2003-10-06* Update TRAB auto update codeLABEL_2003_10_06_2355wdenk
* Make fatload set filesize environment variable fix potential buffer overlow problem * enable basic / medium / high-end configurations for PPChameleonEVB board; fix NAND code * enable TFTP client code to specify to the server the desired timeout value (see RFC-2349)
2003-09-30Improve SDRAM setup for TRAB boardLABEL_2003_10_01_1830dzu
2003-09-30Suppress all output with splashscreen configured only if "splashimage"dzu
is set
2003-09-30* Fix problems with I2C support for mpc5200dzu
2003-09-30Fix problems with I2C support for mpc5200dzu
2003-09-29Suppress all output with splashscreen configured only if "splashimage"dzu
is set
2003-09-29* Adapt TRAB configuration and auto_update to new memory layoutdzu
2003-09-25Add configuration for wtk boarddzu
2003-09-25Add support for the Sharp LQ065T9DR51U LCD displaydzu
2003-09-19"start" may be legitimately 0x0000wdenk
2003-09-18Update MPC5200 port pin configuration for Linux CAN drivers.wdenk
2003-09-18Work on TRAB's auto_update feature.LABEL_2003_09_18_2045wdenk
Cleanup for submitted patches.
2003-09-18* Patch by Rune Torgersen, 17 Sep 2003:wdenk
- Fixes for MPC8266 default config - Allow eth_loopback_test() on 8260 to use a subset of the FCC's
2003-09-18* Patches by Jon Diekema, 17 Sep 2003:wdenk
- update README (SHOW_BOOT_PROGRESS values for cmd_nand.c and env_common.c) - sbc8260 tweaks - adjust "help" output
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2003-09-17Support new configuration of TRAB board with more memorywdenk
Minor cleanup of comments
2003-09-17Add auto-update code for TRAB board using USB memory stickswdenk
2003-09-16Code cleanupLABEL_2003_09_16_2310wdenk
2003-09-16* Disable MPC5200 bus pipelining as workaround for bus contentionwdenk
2003-09-16* Fix timeout problems with 1st packet on MPC5200wdenk
2003-09-16Disable MPC5200 bus pipelining as workaround for bus contentionwdenk
2003-09-16* Modify XLB arbiter priorities on MPC5200 so all devices use samewdenk
priority; configure critical interrupts to be handled like external interrupts
2003-09-16Make IPB clock on MGT5100/MPC5200 configurable in board config file;wdenk
go back to 66 MHz for stability
2003-09-15Cleanup of code, output formatting, and indentation.wdenk
2003-09-15* Patches by Jon Diekema, 15 Sep 2003:wdenk
- add description for missing CFG_CMD_* entries in the README file - sacsng tweaks: include/configs/sacsng.h: + Support extra bootp options like: 2nd DNS and send hostname + Enabling ping and irq command + Adding defines for a bunch of misc configrabled options (patches for these options will be coming) + Adding watchdog support, but it isn't enabled yet. board/sacsng/sacsng.c: + Suppressing unneeded output when the quiet environment is non-zero. + show_boot_progress() now accepts any negative number as a failure code. + show_boot_progress() flashes the error code 5 times, and then resets the board to retry the boot from the top * Patch by Gleb Natapov, 14 Sep 2003: enable watchdog support for all MPC824x boards that have a watchdog
2003-09-14* Patch by Gleb Natapov, 14 Sep 2003:wdenk
enable watchdog support for all MPC824x boards that have a watchdog * On MPC5200, restrict FEC to a maximum of 10 Mbps to work around the "Non-octet Aligned Frame" errors we see at 100 Mbps * Patch by Sharad Gupta, 14 Sep 2003: fix SPR numbers for upper BAT register ([ID]BAT[4-7][UL])
2003-09-13* Patch by llandre, 11 Sep 2003:wdenk
update configuration for PPChameleonEVB board
2003-09-13* Patch by David Müller, 13 Sep 2003:LABEL_2003_09_13_2100wdenk
various changes to VCMA9 board specific files * Add I2C support for MGT5100 / MPC5200
2003-09-12* Patch by Rune Torgersen, 11 Sep 2003:wdenk
Changed default memory option on MPC8266ADS to NOT be Page Based Interleave, since this doesn't work very well with the standard 16MB DIMM * Patch by George G. Davis, 12 Sep 2003: fix Makefile settings for sk98 driver
2003-09-12Move TRAB burn-in tests to TRAB board directoryLABEL_2003_09_12_1745wdenk
2003-09-12Patch by Stefan Roese, 12 Sep 2003stroese
2003-09-12New boards DP405, HUB405, PLU405, VOH405 added.stroese
2003-09-12New board config file added.stroese
2003-09-12Update configuration.stroese
2003-09-12PPC405EP: set vendor id.stroese
2003-09-12Disable memory controller before setting first values.stroese
2003-09-12PMC405 update.stroese
2003-09-12PCI405 update.stroese
2003-09-12CPCI405(AB) update.stroese
2003-09-12ASH405 update.stroese
2003-09-12Xilinx jtag tool added.stroese
2003-09-12Board VOH405 added.stroese
2003-09-12Board PLU405 added.stroese
2003-09-12Board HUB405 added.stroese
2003-09-12Board DP405 added.stroese
2003-09-11* Patch by Martin Krause, 11 Sep 2003:LABEL_2003_09_12_0110wdenk
add burn-in tests for TRAB board * Enable instruction cache on MPC5200 board
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2003-09-05* Add support for SK98xx driverLABEL_2003_09_06_0055wdenk
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors
