2004-11-17Map SRAM on NC650 boardLABEL_2004_11_17_2222wdenk
2004-11-02Work around for Ethernet problems on Xaeniax boardwdenk
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-24* Fix configuration for ERIC board (needs more room)wdenk
* Adjust MIPS compiler options at run-time depending on tools version ("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new, "-mcpu=4kc" for old tools)
2004-10-19Add passing of the command line and memory size information to theLABEL_2004_10_20_0020wdenk
kernel on xaeniax board.
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-11* Enable NAND flash support for NC650 board.wdenk
* Patch by Thomas Lange 07 Oct 2004: Updated README for DBAu1x00 boards to match current status
2004-10-11* Patch by Philippe Robin, 28 Sept 2004:wdenk
Fix Flash support for Versatile. * Patch by Roger Blofeld, 16 Sep 2004: Fix timeout for DHCP command retry
2004-10-11* Patch by Pantelis Antoniou, 14 Sep 2004:wdenk
Fix early serial hang when CONFIG_SERIAL_MULTI is defined. * Patch by Pantelis Antoniou, 14 Sep 2004: Kick watchdog when bz-decompressing
2004-10-11Fix CFG_HZ problems on AT91RM9200 systemswdenk
[Remember: CFG_HZ should be 1000 on ALL systems!]
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-10-10* Configure SX1 board to use drivers/cfi_flash.cwdenk
* Patches by Michael Bendzick, 30 Aug 2004: - Configure omap1510inn board to use drivers/cfi_flash.c - Make drivers/cfi_flash.c protect environment and redundant environment. * Patch by Steven Scholz, 23 Jun 2004: - Add script (tools/img2brec.sh) to programm U-Boot into (Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-10-10Patches by Jon Loeliger, 24 Aug 2004:wdenk
- Add support for the MPC8541 and MPC8555 CDS boards - Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
2004-10-10* Patch by Jon Loeliger, 24 Aug 2004:wdenk
- Fix PCI window on MPC85xx; remove unneeded PCI initialization from board_early_init_f() - Provide SW workaround for PCI initialization on 85xx CDS - Convert MPC85xxADS to use common CFI flash driver * Cleanup: avoid compiler warnings * Add CMC PU2 board to MAKEALL script
2004-10-10Patches by George G. Davis, 24 Aug 2004:wdenk
- Enable ramdisk/initrd tagged param support for omap1610h2_config - Remove static network setup defaults from mx1ads_config
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-10-10Code Cleanupwdenk
Patch by Gary Jennejohn, 04 Oct 2004: - fix I2C on at91rm9200 - add support for Ricoh RS5C372A RTC
2004-10-10* Patch by Gary Jennejohn, 01 Oct 2004:wdenk
- add support for CMC PU2 board - add support for I2C on at91rm9200 * Patch by Gary Jennejohn, 28 Sep 2004: fix baudrate handling on at91rm9200
2004-10-09Patch by Yuli Barcohen, 22 Aug 2004:wdenk
- remove ZPC.1900 board-specific flash driver; switch the port to generic CFI driver; - port clean-up
2004-10-09Patch by Hinko Kocevar, 21 Aug 2004:wdenk
Add calc_fbsize() function used with VIDEOLFB_TAG on TRAB
2004-10-09* Clean up tools/bmp_logo.c to not add trailing white spacewdenk
* Patch by Hinko Kocevar, 21 Aug 2004: - Group common framebuffer functions in common/lcd.c - Group common framebuffer macros and #defines in include/lcd.h - Provide calc_fbsize() for video ATAG
2004-10-09Patch by Sam Song, 21 August 2004:wdenk
- Fix a typo in README - Align "(RO)" output for "flinfo" after "protect on" - Add RESET support for RPXlite_DW board; adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz
2004-10-09Patches by himba, 21 Aug 2004:wdenk
- fix some "use of label at end of compound statement" warnings - Define type of LCD panel on lubbock board if CONFIG_LCD is used
2004-10-09Patch by Steven Scholz, 16 Aug 2004:wdenk
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/
2004-10-09Patch by Andreas Engel, 16 Aug 2004:wdenk
parameter type cleanup for NetSetTimeout()
2004-09-29* Patches by Sean Chang, 09 Aug 2004:wdenk
- Added support for both 8 and 16 bit mode access to System ACE CF through MPU. - Fixed missing System ACE CF device during get FAT partition info in fat_register_device function. - Enabled System ACE CF support on ML300. * Patch by Sean Chang, 09 Aug 2004: Synch defines for saveenv and do_saveenv functions so they get compiled under the same statement.
