2009-08-31Prepare 2009.08v2009.08Wolfgang Denk
Update CHANGELOG Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-31Add common code dir for Matrix Vision boards.Andre Schwarz
This fixes current build failure. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> mvblm7.c: fix warning: implicit declaration of function 'mv_reset_environment' Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-30bugfix CONFIG_SYS_CONSOLE_INFO_QUIETDavid Brownell
The "console: unify printing current devices" patch goofed: CONFIG_SYS_CONSOLE_INFO_QUIET is supposed to *REMOVE* boot time noise, not add it. Said patch changed the #ifndefs to #ifdef; this one restores them to the proper sense. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-08-28Use common code for Matrix Vision boardsAndré Schwarz
Clean up existing boards (mvBC-P/MPC5200 and mvBL-M7/MPC8343) by using common code. Signed-off-by: André Schwarz <andre.schwarz@matrix-vision.de>
2009-08-26mpc83xx: mpc8349itx - accommodate larger kernel sizes & unzero the bootdelayKim Phillips
apparently the ITX was missed last round. Also make bootdelay consistent with other boards, so as to give on the opportunity to fix mistakenly set bootcmd without having checked for an bootdelay zero setting first. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-26mpc83xx: match dtb filename references to their dts equivalents in the linux ↵Kim Phillips
kernel Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-25Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-08-25Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2009-08-25ppc4xx: Fix ECC Correction bug with SMC ordering for NDFC driverFeng Kan
Fix ECC Correction bug where the byte offset location were double flipped causing correction routine to toggle the wrong byte location in the ECC segment. The ndfc_calculate_ecc routine change the order of getting the ECC code. /* The NDFC uses Smart Media (SMC) bytes order */ ecc_code[0] = p[2]; ecc_code[1] = p[1]; ecc_code[2] = p[3]; But in the Correction algorithm when calculating the byte offset location, the s1 is used as the upper part of the address. Which again reverse the order making the final byte offset address location incorrect. byteoffs = (s1 << 0) & 0x80; . . byteoffs |= (s0 >> 4) & 0x08; The order is change to read it in straight and let the correction function to revert it to SMC order. Signed-off-by: Feng Kan <fkan@amcc.com> Acked-by: Victor Gallardo <vgallardo@amcc.com> Acked-by: Prodyut Hazarika <phazarika@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-25include/s3c24x0.h: fix S3C24X0_SPI_CHANNEL declarationWolfgang Denk
The SPI controller on the S3C24X0 has 8 bit registers, not 32 bit. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-23Blackfin: fix typos in gpio commentsMike Frysinger
2009-08-23Blackfin: cm-bf527/cm-bf537: increase flash sectorsHarald Krapfenbauer
Newer revisions of these boards have slightly larger flashes, so increase the configured number of sectors so that U-Boot works on all revisions. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-23sh/rsk7203: add missing include net.hJean-Christophe PLAGNIOL-VILLARD
2009-08-23start a linker script helper fileMike Frysinger
Start a common header file for common linker script code (such as workarounds for older linkers) rather than doing this in the build system. As fallout, we no longer execute the linker every time config.mk is included by a build file (which can easily be 70+ times), but rather only execute it once. This also fixes a bug in the major version checking by creating a macro to easily compare versions and keep people from making the same common mistake (forgetting to check major and minor together). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-23Blackfin: use common code to preprocess linker scriptMike Frysinger
Now that the common code preprocesses the linker script, the Blackfin code no longer needs to do it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-23.gitignore: ignore generated u-boot.ldsMike Frysinger
2009-08-23include/mmc.h: Fix typo in IS_SD() macroAlbin Tonnerre
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-08-22Prepare 2009.08-rc3v2009.08-rc3Wolfgang Denk
Update CHANGELOG, minor Coding Style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-22Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-08-22qemu-mips: Fix Qemu websiteMichal Simek
Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@petalogix.com> Acked-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-08-21mpc83xx: accommodate larger kernel sizes by defaultKim Phillips
linux mpc83xx_defconfig kernels are getting bigger, accommodate for their growth by adjusting default load and fdt addresses. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: mpc8377erdb - change DDR settings to those from latest bspKim Phillips
