This patch extends PCI device id table of the
radeon driver so that the driver will also support
Radeon Mobility 9200 (M9+) based boards.
Adds ATI Radeon 9200 support for 1280x1024, 1024x768,
800x600, 640x480 at 24, 16 and 8 bpp.
If the length of the memory address range passed to the "mtest" command is
not of the form 2^x - 1, not all address lines are tested. This bug is
inherited from the original software at
http://www.netrino.com/Embedded-Systems/How-To/Memory-Test-Suite-C. Fix
this.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
common/cmd_reginfo.c
Makefile
doc/README.standalone
The address of SH7722 is wrong by old document.
This patch fixes this problem.
Constantly rebuilding the version header will force useless relinking, so we
simply need to compare the new header with the existing one before updating
it.
Fix a missing return statement from a non-void function.
Update global_data to define i2c1_clk and i2c2_clk to 85xx and 86xx.
Update the get_clocks() function in 85xx and 86xx to determine the I2C
clock frequency and store it in gd->i2c1_clk and gd->i2c2_clk.
Get board name consistent with Linux and elsewhere;
get rid of local network definitions etc.
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc
will refuse to use load/store multiple insns; instead, it issues a
list of simple load/store instructions upon function entry and exit,
resulting in bigger code size, which in turn makes the build for a
few boards fail.
Use r2 instead.
If the variable "machid" exists, let do_bootm_linux use that instead
of bd->bi_arch_number.
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
MCD_tasks.c lacks [subject] so compilation of mips targets (and more, probably)
fails
Signed-off-by: Vlad Lungu <vlad@comsys.ro>
Current MII_DEBUG is confusing in two ways. One is useless define-then-
undef at the top of the file. The other is there is only one debug() in
this file, and that doesn't seem worthwhile to bother having MII_DEBUG.
While there are many useful printf()/puts() debug codes, but they are for
DEBUG, not for MII_DEBUG.
This patch tries to put them all together into MII_DEBUG and debug().
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
This patch enables the OneNAND boot within U-Boot.
Before this work, we used another OneNAND IPL called X-Loader based
on open source. With this work, we can build the oneboot.bin image
without other program.
The build sequence is simple.
First, it compiles the u-boot.bin
Second, it compiles OneNAND IPL
Finally, it becomes the oneboot.bin from OneNAND IPL and u-boot.bin
The mechanism is similar with NAND boot except it boots from itself.
Another thing is that you can only use the OneNAND IPL only to work
other bootloader such as RedBoot and so on.
A #if statement in fat.c depended on CONFIG_MMC, instead of
defined(CONFIG_MMC). This meant CONFIG_MMC needed to be defined
as "1" rather than just defined. Now it's better.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
sys_eeprom.c:82:9: warning: unknown escape sequence '\/'
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
Signed-off-by: Larry Johnson <lrj@acm.org>
Retry to send NFS packet before reaching timeout.
Signed-off-by: Hiroshi Ito <ito@mlb.co.jp>
Signed-off-by: Johannes Stezenbach <js@sig21.net>
update comments
Fix coding style
One should never add a backup file ending in with ~ to the git repository.
Signed-off-by: Stelian Pop <stelian@popies.net>
These replace direct structure references for IMMR sections.
