2007-11-19Prepare for 1.3.0 release.v1.3.0Wolfgang Denk
2007-11-19Move CONFIG_QE out of CONFIG_PCI wrap for MPC8568MDSHaiying Wang
CONFIG_QE shouldn't be in the wrap of CONFIG_PCI, fix it. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-11-19[MIPS] board/gth2/lowlevel_init.S: Fix a build warningShinya Kuribayashi
lowlevel_init.S: Assembler messages: lowlevel_init.S:413: Warning: Pretending global symbol used as branch target is local. Looking at codes, the `memtest' and `clearmem' are intentional mixed use of `global symbols' and `label' for debugging purpose. To make it build, just disable global-symbols-use for now. As a result `memtest' still remains as unused, but leave it be... Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-11-19Fix build problems with mp2usb boardWolfgang Denk
2007-11-18s3c24x0: Fix usb_ohci.c missing in MakefileJean-Christophe PLAGNIOL-VILLARD
and usb_ohci.c warning differ in signedness Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-18pb1x00 board: Fix u16 status declaration when PCMCIA is definedJean-Christophe PLAGNIOL-VILLARD
2007-11-18Fix compiler warnings for ARM systems.Wolfgang Denk
2007-11-18Fix compiler warnings for PPC systems. Update CHANGELOG.Wolfgang Denk
2007-11-18Fix warning differ in signedness in net/net.c and net/nfs.cJean-Christophe PLAGNIOL-VILLARD
2007-11-18Merge branch 'master' of git://www.denx.de/git/u-boot-mipsWolfgang Denk
2007-11-18gth2.c: Fix a warning on gth2 build.Shinya Kuribayashi
gth2.c: In function 'misc_init_r': gth2.c:434: warning: pointer targets in passing argument 2 of 'setenv' differ in signedness Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-18Fix warning differ in signedness in common/cmd_scsi.cStefan Roese
2007-11-17[MIPS] cpu/mips/config.mk: Fix GNU assembler minor version pickerShinya Kuribayashi
Current trick to pick up GNU assembler minor version does not work with the latest binutils (2007-03-01 or later) due to ${PKGVERSION} now default to "(GNU Binutils) ". $ sde-as --version |grep "GNU assembler" GNU assembler 2.15.94 mipssde-6.02.02-20050602 $ sde-as --version |grep "GNU assembler" |awk '{print $3}' 2.15.94 $ sde-as --version |grep "GNU assembler" |awk '{print $3}' |awk -F. '{print $2}' 15 $ $ mips-linux-as --version |grep "GNU assembler" GNU assembler (GNU Binutils) 2.18 $ mips-linux-as --version |grep "GNU assembler" |awk '{print $3}' (GNU $ mips-linux-as --version |grep "GNU assembler" |awk '{print $3}' |awk -F. '{print $2}' (no output) $ As a result of above, you'll see many noises with such binutils: make -C cpu/mips/ /bin/sh: line 0: [: : integer expression expected /bin/sh: line 0: [: : integer expression expected make[1]: Entering directory `/home/skuribay/devel/u-boot.git/cpu/mips' mips-linux-gcc -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -c -o incaip_wdt.o incaip_wdt.S /bin/sh: line 0: [: : integer expression expected mips-linux-gcc -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -c -o cache.o cache.S /bin/sh: line 0: [: : integer expression expected mips-linux-gcc -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -Wall -Wstrict-prototypes -c -o asc_serial.o asc_serial.c /bin/sh: line 0: [: : integer expression expected This patch simplifies the trick and makes it work with both versions of gas. I also replace an expensive `awk (or gawk)' with `cut'. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-17[MIPS] Remove useless instructions for initializing $gp.Shinya Kuribayashi
2007-11-17[MIPS] MIPS 4K core: Coding style cleanupsShinya Kuribayashi
No logical changes. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-17[MIPS] gth2.c: Fix a warning on gth2 build.Shinya Kuribayashi
2007-11-17[MIPS] au1x00_eth.c: Fixed a warning on pb1000 build.Shinya Kuribayashi
au1x00_eth.c: In function 'au1x00_miiphy_write': au1x00_eth.c:139: warning: 'return' with no value, in function returning non-void Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-17[MIPS] au1x00_eth.c: Fix au1x00_miiphy_{read,write} build errorShinya Kuribayashi
au1x00_eth.c: In function 'au1x00_enet_initialize': au1x00_eth.c:246: error: 'au1x00_miiphy_read' undeclared (first use in this function) au1x00_eth.c:246: error: (Each undeclared identifier is reported only once au1x00_eth.c:246: error: for each function it appears in.) au1x00_eth.c:246: error: 'au1x00_miiphy_write' undeclared (first use in this function) au1x00_eth.c: In function 'au1x00_miiphy_write': au1x00_eth.c:298: warning: 'return' with no value, in function returning non-void make[1]: *** [au1x00_eth.o] Error 1 Fixed by moving these two functions forward. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-17MAKEALL: Added missing pb1000 boardShinya Kuribayashi
