commit d196bd880347373237d73e0d115b4d51c68cf2ad adds
redundand environment to mmc. The usage of malloc in
env_relocate_spec triggers cache errors on armv7.
Tested on a not mainlined i.MX53 board:
Board: TQMa53
I2C: ready
DRAM: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
ERROR: v7_dcache_inval_range - start address is not aligned - 0x8f57c2d8
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8f57e2d8
ERROR: v7_dcache_inval_range - start address is not aligned - 0x8f57e2e0
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8f5802e0
Using default environment
Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de>
As the SPI controller is not initialized before env_init(), it causes
reading env in dataflash failed. So, although saveenv() successfully,
it shows warning information when reboot the system as following:
*** Warning - bad CRC, using default environment
Let the env_relocate() to check env CRC and import it.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
OMAP4 panda rev A6 is a 4430 es2.3 IC with an updated memory
part.
The panda rev A6 uses Elpida 2x4Gb memory and no longer uses Micron
so the timings needs to be updated
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
In [1] we discussed how we should deal with dual (or, more generally,
multiple) licensed files. Add this to Licenses/README so it's
properly documented.
[1] http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/166518
[trini: Add the word 'list' to the end of the line, per Stephen Warren's
feedback]
When a toolchain invocation fails, an exception is thrown but not caught
which then aborts the entire toolchain detection process. To solve this,
request that exceptions not be thrown, since the toolchain init code
already error-checks the command result. This solves e.g.:
- found '/usr/bin/winegcc'
Traceback (most recent call last):
Exception: Error running '/usr/bin/winegcc --version'
Change-Id: I579c72ab3b021e38b14132893c3375ea257c74f0
(formatted to 80cols)
The musb driver defines and uses MUSB_CSR0_H_DIS_PING, however this
bit is reserved on the DM36x. Thus this patch ensures that the
reserved bit is not accesssed.
It has been observed that some USB devices will fail to enumerate
with errors such as 'error in inquiry' without this patch.
See http://www.ti.com/litv/pdf/sprufh9a for details.
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Andrew Murray <amurray@embedded-bits.co.uk>
OMAP5 boards may have both eMMC (on MMC2) and an SD slot (on MMC1). We
Update the default bootcmd to match what happens on AM335x where we try
SD first, and then eMMC. In this case however, the hardware layout used
for powering both of these means that in the kernel eMMC shall be found
first as it is powered by a fixed regulator and SD found second as SD is
powered via the palmas which will result in deferred probing.
Tested-by: Aparna Balasubramanian <aparnab@ti.com>
This allows you to write data to an UBI volume when the amount of memory
available to write that data from is less than the total size of the
data. For example, you may split a root filesystem UBIFS image into
parts, provide the total size of the image to the first write.part
command and then use multiple write.part commands to write the
subsequent parts of the volume. This results in a sequence of commands
akin to:
ext4load mmc 0:1 0x80000000 rootfs.ubifs.0
ubi write.part 0x80000000 root 0x08000000 0x18000000
ext4load mmc 0:1 0x80000000 rootfs.ubifs.1
ext4load mmc 0:1 0x80000000 rootfs.ubifs.2
This would write 384MiB of data to the UBI volume 'root' whilst only
requiring 128MiB of said data to be held in memory at a time.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
int64_t matches the bytes field in struct ubi_mkvol_req to which the
size is assigned. With the prior signed 32 bit integer, volumes were
restricted to being less than 2GiB in size.
This matches the 64 bit size in struct mtd_info and allows the mtdparts
command to function correctly with a flash >= 4GiB. Format specifiers
for size & offset are given the ll length, matching its use in
drivers/mtd in absence of something like inttypes.h/PRIx64.
Linux modified the MTD driver interface in commit edbc4540 (with the
same name as this commit). The effect is that calls to mtd_read will
not return -EUCLEAN if the number of ECC-corrected bit errors is below
a certain threshold, which defaults to the strength of the ECC. This
allows -EUCLEAN to stop indicating "some bits were corrected" and begin
indicating "a large number of bits were corrected, the data held in
this region of flash may be lost soon". UBI makes use of this and when
-EUCLEAN is returned from mtd_read it will move data to another block
of flash. Without adopting this interface change UBI on U-boot attempts
to move data between blocks every time a single bit is corrected using
the ECC, which is a very common occurance on some devices.
