2004-03-25Code cleanupLABEL_2004_03_25_1630wdenk
2004-03-25* Patch by Pavel Bartusek, 21 Mar 2004wdenk
Add Reiserfs support * Patch by Hinko Kocevar, 20 Mar 2004 - Add auto-release for SMSC LAN91c111 driver - Add save/restore of PTR and PNR regs as suggested in datasheet
2004-03-23* Patch by Stephen Williams, 19 March 2004wdenk
Increase speed of sector reads from SystemACE, shorten poll timeout and remove a useless reset * Patch by Tolunay Orkun, 19 Mar 2004: Make GigE PHY 1000Mbps Speed/Duplex detection conditional (CONFIG_PHY_GIGE) * Patch by Brad Kemp, 18 Mar 2004: prevent machine checks during a PCI scan * Patch by Pierre Aubert, 18 Mar 2004: Fix string cleaning in IDE identification
2004-03-23* Patch by Pierre Aubert, 18 Mar 2004:wdenk
- Unify video mode handling for Chips & Technologies 69000 Video chip and Silicon Motion SMI 712/710/810 Video chip - Add selection of the video output (CRT or LCD) via 'videoout' environment variable for the Silicon Motion - README update * Patch by Pierre Aubert, 18 Mar 2004: include/common.h typo fix * Patches by Tolunay Orkun, 17 Mar 2004: - Add support for bd->bi_iic_fast[] initialization via environment variable "i2cfast" (CONFIG_I2CFAST) - Add "i2cfast" u-boot environment variable support for csb272
2004-03-23* Patch by Carl Riechers, 17 Mar 2004:wdenk
Ignore '\0' characters in console input for use with telnet and telco pads. * Patch by Leon Kukovec, 17 Mar 2004: typo fix for strswab prototype #ifdef
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-23* Patch by Phillippe Robin, 16 Mar 2004:wdenk
avoid dereferencing NULL pointer in lib_arm/armlinux.c * Patch by Stephen Williams, 15 Mar 2004: Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation * Patch by Tolunay Orkun, 15 Mar 2004: Initialize bi_opbfreq to real OPB frequency via get_OPB_freq() * Patch by Travis Sawyer, 15 Mar 2004: Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
2004-03-17Patch by Pierre Aubert, 15 Mar 2004:wdenk
Fix buffer overflow in IDE identification
2004-03-15* Patch by Steven Scholz, 27 Feb 2004:LABEL_2004_03_16_2330wdenk
- Adding get_ticks() and get_tbclk() for AT91RM9200 - Many white space fixes in cpu/at91rm9200/interrupts.c * Patches by Steven Scholz, 20 Feb 2004: some cleanup in AT91RM9200 related code
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patches by Travis Sawyer, 12 Mar 2004:wdenk
- Fix Gigabit Ethernet support for 440GX - Add Gigabit Ethernet Support to MII PHY utilities * Patch by Brad Kemp, 12 Mar 2004: Fixes for drivers/cfi_flash.c: - Better support for x8/x16 implementations - Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE - Added defines for AMD command and address constants * Patch by Leon Kukovec, 12 Mar 2004: Fix get_dentfromdir() to correctly handle deleted dentries * Patch by George G. Davis, 11 Mar 2004: Remove hard coded network settings in TI OMAP1610 H2 default board config * Patch by George G. Davis, 11 Mar 2004: add support for ADS GraphicsClient+ board.
2004-03-14* Patch by Pierre Aubert, 11 Mar 2004:wdenk
- add bitmap command and splash screen support in cfb console - add [optional] origin in the bitmap display command * Patch by Travis Sawyer, 11 Mar 2004: Fix ocotea board early init interrupt setup. * Patch by Thomas Viehweger, 11 Mar 2004: Remove redundand code; add PCI-specific bits to include/mpc8260.h
2004-03-14* Patch by Stephan Linz, 09 Mar 2004wdenk
- Add support for the SSV ADNP/ESC1 (Nios Softcore) * Patch by George G. Davis, 9 Mar 2004: fix recent build failure for SA1100 target * Patch by Travis Sawyer, 09 Mar 2004: Support native interrupt mode for the IBM440GX. Previously it was running in 440GP compatibility mode.
