2011-03-31Prepare v2011.03v2011.03Wolfgang Denk
2011-03-31Fix build issues cause by LDFLAGS_FINAL changesWolfgang Denk
Commit 6dc1ece "Introduce a new linker flag LDFLAGS_FINAL" modified a number of Makefiles in a way that broke out-of-tree builds. The problem was that $(nandobj) was used before it got defined. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-03-31Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-03-31Merge branch 'master' of git://git.denx.de/u-boot-cfi-flashWolfgang Denk
2011-03-31Fix build problems caused by "_end" -> "__bss_end__" renameWolfgang Denk
Commit 44c6e65 "rename _end to __bss_end__ broke building of a large number of systems (at least all PowerPC?): libstubs.o: In function `app_startup': examples/standalone/stubs.c:197: undefined reference to `__bss_end__' The rename should not be done for the files in the examples/standalone/ directory, as these are not using the code from start.S, but do their own BSS clearing, and either use their own linker scripts or the ones provided by the compilers. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-03-29powerpc/85xx: Handle PCIe initialization requires for P1021 class SoCsPrabhakar Kushwaha
The P1011, P1012, P1015, P1016, P1020, P1021, P1024, & P1025 SoCs require that we initialize the SERDES registers if the lanes are configured for PCIe. Additionally these devices PCIe controller do not support ASPM and we have to explicitly disable it. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-28cfi_flash: fix bug with flash banks with different sector numbersMartin Krause
The function find_sector() does not take into account if the flash bank has changed since the last call. This could lead to illegal accesses inside and beyond the flash_info_t info strcture. For example if the current flash bank has less sectors than the last used flash bank. This patch adds two cheks. One that insures, that the current sector does not exceed the allowed maximum (which is always a good idea). And one that checks if the current access is to the same flash bank as the last access. If not, the search loop will start with sector 0. Signed-off-by: Martin Krause <martin.krause@tqs.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-03-28powerpc/85xx: Enable various errata on P1022/P1013 SoCsJiang Yutang
Enable workaround for errata ELBC A001, ESDHC 111 & SATA A001 on P1022/P1013 SoCs. Also updated P1022DS config to properly enable CONFIG_FSL_SATA_V2. Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-27Prepare vv2011.03-rc2Wolfgang Denk
2011-03-27Coding Style cleanup: remove trailing empty linesWolfgang Denk
2011-03-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2011-03-27arm: Tegra2: Change mach-type to MACH_TYPE_SEABOARD due to mach-types.h updateTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-03-27S5P: mmc: Resolved interrupt error during mmc_initChander Kashyap
Blocksize was hardcoded to 512 bytes. But the blocksize varies depeding on various mmc subsystem commands (between 8 and 512). This hardcoding was resulting in interrupt error during data transfer. It is now calculated based upon the request sent by mmc subsystem. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27ARMV7: S5P: Fixed register offset in mmc.hChander Kashyap
The MMC registers are accessed through struct s5p_mmc member variables. MMC controller "control4" register offset is set to 0x8C as per data sheet. The size of struct s5p_mmc is also corrected. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27S5P: timer: replace bss variable by gdMinkyu Kang
Use the global data instead of bss variable, replace as follow. count_value -> removed timestamp -> tbl lastdec -> lastinc Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Albert ARIBAUD <albert.aribaud@free.fr>
2011-03-27S5P: universal: Enable the pwm driverMinkyu Kang
2011-03-27S5P: goni: Enable the pwm driverMinkyu Kang
2011-03-27S5P: smdkc100: Enable the pwm driverMinkyu Kang
2011-03-27S5P: timer: Use pwm functionsMinkyu Kang
Use pwm functions for timer that is PWM timer 4. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27ARM: S5P: pwm driver supportDonghwa Lee
This is common pwm driver of S5P. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27SMDK6400: Fixup dram_init for relocation supportseedshope
Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27SMDK6400: Disable LED function in start.s on the nand bootingseedshope
