2007-09-07Fix typo in MAKEALL script.v1.3.0-rc1Wolfgang Denk
2007-09-07Update CHANGELOG, minor coding style cleanup.Wolfgang Denk
2007-09-07PXA270: Added support for TrizepsIV board.stefano babic
This patch add support for the Trizeps IV module (520Mhz). Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-09-07PXA270: Add support for multiple serial ports.stefano babic
This patch adds support for multiple serial ports to the PXA target. FFUART, BTUART and STUART are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-09-07PXA270: fix compile issue (invalid lvalue)stefano babic
Code is broken for PXA270 due to "invalid lvalue in assignment". This patch fix it in pxa-regs.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-09-07Add BUILD_DIR support for bios emulator.Jason Jin
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2007-09-07[MIPS] Remove inline asm string functionsShinya Kuribayashi
Stop using inline string functions on MIPS as other ARCHs do so, since the optimized inline asm versions are not small. This change is triggered by a following MIPS build error: common/libcommon.a(exports.o)(.text+0xdc): In function `jumptable_init': common/exports.c:32: undefined reference to `strcmp' make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-09-07[MIPS] Update asm string headerShinya Kuribayashi
This patches contains several bugfixes and cleanups in the latest upstream: - Don't include linux/config.h - Remove buggy inline version of memscan. - Merge with Linux 2.6.11-rc3. - Fix undefined reference to strcpy in binfmt_misc caused by gcc 3.4. - Goodbye mips64. 31704 lines of code bite the dust. - Replace extern inline with static inline. - Fix return value of strncpy. - Remove a bunch more "$1" clobbers. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-09-07Merge with /home/wd/git/u-boot/custodian/u-boot-mpc85xxWolfgang Denk
2007-09-07Fix do_bootm_linux() so that multi-file images with FDT blob boot.Bartlomiej Sieka
Fix incorrect blob address calculation in do_bootm_linux() that prevents booting the kernel from a multi-file image (kernel + initrd + blob). Also, make minor updates to the U-Boot's output and to the coding style. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-09-07Merge with /home/wd/git/u-boot/custodian/u-boot-mpc5xxxWolfgang Denk
2007-09-06Add support for Sil680 IDE controller.Gary Jennejohn
o add drivers/sil680.c to support the Sil680 IDE-controller. o drivers/Makefile: add sil680.o. Signed-off-by: Gary Jennejohn <garyj@denx.de>
2007-09-06bootm/fdt: Only process the fdt if an fdt address was providedGrant Likely
Boards with CONFIG_OF_LIBFDT enabled are not able to boot old-style kernels using the board info structure (instead of passing a device tree) This change allows the old style booting to be used if the fdt argument was not passed to 'bootm'. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2007-09-06Migrate 5xxx boards from CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDTGrant Likely
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200 Tested on: lite5200b Note: the fixup functions have not been moved to a common place. This patch is targeted for immediate merging as in solves a build issue, but the final name/location of the fixups is still subject to debate. I propose to merge this now, and move the fixups in the next merge window to be usable by all targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-06libfdt: add convenience function fdt_find_and_setprop()Grant Likely
Given the path to a node, fdt_find_and_setprop() allows a property value to be set directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-04Fix ULI RTC support on MPC8544 DSKumar Gala
The RTC on the M1575 ULI chipset requires a dummy read before we are able to talk to the RTC. We accomplish this by adding a second memory region to the PHB the ULI is on and read from it. The second region is added to maintain compatiabilty with Linux's view of the PCI memory map. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-04ft_board_setup update 85xx/86xx of pci/pcie bus-range property.Ed Swarthout
pcie is now differentiated from pci. Add 8641 bus-range updates. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-09-02Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-31ppc4xx: (Re-)Enable CONFIG_PCI_PNP on AMCC 440EPx SequoiaGary Jennejohn
The 440EPx has a problem when the PCI_CACHE_LINE_SIZE register is set to non-zero, because it doesn't support MRM (memory-read- multiple) correctly. We now added the possibility to configure this register in the board config file, so that the default value of 8 can be overridden. Here the details of this patch: o drivers_pci_auto.c: introduce CFG_PCI_CACHE_LINE_SIZE to allow board-specific settings. As an example the sequoia board requires 0. Idea from Stefan Roese <sr@denx.de>. o board/amcc/sequoia/init.S: add a TLB mapping at 0xE8000000 for the PCI IO-space. Obtained from Stefan Roese <sr@denx.de>. o include/configs/sequoia.h: turn CONFIG_PCI_PNP back on and set CFG_PCI_CACHE_LINE_SIZE to 0. Signed-off-by: Gary Jennejohn <garyj@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-31Fix TFTP OACK code for short packets.Wolfgang Denk
The old code had a loop limit overflow bug which caused a semi- infinite loop for small packets, because in "i<len-8", "i" was signed, but "len" was unsigned, and "len-8" became a huge number for small values of "len". This is a workaround which replaces broken commit 8f1bc284. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-30Backout commit 8f1bc284 as it causes TFTP to fail.Wolfgang Denk
2007-08-30Revert "Fix MPC8544DS PCIe3 scsi."Ed Swarthout
This reverts commit 9468e680. Commit 16e23c3f5da removing allocation of PCSRBAR is sufficient. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-08-30tftp: don't implicity trust the format of recevied packetsGrant Likely
