2011-09-29Prepare v2011.09v2011.09Wolfgang Denk
2011-09-28ARM: versatile: delete split_by_variant.shLinus Walleij
Since commit d388298a59ba375c76597b8f95b560afa971a0fb by Stefano Babic this file is no longer needed so delete it. Cc: Stefano Babic <sbabic@denx.de> Cc: Loïc Minier <loic.minier@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-28Revert "phylib: remove a couple of redundant code lines"Wolfgang Denk
This reverts commit 041c542219af7f31c372d89b4c7c6f4c8064a8ce. The lines removed by this commit weren't redundant. The logic is (and probably should be better commented): Find the intersection of the advertised capabilities of both sides of the link (lpa). From that intersection, find the highest capability we can run at (that will be the negotiated link). Now imagine that the intersection (lpa) is (LPA_100HALF | LPA_10FULL). The code will now set phydev->speed to 100, and phydev->duplex to 1, but this link does not support 100FULL. Kudos to Andy Fleming <afleming@gmail.com> for binging this to attention and for the explanation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-28doc/README.scrapyard: Update board removal commit IDsWolfgang Denk
2011-09-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: remove broken "ixdp425" and "ixpdg425" boards
2011-09-27ARM: remove broken "ixdp425" and "ixpdg425" boardsAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Stefan Roese <sr@denx.de>
2011-09-24ASIX: Fix buffer access in asix_get_phy_addr()Marek Vasut
2011-09-23Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: OMAP3: beagle: Fix build warning in beagle.c
2011-09-23doc: provide a correct board_init_r definition pathVladimir Zapolskiy
This is a trivial fix in the documentation, which corrects board_init_r() source reference. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-22OMAP3: beagle: Fix build warning in beagle.cDirk Behme
Fix build warning beagle.c:532: warning: initialization from incompatible pointer type Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: Jason Kridner <jkridner@beagleboard.org> CC: Koen Kooi <koen@dominion.thruhere.net> CC: Joel A Fernandes <agnel.joel@gmail.com> Cc: Greg Turner <gregturner@ti.com> CC: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Jason Kridner <jkridner@beagleboard.org>
2011-09-22Prepare v2011.09-rc2v2011.09-rc2Wolfgang Denk
2011-09-22Minor Coding Style CleanupWolfgang Denk
2011-09-21km/common: fix bug in IVM mac address accessHolger Brunck
The MAC address stored in the inventory eeprom begins at offset 1. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de>
2011-09-21sf: fix debug format string warningVadim Bendebury
On some systems, we get a warning when %lu is used with size_t's, so use the correct format string. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-21net: turn name len check into an assertMike Frysinger
The new sanity check introduces a printf warning for some systems: eth.c:233: warning: format '%zu' expects type 'size_t', but argument 3 has type 'int' Rather than tweak the format string, use the new assert() helper instead. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-21ignore soc asm-offsets.sMike Frysinger
Recent commit a4814a69d3bca6ee05f4bfc4 cleaned up generation of asm-offsets.s for SoC dirs, but missed adding it to the ignore list which makes it show up in `git status`. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-20Drop bogus BOOTFLAG_* definitionsWolfgang Denk
There is no code anywhere that references BOOTFLAG_* so remove these defines. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-09-19net/bootp.c: fix tftp load if autoload environment var isn't setPeter Korsgaard
Commit 093498669 (Put common autoload code into auto_load() function) broke handling of autoload environment variable not being set. The bootp/dhcp code will just keep on requesting IP address forever and never start TFTP download. Fix it by moving TftpStart() outside the conditional like it was before. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2011-09-19ppc4xx: Flush dcache after DDR2 autocalibration with caches onStefan Roese
Flush the dcache before removing the TLB with caches enabled. Otherwise this might lead to problems later on, e.g. while booting Linux (as seen on ICON-440SPe). Signed-off-by: Stefan Roese <sr@denx.de>
2011-09-19Fix incorrect array size of phy settings for 405EXWeirich, Bernhard
Change bd_t->bi_phy* arrays from 1 to 2 for PPC405EX since 405EX has 2 ethernet interfaces. Signed-off-by: Bernhard Weirich <bernhard.weirich@riedel.net> Signed-off-by: Stefan Roese <sr@denx.de>
