Since i.MX8QXP only use one 16K fuse array, it has different fuse address for
2nd half 256 fuse words with QM. According to its fuse map, the fuse addresses
for MAC1 and MAC2 are 708-711.
Signed-off-by: Ye Li <ye.li@nxp.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
This is better done through dts.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
This is deprecated in favor of the generic iommus binding but xen only
supports this older version.
Using the SMMU for some devices (like dpu) requires a streamid to be
assigned to multiple resources.
Determining the resource ids for a device is a problem that occurs in
multiple contexts. So far uboot deals with this by parsing the
power-domain node which is insufficient here.
Add a new devicetree property called fsl,sc_rsrc_id which lists the
resource ids associated by a certain device.
Use streamids specified in dtb because they need to match anyway. This
removes the need to rebuild uboot for stream id assignments.
Met a problem that mii command fails to work after u-boot booting up.
The root cause is the fec_probe function initializes ethernet PHY first,
then reset the FEC controller. This causes the mii_speed register reset
to 0 and lead mdio can't work.
Change the flow to reset FEC controller prior than setup PHY.
Add build config, dts and board codes for i.MX8QM MEK board. Supported
peripherals: UART, eMMC/SD, ENET, I2C, USB TYPEC DFP mode, flexspi.
DTS is ported from kernel commit a4fff857ea5f0a6513b943e0b0b842d5008785f1,
and enable more peripherals.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
In esdhc_set_ios, the clock has been setup before calling esdhc_set_timing.
So no need to call set_sysctl more.
The HS400 ES (Enhanced Strobe) has been added. This patch addes support
for HS400 for eMMC 5.0 devices. It needs tuning at HS200 to synchronize
command response.
Add HS400 ES mode support.
The flow is same as mmc_select_hs400es in kernel drivers/mmc/core/mmc.c.
With HS400 ES, there is no tuning needed.
With Toshiba 32GB Automotive eMMC5.1 on 8QXP ARM2 board, speed test:
'time mmc read 0x90000000 0 0x200000' shows that speed is 282MB/s.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Set usdhc clock to 400M. When enabling HS400 ES, DDR EN is enabled,
if we still have input clock as 200M, the real output clock will be 100M.
So set clock to 400M to get real 200M output when enabling HS400/ES.
Enable the USB3.0 XHCI driver to support host mode on MEK board.
The USB3.0 typec on MEK board uses PTN5110 TCPC as cc logic and power control. Different like
the device on ARM2 board, this IC needs driver to control and get status through I2C bus.
In this patch, we simply call the TCPC API to set to DFP mode, check the CC status for SS MUX select
and enable source VBUS power. When the USB host is shutdown, disable the VBUS power.
Add an simple driver for USB typec port controller in freescale common codes.
The functions in this driver help to initialize the TCPC, set and work with
fixed DFP role.
Will improve it later to support UFP and move to driver directory.
Call the board_usb_cleanup in xhci_imx8_remove (DM) and xhci_hcd_stop (non-DM) to
execute some board level usb stop in cc logic and ss mux.
Find buildinfo easily and copy everything just one click
U-Boot 2017.03-00031-g0596078-dirty (Sep 13 2017 - 10:59:41 -0500)
CPU: Freescale i.MX8QXP revA A35 at 1200 MHz at 6C
Model: Freescale i.MX8QXP LPDDR4 ARM2
Board: iMX8QXP LPDDR4 ARM2
Boot: SD1
DRAM: 3 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
[pcie_ctrlb_sata_phy_init_rc] LNK DOWN 8600000
In: serial
Out: serial
Err: serial
BuildInfo:
- SCFW f0cb8b8e, IMX-MKIMAGE cc994971, ATF 0
- U-Boot 2017.03-00031-g0596078-dirty
switch to partitions
Signed-off-by: Frank Li <Frank.Li@nxp.com>
Accroding to RM, the Receive FIFO Enable (RXFE) field in LPUART FIFO register
is bit 3, so the definition should change to 0x08 not 0x40.
