2009-06-14Prepare v2009.06v2009.06Wolfgang Denk
Update CHANGELOG, fix minor coding stylke issue. Update Makefile. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-14Revert "SMC911x driver fixed for NFS boot"Wolfgang Denk
This reverts commit ca9c8a1e10fac01e6a1129f82a7ce18bd818fa43, which causes compile warnings ("large integer implicitly truncated to unsigned type") on all systems that use this driver. The warning results from passing long constants (TX_CFG, RX_CFG) into smc911x_set_mac_csr() which is declared to accept "unsigned character" arguments only. Being close to a release, with nobody available to actually test the code or the suggested fixes, it seems better to revert the patch.
2009-06-12fsl-ddr: Fix handling of >4G of memory when !CONFIG_PHYS_64BITKumar Gala
The ddr code computes most things as 64-bit quantities and had some places in the middle that it was using phy_addr_t and phys_size_t. Instead we use unsigned long long through out and only at the last stage of setting the LAWs and reporting the amount of memory to the board code do we truncate down to what we can cover via phys_size_t. This has the added benefit that the DDR controller itself is always setup the same way regardless of how much memory we have. Its only the LAW setup that limits what is visible to the system. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Use print_size to report amount of memory not mapped by TLBsKumar Gala
2009-06-1285xx: Add README for MPC8569MDSHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add UART1 support for MPC8569MDSHaiying Wang
MPC8569 UART1 signals are muxed with PortF bit[9-12], we need to define those pins before using UART1. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add PIB support at CS4/CS5 for MPC8569MDSHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Yu Liu <Yu.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Fix some settings for MPC8569MDS boardHaiying Wang
- Increase the size of malloc to 512KB because MPC8569MDS needs more memory for malloc to support up to eight Ethernet interfaces. - Move Environment address out of uboot thus the saved environment variables will not be erased after u-boot is re-programmed. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Fix MURAM size for MPC8569Haiying Wang
MPC8569 has 128K bytes MURAM. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-11Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-06-10at91/cpu.c: add missing Copyright & GPL headerJean-Christophe PLAGNIOL-VILLARD
2009-06-10apollon: Fix a OBJCFLAGS typoShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-06-10Prepare 2009.06-rc3v2009.06-rc3Wolfgang Denk
Update CHANGELOG Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-10rmu board: fix error: 'CONFIG_ENV_SECT_SIZE' undeclaredWolfgang Denk
2009-06-09ubifs: fix small error path mismatchDaniel Mack
In do_readpage(), don't free 'dn' if its allocation failed. Signed-off-by: Daniel Mack <daniel@caiaq.de>
2009-06-09EP88x: fix broken linker scriptWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Mikhail Zaturenskiy <mzaturenskiy@shoppertrak.com>
2009-06-09TQM85xx: minor config file cleanupWolfgang Denk
Remove "saveenv" from "update" definition: the environment is outside the U-Boot image on TQM85xx and therefor not affected by updates. Also "beautify" code a bit (vertical alignment). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-09TQM85xx: adapt for new flash typesWolfgang Denk
Old TQM85xx boards had 'M' type Spansion Flashes from the S29GLxxxM series while new boards have 'N' type Flashes from the S29GLxxxN series, which have bigger sectors: 2 x 128 instead of 2 x 64 KB. We now change the configuration to the new flash types for all boards; this also works on old boards - we just waste two flash sectors for the environment which could be smaller there. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-0985xx: Fix the wrong SYS_CLK_IN for 8569MDSDave Liu
The SYS_CLK_IN of MPC8569MDS is 66.66MHz, The DDR_CLK_IN is same with SYS_CLK_IN in 8569 processor. so, change the SYS_CLK_IN from 66MHz to 66.66MHz. Signed-off-by: Dave Liu <daveliu@freescale.com>
2009-06-0985xx: Fix the wrong BCSR address of 8569MDSDave Liu
The BCSR17[7] = 1 will unlock the write protect of FLASH. The WP# pin only controls the write protect of top/bottom sector, That is why we can save env, but we can't write the first sector before the patch. Signed-off-by: Dave Liu <daveliu@freescale.com>
2009-06-0985xx: bugfix for reading maximum TLB size on mpc85xxFredrik Arnerup
The MAXSIZE field in the TLB1CFG register is 4 bits, not 8 bits. This made setup_ddr_tlbs() try to set up a TLB larger than the e500 maximum (256 MB) which made u-boot hang in board_init_f() when trying to create a new stack in RAM. I have an mpc8540 with one 1GB dimm. Signed-off-by: Fredrik Arnerup <fredrik.arnerup@edgeware.tv> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-0985xx: Fix the clock adjust of mpc8569mds boardDave Liu
Currently the clk_adj is 6 (3/4 cycle), The settings will cause the DDR controller hang at the data init. Change the clk_adj from 6 to 4 (1/2 cycle), make the memory system stable. Signed-off-by: Dave Liu <daveliu@freescale.com>
2009-06-09Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
