2012-08-22Initial Toradex Colibri T20 L4T R15 support.T20_LinuxImageV2.0Alpha1_20120808Marcel Ziswiler
2012-03-29Make u-boot recognize full range of PPT LPC controllersVadim Bendebury
The full range of LPC controllers should be accepted by u-boot when looking for the SPI controller. The values come from Intel's Panther_Point_EDS_v072.pdf (document #472178). BUG=chrome-os-partner:7734 TEST=manual . program the new image on the target . reboot it and observe coming up to ChromeOS login screen Change-Id: Id8f7068c3b48885f868a1f30e7927e678d2154b6 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/19147 Reviewed-by: Jon Salz <jsalz@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/19310 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2012-03-21Increase size of MRC cache on LinkStefan Reinauer
Link's MRC produces significantly more training data than the one used on Stumpy/Lumpy. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> BUG=none TEST=boot tested on Link Change-Id: I9310c3bcc77fb4318db0635b97b115ab0eb7e5ec Reviewed-on: https://gerrit.chromium.org/gerrit/18748 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2012-03-20spi: Atmel: Add support for AT25DFTom Warren
Cardhu boards can use Atmel and Winbond SPI flash parts - support both in one binary. BUG=chromium-os:23496 TEST=build all OK, test on Cardhu. 'sf probe 0' returns: SF: Detected AT25DF321A with page size 256, total 4 MiB. sf read/write/erase all work OK. Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I7df3abb030a49b572e1172ca77227cd4d63e0c21 Reviewed-on: https://gerrit.chromium.org/gerrit/18539 Reviewed-by: Mike Frysinger <vapier@chromium.org>
2012-03-19x86: Make RW unused section labels uniqueDuncan Laurie
BUG=none TEST=check fmap on generated binary for unique names Change-Id: Id1ac5cf223ec6a333fc8f4c587e972afd087f90d Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/18435 Reviewed-by: Stefan Reinauer <reinauer@google.com>
2012-03-16Reduce RW BIOS data sections to 512K from 976KDuncan Laurie
This saves 500ms in the RW BIOS path and still leaves 130K overhead from the current U-boot size (372K) which should be more than enough for any future updates on stumpy/lumpy. This should be re-visited if/when vboot is smart enough to just read+validate the actual binary within the section. BUG=chrome-os-partner:8518 TEST=boot lumpy/stumpy through RW BIOS path and gather timestamps to see 500ms improvement. Change-Id: Ia714b4b95245f02f6e781247f820ca915bb403f5 Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/18372 Reviewed-by: Stefan Reinauer <reinauer@google.com>
2012-03-16Remove code that disabled cache in _x86boot_startDuncan Laurie
When U-boot is loaded via verified boot it starts at the _x86boot_start entry point and promptly disables caching, resulting in about a 500ms hit to boot time. BUG=chrome-os-partner:8518 TEST=boot on lumpy with RW BIOS and gather timestamps to observe 500ms less time spent in u-boot init. Change-Id: I4eb1ad5ebcb20a156fef77452030e47a5e510115 Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/18371 Reviewed-by: Stefan Reinauer <reinauer@google.com>
2012-03-15Use keyboard controller for hard reset instead of CF9Vadim Bendebury
For some still unknown reason writes to localtion 0xcf9 do not cause the Link to reboot, they cause it to shut down instead. While this will have to be investigated and fixed, this change modifies the code to use the keyboard controller (implemented by the EC on Link) to restart the system. Once the 0xcf9 problem is resolved, this change could be reverted. BUG=chrome-os-partner:8397 TEST=manual . when u-boot tires restarting the system it now reboots. before this change it would just shut down. Change-Id: I8076f897304f705e20ec8f2e30cce17d7fdd31c4 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/18332 Reviewed-by: Hung-Te Lin <hungte@chromium.org>
2012-03-15gen: Get disk/part_dos.c to compile when CONFIG_SYS_64BIT_LBA is turned onGabe Black
