2016-06-28mx7: fix i.MX 7 detection where only MXC_CPU_MX7D was usedColibri_iMX7_LinuxImageV2.6Beta2_20160701Colibri_iMX6_LinuxImageV2.6Beta2_20160701Colibri_VF_LinuxImageV2.6Beta2_20160701Colibri_T30_LinuxImageV2.6Beta2_20160701Colibri_T20_LinuxImageV2.6Beta2_20160701Apalis_iMX6_LinuxImageV2.6Beta2_20160701Apalis_TK1_LinuxImageV2.6Beta2_20160701Apalis_T30_LinuxImageV2.6Beta2_20160701Stefan Agner
The i.MX 7 detection taken from upstream U-Boot adds a new macro MXC_CPU_MX7S. The downstream U-Boot still has one runtime occurence which currently checks for MXC_CPU_MX7D only. Fix this SoC detection to detect MXC_CPU_MX7S too. Note: While the GPT timer is available on i.MX 7, it is currently not configured (CONFIG_GPT_TIMER). Instead, the CPU internal syscounter timer is currently used (CONFIG_SYSCOUNTER_TIMER). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-28mxc_ocotp: simplify codeMax Krummenacher
For mx7 the code needn't make provisions, we can use the simple variant of fuse_bank_physical. Also U-Boot does not allow multi- platform (MX6/MX7) configurations, hence we can use compile time defines which select the simpler variant for MX7 always. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-28mx7: get_board_rev: simplify codeMax Krummenacher
Remove code which does not change anything. This also synchronizes this function with the upstream variant of it. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-28apalis/colibri_t30: vdd core pmic handlingMarcel Ziswiler
Just release TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362 VSEL1 to switch VDD_CORE back to boot set 1 defaulting to 1.200V. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-28i.mx 6/7 increase maximum temperature for booting linuxMax Krummenacher
On i.MX 6 and i.MX 7 U-Boot does wait until the measured SOC temperature is below a certain limit. On i.MX 6 this was 80°C, on i.MX7 85°C. Put this consistently to 90°C to allow the extended/industrial temperature rated modules to boot at elevated temperatures. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-22apalis/colibri_t30: fix cam_mclk_pcc0 pin muxing being lockedMarcel Ziswiler
Due to an undefined pin muxing function being used for CAM_MCLK_PCC0 that pin got locked and did no more allow for the Linux kernel and/or our GPIOConfig tool to make any further modifications. On Apalis T30 this pin is used as camera master clock CAM1_MCLK which was impossible to do due to it being locked while on Colibri T30 this pin is just multiplexed with the SD/MMC card clock MM_CLK which is tri-stated by default anyway. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22update.sh: make set<media>update self containedMax Krummenacher
'run setupdate' tries a number of update media to find an update script and then sources it. Each media is probed by its own run set<media>update, however if a script is found it is not sourced immediately but this task is delegated to 'run setupdate'. Thus one cannot just do a 'run setethupdate' to only try to update over Ethernet. This also unifies the functionality with Colibri VF and Colibri iMX7 were it has been implemented like this for a while now. While at it use consistently ${loadaddr}. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-22colibri_imx7: prepare environment to boot the M4 coreStefan Agner
Create a variable to boot the Cortex-M4 core. By default, the command is not doing anything. Flash a firmware into the UBI volume using: Colibri iMX7 # ubi part ubi Colibri iMX7 # fatload ${interface} 0:1 ${loadaddr} hello_world.bin Colibri iMX7 # ubi write ${loadaddr} m4firmware ${filesize} And set the command to boot the firmware automatically: Colibri iMX7 # setenv m4boot 'ubi read 0x7F8000 m4firmware && bootaux 0x7F8000' Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22net: increase maximum frame size to accomediate VLAN packetsStefan Agner
Ethernet packages with IEEE 802.1Q VLAN support may be up to 1522 bytes long. Increase the default size used to allocate packet storage by 4 bytes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22apalis-tk1: change (file) names from apalis_tk1 to apalis-tk1Marcel Ziswiler
