2016-03-09apalis_tk1: adjust defargs for l4t r21.4 bootingMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09Revert "tools: make imxheader size align on page size"Max Krummenacher
This reverts commit c31a8b2bdb47dc8fa71c259423bd8fed840b8a25. The introduction of a union results in correct alignment. The additional reserved word now misaligns the structure again. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Conflicts: tools/imximage.h
2016-03-09colibri_imx7.h: load flashscript from {board}/ directoryMax Krummenacher
2016-03-09apalis_imx6_it_defconfig: add options needed with 3.14.52_1.1.0_gaMax Krummenacher
2016-03-09lcd.c: fix compiler warningMax Krummenacher
2016-03-09apalis_tk1: updated regulator naming in device treeMarcel Ziswiler
Updated regulator naming in device tree as discussed with Stefan earlier. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09toradex: configblock: add Apalis TK1 2GBMarcel Ziswiler
2016-03-09toradex: configblock: cap product idMarcel Ziswiler
Cap product id to avoid issues with a yet unknown one. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09common/Kconfig: add TRDX_CFG_BLOCK_OFFSET2Max Krummenacher
2016-03-09colibri_imx7.h: remove fix MAC addr from default configurationMax Krummenacher
As we now have the configblock handling the MAC address is set from the configblock. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7: add trdx configblock handlingMax Krummenacher
2016-03-09configblock: add Colbri iMX7Max Krummenacher
2016-03-09colibri_imx7: add do_fuse commandMax Krummenacher
Used during manufacturing for setting the boot fuses. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7.c: Prepare for externel PHY clockMax Krummenacher
While at it fix whitespace issue. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7.c: add nand boot modeMax Krummenacher
While at it remove unusable boot modes from the list. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7.h: remove CONFIG_SYS_USE_NANDMax Krummenacher
This lives now in colibri_imx7_defconfig Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09cmd_writebcb_mx7: add command to write FCB, DBBT, Bootloader on MX7Max Krummenacher
Code mostly ported from imx-kobs-5.3. MTD partitioning is set accordingly. writebcb: Write Boot Control Block (FCB and DBBT) writeboot: Write bootloadder Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09lib/bch.c: modify algorithm to conform to iMX7 FCB needsMax Krummenacher
Modification taken from imx-kobs-5.3. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09cmd_nand.c: make raw_access() externMax Krummenacher
We need raw nand access to write the fcb in cmd_writebcb_mx7. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7_defconfig: set SYS_BOOT_NANDMax Krummenacher
All fsl boards use this when booting from NAND. While at it minimize it with savedefconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7: add I2C information for Colibri I2C busStefan Agner
Add pinmux and I2C setup call to register the Colibri I2C bus. The fourth (I2C4) instance is used for the I2C bus defined in the standard Colibri pinout. Use i2c dev 3 to switch to this bus. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-09arm: imx7d: fix input mux for UART2 DTE modeStefan Agner
Note that this input mux seems to be missing in the current reference manual, but has been proven to be working on actual hardware. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-09colibri_imx7.c: fix ethernetMax Krummenacher
HW patch required. Connect RMII_CRS_DV - ENET1_RXC, remove R166 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7.c: fix WEAK_PULLxx macrosMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7.h: change mtd partitionining for kobs-ngMax Krummenacher
kobs-ng needs a partition which holds FCB, DBBT, and Bootloader, not FCB, DBBT alone. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09cmd_writebcb.c: add i.MX7 struct membersMax Krummenacher
2016-03-09colibri_imx7.h: unify config and environmentMax Krummenacher
2016-03-09colibri_imx7.c: add NAND bmodeMax Krummenacher
2016-03-09colibri_imx7.h: remove CONFIG_VIDEO_MODE / panelMax Krummenacher
2016-03-09colibri_imx7.h: set fdt_file for Colibri iMX7Max Krummenacher
2016-03-09colibri_imx7.h: updateMax Krummenacher
2016-03-09colibri_imx7.c: adapt ENET1Max Krummenacher
Output 50MHz reference clock works, sending works but no reception. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7.c: adapt USBMax Krummenacher
2016-03-09colibri_imx7.c: adapt NANDMax Krummenacher
2016-03-09colibri_imx7.c: adapt MMC/SDMax Krummenacher
2016-03-09colibri_imx7.c: adapt displayMax Krummenacher
2016-03-09colibri_imx7.c: adapt pwr_i2cMax Krummenacher
2016-03-09colibri_imx7.c: adapt dte uartMax Krummenacher
2016-03-09colibri_imx7.c: remove unused subsystemsMax Krummenacher
2016-03-09colibri_imx7.c: sort PAD_MUX valuesMax Krummenacher
2016-03-09DDR3 conf: autodetect RAM sizeMax Krummenacher
Use get_ram_size() to autodetect up to 2Gbyte of RAM on rank 0. If chips with two ranks would get stuffed one would have to set the size of one rank in DDRC_ADDRMAP0. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx7.c: remove pfuze300 pmic codeMax Krummenacher
The Colibri iMX7 uses a different pmic Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09imximage.cfg: check ram timings and align with mainlineMax Krummenacher
2016-03-09colibri_imx7: add initial, cp from mx7sabresdMax Krummenacher
2016-03-09mx7dsabresd: add NAND/UBI to configMax Krummenacher
2016-03-09iMX6/7 soc.c: allow for board supplied serialMax Krummenacher
Introduce CONFIG_SERIAL_TAG_BOARD which removes the definition of void get_board_serial(struct tag_serialnr *serialnr) in order to allow its definition in board specific code. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09Apalis/Colibri iMX6: add additional configsMax Krummenacher
Add configs now needed with the update of U-Boot. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09colibri_imx6.c: follow function signature changeMax Krummenacher
2016-03-09Apalis/Colibri iMX6: add callback for CONFIG_LDO_BYPASS_CHECKMax Krummenacher
Add empty callback now needed when CONFIG_LDO_BYPASS_CHECK is defined. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-09MLK-11825 imx: mx6dqp: update ddr script to 1.13Peng Fan
http://sw-stash.freescale.net/projects/IMX/repos/ddr-scripts-rel/commits/8111e4d0cd81226899be637013048281e3c097b4 http://compass.freescale.net/livelink/livelink?func=ll&objId=234753630&objAction=browse&viewType=1 arik_r2_sabre_ddr3_528_1.13.inc is for sabre-AI arik_r2_sdb_ddr3_528_1.13.inc is for sabresd 1.13<-1.12: Change log: 1. Remove 20c4080 1.12<-1.10 Change log: 1. NoC register DDRCONF change to 0 which is compatible for only CS0 is used on board 2. Change 2 values to compatible with our DDR aid script, these two registers doesn’t have any effect on current system tRPA = 0; //this bit only used in DDR2 mode tAOFPD/tAONPD=0x4; //These register only works when MDPDC. SLOW_PD = 1 which is 0 in script Test results: One mx6qp-sdb and one mx6qp-ard board and one mx6qp-ard board passed 60 hours memtester stress teset. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> (cherry picked from commit 5fb08a4dcc7b8478fc4236b90ad8dc2190cf94e7)
