Use Kconfig to select whether UHS should be supported. This works
around issues with UHS seen on Apalis Evaluation board with some
SD cards. It seems that tuning fails. The exact reason is not known,
but since pull-ups on the carrier board are 3.3V, and UHS requires
1.8V, UHS modes should not be used by default anyway.
Inspired-by commit f99c2efe5672 ("mmc: make UHS and HS200 optional")
Current samples are strapped to boot from SD card by default. Also
make sure that the default U-Boot environment boots from SD card.
Add support for interactive recovery of Apalis iMX8 QuadMax
config block.
Add an optional -y parameter to 'cfgblock create’ to simplify
automation.
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
board/toradex/common/configblock.c
Add Toradex config block support for i.MX8QM.
Add default memory layout and networking options typically used
on Toradex modules.
Use USDHC1 which is eMMC to store U-Boot environment and as default
root device for Linux.
Extend bootcmd to also load the HDMI firmware through hdp
command.
Remove GPIOs used on the validation board but not required on
Apalis iMX8.
NXP LPUART1 is used as Apalis UART1, which is the main console
on our Linux BSP.
Make sure we return the clock of UART1 when building for
Apalis iMX8. NXP LPUART1 is used as Apalis UART1, which
is typically the main console on our Linux BSP.
Make sure that all pins connected to the Micrel KSZ9031 PHY
are muxed. Properly reset the PHY after all muxing has been
applied. This makes sure that strapping is not overwritten by
the SoC default mux (particularly it makes sure that CLK125_NDO
is not driven low during reset).
Make sure to not use CONFIG_DM_ETH as it seems to break ETH
support as is.
The Apalis iMX8 module does not have PCA9557 GPIO controllers
on the module.
Initial board support for Apalis iMX8 using a copy of NXP
iMX8QM ARM2 LPDDR4 board.
Flash bootloader will switch the mmc hwpart to boot0 partition which
will cause errors when read/write blocks from user partition. Fix
this bug by switching hwpart to user partition before read/write
user partition every time.
Change-Id: I5e3405de04e22db352efa59f0286e5c5c4697ac5
Signed-off-by: Luo Ji <ji.luo@nxp.com>
Since kernel enables both ENET0 and ENET1, so change to reset ENET1
PHY and MAX7322 as well even the configuration is set to use ENET0
in u-boot.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 9ce009caf4c80fbcb31526049420d6c388494247)
Renaming hdpload to hdp_load for consistancy.
Correcting the strncmp to use only 4 characters to match "load" argument
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
Load HDMI firmware from u-boot.bin instead of
/system partition.
Change-Id: I8945940cfe14db50c95a56b8bff2a94990a7fbaf
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
After align BSP uboot configuration (commit: e363a68), some vedio
related operations was enabled and will take some heap space. AVB
will take about 62M Bytes heap size to load both boot_a and boot_b,
64M Bytes is not enough anymore.
Change-Id: I9f93cd8d32410d144a0c5a976046773fbd07a539
commit cfdb9821531da523fd1f01536eb67c8b8451477f
Author: Oliver Brown <oliver.brown@nxp.com>
Date: Tue Jan 2 07:46:06 2018 -0600
dc: Add controls for display controller resets.
When doing "i2c dev 4; i2c probe" with ENET daughter card connected on iMX8QXP MEK
board, we met a i2c bus busy issue, that the BBF of lpi2c always show busy, but the
master is idle, and stop is detected (SDF set).
This patch addes a handling to re-init the lpi2c master for this case. Then the issue
can be worked around.
Acked-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 6b4021d04c7f637fd60cf73f9cc46fdebc853790)
The i2c mux PCA9646 does not have register offset. We should read/write
its control register immediately following the i2c device address.
Use u-boot,i2c-offset-len to set the register offset length to 0.
(cherry picked from commit e3aa5b1ea468f60b798c9eea9abf18e6019b126b)
When testing a poor USB disk "Transcend JetFlash XPGMC7W5 ", sometime we
will get TRB TX error during getting string descriptors, then the usb process
aborts due to the context state changed to halted.
Actually when the endpoint context state is halted, we can send reset endpoint
command to put it to stopped state, then set TR dequeue pointer for following
doorbell ring to re-run it. This patch adds this error recovery mechanism.
(cherry picked from commit 6a2418e2b0554045ae1e8096b22fa64da5de4d8a)
Load HDMI firmware to make HDMI module work.
The firmware stored in /system partition.
Now choose the target boot slot's system partition
to load the firmware.
