2014-03-07colibri_vf: add vidargsColibri_VF_LinuxImageV2.1Beta3_20140318colibri_vfMarcel Ziswiler
Add default VESA VGA vidargs for our now modedb enabled kernel. This allows easy specifying an alternate parallel RGB resolution. While at it further checkpatchify our board file.
2013-11-21colibri_vf: fix build warningColibri_VF_LinuxImageV2.1Beta2_201311292011.12-colibri_vfMarcel Ziswiler
Add an explicit cast to avoid the following build warning: colibri_vf.c:225:23: warning: initialization makes pointer from integer without a cast [enabled by default]
2013-11-21colibri_vf: rename colibri_vf61 to colibri_vfMarcel Ziswiler
Now as the colibri_vf61 configuration supports memory size as well as module type auto detection actually rename it to colibri_vf to be universally used for Colibri VF50 as well as VF61.
2013-11-20colibri_vf: implement module type auto detectionMarcel Ziswiler
Implement module type (e.g. VF50 vs. VF61) auto detection based on L2 cache availability. Set specific ARM core clock (e.g. 400 vs. 500 MHz) as well as Linux machine id number. While at it actually use memargs instead of hard-coded mem= value. While at it fix sdboot command if initially booting U-Boot from NAND by doing an explicit mmc part 0.
2013-11-20colibri_vf: implement memory size auto detectionMarcel Ziswiler
Implement memory size auto detection including memargs generation analogous to how it was done for Apalis/Colibri T20/T30. While at it make our board file checkpatch compliant.
2013-10-24colibri_vf61: initial integrationMarcel Ziswiler
Add initial Colibri VF61 support based off Timesys' implementation for Freescale's Vybrid Tower System TWR-VF65GS10: - New machine ID. - Default UART_A on SCI0. - ESDHC2 only. - 8-bit NAND. - No quad SPI. - FEC1 only. - Enabled command line editing. - PLL5 based RMII clocking (e.g. no external crystal). - UART_A, UART_B and UART_C I/O muxing. - Increase the available space for the U-Boot binary to half a megabyte by booting from gfxRAM rather than sysRAM0. - Integrate factory configuration block handling for hardware version, MAC address and serial number to be passed to Linux. - The U-Boot environment is stored in NAND flash. - Fix long standing boot hang issue introduced by Freescale's Vybrid 1.1 silicon. - Proper 256 MB Nanya DDR3 RAM timings. Tested on early Colibri VF61 prototypes V1.0b and V1.0c using SD card (mandatory for initial loading) as well as NAND boot.
2013-10-05colibri_vf50: fix boot hang issueColibri_VF50_LinuxImageV2.1Beta1_20131022Marcel Ziswiler
Fix long standing boot hang issue introduced by Freescale's Vybrid 1.1 silicon. https://community.freescale.com/message/336513#336513 Correct Answer by Ioseph Martinez Pelayo on Jul 17, 2013 5:33 PM For the record: DDRMC_CR154 needs to be 0x682C0000 before was: 0x68200000 There was a change from Si 1.0 to 1.1. So this only affects Si 1.1 and this version requires writing this value to the register.
2013-10-05Revert "colibri_vf50: hack to avoid boot hang issue"Marcel Ziswiler
This reverts commit 9629454003a2f85dcff4410e4b56d27e1bde0dd0.
2013-10-04colibri_vf50: fix env offset re-definition warningMarcel Ziswiler
Fix the following build-time warning: u-boot-toradex.git/include/configs/colibri_vf50_sdboot.h:54:0: warning: "CONFIG_ENV_OFFSET" redefined [enabled by default]
2013-10-03colibri_vf50: fix further issue in HCD conversionMarcel Ziswiler
Fix possible uninitialised array member issue in serial number to hexadecimal coded decimal conversion routine.
2013-10-03colibri_vf50: migrate nand vs. sdboot configurationMarcel Ziswiler
Migrate to default NAND boot configuration (e.g. colibri_vf50_config) and SD card boot on request (e.g. colibri_vf50_sdboot_config). Automatically do the padding required for NAND boot image (e.g. u-boot.nand). This is also more in-line with how we did stuff back on the Colibri T20.
2013-09-27colibri_vf50: hack to avoid boot hang issueMarcel Ziswiler
Hack to avoid boot hang issue by just resetting for now if wrong memory size is detected.