For some devices where bit errors are common enough, UBI can get stuck
constantly moving data around because each block it attempts to use has
a single bit error. This condition is hit when wear_leveling_worker
attempts to move data from one PEB to another in response to an
-EUCLEAN/UBI_IO_BITFLIPS error. When this happens ubi_eba_copy_leb is
called to perform the data copy, and after the data is written it is
read back to check its validity. If that read returns UBI_IO_BITFLIPS
(in response to an MTD -EUCLEAN) then ubi_eba_copy_leb returns 1 to
wear_leveling worker, which then proceeds to schedule the destination
PEB for erasure. This leads to erase_worker running on the PEB, and
following a successful erase wear_leveling_worker is called which
begins this whole cycle all over again. The end result is that (without
UBI debug output enabled) the boot appears to simply hang whilst in
reality U-boot busily works away at destroying a block of the NAND
flash. Debug output from this situation:
UBI DBG: ensure_wear_leveling: schedule scrubbing
UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083
UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 1027
UBI DBG: ubi_io_read: read 4096 bytes from PEB 1027:4096
UBI DBG: ubi_eba_copy_leb: copy LEB 0:0, PEB 1027 to PEB 4083
UBI DBG: ubi_eba_copy_leb: read 1040384 bytes of data
UBI DBG: ubi_io_read: read 1040384 bytes from PEB 1027:8192
UBI: fixable bit-flip detected at PEB 1027
UBI DBG: ubi_io_write_vid_hdr: write VID header to PEB 4083
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:4096
UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 4083
UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:4096
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:8192
UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:8192
UBI: fixable bit-flip detected at PEB 4083
UBI DBG: schedule_erase: schedule erasure of PEB 4083, EC 55, torture 0
UBI DBG: erase_worker: erase PEB 4083 EC 55
UBI DBG: sync_erase: erase PEB 4083, old EC 55
UBI DBG: do_sync_erase: erase PEB 4083
UBI DBG: sync_erase: erased PEB 4083, new EC 56
UBI DBG: ubi_io_write_ec_hdr: write EC header to PEB 4083
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:0
This patch adopts the interface change as in Linux commit edbc4540 in
order to avoid such situations. Given that none of the drivers under
drivers/mtd return -EUCLEAN, this should only affect those using
software ECC. I have tested that it works on a board which is
currently out of tree, but which I hope to be able to begin
upstreaming soon.
'actual_bank' is not used anymore, instead boot_bank is used.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
This define is not used in u-boot code, we can drop this define safely.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
commit a5510058 powerpc/83xx/km: make local functions and structs static
removed the staticness also from this struct. But this struct is needed
in arch/powerpc/cpu/mpc83xx/cpu_init.c and declared as extern.
When we have CONFIG_SPI_FLASH set we now require CONFIG_CMD_SF.
mmcroot."
Upon further inspection and review and chatting with kernel folks, what
happens here is that what mmcblk# a device gets is based on probe order.
So a system with an SD card inserted with place eMMC on mmcblk1, but
without an SD card, it will be on mmcblk0. So U-boot can only provide a
best guess. In this case, if no SD card is present, we would want to
pass mmcblk0p2 still. If an SD card is present, it woudl be able to
provide a uEnv.txt that would be loaded (even if the kernel is NOT
there) which can still update mmcroot variable.
This reverts commit 827512fb1154c05c6eb1e2259e936df55c98a535.
Cc: Robert P. J. Day <rpjday@crashcourse.ca>
Since SPI register access is so expensive, it is worth transferring data
a word at a time if we can. This complicates the driver unfortunately.
Use the byte-swapping feature to avoid having to convert to/from big
endian in software.
This change increases speed from about 2MB/s to about 4.5MB/s.
Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Accessing SPI registers is slow, but access to the FIFO level register
in particular seems to be extraordinarily expensive (I measure up to
600ns). Perhaps it is required to synchronise with the SPI byte output
logic which might run at 1/8th of the 40MHz SPI speed (just a guess).
Reduce access to this register by filling up and emptying FIFOs
more completely, rather than just one word each time around the inner
loop.
Since the rxfifo value will now likely be much greater that what we read
before we fill the txfifo, we only fill the txfifo halfway. This is
because if the txfifo is empty, but the rxfifo has data in it, then writing
too much data to the txfifo may overflow the rxfifo as data arrives.
