG_SPL_LIBGENERIC_SUPPORT in order for CONFIG_SPL_NAND_SUPPORT to link. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-16BeagleBoard: Remove userbutton command and use gpio command insteadJoel Fernandes
Remove userbutton command and do the detection in board config file using the gpio command Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2012-04-16OMAP: Move omap1510inn to Unmaintained / OrphanedTom Rini
After removing omap1610inn for not building, move omap1510inn to orphaned. Also update boards.cfg to note it's part of the 'omap' SoC to make sure the board is built more often and future breakage noticed quicker. Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-04-14drivers/mtd/spr_smi.c: Fix build warningAnatolij Gustschin
Fix: spr_smi.c: In function 'smi_write': spr_smi.c:325:15: warning: variable 'WM' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-04-11README: supported boards are in boards.cfg, not MakefileMichael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