2009-06-09at91: fix a USB problem for AT91SAM9261RONETIX - Ilko Iliev
This patch corrects the missing PLLB initialization in usb_cpu_init() for AT91SAM9261. Because of the missing PLLB initialization, the USB support for all AT91SAM9261 based boards will work only if the PLLB is configured by a precedent bootloader. Signed-off-by: Ilko Iliev <iliev@ronetix.at> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-08ppc4xx/net: Fix MDIO clock setupFelix Radensky
This patch fixes MDIO clock setup in case when OPB frequency is 100MHz. Current code assumes that the value of sysinfo.freqOPB is 100000000 when OPB frequency is 100MHz. In reality it is 100000001. As a result MDIO clock is set to incorrect value, larger than 2.5MHz, thus violating the standard. This in not a problem on boards equipped with Marvell PHYs (e.g. Canyonlands), since those PHYs support MDIO clocks up to 8.3MHz, but can be a problem for other PHYs (e.g. Realtek ones). Signed-off-by: Felix Radensky <felix@embedded-sol.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-08rtl8169: fix PCI system memory addressYoshihiro Shimoda
When PCI device use system memory, some PCI host controller should be set physical memory address. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-08SMC911x driver fixed for NFS bootManikandan Pillai
eth_halt() function in the smc911x drivers used to call the smc911x_reset() function. eth_halt() used to be called after tftp transfers. This used to put the ethernet chip in reset while the linux boots up resulting in the ethernet driver not coming up. NFS boot used to fail as a result. This patch calls smc911x_shutdown() instead of smc911x_reset(). Some comments received has also been fixed. Signed-off-by: Manikandan Pillai <mani.pillai@ti.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-08Add config option for disabling DM9000-SROM support.Remy Bohmer
Some boards do not have SROM support for the DM9000 network adapter. Instead of listing these board names in the driver code, make this option configurable from the board config file. It also removes a build warning for the at91sam9261ek board: 'dm9000x.c:545: warning: 'read_srom_word' defined but not used' And it repaires the trizepsiv board build which was broken around the same routines Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-08mpc83xx: don't set SICRH_TSOBI1 to RMII/RTBI operationKim Phillips
In GMII mode (which operates at 3.3V) both SICRH TSEC1/2 output buffer impedance bits should be clear, i.e., SICRH[TSIOB1] = 0 and SICRH[TSIOB2] = 0. SICRH[TSIOB1] was erroneously being set high. U-Boot always operated this PHY interface in GMII mode. It is assumed this was missed in the clean up by the original board porters, and copied along to the TQM and sbc boards. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Ira Snyder <iws@ovro.caltech.edu> Reviewed-by: David Hawkins <dwh@ovro.caltech.edu> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Dave Liu <DaveLiu@freescale.com>
2009-06-07smc911x: write back the manually set MAC addressDaniel Mack
If the MAX address is given by the environment, write it back to the hardware. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-04Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
2009-06-04Redundant Environment: protect full sector sizeWolfgang Denk
Several boards used different ways to specify the size of the protected area when enabling flash write protection for the sectors holding the environment variables: some used CONFIG_ENV_SIZE and CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even a mix of both for the "normal" and the "redundant" areas. Normally, this makes no difference at all. However, things are different when you have to deal with boards that can come with different types of flash chips, which may have different sector sizes. Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the biggest sector size, which may include several sectors on boards using the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the case that only the first of these sectors get protected, while the following ones aren't. This is no real problem, but it can be confusing for the user - especially on boards that use CONFIG_ENV_SECT_SIZE to protect the "normal" areas, while using CONFIG_ENV_SIZE_REDUND for the "redundant" area. To avoid such inconsistencies, I changed all sucn boards that I found to consistently use CONFIG_ENV_SECT_SIZE for protection. This should not cause any functional changes to the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Paul Ruhland Cc: Pantelis Antoniou <panto@intracom.gr> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Dave Ellis <DGE@sixnetio.com> Acked-by: Stefan Roese <sr@denx.de>
2009-06-04mmc: it's safe to ignore mmc_send_if_cond() return valueIlya Yanok
Return value of mmc_send_if_cond() can be safely ignored (as it is done in Linux). This makes older cards work with MXC MCI controller. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2009-06-03cfi_mtd: Fix bug in last sector detectionStefan Roese
This patch now enabled this cfi-mtd wrapper to correctly detect and erase the last sector in an NOR FLASH device. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-02mmc: Fix decoding of SCR & function switch data on little-endian machinesYauhen Kharuzhy