Otherwise the Receive FIFO is not disabled.
Export the board_name and board_rev for these boards:
- 8MQ EVK
- 8QM ARM2
- 8QXP ARM2
- 8QXP MEK
These two variables are used by an autotest u-boot script,
to request the needed BSP files.
Signed-off-by: Adrian Negreanu <adrian.negreanu@nxp.com>
Since the arm trusted firmware has implemented the system reset in PSCI.
We can enable the CONFIG_PSCI_RESET to call PSCI API to reset the u-boot.
Found kernel won't be loaded when UART does not connect to the board. This is
because UART received one data with frame error in this case, and stop in
u-boot console.
The root cause is we set wrong pad setting for UART. The pad should be set
to pull up not pull down. The pull down will cause problem to UART START bit.
This patch fix the UART pad to 0x600020 (input and output, high drive strength,
and pull up).
Acked-by: Fugang Duan <fugang.duan@nxp.com>
Since we have many software running on QM/QXP, it is better to print their
commit ids in u-boot to know their versions.
This patch enables the CONFIG_ARCH_MISC_INIT. In arch_misc_init to gets the
commit ids for SCFW and ATF via their APIs and get the commit for imx-mkimage
at the end of u-boot.bin loading address.
Once the commit ids are acquired, show them in console like:
BuildInfo: SCFW 45c567e8, IMX-MKIMAGE cc994971, ATF 0a9efa7
and set them to environment variables like:
commit_atf=0a9efa7
commit_mkimage=cc994971
commit_scfw=45c567e8
If old software are running which does not support provide commit it, the patch
use 0 instead.
Update SCFW API to latest commit 45c567e830b2b915982ea5f2fcd60d235991a415
which contains new API to get build info for SCFW.
System cannot run into bootloader/recovery mode once there is unknown cmd
in misc partition as:
1. uboot will never clean the unknown cmd.
2. init will never overwrite the unknown cmd.
arm2_8q:/ # reboot bootloader
init: [libfs_mgr]fs_mgr_read_fstab_dt(): failed to read fstab from dt
init: reboot-bootloader: Error writing bootloader_message: Bootloader command pending.
init: Reboot start, reason: reboot,bootloader, rebootTarget: bootloader
Change-Id: I51043e7cbde3f3e508c5fe99e9dba27e5f99f443
Signed-off-by: guoyin.chen <guoyin.chen@nxp.com>
after softare reboot the first time. 40%
RTC timer is default disabled after power off and bootup again. it will be
enabled in kernel rtc driver init. But rtc time is shorter than system clock,
so rtc time cannot update to system clock in rtc_hctosys(), and the sysfs
file /sys/class/rtc/rtc0/hctosys cat result is 0. Android AlarmManagerService
cannot work normally when hctosys is 0.
Enable RTC in u-boot so the time in RTC timer is longer than system clock.
Change-Id: Ie8b1c1b36e5ab48031efe44dd06468ac35ca3d3b
Signed-off-by: Zhang Bo <bo.zhang@nxp.com>
It will be used by android init to load the init.imx8mq.rc
Change-Id: Id157cfe6952c9ccf4021d9098e25d9e9d545859f
When using ethernet DM driver, the recv interface has a change with non-DM
interface, that driver needs to set the packet pointer and provide it to upper
layer to process.
In fec driver, the fecmxc_recv functions does not handle the packet pointer parameter.
This may cause crash in upper layer processing because the packet pointer is not set.
This patch allocates a buffer for the packet pointer and free it through free_pkt interface.
Add SD/MMC legacy capability. Otherwise the legacy cards supports will
be broken.
The sw_info in handover structure has included the boot device info
provided by SC ROM. We can exploit this info, no need to check the
USB2 PHY PWD register.
We met u-boot hang when booting from eMMC fastboot on QM/QXP boards.
The hang happens on u-boot accessing USB2 PHY for checking USB boot.