The code in this file tries to print an LBA using the format specifier "%10ld", but when CONFIG_SYS_64BIT_LBA is turned on, the argument passed in this position is a 64 bit value and isn't compatible. This change selects the appropriate format specifier, the original or "10lld", based on whether CONFIG_SYS_64BIT_LBA is turned on. BUG=chrome-os-partner:8180 TEST=Built for Stumpy with BUILD_PART_FS_STUFF turned on and CONFIG_SYS_64BIT_LBA enabled and disable, and saw the compile errors go away. Change-Id: Ib80b1567ce07673aea2b47dfba9b3526b32f9de5 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/18219 Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
2012-03-15arm: Tegra3: pass board id through the dts filesVarun Wadekar
BUG=chromium-os:23496 TEST=build on Waluigi, Seaboard, Cardhu Change-Id: I9ccd3085fb551e9887815592e9b518b6944beda7 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14474 Reviewed-by: Simon Glass <sjg@chromium.org>
2012-03-14gen: Make the AHCI code find the capacity of disks > 128 GB properlyGabe Black
In the structure returned by the ATA identify device command, there are two fields which describe the device capacity. One is a 32 bit data type which reports the number of sectors as a 28 bit LBA, and the other is a 64 bit data type which is for a 48 bit LBA. If the device doesn't support 48 bit LBAs, the small value is the only value with the correct size. If it supports more, if the number of sectors is small enough to fit into 28 bits, both fields reflect the correct value. If it's too large, the smaller field has 28 bits of 1s, 0xfffffff, and the other field has the correct value. The AHCI driver is implemented by attaching to the generic SCSI code and translating on the fly between SCSI binary data structures and AHCI data structures. It responds to requests to execute specific SCSI commands by executing the equivalent AHCI commands and then crafting a response which matches what a SCSI disk would send. The AHCI driver now considers both fields and chooses the correct one when implementing both the SCSI READ CAPACITY (10) and READ CAPACITY (16) commands. BUG=chrome-os-partner:8180 TEST=Built and booted to ChromeOS with this code on a CRB with a 250 GB drive and a Stumpy with a 16 GB drive. Checked the serial output to make sure U-Boot reported the correct size. Forced the READ CAPACITY (10) command to saturate so that the READ CAPACITY (16) command would be used and verified that that also booted correctly on a CRB. Change-Id: I31b662498f4c9657d70bb90400032c83e9d9c8da Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/18061 Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
2012-03-13gen: Make the SCSI command aware of READ CAPACITY (16) and how to use itGabe Black
The generic SCSI code in U-Boot was only aware of the READ CAPACITY (10) SCSI command which can detect the size of disks up to 2TB in size. If that size is exceeded, it should then try the READ CAPACITY (16) command which returns a 64 bit block count value. BUG=chrome-os-partner:8180 TEST=In conjunction with the next change, built and booted into ChromeOS on the Emerald Lake 2 CRB with a 250 GB SSD. Did the same but forced the READ CAPACITY (10) command to saturate and the code to fall back to READ CAPACITY (16). Note that this code has not be tested with a real SCSI disk, just the AHCI code pretending to be a SCSI disk as it historically has. Change-Id: Ia0ee3fa1264649f25065658d5d368101d39ce614 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/18060 Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
2012-03-13x86: config: Turn on the CONFIG_SYS_64BIT_LBA option for corebootGabe Black
BUG=chrome-os-partner:8180 TEST=Built and booted on emeraldlake2 and Stumpy. Change-Id: If14ff4930015fae36d421fd30ab5bd126c464db9 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/18059 Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
2012-03-13gen: Make the SCSI and USB drivers compile with the CONFIG_SYS_64BIT_LBA optionGabe Black
