2006-04-18MPC5200: enable snooping of DMA transactions on XLB even if no PCILABEL_2006_04_18_1106Wolfgang Denk
is configured; othrwise DMA accesses aren't cache coherent which causes for example USB to fail.
2006-04-16Some code cleanupWolfgang Denk
2006-04-16Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-04-13Fix Quad UART mapping on MCC200 board due to new HW revisionWolfgang Denk
2006-04-12Merge with /home/m8/git/u-bootWolfgang Denk
2006-04-11* Fix dbau1x00 BoardHeiko Schocher
- Fix dbau1x00 boards broken by dbau1550 patch PLL:s were not set for boards other than 1550. Flash CFI caused card to hang due to undefined CFG_FLASH_BANKS_LIST. Default boot is now bootp for cards other than 1550. Patch by Thomas Lange Aug 10 2005
2006-04-11Fixes common/cmd_flash.c:Heiko Schocher
- fix some compiler/parser error, if using m68k tool chain - optical fix for protect on/off all messages, if using more then one bank Patch by Jens Scharsig, 28 July 2005
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-04-06MCC200 Board: fix flash unprotection code for flash > 32 MB.Wolfgang Denk
2006-04-06Update CHANGELOGWolfgang Denk
2006-04-06Fix Lite500B support: Merge with /home/raj/git/u-boot.l5200b_pciWolfgang Denk
2006-04-06Merge with /home/sr/git/u-boot/cfi-flashWolfgang Denk
2006-04-05Merge with /home/sr/git/u-boot/4xx-sdramWolfgang Denk
2006-04-05Remove dependencies between DoC code and old legacy NAND driver.Marian Balakowicz
Necessary defines and data structures were copied to DoC specific files so that legacy NAND code could be entirely removed from u-boot tree in the near future.
2006-04-05Correct PM828_PCI_config Makefile target.Marian Balakowicz
2006-04-03Fix CONFIG_SKIP_LOWLEVEL_INIT dependency in cpu/arm920t/start.SWolfgang Denk
Patch by Peter Menzebach, 13 Oct 2005 [DNX#2006040142000473]
2006-04-01* Add support for ymodem protocol downloadWolfgang Denk
Patch by Stefano Babic, 29 Mar 2006 * Memory Map Update for Delta board: U-Boot is at 0x80000000-0x84000000 Merge with /home/mk/8-benq/u-boot
2006-04-01* Changes/fixes for drivers/cfi_flash.c:Stefan Roese
- Add Intel legacy lock/unlock support to common CFI driver On some Intel flash's (e.g. Intel J3) legacy unlocking is supported, meaning that unlocking of one sector will unlock all sectors of this bank. Using this feature, unlocking of all sectors upon startup (via env var "unlock=yes") will get much faster. - Fixed problem with multiple reads of envronment variable "unlock" as pointed out by Reinhard Arlt & Anders Larsen. - Removed unwanted linefeeds from "protect" command when CFG_FLASH_PROTECTION is enabled. - Changed p3p400 board to use CFG_FLASH_PROTECTION Patch by Stefan Roese, 01 Apr 2006 * Changes/fixes for drivers/cfi_flash.c: - Correctly handle the cases where CFG_HZ != 1000 (several XScale-based boards) - Fix the timeout calculation of buffered writes (off by a factor of 1000) Patch by Anders Larsen, 31 Mar 2006
2006-03-31Reorder CHANGELOGStefan Roese
2006-03-31Updates to common PPC4xx onboard (DDR)SDRAM init code (405 and 440)Stefan Roese
405 SDRAM: - The SDRAM parameters can now be defined in the board config file and the 405 SDRAM controller values will be calculated upon bootup (see PPChameleonEVB). When those settings are not defined in the board config file, the register setup will be as it is now, so this implementation should not break any current design using this code. Thanks to Andrea Marson from DAVE for this patch. 440 DDR: - Added function sdram_tr1_set to auto calculate the TR1 value for the DDR. - Added ECC support (see p3p440). Patch by Stefan Roese, 17 Mar 2006
2006-03-30delta board: one more DA9030 fix.Markus Klotzbuecher
2006-03-30Add support for ymodem protocol (loady command).Markus Klotzbuecher
2006-03-29Change delta board memory map to start at 0x80000000.Markus Klotzbuecher
2006-03-29delta board: minor update to DA9030 code.Markus Klotzbuecher
2006-03-29Set SDelay register in the DDR controller for the MPC5200B chip.Rafal Jaworowski
2006-03-27delta board: fix DA9030 reset procedure.Markus Klotzbuecher
2006-03-25Update CHANGELOGWolfgang Denk
2006-03-24Merge with http://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2006-03-24Monahans related documentation update.Markus Klotzbuecher
2006-03-24Added config options CFG_MONAHANS_RUN_MODE_OSC_RATIO andMarkus Klotzbuecher
CFG_MONAHANS_TURBO_RUN_MODE_RATIO for configuring the Monahans core frequency.
2006-03-24delta board: DA9030 initialization and i2c support. Some minor changes toMarkus Klotzbuecher
make the pxa i2c driver work with the monahans cpu.
2006-03-23Enable Quad UART om MCC200 board.Wolfgang Denk
2006-03-21Cleanup MCC200 board configuration; omit non-existent stuff.Wolfgang Denk
2006-03-20Cleanup of the monahans cpu and delta board port.Markus Klotzbuecher
2006-03-20Support for redundant environment in NAND Flash.Markus Klotzbuecher
2006-03-19Update CHANGELOGWolfgang Denk
2006-03-18Add support for MPC859/866 Rev. A.0Wolfgang Denk
2006-03-17Merge with port of MPC8349EMDS boardWolfgang Denk
2006-03-17Add support for Lite5200B board.Wolfgang Denk
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
2006-03-16Support for DDR with 32-data path. Addotional notes on injectingRafal Jaworowski
multiple-bit errors.
2006-03-16Add command for handling DDR ECC registers on MPC8349EE MDS board.Marian Balakowicz
2006-03-16Fix DDR ECC bit definitions for MPC83xx.Marian Balakowicz
2006-03-14Add initial support for MPC8349E MDS board.Marian Balakowicz
2006-03-14Add support for ECC DDR initialization on MPC83xx.Marian Balakowicz
2006-03-14Add DMA support for MPC83xx.Marian Balakowicz
2006-03-14Add sync in do_reset() routine for MPC83xx after RPR registerMarian Balakowicz
was written to. It is need on some targets when BAT translation is enabled.
2006-03-14Add bit definitions for MPC83xx DDR controller registers.Marian Balakowicz
2006-03-14Add Dcbz(), Dcbi() and Dcbf() routines for MPC83xx.Marian Balakowicz
2006-03-14Correct shift offsets in icache_status and dcache_status for MPC83xx.Marian Balakowicz
