2014-12-19colibri_vf: set USB vendor and product ID when using DFUColibri_VF_LinuxImageV2.3Beta5_20141219Colibri_T30_LinuxImageV2.3Beta5_20141219Apalis_T30_LinuxImageV2.3Beta5_20141219Stefan Agner
Set USB vendor and product ID of the module when using DFU. This allows to identify the module over USB and act accordingly if necessary (e.g. flash different version or root filesystem or similar use cases). Also the serial number of the USB device is visible by using the lsusb utility: $ lsusb -d 1b67: -v Bus 002 Device 092: ID 1b67:0018 Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 2 Communications bDeviceSubClass 2 Abstract (modem) bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x1b67 idProduct 0x0018 bcdDevice 2.21 iManufacturer 1 Toradex iProduct 2 USB download gadget iSerial 3 4799890 ...
2014-12-16colibri_vf: switch console to ttyLP0 by defaultStefan Agner
Switch default console to ttyLP0 by default since future image will use the mainline kernel which uses the lpuart driver.
2014-12-03ARM: vf610: fix DIV_SELECT and clear it for USB PLL'sStefan Agner
Fix the DIV_SELECT definition for PLL3 and PLL7, but don't set it in the PLL control registers since USB needs a clock multiplier of 20 to get 480MHz. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2014-11-27arm: vf610: improve evaluation of reset sourceStefan Agner
Improve the evaluation of the reset source. Bit description according to latest reference manual rev. 7.
2014-11-27colibri_vf: set environment range correctStefan Agner
Environment range is used to move the config block to the next block in case the first erase block of the environment is marked as bad block. The absence of this config made saving of the environment impossible when the first block of the environment partition was marked bad.
2014-11-25colibri_vf/usb: fix multiple USB controller usageStefan Agner
Fix usage of multiple USB controllers by setting returning ENODEV for the respective controllers when trying to initialize them in the non-standard mode (on USBH allows only host mode, on USBC allow only device mode).
2014-11-25colibri_vf: Enable USB support for Colibri VybridSanchayan Maity
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2014-11-25usb: host: Add ehci-vf USB driver for ARM Vybrid SOC'sSanchayan Maity
2014-11-25colibri_vf: Enable USB peripheralsSanchayan Maity
Enable clock and PLL's for USB Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2014-11-25ARM: vf610: Add USB peripheral supportSanchayan Maity
2014-11-25mtd/nand/vf610_nfc: Disable subpage writesSanchayan Maity
This patch disables subpage writes for vf610_nfc nand driver. This is required as without this fix, writing unaligned u-boot images with DFU results in a hang. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2014-11-19colibri_vf: switch to Thumb2 buildsStefan Agner
Switch to Thumb to builds which are considerable smaller: 415512 19. Nov 14:52 ../u-boot-toradex/u-boot.imx vs. 313112 19. Nov 14:55 ../u-boot-toradex/u-boot.imx Especially download time through serial loader is linearly to size, hence download time is faster by 25% too.
2014-11-19arm: make arch memset/memcpy to work with Thumb2 buildsStefan Agner
Resynchronize memcpy/memset with kernel and build them explicitly in Thumb2 mode (unified syntax). Those assembler files can be built and linked in ARM mode too, however when calling them from Thumb2 built code, the stack got corrupted and the copy did not succeed (the exact details have not been traced back). Hoever, the Linux kernel builds those files in Thumb2 mode. Hence U-Boot should build them in Thumb2 mode too when CONFIG_SYS_THUMB_BUILD is set. Also add implicit-it=always to AFLAGS when building for Thumb2. Furthermore add no-warn-deprecated option to AFLAGS to rid of deprecated unified syntax: arch/arm/lib/memcpy.S: Assembler messages: arch/arm/lib/memcpy.S:153: Warning: conditional infixes are deprecated in unified syntax arch/arm/lib/memcpy.S:154: Warning: conditional infixes are deprecated in unified syntax ...
2014-11-18toradex: improve configblock error handlingStefan Agner
Improve error handling in common configblock code. Also fixes a warning when loading configblock from NAND (unused variable offset).
2014-11-18colibri_vf: calculate and set secondary MAC addressStefan Agner
In order to support dual ethernet configurations, a second MAC address is needed. Toradex assignes two addresses for each module, one address is the serial number, and the second is the serial number with an offset of 0x100000.