These drivers wouldn't compile when the CONFIG_SYS_64BIT_LBA option is turned on because the used fixed size data types in their exported functions when they should have used lbaint_t for the block count parameter. That meant that when the sizes happened to be the same, when using a 28 bit LBA, the driver would build, but when it wasn't, a 48 bit LBA, things broke. This change adjusts the signatures to use the right type and makes small adjustments in the affected functions. BUG=chrome-os-partner:8180 TEST=Built for emeraldlake2 with the CONFIG_SYS_64BIT_LBA option enabled and saw its compile errors go away. Change-Id: I7443b5976d3d06b82070344011fba46a28bd77de Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/18058 Reviewed-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com>
2012-03-13x86: Add an emeraldlake2 device treeGabe Black
BUG=chrome-os-partner:8180 TEST=Built u-boot for emeraldlake2. Change-Id: Iae62f047ddc102fbf530e1f8f9af34939971a6a3 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/18057 Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2012-03-08tegra: Remove keyboard support from fdtSimon Glass
This uses a format which is not supported by the upstream dtc, so remove this. BUG=chromium-os:23249 TEST=emerge-tegra2_kaen chromeos-u-boot with new dtc Signed-off-by: Simon Glass <sjg@chromium.org> Change-Id: I18b9420dbee20c2d115cc5ff1b13425faffe2a3e Reviewed-on: https://gerrit.chromium.org/gerrit/17630
2012-02-28Print firmware version in tab screenStefan Reinauer
In bug reports with screen shots of the firmware screens with tab pressed, it would be extremely useful to see the version of the currently running firmware and the read-only firmware, so output this information. BUG=none TEST=press TAB at dev screen, see firmware versions printed on the screen. Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: If91d4b1da8a7f69ff797b0b00c507248139601cd Reviewed-on: https://gerrit.chromium.org/gerrit/17002 Tested-by: Stefan Reinauer <reinauer@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Randall Spangler <rspangler@chromium.org>
2012-02-28Don't ever return from cold_reboot() functionStefan Reinauer
cold_reboot() should wait until the reset kicks in, instead of returning and continuing in an undefined code path. Without this patch, vboot_twostop will return, and secure_boot() will start printing an error message, which results in a sporadic # on the screen when pressing space or ESC on the dev screen in order to go to recovery mode. BUG=chrome-os-partner:7683 TEST=boot to dev screen on lumpy, press ESC or space. Observe there is no # character printed before going to recovery mode. Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Ic2ee570032686e48603f0fb3b1ec9cbfae9451bc Reviewed-on: https://gerrit.chromium.org/gerrit/17007 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
2012-02-27Add flag fast-developer-mode to make default developer mode time on x86 2sStefan Reinauer
This will trigger setting gbb.flags to 1 in cros_bundle_firmware so the factory time is reduced. GBB.flags will be changed in the factory process. Also needs https://gerrit.chromium.org/gerrit/#change,16845 BUG=chrome-os-partner:7671 TEST=manual emerge-stumpy chromeos-bootimage gbb_utility -g --flags /build/stumpy/firmware/image.bin Should report "flags: 0x00000001" Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Ie05433ad737005bd5dcca2f88232b0a5bbd00df9 Reviewed-on: https://gerrit.chromium.org/gerrit/16113 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
2012-02-27tegra: configs: enable warm boot on CardhuVarun Wadekar
enable CONFIG_TEGRA_LP0 and CONFIG_TEGRA3_WARMBOOT BUG=chromium-os:23496 TEST=build and boot on Cardhu Change-Id: If21303468193c7f5f6ba1c0c0b7cd0ccb5a08c0e Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13801
2012-02-27tegra: configs: enable warm boot on WaluigiVarun Wadekar
enable CONFIG_TEGRA_LP0 and CONFIG_TEGRA3_WARMBOOT BUG=chromium-os:23496 TEST=build and boot on Waluigi Change-Id: I622d228d02767954ffa7e101ad6f5f5fb1146702 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13802
2012-02-27arm: tegra3: add warmboot code needed for LP0Varun Wadekar