2011-09-13DA830: Fix Build WarningSandeep Paulraj
This commit fixes a build warning in the DA830 EVM build Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13led: remove camel casing of led identifiers globallyJason Kridner
Result of running the following command to address Wolfgang's comment about camel case: for file in `find . | grep '\.[chS]$'`; do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done Discussion: http://patchwork.ozlabs.org/patch/84988/ Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap4: fix pad configuration settings for SDP and PandaAneesh V
omap4: fix pad configuration settings for SDP and Panda Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sebastien Jan <s-jan@ti.com> Signed-off-by: David Anders <x0132446@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap4: IO settingsAneesh V
Tuning some IO settings for better performance and power. And consolidate all such IO settings at one place. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap4: make SDRAM init work for ES1.0 siliconAneesh V
SDRAM init was not working on ES1.0 due to a programming error. A pointer that was passed by value to a function was set in function emif_get_device_details(), but the effect wouldn't be seen in the calling function. The issue came out while testing for ES1.0 because ES1.0 doesn't have any SDRAM chips connected to CS1 Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap4: factor out common part from board config headersAneesh V
Factor out common parts from omap4_sdp4430.h and omap4_panda.h into a new file omap4_common.h Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: Adapt board files to use generic APISanjeev Premi
This patch contains updates the sources in the board files to use the generic API. Signed-off-by: Sanjeev Premi <premi@ti.com>
2011-09-13omap: gpio: generic changes after changing APISanjeev Premi
This patch contains the generic changes required after change to generic API in the previous patch. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: Use generic APISanjeev Premi
Convert all OMAP specific functions to use the common API definitions in include/asm/gpio.h. In the process, made few additional changes: - Use -EINVAL consistently. -1 was used in many places. - Removed one-liner static functions that were used only once. Replaced the content as necessary. - Combines implementation of functions omap_get_gpio_dataout() and omap_get_gpio_datain(). To do so, new static function _get_gpio_direction() was added. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12OMAP3 Beagle: Minor config cleanupSandeep Paulraj
This patch removes a hardcoded MAC address Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: modify the MEMTEST start and end addressNagabhushana Netagunte
Modify the MEMTEST start and end address. The memtest range was overlapping the CONFIG_SYS_LOAD_ADDR which causes the uImage to be corrupt.Also, modify the size for which mtest is run to 32MB from 16MB. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: enable SPI flash boot modeNagabhushana Netagunte
Enable SPI flash boot mode in configuration file as default. With the introduction of 456MHz part, SPI operating frequency will increase and at this frequency SPI does not work correctly. Hence reduce the default SPI speed to 30MHz from 50MHz. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: modify the U-Boot prompt stringNagabhushana Netagunte
Modify U-boot promt string from 'DA830-evm >' to 'U-Boot >' as there are many variants of da830 based boards which have diffrent names such as L137, AM1707 etc. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12ARMV7: OMAP3: Add 37xx ESx revision numbers.Howard D. Gray
OMAP3: Add 37xx ESx revision numbers. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Howard D. Gray <howard.gray@matrix-vision.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12ARMV7: OMAP: I2C driver: cosmetic: make checkpatch-compatibleMichael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12ARMV7: OMAP: Write more than 1 byte at a time in i2c_writeMichael Jones
This allows the EEPROM layer to send a single i2c write command per page, and wait CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS between i2c write commands. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12OMAP: Add function to get state of a GPIO outputJoel A Fernandes