Change file and other names resp. strings to apalis-tk1 rather than apalis_tk1 due to upstream Linux kernel device tree maintainers no longer allowing any underscores to be used in any such. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_vf/imx6/7 apalis_imx6: synchronize/improve memory optionsStefan Agner
Synchronize initramfs related configuration options and improve memory layout. The memory layout with an offset of 16MiB allows to boot bigger kernels. With AUTO_ZRELADDR, which is pretty much the standard nowadays, the kernel relacates itself to PC masked with 0xf8000000 plus a text offset of 0x8000 (hence 0x80008000 for Vybrid/i.MX 7 or 0x10008000 for i.MX 6). To avoid that the kernel overwrites itself during uncompress, move the kernel further away from its decompressed location. With a 16MiB offset from the start of memory and a 16MiB distance to the device-tree, we allow kernel up to ~16MiB. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-22colibri_imx7: read kernel and device tree from static UBI volumesStefan Agner
With the next release our update scripts write the kernel and device tree in seperate UBI volumes. This allows to use a lot less UBI/UBIFS support in U-Boot, which should lower the risk of hitting bugs in this area. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_imx7: get rid of obsolete bootaux qspi stuffMarcel Ziswiler
2016-06-22apalis/colibri_imx6/imx7/vf: white space fixesMarcel Ziswiler
2016-06-22colibri_imx7: get rid of spurious val6 variableMarcel Ziswiler
2016-06-22apalis_tk1: fix apalis dap1 hda operationMarcel Ziswiler
Regular HDA mode requires the TK1 SoC being the master to drive the DAP1_BIT_CLK and DAP1_SYNC pins therefore do not tristate their outputs. Further more despite the level shifter direction of those pins being called Shift_CTRL_Dir_In[2] those need to be configured as output for regular HDA mode. Note: If connecting to a I2S codec operating in master mode (e.g. as on our i.MX 6 designs) the later would have to be changed to inputs again. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_imx7: make use of soc environment variable for dt fileStefan Agner
Use the exact SoC information from the soc environment variable to load the device tree file for the Colibri iMX7S or iMX7D. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22mx7: set soc environment according to exact SoC typeStefan Agner
This can be useful if the same U-Boot binary is used for boards available with a i.MX 7Solo and i.MX 7Dual. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_imx7: remove old environmentStefan Agner
2016-06-22colibri_imx7: implement reset through PMICStefan Agner
To properly reset a Colibri iMX7 the PMIC reset capabilities need to be used. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_imx7: enable stdio deregister to allow USB resetStefan Agner
The command usb reset potentially requires to deregister USB keyboards, hence enable it if USB Keyboards are enabled. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_imx7: do not initialize second USB instance on i.MX 7SoloStefan Agner
The i.MX 7Solo only has one USB controller. Do not enable USB_PEN but return a -ENODEV return code instead. This allows "usb start" to work properly on Colibri iMX7S modules. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22usb: ehci-mx7: allow board_ehci_hcd_init to failStefan Agner
There could be runtime determined board specific reason why a EHCI initialization fails (e.g. ENODEV if a Port is not available). In this case, properly return the error code. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22mx7: Distinguish between dual and solo versionsFabio Estevam
Read the number of cores in the fuses to distinguish between the dual and solo versions. Tested on a mx7d sabresd and on a mx7solo warp7. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> (cherry picked from commit e25a0656bac63c5fcd20ef4313dc09c409fc512d) Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-22MLK-12066 imx: mx7: default enable MDIO open drainPeng Fan
The management data input/output (MDIO) requires open-drain, i.MX7D TO1.0 ENET MDIO pin has no open drain, but TO1.1 supports this feature. So to TO1.1, need to enable open drain by setting bits GPR0[8:7] for TO1.1. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2016-06-22colibri_imx7: enable resource domain controllerStefan Agner