SCR & switch data are read from card as big-endian words and should be converted to CPU byte order. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-06-02mmc: Remove return from mmc_init for non SD 2.0 compatible cards.Yauhen Kharuzhy
Cards which are not compatible with SD 2.0 standard, may return response for CMD8 command, but it will be invalid in terms of SD 2.0. We should accept this case as admissible, just like Linux does. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-06-02mmc: drop unnecessary castsRabin Vincent
Now that response is a uint, we can drop all the casts. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-06-02mmc: fix response decoding on little endianRabin Vincent
The mmc code defines the response as an array of chars. However, it access the response bytes both as (i) an array of four uints (with casts) and (ii) as individual chars. The former case is used more often, including by the driver when it assigns the response. The char-wise accesses are broken on little endian systems because they assume that the bytes in the uints are in big endian byte order. This patch fixes this by changing the response to be an array of four uints and replacing the char-wise accesses with equivalent uint-wise accesses. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-06-02mmc: use lldiv to fix arm eabi buildRabin Vincent
The generic MMC core uses direct long long divisions, which do not build with ARM EABI toolchains. Use lldiv() instead, which works everywhere. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-06-02mmc: check find_mmc_device return valueRabin Vincent
find_mmc_device returns NULL if an invalid device number is specified. Check for this to avoid dereferencing NULL pointers. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-06-02mmc: clean up help textsRabin Vincent
Remove some repeated words and superfluous newlines in the mmc command help entries. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-05-29Blackfin: spi: fix pin handling of SPI0 SSEL4Mike Frysinger
CS4 on SPI0 has a dedicated PH8 pin which needs to be enabled as a peripheral in order to work. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-05-29Blackfin: fix if() logic in bootrom evt1 checkMike Frysinger
A missing set of parenthesis caused the silicon revision to apply only to the BF533 and not the BF531/BF532 variants. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-05-28Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2009-05-28jffs2/mtdparts: Fix problem with usage from JFFS2 and MTDPARTS togetherStefan Roese
Currently using JFFS2 with MTDPARTS enabled doesn't work. This is because mtdparts_init() is available in both files, cmd_mtdparts.c and cmd_jffs2.c. Please note that in the original cmd_jffs2.c file (before the jffs2/mtdparts command/file split those 2 different versions already existed. So this is nothing new. The main problem is that the variables "current_dev" and "current_partnum" are declared in both files now. This doesn't work. This patch now changes the names of those variable to more specific names: "current_mtd_dev" and "current_mtd_partnum". This is because this patch also changes the declaration from static to global, so that they can be used from both files. Please note that my first tests were not successful. The MTD devices selected via mtdparts are now accessed but I'm failing to see the directory listed via the "ls" command. Nothing is displayed. Perhaps I didn't generate the JFFS2 image correctly (I never used JFFS2 in U-Boot before). Not sure. Perhaps somebody else could take a look at this as well. I'll continue looking into this on Monday. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Renaud barbier <renaud.barbier@ge.com>
2009-05-25Blackfin: bf518f-ezbrd: setup portmux for async flashGraf Yang
The pins for async memory where parallel flash lives are not enabled by default, so make sure we mux them as needed. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-05-23nand: Fix problem with ECC ordering for PPC4xx NDFC platformsStefan Roese
This patch enables Smart Media (SMC) ECC byte ordering which is used on the PPC4xx NAND FLASH controller (NDFC). Without this patch we have incompatible ECC byte ordering to the Linux kernel NDFC driver. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2009-05-23ppc4xx: Fix problem with ECC ordering for PPC4xx NDFC platformsStefan Roese
This patch now uses the correct ECC byte order (Smart Media - SMC) to be used on the 4xx NAND FLASH driver. Without this patch we have incompatible ECC byte ordering to the Linux kernel NDFC driver. Please note that we also have to enable CONFIG_MTD_NAND_ECC_SMC in drivers/mtd/nand/nand_ecc.c for correct operation. This is done with a seperate patch. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2009-05-23ppc4xx: Move definition for PPC4xx NAND FLASH controller to headerStefan Roese
This patch moves the definition for the PPC4xx NAND FLASH controller (NDFC) CONFIG_NAND_NDFC into include/ppc4xx.h. This is needed for the upcoming fix for the ECC byte ordering of the NDFC driver. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2009-05-20Merge branch 'master' of git://git.denx.de/u-boot-ubiWolfgang Denk