2013-09-24colibri_vf50: integrate config block handlingMarcel Ziswiler
Integrate factory configuration block handling for hardware version, MAC address and serial number to be passed to Linux. The U-Boot environment is stored in NAND flash. Default is to boot out of NAND flash using the UBI abstraction. Optional NFS as well as MMC/SD boot variants are also available. This brings the configuration more in-line with our Tegra based versions. While at it enable board size limit check set to 512 KB related to the gfxRAM area of the OCRAM. Please note that a boot delay of zero did not quite work the same way as on the Tegras where one was still able to interrupt the boot process by continuously hitting a key. Therefore set it to one second for now.
2013-09-20colibri_vf50: increase available space by booting from gfxramMarcel Ziswiler
Increase the available space for the U-Boot binary to half a megabyte by booting from gfxRAM rather than sysRAM0. Please note that according to the Vybrid Reference Manual the bigger lower part of the sysRAM1 which immediately follows sysRAM0 should be available as well but testing showed that as soon as the U-Boot binary got bigger than 256 KB booting failed.
2013-09-20colibri_vf50: fix esdhc compile time warningMarcel Ziswiler
Fix the following compile time warning: colibri_vf50.c:392:32: warning: ‘index’ is used uninitialized in this function [-Wuninitialized]
2013-09-09colibri_vf50: initial integrationMarcel Ziswiler
Add initial Colibri VF50 support based off Timesys' implementation for Freescale's Vybrid Tower System TWR-VF65GS10: - New machine ID. - Default UART_A on SCI0. - ESDHC2 only. - 8-bit NAND. - No quad SPI. - FEC1 only. - Enabled command line editing. - PLL5 based RMII clocking (e.g. no external crystal). - UART_A, UART_B and UART_C I/O muxing. Tested on early Colibri VF50 prototypes V1.0a using SD card (mandatory for initial loading) as well as NAND boot.
2013-09-09net: mcffec: add support for FEC1 only operationMarcel Ziswiler
Add support for FEC1 only operation in case FEC0 is not used at all.
2013-09-09mtd/nand: fsl_nfc: add option for 8-bit wide bus widthMarcel Ziswiler
Add configuration option CONFIG_NAND_FSL_NFC_8BIT to be able to specify narrow 8-bit wide bus width in connecting NAND chips.
2013-09-08NAND Boot:Dan Douglass
- nb_update tool in fsl_nfc driver rewritten to write FCB, BBT, and image to NAND. - vybrid_nand board config added. - NAND read commands added to DCD that force NFC controller to read NAND page twice to prevent NFC hang.
2012-12-19vybrid: Fix hardware clock drift2011.12-mvf-201212191113Justin Waters
We must enable the external 32kHz oscillator in order to work around a known clock drift issue with the internal 32kHz oscillator. This fixes the Linux kernel system clock drift. Signed-off-by: Anthony Huereca <B04178@freescale.com> Signed-off-by: Jiri Kotzian <B36968@freescale.com> Signed-off-by: Justin Waters <justin.waters@timesys.com>
2012-09-07ENGR00219758: Enable the softecc for Vybrid NFC controllerJason Jin
When enable the hardware ecc in kernel, there are crc errors for JFFS2 filesystem after write to the filesystem. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-07Add NFC support for faraday boardJason Jin
2012-09-07Add quad SPI support for VybridJingchang Lu
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2012-09-07Add Vybrid tower board VF600 initializationJingchang Lu
Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-07Add eSDHC support for Vybrid platformJingchang Lu
On some platform, such as vybrid, there is no scr register, but the dis-order excution may wrongly excute the register write. The barrier used to prevent this. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-07Add Vybrid ENET supportJason Jin
2012-09-07Add UART console support for Vybrid platformJingchang Lu
2012-09-07Add GPIO support for Vybrid platformJingchang Lu
2012-09-07Add arch support for Vybrid platformJingchang Lu
2012-03-21cfi: fix the incomplete erased status check in buffer writeTao Hou
Without the fix, flash_write_cfibuffer will terminate the erased status check once an all-0xFF word has been found instead of continuing the erased status check utill the first non-0xFF word. Signed-off-by: Tao Hou <hotforest@gmail.com> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-03-19Armada100: gplugD: Add FAT & EXT2 command supportAjay Bhargav
This patch adds FAT and ext2 command support for marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19Armada100: gplugD: Add USB command supportAjay Bhargav
This patch adds support for USB commands and USB storage device for Marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19USB: Armada100: EHCI Driver for Armada100 SOCsAjay Bhargav
This patch adds support for USB EHCI driver for Armada100 SOCs. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19USB: Armada100: Add UTMI PHY interface driverAjay Bhargav
This patch adds USB host controller's UTMI PHY interface driver for Armada100 SOCs. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19git-mailrc: change usb maintainer to MarekMike Frysinger