Enabled RDC (resource domain controller) to isolate peripherals between the A7(s) and M4 core. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22MLK-11408-2 imx: mx7d: Isolate 26 IP resources to domain 0 for A coreYe.Li
In current design, if any peripheral was assigned to both A7 and M4, it will receive ipg_stop or ipg_wait when any of the 2 platforms enter low power mode. We will have a risk that, if A7 enter wait, M4 enter stop, peripheral will have chance to get ipg_stop and ipg_wait asserted same time. There are 26 peripherals impacted by this IC issue: SIM2(sim2/emvsim2) SIM1(sim1/emvsim1) UART1/UART2/UART3/UART4/UART5/UART6/UART7 SAI1/SAI2/SAI3 WDOG1/WDOG2/WDOG3/WDOG4 GPT1/GPT2/GPT3/GPT4 PWM1/PWM2/PWM3/PWM4 ENET1/ENET2 Software Workaround: The solution is set M4 to a different domain with A core. So the peripherals are not shared by them. This way requires the uboot implemented the RDC driver and set the 26 IPs above to domain 0 only. CM4 image will set the M4 to domain 1 only. This patch enables the CONFIG_MXC_RDC for mx7d SABRESD board and ARM2 boards, and setup the 26 IP resources to domain 0. Signed-off-by: Ye.Li <B37916@freescale.com>
2016-06-22MLK-11408-1 imx: mx7d: Add mx7d RDC driver supportYe.Li
Add the peripherals/masters definitions and registers base addresses for mx7d RDC. Enable the RDC driver by setting CONFIG_MXC_RDC. Signed-off-by: Ye.Li <B37916@freescale.com>
2016-06-22MLK-12030: imx: mx7d: fix the temperature checking for TO1.1Peng Fan
We can rely on finish bit for temperature reading for TO1.1. Also introduce CHIP_REV_xx macros for 7D. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2016-06-22MLK-11995 ARM: imx7: add i.mx7d TO1.1 support for LPSR modeAnson Huang
i.MX7D TO1.1 changes DDR retension mode control to IOMUXC_GPR, add support to this change for LPSR which needs to exit from DDR retension mode. Signed-off-by: Anson Huang <Anson.Huang@freescale.com>
2016-06-22apalis_imx6: fix Ethernet when using gigabit switchStefan Agner
U-Boot on Apalis iMX6 has a known problem: Apparently Apalis iMX6 does not works with Gigabit switches... Limiting speed to 10/100Mbps, and setting master mode, seems to be the only way to have a successful PHY auto negotiation. How to fix: Understand why Linux kernel do not have this issue. However, the current work around did not take effect since the generic phy config function (which gets called after the board level work-around) reenabled gigabit advertisment again. Use the newly introduced environment variable to disable gigabit Ethernet advertisement. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22net: phy: allow disabling gigabit ethernetStefan Agner
Disable Gigabit ethernet advertisment when the environment variable "disable_giga" is set. This feature is already present in the KSZ9023, this patch implements the same functionality as part of phylib. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22apalis_tk1: fix level shifter output enablesMarcel Ziswiler
The four level shifter output enables Shift_CTRL_OE[0 to 2 and 4] were wrongly pulled up therefore disabling the respective pin's input resp. output capabilities. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_t20: read kernel and device tree from static UBI volumesDominik Sliwa
With the next release our update scripts write the kernel and device tree in seperate UBI volumes. This allows to use a lot less UBI/UBIFS support in U-Boot, which should lower the risk of hitting bugs in this area. Boot times are also slightly faster (measurements showed an improvement of ~150ms). Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22apalis_t30: add optional pcie evalboard initialisationMarcel Ziswiler
Implement optional PCIe EvalBoard initialisation which properly reset the PLX (now Avago) PEX 8605 PCIe switch plus PCIe devices on the Apalis Evaluation carrier board. Please note that you will have to enable the second PCIe port in the dts as well e.g.: diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts index be4f4d6..321c7d6 100644 --- a/arch/arm/dts/tegra30-apalis.dts +++ b/arch/arm/dts/tegra30-apalis.dts @@ -59,6 +59,7 @@ }; pci@2,0 { + status = "okay"; nvidia,num-lanes = <1>; }; Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22apalis_tk1: fix gigabit ethernet initialisationMarcel Ziswiler