when using Linus' 83xx_defconfig, the mpc8377rdb would hang at boot at either: NET: Registered protocol family 16 or the io scheduler cfq registered message. Fixing up these DDR settings appears to fix the problem. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: tqm8349 - remove pci & flash window conflictKim Phillips
commit 9993e196da707a0a1cd4584f1fcef12382c1c144 "mpc83xx: convert all remaining boards over to 83XX_GENERIC_PCI" remapped pci windows on tqm834x to make it more consistent with the other 83xx boards. During that time however, the author failed to realize that FLASH_BASE was occupying the same range as what PCI1_MEM_BASE was being assigned. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Tested-by: Wolfgang Denk <wd@denx.de>
2009-08-21mpc83xx: add missing CSCONFIG_ODT_WR_CFG for 832x CPUsHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: mpc8349 - delete unused SYS_MID_FLASH_JUMPPaul Gortmaker
This was introduced with the MPC8349EMDS board, and then copied to a couple other boards by nature of being the reference implementation. u-boot$git grep CONFIG_SYS_MID_FLASH_JUMP include/configs/MPC8349EMDS.h:#define CONFIG_SYS_MID_FLASH_JUMP 0x7F000000 include/configs/sbc8349.h:#define CONFIG_SYS_MID_FLASH_JUMP 0x7F000000 include/configs/vme8349.h:#define CONFIG_SYS_MID_FLASH_JUMP 0x7F000000 u-boot$ It currently isn't used, so delete it before it spreads further. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: sbc8349 - make enabling PCI more user friendlyPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, which isn't really user friendly. This adds the typical PCI make targets to the toplevel Makefile in accordance with what is being done with other boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21eeprom_m95xxx: remove unused variable iJean-Christophe PLAGNIOL-VILLARD
2009-08-21jffs2: some fixes to summary supportIlya Yanok
This patch fixes some issues with JFFS2 summary support in U-Boot. 1/ Summary support made compilation configurable (as summary support considered expiremental even in Linux). 2/ Summary code can do unaligned 16-bit and 32-bit memory accesses. We need to get data byte by byte to exclude data aborts. 3/ Make summary scan in two passes so we can safely fall back to full scan if we found unsupported entry in the summary. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2009-08-21arm: rd6281a: Fixed NAND specific warningPrafulla Wadaskar
It is recommended to define the macro CONFIG_SYS_64BIT_VSPRINTF for NAND specific warning removal, same is done in this patch Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-08-21TRAB: make independent of specific libgcc helper routinesWolfgang Denk
The TRAB board references local libgcc helper routines (lib_arm/div0.o and lib_arm/_umodsi3.o) which cause build problems when we try to use the normal, compiler provided libgcc instead. Removing these references allows to build both with and without the local libgcc helper routines. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-08-21ARM: compiler options cleanup - improve tool chain supportWolfgang Denk
For some time there have been repeated reports about build problems with some ARM (cross) tool chains. Especially issues about (in)compatibility with the tool chain provided runtime support library libgcc.a caused to add and support a private implementation of such runtime support code in U-Boot. A closer look at the code indicated that some of these issues are actually home-made. This patch attempts to clean up some of the most obvious problems and make building of U-Boot with different tool chains easier: - Even though all ARM systems basicy used the same compiler options to select a specific ABI from the tool chain, the code for this was distributed over all cpu/*/config.mk files. We move this one level up into lib_arm/config.mk instead. - So far, we only checked if "-mapcs-32" was supported by the tool chain; if yes, this was used, if not, "-mabi=apcs-gnu" was selected, no matter if the tool chain actually understood this option. There was no support for EABI conformant tool chains. This patch implements the following logic: 1) If the tool chain supports "-mabi=aapcs-linux -mno-thumb-interwork" we use these options (EABI conformant tool chain). 2) Otherwise, we check first if "-mapcs-32" is supported, and then check for "-mabi=apcs-gnu" If one test succeeds, we use the first found option. 3) In case 2), we also test if "-mno-thumb-interwork", and use this if the test succeeds. [For "-mabi=aapcs-linux" we set "-mno-thumb-interwork" mandatorily.] This way we use a similar logic for the compile options as the Linux kernel does. - Some EABI conformant tool chains cause external references to utility functions like raise(); such functions are provided in the new file lib_arm/eabi_compat.c Note that lib_arm/config.mk gets parsed several times, so we must make sure to add eabi_compat.o only once to the linker list. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Dirk Behme <dirk.behme@googlemail.com> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Sergey Kubushyn <ksi@koi8.net> Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Tested-by: Andrzej Wolski <awolski@poczta.fm> Tested-by: Gaye Abdoulaye Walsimou <walsimou@walsimou.com> Tested-by: Tom Rix <Tom.Rix@windriver.com> Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-08-21Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-08-21Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2009-08-21NAND boot: fix nand_load overlap issueMingkai Hu
The code copy data from NAND flash block by block, so when the data length isn't a whole-number multiple of the block size, it will overlap the rest space. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-21add WATCHDOG_RESET() on nand write and readGiulio Benetti
Signed-off-by: giulio.benetti@micronovasrl.com Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-21tsec: Wait for auto-negotiation to complete without linkPeter Tyser
Previously, waiting for auto-negotiation would only occur if a valid link had been detected. Problems arose when attempting to use a tsec immediately after bootup but before link was achieved, eg: => dhcp Auto-neg error, defaulting to 10BT/HD eTSEC1: No link. Auto-neg error, defaulting to 10BT/HD eTSEC2: No link. => With this patch applied the same operation as above resulted in: => dhcp Waiting for PHY auto negotiation to complete. done Enet starting in 1000BT/FD Speed: 1000, full duplex Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-21arm: kirkwood: See to it that sent data is 8-byte alignedSimon Kagstrom
U-boot might use non-8-byte-aligned addresses for sending data, which the kwgbe_send doesn't accept (bootp does this for me). This patch copies the data to be sent to a malloced temporary buffer if it is non-aligned. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-21Wait for the link to come up on kirkwood network initSimon Kagstrom
This patch makes the device wait for up to 5 seconds for the link to come up, similar to what many of the other network drivers do. This avoids confusing situations where, e.g., a tftp fails when initiated early after U-boot has started (before the link has come up). Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-21arm:kirkwood Define kirkwood phy address magic numberSimon Kagstrom
2009-08-21e1000: fix PCI memory addressingTimur Tabi
The Intel E1000 driver was making assumptions about the relationship between some virtual, physical, and PCI addresses. Also fix some bad usage of the DEBUGOUT macro Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-18jffs2: clean the cache in case of malloc fails in build_listsIlya Yanok
We should call jffs2_clean_cache() if we return from jffs2_build_lists() with an error to prevent usage of incomplete lists. Also we should free() a local buffer to prevent memory leaks. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2009-08-18ppc: trigger WDT before starting LinuxHeiko Schocher
2009-08-18Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-08-18Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-08-18Update the mtd driver name in bootargs for at91-based boardsAlbin Tonnerre
The name of the atmel nand driver in the kernel changed from at91_nand to atmel_nand back in June 2008, but the at91-based boards config files still refer to at91_nand. This patch updates them with the new name Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-08-18omap3: Fixed a problem with hweccBen Goska
In commit 187af954cf7958c24efcf0fd62289bbdb4f1f24e there was a typo that offset all the ecc registers by 4 bytes, fixed that. Signed-off-by: Ben Goska <goskab@onid.oregonstate.edu> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-18ppc4xx: Fix "chip_config" command for AMCC ArchesStefan Roese
This patch fixes the "chip_config" command for I2C bootstrap EEPROM configuration. First it changes the I2C bootstrap EEPROM address to 0x54 as this is used on Arches (instead of 0x52 on Canyonlands/ Glacier). Additionally, the NAND bootstrap settings are removed for Arches since Arches doesn't support NAND-booting. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-17Monahans: avoid floating point calculationsWolfgang Denk
Current code for the Monahans CPU defined OSCR_CLK_FREQ as 3.250 (MHz) which caused floating point operations to be used. This resulted in unresolved references to some FP related libgcc functions when using U-Boot's private libgcc functions. Change the code to use fixed point math only. Signed-off-by: Wolfgang Denk <wd@denx.de>