Since nand boot have some limit for the first 4KB, We only disable the LED function to reduce the code space. At the same time, Fix the compile error for LED function undefined in the compile time of nand_spl. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27SMDK6400: Add some labels to u-boot.lds to support nand_splseedshope
In the nand_spl feature of SMDK6400. Add some relocation symbols to nand_spl/board/samsung/smdk6400/u-boot.lds to fix the compile error. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27SMDK6400: Fix the mutiple link errorseedshope
The first, the cpu_init.o have already been link for cmd_link_o_target atfer compile, But, The link script re-link the point file. So the link machine will generate multiple definition error information. The second, Since the first 4kB of nand boot featue code move to nand_spl, So It is not necessary to force the cpu_init.o in non-nand boot. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27SMDK6400: Fix some label undefined in build errorseedshope
Modify Makefile for cpu_init.c and Start.s use some label,this defined u-boot.lds of arch/arm/cpu/arm1176. But SMDK6400 use the link script board/samsung/smdk6400/u-boot-nand.lds. So add some label form u-boot.lds to u-boot-nand.lds Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27SMDK6400: Fix CONFIG_SYS_INIT_SP_ADDR undefinedseedshope
Fix CONFIG_SYS_INIT_SP_ADDR undefined issue. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27arm: fix incorrect monitor protection region in FLASHPo-Yu Chuang
Monitor protection region in FLASH did not cover .rel.dyn and .dynsym sections, because it uses __bss_start to compute monitor_flash_len. Use _end instead. Add _end to linker scripts for end of u-boot image Add _end_ofs to all the start.S. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-03-24powerpc/85xx: Fix PCI memory map setup on P1_P2_RDBPrabhakar Kushwaha
Update the PCIe address map to match standard FSL memory map. Additionally, fix the TLBs so the cover the PCIe address space properly so cards plugged in like an e1000 work correctly. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-24powerpc/mpc8xxx: fix workaround for errata DDR111 and DDR134York Sun
The fix for errata workaround is to avoid covering physical address 0xff000000 to 0xffffffff during the implementation. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-24powerpc/mpc8xxx: disable rcw_en bit for non-DDR3York Sun
rcw_en bit is only available for DDR3 controllers. It is a reserved bit on DDR1 and DDR2 controllers. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-24powerpc/mpc8572ds: revise board specific timing for dual-rank DIMMsYork Sun
Tested all possible values for clk_adjust and write_data_delay for dual rank UDIMM and RDIMM to revise the tables. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-24powerpc/mpc8xxx: fix recognition of DIMMs with ECC and Address ParityYork Sun
To recognize DIMMs with ECC capability by testing ECC bit only. Not to be confused by Address Parity bit. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-22strmhz: Make hz unsigned to support greater than 2146 MHz clockEd Swarthout
For example, an input of 0x80000000 should print: 2147.484 instead of -2147.-483. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-22Introduce a new linker flag LDFLAGS_FINALHaiying Wang
commit 8aba9dceebb14144e07d19593111ee3a999c37fc Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS breaks the usage of --gc-section to build nand_spl. We still need linker option --gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes the --gc-sections to each uboot image. To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace PLATFORM_LDFLAGS in the Makefile of each nand_spl board. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2011-03-22Fix hash table deletion to prevent lost entriesPeter Barada
Use negative used value to mark deleted entry. Search keeps probing past deleted entries. Adding an entry uses first deleted entry when it hits end of probe chain. Initially found that "ramdiskimage" and "preboot" collide modulus 347, causing "preboot" to be inserted at idx 190, "ramdiskimage" at idx 191. Previous to this fix when "preboot" is deleted, "ramdiskimage" is orphaned. Signed-off-by: Peter Barada <peter.barada@logicpd.com> Tested-by: Wolfgang Denk <wd@denx.de>
2011-03-21Top config.mk: add include/config.mkJoakim Tjernlund
Seems to me that the top level config.mk should include the auto generated include/config.mk so that all Makefile's pickup those definitions. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-21net: ftmac100: update get_timer() usagesPo-Yu Chuang