Make sure the Intel i210 gigabit Ethernet controller gets properly enabled by disabling DEV_OFF_N in the initialisation sequence. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22apalis_tk1: fix pcie gigabit ethernet initialisationMarcel Ziswiler
Fix PCIe gigabit Ethernet initialisation by explicitly controlling +V3.3_ETH provided by LDO9 and LDO10. Note: For this to work an assembly option needs to be patched on the current prototypes. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-22colibri_imx6: update do_patch_ddr_size to parse ivt and dcdMax Krummenacher
Newer U-Boot changed the DCD alignment with the effect that the MMDCx_MDCTL reg/val pair moved 4 bytes. Move away from a hardcoded offset and parse the IVT and DCD table to find the correct location. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-21apalis_tk1: fix l4t booting by removing noatime mount optionMarcel Ziswiler
Get rid of the noatime mount option as L4T resp. Ubuntu does not seem to like that one at all and rather fails booting as follows: * Starting NVIDIA specific init script [fail] ... * Starting NSM status monitor [ OK ] The disk drive for / is not ready yet or not present. keys:Continue to wait, or Press S to skip mounting or M for manual recovery * Starting NSM status monitor [ OK ] ... * Starting NSM status monitor [fail] * Stopping NSM status monitor [ OK ] * Starting Bridge socket events into upstart [ OK ] The mount now defaults to relatime. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30apalis/colibri_imx6: availability check for update fusing commandColibri_iMX6_LinuxImageV2.6Beta1_20160331Colibri_VF_LinuxImageV2.6Beta1_20160331Colibri_T30_LinuxImageV2.6Beta1_20160331Colibri_T20_LinuxImageV2.6Beta1_20160331Apalis_iMX6_LinuxImageV2.6Beta1_20160331Apalis_T30_LinuxImageV2.6Beta1_20160331Marcel Ziswiler
Adding command availability check for update fusing command useful for update scripts. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-30apalis/colibri_imx6: adding update fusing commandMarcel Ziswiler
Adding update fusing command to assist in updating modules to the fast boot mode as per the following article on our developer website: http://developer.toradex.com/knowledge-base/linux-booting#eMMC_Fast_Boot_Mode_ApalisColibri_iMX6 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30colibri_imx7: cleanup configuration header fileMarcel Ziswiler
2016-03-30toradex boards: updating maintainers file with new web urlMarcel Ziswiler
2016-03-30colibri_imx7: adding maintainers fileMarcel Ziswiler
2016-03-30colibri_vf: use same NAND clock as Linux usesStefan Agner
Currently a divider of 6 has been used, leading to following NAND Flash Controller (NFC) clocks: VF61: 27.7 MHz (166.7MHz bus clock) VF50: 22 MHz (132MHz bus clock) The NAND Flash Memory used on VF50 allows to use clock speed of up to 33MHz, while the Flash Memory of VF61 allows 50MHz. We can use the same divider of 4 on both modules to configure the maximal possible clock speeds: VF61: 41.7 MHz VF50: 33 MHz Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-30colibri_imx7: add RN5T567 PMIC support to board fileStefan Agner
Configure the Ricoh PMIC RN5T567 at startup to reset the board without delay. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-30power: pmic: add Ricoh RN5T567 PMIC supportStefan Agner
Add power driver for Ricoh PMIC used on Colibri iMX7. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-09colibri_vf: read kernel and device tree from static UBI volumesColibri_iMX7_LinuxImageV2.6Alpha1_20160315Stefan Agner
With the next release our update scripts write the kernel and device tree in seperate UBI volumes. This allows to use a lot less UBI/UBIFS support in U-Boot, which should lower the risk of hitting bugs in this area. Boot times are also slightly faster (measurements showed an improvement of ~150ms). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-09colibri_imx7.c: Use externel PHY clockMax Krummenacher
2016-03-09mx7/soc.c: remove bmode usb, currently not workingMax Krummenacher