2007-11-17[MIPS] pb1000: Replace obsolete memsetup.S with lowlevel_init.SShinya Kuribayashi
2007-11-17[MIPS] u-boot.lds: Cleanup __u_boot_cmd_{start,end}Shinya Kuribayashi
2007-11-17Update CHANGELOIG, prepare for -rc4v1.3.0-rc4Wolfgang Denk
2007-11-17Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2007-11-17Merge branch 'master' of git://www.denx.de/git/u-boot-mpc5xxxWolfgang Denk
2007-11-17Fix the i2c frequency and default address in rsdproto boardLuotao Fu
rsdproto board support has wrong I2C frequency and wrong return value handling. Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
2007-11-17powerpc: Backout relocation changes for MPC5121, too.Wolfgang Denk
Apply Grant Likely's backout to MPC5121 code, too. Pointed out by Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-11-17powerpc: Backout relocation changes.Grant Likely
Ugh. I *hate* to back this change out, but these compiler flags don't work for relocation on all versions of GCC. I've not been able to reproduce the environment in my setup (and hence, not been able to find a combination that *does* work), so I've got no choice but to go back to the old gcc flags and linker script. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-17Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2007-11-17Fix a bug in the slave serial programming mode for the XilinxWolfgang Denk
Spartan2/3 FPGAs. The old code used "< 0" on a "char" type to test if the most significant bit was set, which did not work on any architecture where "char" defaulted to be an unsigned type. Based on a patch by Angelos Manousaridis <amanous@inaccessnetworks.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-11-1786xx: Fix broken variable reference when #def DEBUGing.Jon Loeliger
Sometimes you can't reference the DDR2 controller variables. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-11-17make 8610 board use pixis resetJason Jin
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2007-11-17Unify pixis_reset altbank across board familiesJason Jin
Basically, refactor the CFG_PIXIS_VBOOT_MASK values into the separate board config files. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-11-17Merge branch 'master' of /home/wd/git/u-boot/workWolfgang Denk
2007-11-17Fix warning: pointer targets in assignment differ in signednessJean-Christophe PLAGNIOL-VILLARD
2007-11-16Fix warning differ in signedness in common/cmd_ide.cJean-Christophe PLAGNIOL-VILLARD
2007-11-16Merge branch 'master' of git://www.denx.de/git/u-boot-netWolfgang Denk
2007-11-15Revert "Correct relocation fixup for mpc5xx"Grant Likely
This reverts commit 3649cd99ba815b6601868735765602f00ef3692b. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for MPC5xxx"Grant Likely
This reverts commit 6f7576b20ecf0d040c3ac3b032b5cbc860e38a90. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc8220"Grant Likely
This reverts commit a85dd254c0577fca13627c46e93fc2ad4c4f1f00. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc824x"Grant Likely
This reverts commit f3a52fe05923935db86985daf9438e2f70ac39aa. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc8260"Grant Likely
This reverts commit 5af61b2f4b838a05f79be274f3e5a66edd2d9c96. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc83xx"Grant Likely
This reverts commit 057004f4a4863554d56cc56268bfa7c7d9738e27. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "[MPC512x] Correct fixup relocation"Grant Likely
This reverts commit 8d17979d0359492a822a0a409d26e3a3549b4cd4. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-13ppc4xx: lwmon5: Change PHY reset sequence for PHY MDIO address latchingStefan Roese
2007-11-13Merge branch 'master' of git://www.denx.de/git/u-bootStefan Roese
2007-11-13[UC101] SRAM now with 2 MB working.Heiko Schocher
2007-11-08ColdFire: MCF5329 - Remove reset registers from CCMTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-11-08ColdFire: MCF5329 - Add Reset structure to immap_5329.hTsiChungLiew
2007-11-08ColdFire: MCF5329 - revert include/asm-m68k/m5329.h file modeTsiChungLiew