The root cause is when putting AP image (u-boot-atf.bin) in first container,
the USB2 PHY reset bit won’t be set in CONN SS by SCFW, because this SS has been
powered on by SC ROM.
In normal boot case, we won't meet such issue. Because we put u-boot-atf.bin in second
container and AP ROM will boot up for loading this binary. When AP ROM completes the
loading, it calls “misc_boot_status” API to power off the boot device and also power
off the CONN SS. Then when u-boot enables any the module in CONN, the CONN SS will power
on again by SCFW and set the USB2 PHY reset bit.
Since the clock settings are different in SC ROM and SCFW, so it is suggested to power off
CONN SS when booting is completed. In this patch, we check the g_ap_mu field in pass over
structure which is used to pass into from SC ROM to AP ROM. This field is set only when AP
image is included in the second container. If this field is not set, we suppose the booting
only uses SC ROM, then u-boot calls "misc_boot_status" at early stage to power off
boot device.
unique id from ocopt
Correct fuse_bank0_regs structure to make bank register be match with fuse map.
Change-Id: I023c7d57b9fe1d57b0c2735f058714e9f25dca56
This memory region is for LSIO subsystem, including OCRAM, AP ROM,
flexspi0 mapped memory and flexspi1 buffer. If we set it to cachable,
the AHB read in flexspi driver will have coherence problem.
This patch set this memory region to strongly order to avoid any issue
in driver.
The MEK board has two display ports, we enable the LVDS0 as default display. User
needs to connect miniSAS LVDS to HDMI card on the CPU board and set "panel" env variable
to "IT6263" to enable the display.
Read the unique id directly from the ocopt register.
Change-Id: I6cfb246153812709ea98edd5b9a85aff4714a329
Met randomly switch fail (60%) on 8QXP ARM2 A1 board, when entering eMMC HS200 or SD SDR104 mode.
The failure happens on the first command (CMD55 for SD, CMD8 for eMMC) after the tuning process
is done. The failure error is CTOE (command timeout). Can't reproduce it on QXP MEK.
This patch addes a workaround to send CMD12 after tuning process is done. This helps to stop any
transmission that device may involve during tuning. The stress test is passed on QXP ARM A1 with
this workaround added.
Also this patch fixes a issue for tuning parameter "tuning_start_tap".
Sychronize the usdhc pad settings from kernel DTS file to
fix DSE setting problem. For dual voltage pads, only bits[0]
is defined for DSE.
0: high drive strength
1: low drive strength
Kernel commit: 7084cf02e6cc2c9fb7f474f6cc1ba8f8d00793c7
i.MX6/7 uses fdt_addr while all i.MX8/8M uses fdtaddr, this causes
the env is inconsistent for the autotest u-boot scripts. So rename
the fdtaddr to fdt_addr.
According to the MX6DL datasheet (IMX6SDLCEC Rev. 5, 06/2015)
"LDO Output Set Point (VDD_ARM_CAP) = 1.125 V minimum for operation
up to 396 MHz."
So change the VDD ARM to 1.15V (with 25mv margin).
Reviewed-by: Robin Gong <yibin.gong@nxp.com>
Fix uild warning below introduced by
commit: cb20ff23c83b80b4115c8a44ea436cb6b40429f1
drivers/gpio/pca953x_gpio.c: In function ‘pca953x_probe’:
drivers/gpio/pca953x_gpio.c:325:48: warning: passing argument 3 of
‘pca953x_write_regs’ from incompatible pointer type [-Wincompatible-pointer-types]
ret = pca953x_write_regs(dev, PCA953X_INVERT, &val);
drivers/gpio/pca953x_gpio.c:135:12: note: expected ‘u8 * {aka unsigned char *}’
but argument is of type ‘u8 (*)[5] {aka unsigned char (*)[5]}’
static int pca953x_write_regs(struct udevice *dev, int reg, u8 *val)
Current value of "off-on-delay-us" is 3500us for usdhc2 vmmc regulator,
this is measured value but not have margin added. We found QXP ARM2
RevA1 board can't work with this value. So increase it to 5000us with
1500us margin added.
enable CONFIG_CMD_FASTBOOT which support command:"fastboot 0"
enable CONFIG_FASTBOOT_FLASH wihch support commands:"fastboot flash XXX"
Change-Id: I514e2d5ea221a8551f4afa799fa5b48e4373fca4
Signed-off-by: zhang sanshan <sanshan.zhang@nxp.com>
Enable dwc3 controller driver and gadget mass storage drivers.