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
2004-03-14* Patch by Tolunay Orkun, 5 Mar 2004:wdenk
Fix early board initialization for Cogent CSB272 board * Patch by Ed Okerson, 3 Mar 2004: fix CFI flash writes for little endian systems * Patch by Reinhard Meyer, 01 Mar 2004: generalize USB and IDE support for MPC5200 with according changes to IceCube.h and TOP5200.h add Am29LV256 256 MBit FLASH support for TOP5200 boards add info about USB and IDE to README
2004-03-14* Patch by Yuli Barcohen, 4 Mar 2004:wdenk
Fix problems with GCC 3.3.x which changed handling of global variables explicitly initialized to zero (now in .bss instead of .data as before). * Patch by Leon Kukovec, 02 Mar 2004: add strswab() to fix IDE LBA capacity, firmware and model numbers on little endian machines * Patch by Masami Komiya, 02 Mar 2004: - Remove get_ticks() from NFS code - Add verification of RPC transaction ID * Patch by Pierre Aubert, 02 Mar 2004: cleanup for IDE and USB drivers for MPC5200
2004-03-14* Patch by Travis Sawyer, 01 Mar 2004:wdenk
Ocotea: - Add IBM PPC440GX Ref Platform support (Ocotea) Original code by Paul Reynolds <PaulReynolds@lhsolutions.com> Adapted to U-Boot and 440GX port 440gx_enet.c: - Add gracious handling of all Ethernet Pin Selections for 440GX - Add RGMII selection for Cicada CIS8201 Gigabit PHY ppc440.h: - Add needed bit definitions - Fix formatting * Patch by Carl Riechers, 1 Mar 2004: Add PPC440GX prbdv0 divider to fix memory clock calculation. * Patch by Stephan Linz, 27 Feb 2004 - avoid problems for targets without NFS download support
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2004-03-12SX1 patches: use "serial#" for USB serial #;wdenk
use redundand environment storage; auto-set console on USB port (using preboot command)
2004-03-12Cleanup.wdenk
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
2004-03-11Fix LOWBOOT configuration for MPC5200 with DDR memorywdenk
2004-03-02* Fix SDRAM timings for LITE5200 / IceCube boardwdenk
* Handle Auti-MDIX / connection status for INCA-IP * Fix USB problems when attempting to read 0 bytes
2004-02-27* Patch by Travis Sawyer, 26 Feb 2004:wdenk
Fix broken compile for XPEDITE1K target. * Patch by Stephan Linz, 26 Feb 2004: Bug fix for NFS code on NIOS targets * Patch by Stephen Williams, 26 Feb 2004: Break up SystemACE reads of large block counts
2004-02-27* Patch by Pierre Aubert, 26 Feb 2004wdenk
add IDE support for MPC5200 * Patch by Masami Komiya, 26 Feb 2004: add autoload via NFS * Patch by Stephen Williams Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses elsewhere in the source.
2004-02-27* Patch by Steven Scholz, 25 Feb 2004:wdenk
- Timeouts in FPGA code should be based on CFG_HZ - Minor cleanup in code for Altera FPGA ACEX1K * Patch by Steven Scholz, 25 Feb 2004: Changed "Directory Hierarchy" section in README * Patch by Masami Komiya, 25 Feb 2004: Reduce copy count in nfs_read_reply() of NFS code
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2004-02-26* Patch by Rahul Shanbhag, 19 Feb 2004:wdenk
Fixes for for OMAP1610 board: - shift some IRQ specific code to platform.S file - remove duplicatewatchdog reset code from start.S * Make Auto-MDIX Support configurable on INCA-IP board * Fix license for mkimage tool
2004-02-24* Patch by Masami Komiya, 24 Feb 2004:wdenk
Update NetBootFileXferSize in NFS code * Patch by Scott McNutt, 24 Feb 2004: fix packet length in NFS code
2004-02-24Add missing board/dave/B2/B2.c file.LABEL_2004_02_24_0305wdenk
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
2004-02-23* Patch by Peter Ryser, 20 Feb 2004:wdenk
Add support for the Xilinx ML300 platform * Patch by Stephan Linz, 17 Feb 2004: Fix watchdog support for NIOS * Patch by Josh Fryman, 16 Feb 2004: Fix byte-swapping for cfi_flash.c for different bus widths * Patch by Jon Diekema, 14 Jeb 2004: Remove duplicate "FPGA Support" notes from the README file
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-02-23* Patch by Laurent Mohin, 10 Feb 2004:wdenk
Fix buffer overflow in common/usb.c * Patch by Tolunay Orkun, 10 Feb 2004: Add support for Cogent CSB272 board * Code cleanup
2004-02-23* Patch by Thomas Elste, 10 Feb 2004:wdenk
