Release version 1.0.2
* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
modules at CPU clock frequencies above 66 MHz.
* Optimize flash programming speed for LWMON (by another 100% :-)
- Changed the incorrect FAT12BUFSIZE
- data_begin in fsdata can be negative. Changed it to be short.
* Code cleanup
1: - board/altera/common/flash.c:flash_erase():
o allow interrupts befor get_timer() call
o check-up each erased sector and avoid unexpected timeouts
- board/altera/dk1c20/dk1s10.c:board_early_init_f():
o enclose sevenseg_set() in cpp condition
- remove the ASMI configuration for DK1S10_standard_32 (never present)
- fix some typed in mistakes in the NIOS documentation
2: - split DK1C20 configuration into several header files:
o two new files for each NIOS CPU description
o U-Boot related part is remaining in DK1C20.h
3: - split DK1S10 configuration into several header files:
o U-Boot related part is remaining in DK1S10.h
4: - Add support for the Microtronix Linux Development Kit
NIOS CPU configuration at the Altera Nios Development Kit,
Stratix Edition (DK-1S10)
5: - Add documentation for the Altera Nios Development Kit,
6: - Add support for the Nios Serial Peripharel Interface (SPI)
(master only)
7: - Add support for the common U-Boot SPI framework at
RTC driver DS1306
Fix flash protection/locking handling for OMAP1610 innovator board.
* Patch by Rolf Peukert, 28 Jan 2004:
fix flash write problems on CSB226 board (write with 32 bit bus width)
* Patches by Mark Jonas, 16 Jan 2004:
- fix rounding error when calculating baudrates for MPC5200 PSCs
- make sure CFG_RAMBOOT and CFG_LOWBOOT are not enabled at the same
time which is not supported
Allow bzip2 compression for small memory footprint boards
* Patch by Brad Kemp, 21 Jan 2004:
Add support for CFI flash driver for both the Intel and the AMD
command sets.
* Patch by Travis Sawyer, 20 Jan 2004:
Fix pci bridge auto enumeration of sibling p2p bridges.
* Patch by Tolunay Orkun, 12 Jan 2004:
Add some delays as needed for Intel LXT971A PHY support
* Patches by Stephan Linz, 09 Jan 2004:
- avoid warning: unused variable `piop' in board/altera/common/sevenseg.c
- make DK1C20 board configuration related to ASMI conform to
documentation
ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
Fix Intel 28F128J3 ID in include/flash.h
* Patch by Masami Komiya, 09 Jan 2004:
add support for TB0229 board (NEC VR4131 MIPS processor)
* Patch by Leon Kukovec, 12 Dec 2003:
changed extern __inline__ into static __inline__ in
include/linux/byteorder/swab.h
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
made CONFIG_SILENT_CONSOLE usable on all architectures
* Disable date command on TQM866M - there is no RTC on MPC866
clock frequency for INCA-IP; fix problem with board hanging when
switching from 150MHz to 100MHz
* Add PCMCIA CS support for BMS2003 board
see doc/README.MPC866 for details;
implement workaround for "SIU4" and "SIU9" silicon bugs on MPC866;
calculate CPU clock frequency from PLL register values.
* Add support for 128 MB RAM on TQM8xxL/M modules
pointing to a location in flash
* Fix INCA-IP clock calculation: 400/3 = 133.3 MHz, not 130.
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
fix problem with PARTNUM detection
version of the repository???]
* Patch by Reinhard Meyer, 09 Jan 2004:
- add RTC support for MPC5200 based boards (requires RTC_XTAL)
* Add support for IDE LED on BMS2003 board
(exclusive with status LED!)