Signed-off-by: Li Jun <jun.li@nxp.com>
Add USB0(type-c) config and PHY init to enable device mode.
Some dwc3 based USB3 IP may have a wrong default suspend clk
setting, so add an interface to correct it by board setting.
We don't want to claim that we support a serial number string and
later return nothing. Because of that, if g_dnl_serial is an empty
string, let's skip setting iSerialNumber to a valid number.
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
(cherry picked from commit 842778a091047b0c868efa12229633959f711152)
Both these numbers are calculated in runtime and dynamically assigned
to the device descriptor during bind().
(cherry picked from commit 207835b13feeae15db0555574d89352a4e5379a4)
Merely using dma_alloc_coherent does not ensure that there is no stale
data left in the caches for the allocated DMA buffer (i.e. that the
affected cacheline may still be dirty).
The original code was doing the following (on AArch64, which
translates a 'flush' into a 'clean + invalidate'):
# during initialisation:
1. allocate buffers via memalign
=> buffers may still be modified (cached, dirty)
# during interrupt processing
2. clean + invalidate buffers
=> may commit stale data from a modified cacheline
3. read from buffers
This could lead to garbage info being written to buffers before
reading them during even-processing.
To make the event processing more robust, we use the following sequence
for the cache-maintenance:
(we only need the 'invalidate' part, but dwc3_flush_cache()
always performs a 'clean + invalidate')
3. read the buffers
(we know these lines are not cached, due to the previous
invalidation and no other code touching them in-between)
4. clean + invalidate buffers
=> writes back any modification we may have made during event
processing and ensures that the lines are not in the cache
the next time we enter interrupt processing
Note that with the original sequence, we observe reproducible
(depending on the cache state: i.e. running dhcp/usb start before will
upset caches to get us around this) issues in the event processing (a
fatal synchronous abort in dwc3_gadget_uboot_handle_interrupt on the
first time interrupt handling is invoked) when running USB mass
storage emulation on our RK3399-Q7 with data-caches on.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
(cherry picked from commit 889239d6b5c15c82d507498ded5e3b8fea2d44cf)
The dwc3_flush_cache() call was declared and used inconsistently:
* The declaration assumed 'int' for addresses (a potential issue
when running in a LP64 memory model).
* The invocation cast the address to 'long'.
This change ensures that both the declaration and usage of this
function consistently uses 'uintptr_t' for correct behaviour even
when the allocated buffers (to be flushed) reside outside of the
lower 32bits of memory.
(cherry picked from commit b7bf4a95922c3e1a4974aa34ebb714ac2eb89937)
Update uboot to the latest SCFW based on commit:
commit 129c16e312334af7b07d71d6dccac1cda1808b93
Author: Ranjani Vaidyanathan <ranjani.vaidyanathan@nxp.com>
Date: Thu Aug 24 16:50:59 2017 -0500
Add support to change DRC clock rate.
Signed-off-by: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@nxp.com>
Measured signal using oscilloscope.
Add startup delay and off-on-delay-us to make usdhc2 vmmc
supply work properly. Otherwise, the delay between power
off/on is short and power actully not off, then card report
S18A as 0 and could not switch voltage to 1.8V.
When booting for mfgtool, we need to disable DCSS and HDMI since the HDMI
firmware won't be loaded by mfgtool. Add the detect in u-boot and update the
DTB.
Update SoC codes, DTSi and defconfig to enable TMU for i.MX8M EVK board.
Also implement functions to get speed grade and market segment info from fuse.