Change-Id: Icfcd5f6c8237ee0c8875317395cf86c07d53c58e
Add 'append_bootargs' to hold some paramemters which need to be
appended to bootargs.
Change-Id: I80f18a421dea270cc8f555fe1b2799a5eb00aadc
Fix ENET1 build and enablement.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit b799894c4e56a4afee0d7c8041bd49d718d0bd35)
Fix build error.
Correct ENET1 enablement, Define CONFIG_FEC_ENET_DEV 1, to enable
ENET1 on Base board.
(cherry picked from commit 2440ee9ac2c66819e1cc664bd92fb8f092544059)
Since android needs the USB OTG port on base board to run fastboot,
add the USBOTG1 node to imx8qm mek DTS, so that the OTG can work on
reworked board.
Tested-by: Chen Guoyin <guoyin.chen@nxp.com>
(cherry picked from commit f347ebae3610c41f9b6eec33baff485192547761)
The USB OTG port on MEK base board is not enabled at default, due to the default
design connects it to M2 connector for BT/WIFI.
Since most boards have reworked it, we enable it to support both host and device
mode in u-boot.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit d43ad95777d28baf3ae33c7cd09e605a12641e13)
There is the 8M block sized NAND chip on QXP board, the previous 64MB
u-boot environment offset overlapped with the boot image location.
Changed the offset from 64MB to 120MB to avoid the overlap.
Signed-off-by: Han Xu <han.xu@nxp.com>
(cherry picked from commit e08d69114cc77fa1b261a2870219a2ad48e389b8)
Met build errors below when CONFIG_VIDEO_IMX_HDP_LOAD is not selected. Because the u-boot
make script checks the "$(obj-y) $(obj-m) $(obj-) $(subdir-m) $(lib-target)" for built-in target.
aarch64-poky-linux-ld.bfd: cannot find drivers/video/imx/built-in.o: No such file or directory
scripts/Makefile.build:359: recipe for target 'drivers/video/built-in.o' failed
(cherry picked from commit 8c81dfb83f59ceb358f91564b9d48052d3df97cb)
BSP add HDP firmware loading for video.
android daily build for the configure is not align with BSP.
align BSP uboot configure.
Change-Id: I56ce146a40eeed63e71795870d48387385903f8a
Signed-off-by: zhang sanshan <sanshan.zhang@nxp.com>
Added default environment for hdp loading.
Added hdp loading as default for iMX8QM ARM2 and MEK boards.
Adding the HDP firmware loading to the build.
This adds a command to load the HDP firmware and supporting libraries.
When sd/mmc work at DDR mode, like HS400/HS400ES/DDR52/DDR50 mode,
the actual clock rate is just half of the expected clock.
This patch set the DDR_EN bit first for DDR mode, hardware divide
the usdhc clock automatically, then follow the original sdr clock
setting method.
This patch also remove the unused variable 'is_ddr'.
Acked-by: Li Ye <ye.li@nxp.com>
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
(cherry picked from commit 2f1eed596782be19eb2c14e708e6db8596876346)
Since SCFW switches off the base board at default, we need to turn on it
in u-boot, so that perpherals on base board can work.
(cherry picked from commit 3bc93fa619c29b1344002ef4d96478bf8f9a2fde)
Currently, the DPLL of conn ss is not stable, will cause usdhc
data CRC error. So here change USDHC_CLK_ROOT source from AVPLL
as a workaround. And config USDHC1_CLK_ROOT to 333MHz, USDHC2_CLK_ROOT
to 200MHz. This workaround do not impact SD performance, but decrease
the eMMC performance, HS400ES work clock change from 198MHz to 166MHz,
read performance drop about 10%, write performance drop about 6%.
(cherry picked from commit c573014c0bd3e5d111c7078ae03dbe1c066db3c1)
Change the pre_div to value 1, otherwise the actual sd/mmc clock
frequency is always half of the expect frequency.
(cherry picked from commit 63c48958551b1e41e716a90cc40dd143df7d2c3f)
The offset of u-boot for i.MX8 boards is 33k bytes, writing whole gpt
image (34k) will break u-boot when the board is booted with SD card.
This patch only write vaild part (first 17k bytes) of gpt into SD card
and will keep backup gpt at the last LBA.
Change-Id: Iac5d337fb11a3e3ad2a9686efbfbacf9523dae58
Add support for DDR4 board in u-boot.
Main changes are the SD card slot and ddr
type
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Use mx6qp.cfg for optee support.
Add xen env, "run xenboot" to boot xen.