2012-03-19usb:udc:samsung:fix Remove the req_config flagŁukasz Majewski
The dev->req_config flag was indicating that the forwarded request needs to perform the usb gadget delayed status. This is however not needed anymore, so it can be removed. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2012-03-19USB:gadget:designware Fix memory nonalignment issueShiraz Hashim
While receiving packets from FIFO sometimes the buffer provided was nonaligned. Fix this by taking a temporary aligned buffer and then copying the content to nonaligned buffer. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-03-19USB:gadget:designware Make locally used functions staticAmit Virdi
2012-03-19USB:gadget:designware Support high speedVipin KUMAR
This patch adds the support for usb device high speed for designware peripheral. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-03-19USB:gadget:designware Device controller bugfixesVipin KUMAR
This patch fixes a few bugs in USB device controller driver. The fixes are as follows 1. Adding error condition checks eg. NULL return 2. Endpoint other than endpoint 0 (control endpoint) are initialized only if usb state machine reaches STATE_ADDRESSED or above 3. Zero length packet handling corrected 4. Dead code removed 5. Bulk out endpoint returns after servicing 1 interrupt and returns back to service if more interrupts are pending Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Marek Vasut <marex@denx.de>
2012-03-19USB:gadget:designware USB device controller (UDC) implementationVipin KUMAR
The earlier usb device controller driver was specific to spear platforms. This patch implements the usb device controller driver as a generic controller which can be reused by other platforms using this peripheral. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Marek Vasut <marex@denx.de>
2012-03-19usb: replace wait_ms() with mdelay()Mike Frysinger
Common code has a mdelay() func, so use that instead of the usb-specific wait_ms() func. This also fixes the build errors: ohci-hcd.c: In function 'submit_common_msg': /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1519:9: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1816:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1827:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1844:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1563:11: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1583:9: sorry, unimplemented: called from here make[1]: *** [ohci-hcd.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marex@denx.de>
2012-03-19usb: musb: fix printf warningMike Frysinger
musb_hcd.c: In function 'musb_submit_rh_msg': musb_hcd.c:827:2: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18bootstage: arm: Add bootstage calls in board and bootmSimon Glass
Add calls to bootstage before and after relocation, and just before jumping to the OS. The idea here is you can call bootstage_report() to get a report. Additionally, if you define CONFIG_BOOTSTAGE_REPORT then a report is printed automatically by U-Boot just before jumping to the kernel. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Plumb in bootstage calls for basic operationsSimon Glass
This inserts bootstage calls into tftp, usb start and bootm. We could go further, but this is a reasonable start to illustrate the concept. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Implement core microsecond boot time measurementSimon Glass
This defines the basics of a new boot time measurement feature. This allows logging of very accurate time measurements as the boot proceeds, by using an available microsecond counter. To enable the feature, define CONFIG_BOOTSTAGE in your board config file. Also available is CONFIG_BOOTSTAGE_REPORT which will cause a report to be printed just before handing off to the OS. Most IDs are not named at this stage. For that I would first like to renumber them all. Timer summary in microseconds: Mark Elapsed Stage 0 0 reset 205,000 205,000 board_init_f 6,053,000 5,848,000 bootm_start 6,053,000 0 id=1 6,058,000 5,000 id=101 6,058,000 0 id=100 6,061,000 3,000 id=103 6,064,000 3,000 id=104 6,093,000 29,000 id=107 6,093,000 0 id=106 6,093,000 0 id=105 6,093,000 0 id=108 7,089,000 996,000 id=7 7,089,000 0 id=15 7,089,000 0 id=8 7,097,000 8,000 start_kernel Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Define an optional microsecond timerSimon Glass
Define timer_get_boot_us() which returns the number of microseconds since boot. If undefined then we use get_timer() * 1000. We can fit this in a 32-bit register which keeps everyone happy on the efficiency side. It will wrap around after about an hour. If we are still looking at it after an hour then we had better not be timing the boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Convert FIT progress numbers to enumsSimon Glass
This changes over all the FIT image progress numbers to use enums from bootstage.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Convert net progress numbers to enumsSimon Glass
This changes over the network-related progress numbers to use enums from bootstage.h. Signed-off-by: Simon Glass <sjg@chromium.org>