Add support for NET+50 CPU and ModNET50 board * Patch by Sam Song, 10 Feb 2004: Fix typos in cfi_flash.c * Patch by Leon Kukovec, 10 Feb 2004 Fixed long dir entry slot id calculation in get_vfatname * Patch by Robin Gilks, 10 Feb 2004: add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==, !=, <>, <, >, <=, >=)
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2004-02-22* Patch by Travis Sawyer, 09 Feb 2004:wdenk
o 440GX: - Fix PCI Indirect access for type 1 config cycles with ppc440. - Add phymode for 440 enet - fix pci pre init o XPedite1K: - Change board_pre_init to board_early_init_f - Add user flash to bus controller setup - Fix pci pre init - Fix is_pci_host to check GPIO for monarch bit - Force xpedite1k to pci conventional mode (via #define option) * Patch by Brad Kemp, 4 Feb 2004: - handle the machine check that is generated during the PCI scans on 82xx processors. - define the registers used in the IMMR by the PCI subsystem. * Patch by Pierre Aubert, 03 Feb 2004: cpu/mpc5xxx/start.S: copy MBAR into SPR311 * Patch by Jeff Angielski, 03 Feb 2004: Fix copy & paste error in cpu/mpc8260/pci.c * Patch by Reinhard Meyer, 24 Jan 2004: Fix typo in cpu/mpc5xxx/pci_mpc5200.c
2004-02-20Add Auto-MDIX support for INCA-IPLABEL_2004_02_20_2310wdenk
2004-02-12Last minute fixes / cleanup.U-Boot-1_0_2wdenk
2004-02-12Fix typo.wdenk
Release version 1.0.2
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2004-02-11* Make sure to use a bus clock divider of 2 only when running TQM8xxMLABEL_2004_02_11_2240wdenk
modules at CPU clock frequencies above 66 MHz. * Optimize flash programming speed for LWMON (by another 100% :-)
2004-02-10* Patch by Jian Zhang, 3 Feb 2004:wdenk
- Changed the incorrect FAT12BUFSIZE - data_begin in fsdata can be negative. Changed it to be short. * Code cleanup
2004-02-09Patches by Stephan Linz, 30 Jan 2004:wdenk
1: - board/altera/common/flash.c:flash_erase(): o allow interrupts befor get_timer() call o check-up each erased sector and avoid unexpected timeouts - board/altera/dk1c20/dk1s10.c:board_early_init_f(): o enclose sevenseg_set() in cpp condition - remove the ASMI configuration for DK1S10_standard_32 (never present) - fix some typed in mistakes in the NIOS documentation 2: - split DK1C20 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1C20.h 3: - split DK1S10 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1S10.h 4: - Add support for the Microtronix Linux Development Kit NIOS CPU configuration at the Altera Nios Development Kit, Stratix Edition (DK-1S10) 5: - Add documentation for the Altera Nios Development Kit, Stratix Edition (DK-1S10) 6: - Add support for the Nios Serial Peripharel Interface (SPI) (master only) 7: - Add support for the common U-Boot SPI framework at RTC driver DS1306
2004-02-09* Patch by Rahul Shanbhag, 28 Jan 2004:wdenk
Fix flash protection/locking handling for OMAP1610 innovator board. * Patch by Rolf Peukert, 28 Jan 2004: fix flash write problems on CSB226 board (write with 32 bit bus width) * Patches by Mark Jonas, 16 Jan 2004: - fix rounding error when calculating baudrates for MPC5200 PSCs - make sure CFG_RAMBOOT and CFG_LOWBOOT are not enabled at the same time which is not supported
2004-02-08* Patch by Yuli Barcohen, 26 Jan 2004:wdenk
Allow bzip2 compression for small memory footprint boards * Patch by Brad Kemp, 21 Jan 2004: Add support for CFI flash driver for both the Intel and the AMD command sets. * Patch by Travis Sawyer, 20 Jan 2004: Fix pci bridge auto enumeration of sibling p2p bridges. * Patch by Tolunay Orkun, 12 Jan 2004: Add some delays as needed for Intel LXT971A PHY support * Patches by Stephan Linz, 09 Jan 2004: - avoid warning: unused variable `piop' in board/altera/common/sevenseg.c - make DK1C20 board configuration related to ASMI conform to documentation
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2004-02-07* Patch by liang a lei, 9 Jan 2004:wdenk
Fix Intel 28F128J3 ID in include/flash.h * Patch by Masami Komiya, 09 Jan 2004: add support for TB0229 board (NEC VR4131 MIPS processor) * Patch by Leon Kukovec, 12 Dec 2003: changed extern __inline__ into static __inline__ in include/linux/byteorder/swab.h