Read directly from OMAP_GPIO_DATAOUT to get the output state of the GPIO pin Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12MX25: tx25: Cleanup tx25.h configFabio Estevam
Cleanup tx25.h by removing unnecessary defines and by removing unneeded "1"'s. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-12MX25: tx25: Fix build by making use of GPIO frameworkFabio Estevam
Make use of GPIO framework and avoid the following build error: tx25.c: In function 'tx25_fec_init': tx25.c:73: error: dereferencing pointer to incomplete type tx25.c:74: error: dereferencing pointer to incomplete type tx25.c:75: error: dereferencing pointer to incomplete type tx25.c:76: error: dereferencing pointer to incomplete type tx25.c:83: error: dereferencing pointer to incomplete type tx25.c:84: error: dereferencing pointer to incomplete type tx25.c:114: error: dereferencing pointer to incomplete type tx25.c:115: error: dereferencing pointer to incomplete type tx25.c:116: error: dereferencing pointer to incomplete type tx25.c:117: error: dereferencing pointer to incomplete type tx25.c:124: error: dereferencing pointer to incomplete type tx25.c:125: error: dereferencing pointer to incomplete type tx25.c:126: error: dereferencing pointer to incomplete type Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-12omap3: beagle: Fix build warningSanjeev Premi
This patch fixes the warning dure to recent changes to the board configuration: cmd_i2c.o cmd_i2c.c -c cmd_i2c.c:109:1: warning: missing braces around initializer cmd_i2c.c:109:1: warning: (near initialization for 'i2c_no_probes[0]') Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Jason Kridner <jkridner@beagleboard.org> Acked-by: Jason Kridner <jdk@ti.com>
2011-09-11Prepare v2011.09v2011.09-rc1Wolfgang Denk
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-09-10ARM: hawkboard: fix compilation of nand_splWolfgang Denk
Fix build problem: nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c: In function 'board_init_f': nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:132: warning: implicit declaration of function 'nand_boot' nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:133: warning: 'noreturn' function does return Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-09-10cm4008, cm41xx: fix build warningsWolfgang Denk
Fix these: cm4008.c: In function 'board_eth_init': cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' cm41xx.c: In function 'board_eth_init': cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' While we are at it, sort include list in netdev.h Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10tegra2: fix warning: "assert" redefinedWolfgang Denk
Commit 21726a7 "Add assert() for debug assertions" caused build warnings for all tegra2 based boards: clock.c:36:1: warning: "assert" redefined In file included from clock.c:29: include/common.h:144:1: warning: this is the location of the previous definition Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org>
2011-09-10ARM: hawkboard_nand: fix compilation of nand_splStefano Babic
get_ram_size() is called, but memsize.c is not compiled. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM41xx: fix signedness of env bootargs string pointerGreg Ungerer
The pointer to the flash based bootargs should be a "char *", not unsigned. Fixes: cm41xx.c: In function ‘env_flash_cmdline’: cm41xx.c:67: warning: pointer targets in passing argument 2 of ‘setenv’ differ in signedness Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM4008: fix signedness of env bootargs string pointerGreg Ungerer
The pointer to the flash based bootargs should be a "char *", not unsigned. Fixes: cm4008.c: In function ‘env_flash_cmdline’: cm4008.c:67: warning: pointer targets in passing argument 2 of ‘setenv’ differ in signedness Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10utx8245: fix build breakage due to assert()Wolfgang Denk
Commit 21726a7 "Add assert() for debug assertions" broke building the utx8245 board: dlmalloc.c: In function 'do_check_chunk': dlmalloc.c:1660: error: 'sz' undeclared (first use in this function) dlmalloc.c:1660: error: (Each undeclared identifier is reported only once dlmalloc.c:1660: error: for each function it appears in.) dlmalloc.c: In function 'do_check_free_chunk': dlmalloc.c:1689: error: 'next' undeclared (first use in this function) dlmalloc.c: In function 'do_check_malloced_chunk': dlmalloc.c:1748: error: 'sz' undeclared (first use in this function) dlmalloc.c:1750: error: 'room' undeclared (first use in this function) Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org>