BUG=chromium-os:23496 TEST=build and boot on Waluigi, Cardhu by enabling CONFIG_TEGRA_LP0 and CONFIG_TEGRA3_WARMBOOT. odification of the work done by: a. Jimmy Zhang <jimmzhang@nvidia.com> b. Yen Lin <yelin@nvidia.com> c. Wei Ni <wni@nvidia.com> Change-Id: If2fa63ccd23341694955bca25fb5cfc4a8a805ad Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13800
2012-02-24arm: tegra: move warmboot_avp.h over to common locationVarun Wadekar
warmboot_avp.h needs to be present in include/arch-tegra in order to use it for Tegra3. BUG=chromium-os:23496 TEST=build for Seaboard Change-Id: I3f369194e4002e8257c9d2ff37253bc20733138d Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/15394
2012-02-24arm: tegra3: header file for the MC/EMC registersVarun Wadekar
BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: I6d26502d1ecc393b266ffe06b540f59c595e19ae Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14811
2012-02-24arm: tegra3: header file for sdmmc controller registersVarun Wadekar
BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: Ifa06f941798ff242197dcd31f4091567d91fe4b2 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14810
2012-02-24arm: tegra3: add header for APB_MISC_GP and padctrl registersVarun Wadekar
BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: I74bb2418ab996e362060351de3ba7efd538ffd87 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14809
2012-02-24arm: tegra3: add header file to describe the AHB controllerVarun Wadekar
BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: I20ac75c71d86d65ff422ff3f4f966a69718f4f91 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14808
2012-02-24arm: tegra3: add PMC registersVarun Wadekar
These registers would be useful for the warmboot code. BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: I58f52b6b8653d72b2e842ee44bdf3632eff304a2 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14690
2012-02-24arm: tegra3: add AHB aperture base addressVarun Wadekar
Would be useful for the warmboot code. BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: I271f6cdcc0248337e516c2c32014c6ec4f08fb15 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14689
2012-02-24arm: tegra3: add flow controller registersVarun Wadekar
These registers would be useful for the warmboot code. BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: I8da1ed3a382e1b65247236cb19f527f81d8ecaac Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14688
2012-02-23ehci: fix PCI controllers lookupVincent Palatin
We were not searching on the last PCI bus. Fix the loop to go up to pci_last_busno() included. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=None TEST=run on Link with only one PCI bus active, see we can detect the EHCI controllers. Change-Id: Icdcd19df0c622039f56e7403c2616348b5d8b7d6 Reviewed-on: https://gerrit.chromium.org/gerrit/16481 Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org> Commit-Ready: Vincent Palatin <vpalatin@chromium.org>
2012-02-21Fix vbexport_test displayVadim Bendebury
It turns out that running 'vbexport_test display' on coreboot platforms fails to display bitmap images, sometimes reporting memory corruption and rebooting the system. The problem was twofold: - the gbb pointer is not properly initialized (as it is supposed to when CONFIG_HARDWARE_MAPPED_SPI is defined). - the bitmap images block includes an element which in fact is not a bitmap. When scanning the block, the test tried displaying all elements, generating an error when this one-off element is encountered. This change fixes both issues. BUG=chromium-os:26586 TEST=manual . build a new chromeos-bootimage . reboot the system stopping it in u-boot console dialogue . run `vbexport_test display' command from the console The test was failing before this change, it is passing now. Change-Id: Iee9491d150b9ce5513f7446ab4df806d23e6d4d8 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/16206 Reviewed-by: Bill Richardson <wfrichar@chromium.org>
2012-02-17usb: properly detect empty mass storage media readerVincent Palatin
