Update etags build target
* Improve NetConsole support: add support for broadcast destination
address and buffered input.
* Cleanup compiler warnings for GCC 3.3.x and later
* Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
* Enable MSDOS/VFAT filesystem support for LWMON board
* Clear Block Lock-Bits when erasing flash on LWMON board.
* Fix return code of "fatload" command
* Disable debugging for TQM5200 board
change timing for SM501 graphics controller on TQM5200 module
* Patch by Mark Jonas, 13 July 2004:
- Total5200 LCD now run in little endian mode. Endianess conversion
is done in hardware.
- Removed last reference to "console" environment variable.
- move at45.c to board/at91rm9200dk/ since this is at91rm9200dk
board specific
- split out the LXT971A PHY from ns_9750_eth.h
- split the dm9161 phy part out of at91rm9200_ether.c
Replaced hardcoded PL011 clock frequency with config variable.
Fixed wrong CONFIG_CMD_DFL doc.
* Patch by Thomas Viehweger, 09 Jun 2004:
make it possible to remove chpart when there is only one partition
netconsole patch under Linux)
- support larger DDR memories up to 2G on the PC8540/8560ADS and
STXGP3 boards
- Made MPC8540/8560ADS be 33Mhz PCI by default.
- Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16
and CONFIG_L2_INIT_RAM options.
- Refactor Local Bus initialization out of SDRAM setup.
- Re-implement new version of LBC11/DDR11 errata workarounds.
- Moved board specific PCI init parts out of CPU directory.
- Added TLB entry for PCI-1 IO Memory
- Updated README.mpc85xxads
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
* Add link for preloader for Motorola Coldfire to RAEDME.m68k
fix output formatting in drivers/cfi_flash.c
Fix lowboot (again) on MPC5xxx
relocate exception vectors on arm720t if needed
- update mach-types.h to latest arm.linux.org.uk master list
- Set correct OMAP1610 bi_arch_number for build target
* Patch by Curt Brune, 06 Jul 2004:
evb4510: add support for timer interrupt; cleanup
Fix sbc8260 environment variables
* Cleanup redundand "console" environment variable
* Patch by Mark Jonas, 05 Jul 2004:
add support for the Total5100's and Total5200's LCD screen
* Patches by Dan Eisenhut, 01 Jul 2004:
- README fixes.
- Move doc2000.h include to prevent compiler warning on some boards
Added support for Total5100 and Total5200 (Rev.1 and Rev.2)
MGT5100 and MPC5200 based Freescale platforms.
Add initialization for Integrator and versatile board files.
* Patch by Hinko Kocevar, 01 Jun 2004:
Fix VFD FB allocation, add LCD FB allocation on ARM
Add support for TQM5200 board
* Patch by Martin Krause, 29 Jun 2004:
Add loopw command: infinite write loop on address range
- add empty include/asm-microblaze/processor.h
- add to CREDITS and MAINTAINERS
- add gd initialization
- add MicroBlaze and SUZAKU board to MAKEALL script
- add reset support for SUZAKU
- add flush_cache() for MicroBlaze
- add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed
size flash memory on SUZAKU
Add support for the PXA250 based Intrinsyc Cerf board.
* Patch by Yasushi Shoji, 27 Jun 2004:
fix comment in include/common.h
* Patch by Daniel Poirot, 24 Jun 2004:
Add support for Wind River's sbc8240 board
* Patches by Yasushi Shoji, 26 Jun 2004:
- drivers/serial_xuartlite.c: fix "return 0" in void function
- add microblaze support to mkimage tool
Add support for WindRiver's SBC8560 board
* Patch by Nicolas Lacressonniere, 24 Jun 2004
Small Bugs fixes for "at91rm9200dk" board:
- Timing modifications for SPI DataFlash access
- Fix NAND flash detection bug
* Patch by Nicolas Lacressonniere, 24 Jun 2004:
Add Support for Flash AT49BV6416 for AT91RM9200DK board
Completion of the 8540ADS/8560ADS updates:
Fix some PCI and Rapid I/O memory maps,
Initialize both TSEC 1 and 2,
Initialize SDRAM
Update MAINTAINER for 85xx boards and README.mpc85xxads
Remove obsolete AdderII port which was superseded by unified
AdderII/Adder87x port
* Patch by Ladislav Michl, 16 Jun 2004:
Fix gcc-3.3.3 warnings for smc91111.c
Remove debug code from 'board/lpd7a40x/flash.c'
Update for PPChameleon board:
- support for SysClk @ 25MHz
- support for Silicon Motion SM712 VGA controller
- some clean ups
- fix problems with examples/stubs.c for GCC >= 3.4
- fix problems with gd initialization
* Enable FAT filesystem support for HMI10 board
* Patch by Curt Brune, 17 May 2004:
- Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC)
- Add support for ESPD-Inc. EVB4510 Board
* Increase NFS download timeout (now 1 min - 10 sec is to short for a
slow download of a big image)
display even after showing a bitmap
- DDR Ram support for PM520 (MPC5200)
- support for different flash types (PM520)
- USB / IDE / CF-Card / DiskOnChip support for PM520
- 8 bit boot rom support for PM520/CE520
- Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245)
- I2C and RTC support for CPC45
- support of new flash type (28F160C3T) for CPC45
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
fix support for Logic SDK-LH7A404 board and clean up the
LH7A404 register macros.
* Patch by Matthew McClintock, 10 Jun 2004:
Modify code to select correct serial clock on Sandpoint8245
Add support for Intel K3 strata flash.
* Some cleanup
* Patch by Thomas Brand, 10 Jun 2004:
Fix "loads" command on DK1S10 board
Add support for 8MB flash SIMM and JFFS2 file system on
Motorola FADS board and its derivatives (MPC86xADS, MPC885ADS).
Add support for Analogue&Micro Adder87x and the older AdderII board.
* Patch by Ming-Len Wu, 09 Jun 2004:
Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
- Add support for RPXlite_DW board
- Update FLASH driver for 4*AM29DL323DB90VI
- Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
- Make MPC5200 boards evaluate the SVR to print processor name and
version in checkcpu() (cpu/mpc5xxx/cpu.c).
* Patch by Kai-Uwe Bloem, 06 May 2004:
Fix endianess problem in cramfs code
Add support for MAX6900 RTC
* Patches by Ladislav Michl, 03 Jun 2004:
- fix cfi_flash.c on LE systems
- let 'make mrproper' delete u-boot.img as well
- turn printf into debug in cfi_flash.c
Add support for Exys XSEngine board
Some code cleanup.