The TFTP OACK code trusts that the incoming packet is formated as ASCII text and can be processed by string functions. It also has a loop limit overflow bug where if the packet length is less than 8, it ends up looping over *all* of memory to find the 'blksize' string. This patch solves the problem by forcing the packet to be null terminated and using strstr() to search for the sub string. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-29Merge with git+ssh://gemini/home/wd/git/u-boot/masterWolfgang Denk
2007-08-29sbc8641: remove unused OF_FLAT_TREE_MAX_SIZEKim Phillips
this had slipped through the cracks, since the sbc board was added after I wrote the original patch to remove all these symbols, and before it was merged. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29Add mii_init() prototypeWolfgang Denk
to get rid of a *lot* of compiler warnings. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-29Disable network support on cmi_mpc5xx boardWolfgang Denk
..because it caused compiler errors and there seems to be no board maintainer to take care of this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-29Fix MPC8544DS PCIe3 scsi.Kumar Gala
<ed.swarthout@freescale.com> The problem is pciauto_setup_device() getting called from fsl_pci_init.c is allocating memory space it doesn't need. Signed-off-by: Ed Swarthout <ed.swarthout@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-298548cds fixesEd Swarthout
Restore CONFIG_EXTRA_ENV_SETTINGS definition which contains the correct consoledev needed for linux boot. Standardize on fdt{file,addr} var to hold dtb file name. Set PCI inbound memory region from CFG_MEMORY_{BUS,PHYS}. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-08-29Enable L2 cache for MPC8568MDS boardHaiying Wang
The L2 cache size is 512KB for 8568, print out the correct informaiton. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-08-29Remove the bios emulator binary files from MAI boardJason Jin
2007-08-29support board vendor-common makefilesKim Phillips
if a board/$(VENDOR)/common/Makefile exists, build it. also add the first such case, board/freescale/common/Makefile, to handle building board-shared EEPROM, PIXIS, and MDS-PIB code, as dictated by board configuration. thusly get rid of alternate build dir errors such as: FATAL: can't create /work/wd/tmp/u-boot-ppc/board/freescale/mpc8360emds/../common/pq-mds-pib.o: No such file or directory by putting the common/ mkdir command in its proper place (the common Makefile). Common bits from existing individual board Makefiles have been removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29Fix: TFTP is not working on little endian systemsstefano babic
TFTP does not work anymore after multicast tftp patch was applied on little endian systems. This patch fix it. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-08-29Fix MAC address setting in DM9000 driver.stefano babic
The logic to check if there is a correct MAC address in the DM9000 EEPROM, added in the last patch, is wrong. Now the MAC address is always taken from the environment, even if a suitable MAC is present in the EEPROM. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-08-29MPC5xxx: fix some compiler warnings in USB codeMartin Krause
Fix the following warnings: - usb.c:xx: warning: function declaration isn't a prototype - usb_ohci.c:xxx: warning: passing argument 1 of '__fswab32' makes integer from pointer wihtout a cast Signed-off-by: Martin Krause <martin.krase@tqs.de>
2007-08-29fsl_pci_init - Remove self PCSRBAR allocationEd Swarthout
CPU physical address space was being wasted by allocating a PCSRBAR PCI inbound region to it's memory space. As a rule, PCSRBAR should be left alone since it does not affect transactions from self and other masters may have changed it. Signed-off-by: Ed Swarthout <ed.swarthout@freescale.com>
2007-08-29Fix compiler warning in include/s3c2410.hMartin Krause
This patch fixes the "type qualifiers ignored on fuction return tpye" warning for include/s3c2410.h Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-08-29Fix compilation error for omap2420h4_config.Dirk Behme
omap2420h4 switched to cfi, so remove old (already disabled) flash.c and flash_probe() calls in env_flash.c. Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29Minor coding style cleanup.Wolfgang Denk
2007-08-29Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-08-28[UC101] Fix: if no CF in the board, U-Boot resets sometimes.Heiko Schocher
2007-08-28IDE: - make ide_inb () and ide_outb () "weak", so boards canHeiko Schocher
define there own I/O functions. (Needed for the pcs440ep board). - The default I/O Functions are again 8 Bit accesses. - Added CONFIG_CMD_IDE for the pcs440ep Board. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-08-25POST: limit memory test area to not touch global data anymoreYuri Tikhonov
As experienced on lwmon5, on some boards the POST memory test can corrupt the global data buffer (bd). This patch fixes this issue by checking and limiting this area. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-24ppc4xx: Add RTC POST test to lwmon5 board configurationStefan Roese
Since this RTC POST test is taking quite a while to complete it's only initiated upon special keypress same as the complete memory POST. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-24ppc4xx: Change GPIO signal for watchdog triggering on lwmon5Stefan Roese
2007-08-23ppc4xx: Add support for 2nd I2C EEPROM on lwmon5 boardStefan Roese
This patch adds support for the 2nd EEPROM (AT24C128) on the lwmon5 board. Now the "eeprom" command can be used to read/write from/to this device. Additionally a new command was added "eepromwp" to en-/disable the write-protect of this 2nd EEPROM. The 1st EEPROM is not affected by this write-protect command. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-22ppc4xx: Remove unused option CFG_INIT_RAM_OCMStefan Roese
2007-08-21Merge with /home/stefan/git/u-boot/u-boot-ppc4xxStefan Roese
2007-08-21ppc4xx: Add matrix kbd support to lwmon5 board (440EPx based)Stefan Roese
This patch adds support for the matrix keyboard on the lwmon5 board. Since the implementation in the dsPCI is kind of compatible with the "old" lwmon board, most of the code is copied from the lwmon board directory. Signed-off-by: Stefan Roese <sr@denx.de>