When a USB card reader is empty, it will return "Not Ready - medium not present" as Key Code Qualifier. In that situation, it's useless waiting for the full timeout since the result won't change until the user inserts a card. U-Boot mass storage returns empty mass storage devices with a size of 0, skip them in the VBoot devices enumeration. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=None TEST=On Link, run without a MMC card. Change-Id: Iac37887742e5738e249f595e0413eec16b391fae Reviewed-on: https://gerrit.chromium.org/gerrit/15582 Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2012-02-16arm: tegra: add chipid value to uniquely identify tegra3Varun Wadekar
BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi Change-Id: Iacd6fdb178afbfdb978dbe53bbe2766916bf26f9 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14685
2012-02-16arm: config: tegra: add bct offset addressVarun Wadekar
BUG=chromium-os:23496 TEST=build for Cardhu, Waluigi and Seaboard Change-Id: I32dbfa02ac1d6954b3a7e515914fbc0b6695f98b Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14683
2012-02-15Fix USB keyboard in RW imagesStefan Reinauer
USB keyboard initialization was added in twostop_boot as a hack. However, if u-boot is running from one of the RW sections, twostop_boot is never executed, instead the code proceeds to twostop_readwrite_main_firmware() which was lacking the USB keyboard initialization. This patch adds USB keyboard initialization to the RW code path. BUG=chrome-os-partner:7940 TEST=boot from RW section in dev mode, observe that USB keyboard is working. (stumpy) Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Ie49d14680a72c2216b4a68091ae6e6adcca91242 Reviewed-on: https://gerrit.chromium.org/gerrit/15913 Reviewed-by: Vincent Palatin <vpalatin@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org>
2012-02-15chromium: Report Ctrl-Enter key to verified boot.Tom Wai-Hong Tam
Add this special handle of Ctrl-Enter, which is converted into '\n' by i8042 driver. BUG=chrome-os-partner:6759 TEST=compile the firmware and update it to Lumpy; during the dev screen, press Ctrl-Enter to trigger USB boot. Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Change-Id: Ifde312f4ef6de9b328dc22b96ca02a2a9ccf6068 Reviewed-on: https://gerrit.chromium.org/gerrit/15805 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Tom Wai-Hong Tam <waihong@chromium.org> Commit-Ready: Tom Wai-Hong Tam <waihong@chromium.org>
2012-02-14X86: Add support for Ctrl-Enter in i8042 driver.Tom Wai-Hong Tam
Make Ctrl-Enter act like LF (Line Feed) such that u-boot can differentiate it from pure Enter key. There are other Ctrl-(numeric keypad key)'s, like Ctrl-[ for ESC (Escape) key, but they are not useful yet in current u-boot. So keep the Ctrl-(key) and non-Ctrl-(key) tables the same except Enter. This change is together with https://gerrit.chromium.org/gerrit/15749 BUG=chrome-os-partner:6759 TEST=compile the firmware and update it to Lumpy; during the dev screen, press Ctrl-Enter to trigger USB boot. Change-Id: Ie3197f7ba93ed63c851bdfb918c8e384c90977dd Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/15750 Reviewed-by: Simon Glass <sjg@chromium.org>
2012-02-14arm: tegra2: split LP0 code to help future chipsVarun Wadekar
split the LP0 code for tegra2 into common LP0 code and chip specific warm boot code BUG=chromium-os:23496 TEST=build for Seaboard Change-Id: Ie04bf9ac17482a37afd0f4515dc3aafeb4f48ae7 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/15883
2012-02-08Revert "arm: tegra2: split LP0 code to help future chips"Brian Harring
This reverts commit 4c7502242627f64d91432cb4958be5f93f65fbff Don't think this is the cause of http://code.google.com/p/chromium-os/issues/detail?id=26116, but it was in the same batch so I'm reverting in the process. Change-Id: Icc013ced6c22e29d569ee4ca8ef73522154ec1a8 Reviewed-on: https://gerrit.chromium.org/gerrit/15561 Reviewed-by: Brian Harring <ferringb@chromium.org> Tested-by: Brian Harring <ferringb@chromium.org>
2012-02-08Revert "arm: tegra2: add .lds to calculate warm boot code size"Brian Harring