2004-09-29* Patch by Sean Chang, 9 Aug 2004:wdenk
- Added I2C support for ML300. - Added support for ML300 to read out its environment information stored on the EEPROM. - Added support to use board specific parameters as part of U-Boot's environment information. - Updated MLD files to support configuration for new features above. * Patches by Travis Sawyer, 5 Aug 2004: - Remove incorrect bridge settings for eth group 6 - Add call to setup bridge in ppc_440x_eth_initialize - Fix ppc_440x_eth_init to reset the phy only if its the first time through, otherwise, just check the phy for the autonegotiated speed/duplex. This allows the use of netconsole - only print the speed/duplex the first time the phy is reset.
2004-09-29* Patch by Shlomo Kut, 29 Mar 2004:wdenk
Add support for MKS Instruments "Quantum" board * Fix build problem with Cogent boards; avoid using <asm/byteorder.h> when using the host compiler
2004-09-28* Patch by Ganapathi C, 04 Aug 2004:wdenk
Fix NFS timeout issue
2004-09-28* Patch by Yuli Barcohen, 19 Jul 2004:wdenk
- Fix host tools building in Cygwin environment - Fix header files search order for host tools * Patch by Tom Armistead, 19 Jul 2004: Fix kgdb.S support for 74xx_75x cpu
2004-09-28* Patch by Jon Loeliger, 15 Jul 2004:wdenk
Fix MPC85xx I2C driver
2004-09-28Fix problems with CDROM drive as slave device on Lite5200 IDE bus.wdenk
2004-09-28* Patch by Stephen Williams, 15 July 2004wdenk
Set the PCI class code for JSE board as part of PCI interface setup * Patch by Michael Bendzick, 15 Jul 2004: Fix problem with writes with odd sizes in drivers/cfi_flash.c when CFG_FLASH_USE_BUFFER_WRITE is set
2004-09-28* Patch by Yuli Barcohen, 13 Jul 2004:wdenk
Allow clock setting on MPC866/MPC885 series chips according to environment variable `cpuclk' * Patch by Yuli Barcohen, 20 Apr 2004: Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
2004-09-28Patch by Vincent Dubey, 24 Sep 2004:wdenk
Add support for xaeniax board
2004-09-27* Add comment about non-GPL character of standalone applications towdenk
COPYING file * Fix FEC ethernet problem on NSCU board.
2004-09-21Patch by Gary Jennejohn, 09 Sep 2004:wdenk
allow to use USART1 as console port on at91rm9200dk boards
2004-09-16Fix [noeol] problem in board/esd/ar405/fpgadata_xl30.cwdenk
2004-09-16Patch by Stefan Roese, 16 Sep 2004stroese
2004-09-16Update AR405 board.stroese
2004-09-16esd misc file esd common routines added.stroese
2004-09-09Fix SysClk handling for PPChameleon and CATcenter boardswdenk
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-08-28Add support for IDS "NC650" boardLABEL_2004_08_29_0045wdenk
2004-08-28* Add automatic update support for LWMON boardLABEL_2004_08_28_2355wdenk
* Enable MSDOS/VFAT filesystem support for LWMON board * Clear Block Lock-Bits when erasing flash on LWMON board. * Fix return code of "fatload" command * Disable debugging for TQM5200 board
2004-08-04* Patch by Martin Krause, 03 Aug 2004:wdenk
change timing for SM501 graphics controller on TQM5200 module * Patch by Mark Jonas, 13 July 2004: - Total5200 LCD now run in little endian mode. Endianess conversion is done in hardware. - Removed last reference to "console" environment variable.
2004-08-02Patches by Lars Munch, 12 Jul 2004:wdenk
- move at45.c to board/at91rm9200dk/ since this is at91rm9200dk board specific - split out the LXT971A PHY from ns_9750_eth.h - split the dm9161 phy part out of at91rm9200_ether.c