* Add support for PS/2 keyboard (used with PS/2 multiplexor on
BMS2003 board)
* Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004:
Add common files for "emk" boards
Prepare for 1.0.1 release
add I2C support; add support for DS1337 RTC
* Add CompactFlash support for BMS2003 board
* Add support for status LED on BMS2003 board
* Patch by Scott McNutt, 02 Jan 2004:
Add support for the Nios Active Serial Memory Interface (ASMI)
on Cyclone devices
* Patch by Andrea Marson, 16 Dec 2003:
Add support for the PPChameleon ME and HI modules
* Patch by Yuli Barcohen, 22 Dec 2003:
Add support for Motorola DUET ADS board (MPC87x/88x)
add support for cramfs (uses JFFS2 command interface)
- more documentation for NIOS port
- new struct nios_pio_t, struct nios_spi_t
- Reconfiguration for NIOS Development Kit DK1C20:
o move board related code from board/dk1c20
to board/altera/dk1c20
o create a new common source path board/altera/common
and move generic flash access stuff into it
o change/expand configuration file DK1C20.h
- Add support for NIOS Development Kit DK1S10
- Add status LED support for NIOS systems
- Add dual 7-segment LED support for Altera NIOS DevKits
Add support for the Marvell DB64360 / DB64460 development boards
* Patch by Detlev Zundel, 10 Dec 2003:
fix dependency problem in examples/Makefile
- add support for the PATI board (MPC555)
- add SPI support for the MPC5xx
* Patch by Anders Larsen, 08 Dec 2003:
add configuration options CONFIG_SERIAL_TAG and CONFIG_REVISION_TAG
to pass ATAG_SERIAL and ATAG_REVISION, resp., to the ARM target;
cleanup some redundand #defines
fixes for Davicom DM9102A Ethernet Chip (#define CONFIG_TULIP_FIX_DAVICOM):
- TX and RX deskriptors must be quad-word aligned
- does not work with only one TX deskriptor
- standard reset method does not work
* Patch by Masami Komiya, 08 Dec 2003:
add RTL8139 ethernet driver
* Patches by Ed Okerson, 07 Dec 2003:
- fix ethernet for the AU1x00 processors in little-endian mode.
- extend memsetup.S for the AU1x00 processors in BE and LE modes
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
Add initial support for TOP5200 board
environment variable which can set to "100", "133", or "150". The
CPU clock will be configured accordingly upon next reboot. Other
values are ignored. In case of an invalid or undefined "cpuclk"
value, the compile-time default CPU clock speed will be used.
* Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory
window that is used to access the UART registers by the Linux driver)
* Patch by Reinhard Meyer, 20 Dec 2003:
Fix clock calculation for the MPC5200 for higher clock frequencies
(above 2**32 / 10 = 429.5 MHz).
* Add new configuration for IceCube board with DDR memory
* Update TRAB memory configurations
add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
- add a return value for the fpga command
- add ide_preinit() function called in ide_init if CONFIG_IDE_PREINIT
is defined. If ide_preinit fails, ide_init is aborted.
- fix an endianess problem in fat.h
Add support for SNMC's QS850/QS823/QS860T boards
"revive" U-Boot support for old Motorola MPC860ADS board
* Patch by Cam(ilo?), 03 Dec 2003:
make examples build even with broken Montavista objcopy
* Patch by Pavel Bartusek, 27 Nov 2003:
fix conversion problem with "bootretry" evironment variable
add support for mvblue (mvBlueLYNX and mvBlueBOX) boards
* Patch by Pavel Bartusek, 21 Nov 2003:
set ZMII bridge speed on 440
* Patch by Anders Larsen, 17 Nov 2003:
Fix mismatched #ifdef / #endif in include/asm-arm/arch-pxa/hardware.h
- board/mpl/common/common_util.c
* implement support for BZIP2 compressed images
* various cleanups (printf -> puts, ...)
- board/mpl/common/flash.c
* report correct errors to upper layers
* check the erase fail and VPP low bits in status reg
- board/mpl/vcma9/cmd_vcma9.c
- board/mpl/vcma9/flash.c
- common/cmd_usb.c
* fix typo in comment
- cpu/arm920t/usb_ohci.c
* support for S3C2410 is missing in #if line
- drivers/cs8900.c
* reinit some registers in case of error (cable missing, ...)
- fs/fat/fat.c
* support for USB/MMC devices is missing in #if line
- include/configs/MIP405.h
- include/configs/PIP405.h
* enable BZIP2 support
* enlarge malloc space to 1MiB because of BZIP2 support
- include/configs/VCMA9.h
* enable USB support
- lib_arm/armlinux.c
* change calling convention of ARM Linux kernel as
described on http://www.arm.linux.org.uk/developer/booting.php
* Patch by Thomas Lange, 14 Nov 2003:
Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to
support all these AMD boards.
Workaround for mips au1x00 physical memory accesses (the au1x00
uses a 36 bit bus internally and cannot access physical memory
directly. Use the uncached SDRAM address instead of the physical
one.)