This reverts commit 9a3fbb5f0b02382c7abe0cf40a4f08abbf269d05 Broke tegra2: http://code.google.com/p/chromium-os/issues/detail?id=26116 Change-Id: I7d35211c6ebce7a10750cb1033c6f8ba9a0f63bc Reviewed-on: https://gerrit.chromium.org/gerrit/15560 Reviewed-by: Brian Harring <ferringb@chromium.org> Tested-by: Brian Harring <ferringb@chromium.org>
2012-02-08arm: tegra2: add .lds to calculate warm boot code sizeVarun Wadekar
move away from the current method, where we add wb_end() immediately after wb_start() and then use the function addresses to calculate the WB code size. Add a .lds script to expose __wb_end after wb_start() in the .text section and then reference this variable in the WB size calculation code. BUG=chromium-os:23496 TEST=build on Seaboard. Verified that uboot.map has the correct address assigned to __wb_end and that LP0 works reliably. Change-Id: I170277f00b450d38063018453faf44d5a38abaaa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14682
2012-02-08arm: tegra2: split LP0 code to help future chipsVarun Wadekar
split the LP0 code for tegra2 into common LP0 code and chip specific warm boot code BUG=chromium-os:23496 TEST=build for Seaboard Change-Id: Id9756c08f61502affa8beee636d883d01468e6ec Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13799
2012-02-07video: tegra: Change the clock settings for LCD driverPuneet Saxena
As clock source for graphics related clocks is different for Tegra2 and Tegra3, define it under platform specific directories. BUG=chromium-os:23496 TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi. Original work by - Mayuresh Kulkarni <mkulkarni@nvidia.com> Change-Id: I6cee11df5e75eaf3836565c4fa4f3ab3e45d8cac Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14700
2012-02-07video: tegra: Update LCD max height & 'lcd_line_length'Puneet Saxena
Assert occurs due to LCD max height was bigger than default Maximum LCD height, causing 'panel_info' is not initialized. Increase default Max LCD height as Waluigi has LCD height in pixel more than 768. Initialize global variable 'lcd_line_length' correctly. 'lcd_line_length' was not initialized before use, causing initialization of dependent variables wrongly. BUG=chromium-os:23496 TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi. Change-Id: I24a9fc54541c861c48fd885e2d58d32786c31bf8 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14699
2012-02-07tegra3: fdt: change lcd frame buffer addressPuneet Saxena
For Waluigi, existing frame buffer address does not fall under external memory map. Setting it to the location set as per the default initialization. BUG=chromium-os:23496 TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi. Change-Id: I2284d43c11f4d6622344429508b1f99e30929f19 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14698
2012-02-07tegra: Change parent clock for Tegra2 and Tegra3Puneet Saxena
Set display parent clock separately for Tegra2 and Tegra3. BUG=chromium-os:23496 TEST=Built ok for Cardhu Walgui and Seaboard. Tested on Waluigi. Change-Id: Ie03d37b8dda77dcfcb72e70c34e769a23323e598 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14697
2012-02-07tegra: Extend support for RAM size as 2GBPuneet Saxena
Add a case for returning RAM size as 2GB by reading PMC scratch20 register. BUG=chromium-os:23496 TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi. Change-Id: I5dc8fdf7cd9718e5dd2ca24cd1f467c5b6e9a6aa Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14696
2012-02-07video: tegra: Handle pinmux setting differenly for Tegra2 an Tegra3Puneet Saxena
For Tegra2, pinmuxing is done in each driver, For Tegra3 it is done at boot up time. Handling it conditionally for Tegra2 and Tegra3. BUG=chromium-os:23496 TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi. Change-Id: I95e2dc4d46c0c47037611ff9177f2d8823c11d1f Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14695
2012-02-07tegra: Move display.c & pwfm.c from tegra2 to tegra-commonPuneet Saxena
Move pwfm.c and display.c under common folder tegra-common. BUG=chromium-os:23496 TEST=Built ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi. Change-Id: I23c5f02270dde7bfdd6e1d26ed9984385986194e Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14694