This speeds up SPI flash reading from about 1MB/s to about 2MB/s on snow.
For devices that need some time to react after a spi transaction
finishes, add the ability to set a delay.
Implement this as a delay on the first/next transaction to avoid
any delay in the fairly common case where a SPI transaction is
followed by other processing.
This function, if implemented by the board, provides a microsecond
timer. The granularity may be larger than 1us if hardware does not
support this.
As documented, almost all U-Boot commands expect numbers to be entered
in hexadecimal input format. (Exception: for historical reasons, the
"sleep" command takes its argument in decimal input format.)
This rule was broken for the "load" command; for details please see
especially commits 045fa1e "fs: add filesystem switch libary,
implement ls and fsload commands" and 3f83c87 "fs: fix number base
behaviour change in fatload/ext*load". In the result, the load
command would always require an explicit "0x" prefix for regular
(i. e. base 16 formatted) input.
Change this to use the standard notation of base 16 input format.
While strictly speaking this is a change of the user interface, we
hope that it will not cause trouble. Stephen Warren comments (see
[1]):
I suppose you can change the behaviour if you want; anyone
writing "0x..." for their values presumably won't be
affected, and if people really do assume all values in U-Boot
are in hex, presumably nobody currently relies upon using
non-prefixed values with the generic load command, since it
doesn't work like that right now.
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/171172
Acked-by: Tom Rini <trini@ti.com>
Adding the generated pin mux configuration by Preloader
Generator tool
Signed-off-by: Chin Liang See <clsee@altera.com>
Reviewed-by: Pavel Machek <pavel@denx.de>
Acked-by: Dinh Nguyen <dinguyen@altera.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Adding System Manager driver which will configure the
pin mux for real hardware Cyclone V development kit
(not Virtual Platform)
omap1510inn is orphan and has been for years now.
Reove it and, as it was the only arm925t target,
also remove arm925t support.
Update doc/README.scrapyard accordingly.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Updated SPI/status.txt, with memory_map and TODO.
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
There is no page_size for ramtron flashes,
so just print the detected flash and it's size.
- Add spaces, tabs
- Commenting.
- Rearrange code.
- Add static qualifier for missing func.
- Remove memory_map from ramtron.c
- Ramtron: spi_flash_internal.h -> sf_internal.h
Contains documentation and testing details for qspi flash
interface.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Enables support for SPI SPL, QSPI and Spansion serial flash device
on the EVM. Configures pin muxes for QSPI mode.
Signed-off-by: Matt Porter <matt.porter@linaro.org>
Adds a SPI master driver for the TI QSPI peripheral.
- Added quad read support.
- Added memory mapped support.
Qspi controller can have a memory mapped port which can be used for
data read. Added support to enable memory mapped port read.
This patch enables the following:
- It enables exchange of memory map address between mtd and qspi
through the introduction of "memory_map" flag.
- Add support to communicate to the driver that memory mapped
transfer is to be started through introduction of new flags like
"SPI_XFER_MEM_MAP" and "SPI_XFER_MEM_MAP_END".
This will enable the spi controller to do memory mapped configurations
if required.
Clock requirement for qspi clk is 192 Mhz.
According to the below formulae,
f dpll = f ref * 2 * m /(n + 1)
clockoutx2_Hmn = f dpll / (hmn+ 1)
fref = 20 Mhz, m = 96, n = 4 gives f dpll = 768 Mhz
For clockoutx2_Hmn to be 768, hmn + 1 should be 4.
Add QSPI definitions and clock configuration support.
Add support for EON EN25S64 SPI flash.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
doc/SPI/status.txt added to track the u-boot SPI subsystem status.
Renamed:
spi_flash.c -> sf.c
spi_flash_ops.c -> sf_ops.c
spi_flash_probe.c -> sf_probe.c
- Rearranged multi-line comment style.
- Add tabs.
- Add spaces.
More cleanups on spi_flash side:
- Removed unneeded comments.
- Rearranged macros in proper location.
- Rearranged func declerations
- Renamed few function names.
- Added License headers.
Added a support for common probe, hence removed removed
spi_flash_do_alloc reference.
Add support for Macronix MX25L51235F SPI flash.
Add support for Macronix MX25L25635F SPI flash.