Use get_timer() the same way as drivers/net/ftgmac100.c Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Reviewed-by: Macpaul Lin <macpaul@gmail.com> Tested-by: Macpaul Lin <macpaul@gmail.com>
2011-03-21net: ftmac100: remove unnecessary volatilesPo-Yu Chuang
2011-03-21mpc52xx, digsy_mtc_rev5: Fix Linux crash, if no Flash in bank 2Heiko Schocher
If no Flash is connected to cs1, Linux crashes, because reg entries are not correct adapted. Following fix is needed: - swap base addresses in CONFIG_SYS_FLASH_BANKS_LIST, as flash bank 1 is on chipselect 0 and flash bank 2 on chipselect 1 - call fdt_fixup_nor_flash_size() from ft_board_setup() Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <hs@denx.de> cc: Werner Pfister <Pfister_Werner@intercontrol.de> cc: Detlev Zundel <dzu@denx.de>
2011-03-21Merge branch 'master' of git://git.denx.de/u-boot-ubiWolfgang Denk
2011-03-21Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2011-03-21UBI: Fix error code handling in ubi commandsStefan Roese
Some ubi commands returned negative error codes, resulting in the following error message on the prompt: "exit not allowed from main input shell." Negative error codes are not allowed. This patch now changes the UBI code to return positive error codes. Additionally "better" error codes are used, for example "ENOMEM" when no memory is available for the UBI volume creation any more. Also the output of some commands is enhanced: Before: => ubi read 100000 testvol 100000 Volume testvol found at volume id 0 read 1048576 bytes from volume 0 to 100000(buf address) => ubi write 100000 testvol 1000 Volume testvol found at volume id 0 After: => ubi read 100000 testvol 100000 Read 1048576 bytes from volume testvol to 00100000 => ubi write 100000 testvol 1000 4096 bytes written to volume testvol Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2011-03-16sh: Add KEEP order to start.o sectionNobuhiro Iwamatsu
The start.o section is changed by --gc-section option of ld. Of this using KEEP order, therefore, evade this problem. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-16sh: Add handling of CONFIG_SYS_NO_FLASH for board.cNobuhiro Iwamatsu
Some board of SH does not have flash memoy. This revises it to initialize Flash when CONFIG_SYS_NO_FLASH is not defined. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-16net: sh_eth: add support for SH7757's ETHERYoshihiro Shimoda
SH7757 has ETHER and GETHER. This patch supports EHTER only. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-15powerpc/85xx: Fix synchronization of timebase on MP bootKumar Gala
There is a small ordering issue in the master core in that we need to make sure the disabling of the timebase in the SoC is visible before we set the value to 0. We can simply just read back the value to synchronizatize the write, before we set TB to 0. Reported-by: Dan Hettena Tested-by: Dan Hettena Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-13mpc8[5/6]xx: Ensure POST word does not get resetJohn Schmoller
The POST word is stored in a spare register in the PIC on MPC8[5/6]xx processors. When interrupt_init() is called, this register gets reset which resulted in all POST_RAM POSTs not being ran due to the corrupted POST word. To resolve this, store off POST word before the PIC is reset, and restore it after the PIC has been initialized. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-07fsl_esdhc: Correcting esdhc timeout counter calculationPriyanka Jain
- Timeout counter value is set as DTOCV bits in SYSCTL register For counter value set as timeout, Timeout period = (2^(timeout + 13)) SD Clock cycles - As per 4.6.2.2 section of SD Card specification v2.00, host should cofigure timeout period value to minimum 0.25 sec. - Number of SD Clock cycles for 0.25sec should be minimum (SD Clock/sec * 0.25 sec) SD Clock cycles = (mmc->tran_speed * 1/4) SD Clock cycles - Calculating timeout based on (2^(timeout + 13)) >= mmc->tran_speed * 1/4 Taking log2 both the sides and rounding up to next power of 2 => timeout + 13 = log2(mmc->tran_speed/4) + 1 Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Mingkai Hu <Mingkai.Hu@freescale.com> Tested-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-06powerpc/85xx: Fix pixis_reset altbank mask on MPC8536DSMatthew McClintock
Currently, pixis_reset altbank does not work properly. This patch uses the correct mask to boot into the alternate bank. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