2014-10-31fw_env.h: include autoconf.hColibri_VF_LinuxImageV2.3Beta3_20141031Colibri_T30_LinuxImageV2.3Beta3_20141031Apalis_T30_LinuxImageV2.3Beta3_20141031Max Krummenacher
Without this, when CONFIG_ENV_VARS_UBOOT_CONFIG is active we get a compile time error when doing 'make env'. In file included from tools/env/fw_env.c:117:0: include/env_default.h:110:11: error: expected ‘}’ before ‘CONFIG_SYS_ARCH’ When building U-Boot this is included indirectly by the compiler switch -include /home/trdx/git.toradex.com/u-boot-2014.10-toradex/include/linux/kconfig.h
2014-10-28net: asix: fix operation without eepromMarcel Ziswiler
This patch fixes operation of our on-board AX88772B chip without EEPROM but with a ethaddr coming from the regular U-Boot environment. This is a forward port of some remaining parts initially implemented by Antmicro.
2014-10-28arm: vf610: extract leveling parameter in a structStefan Agner
DDR leveling parameters are board specific, hence we should be able to set them differently per board. Extract the leveling parameters in a seperate struct to be able to set them per board.
2014-10-28arm: vf610: improve DDR initializationStefan Agner
With the new JEDEC standardized initialization parameter, the initialization takes longer than 200us. Use the status bit to determine whether the memory initialization was completed. Also use recommended JEDEC defaults for t_INIT.
2014-10-28colibri_vf: use PLL1 as DDR clock on VF50Stefan Agner
On VF50, we can use PLL1 as DDR clock since the CPU is clocked with 400MHz as well. This saves some power (measured around ~10mW).
2014-10-28colibri_vf: read Toradex config blockStefan Agner
Add Toradex config block support using the new common config block handling. Extend common config block handling to support reading from NAND too.
2014-10-28apalis/colibri_t30: migrate and integrate new update conceptMarcel Ziswiler
Migrate Apalis/Colibri T30 to U-Boot 2014.10 and integrate new update concept based on Apalis/Colibri iMX6 and Colibri VF50/VF61.
2014-10-23toradex: add common config block codeMarcel Ziswiler
Add common confg block hanlding. The config block is a Toradex specific data structure containing manufacturing data and static module information such as ethernet address.
2014-10-23e1000: reduce i210/i211 hackMarcel Ziswiler
Now that the FW/SW synchronisation is fixed we can reduce the hack introduced by the following commit: 02bf24ad4a7c882e25771f656b973d5458695cf0 e1000: i210/i211 hack Note that we leave one final hack for now required for unprogrammed i210 operation.
2014-10-23e1000: fix sw fw sync on igb i210/i211Marcel Ziswiler
I finally had a look at the datasheet and spotted an additional register address difference between regular E1000 and i210/i211 chips. This patch fixes this and now successfully works on programmed i210/i211 as well as unprogrammed i211. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2014-10-23net/e1000: Fix EEPROM access errorYork Sun
Commit 951860634fdb557bbb58e0f99215391bc0c29779 may have changed the logic unintentially from "if (!(swfw_sync & (fwmask | swmask)))" to "if ((swfw_sync & swmask) && !(swfw_sync & fwmask))". This change breaks some e1000 NIC with a message "ERROR: Unable to read EEPROM!". Signed-off-by: York Sun <yorksun@freescale.com> CC: Marek Vasut <marex@denx.de> CC: Tim Harvey <tharvey@gateworks.com>
2014-10-23Revert "dm: tegra: Enable driver model for serial"Marcel Ziswiler
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting slower. With mainline Linux I noticed about a 1 to 2 second increase while booting downstream L4T takes 10 to 15 seconds longer! This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813. Conflicts: drivers/serial/Makefile
2014-10-23colibri_vf: synchronize environment with i.MX6 U-BootStefan Agner
Synchronize environment with i.MX6 U-boot. Load device tree unconditionally, but set parameter to device tree file only when loading succeeded. Also load the device tree when using SD or NFS boot.
2014-10-23colibri_vf: fix environment for NFS/SD-BootStefan Agner
Switch to zImage for SD and NFS-Boot. Explicitly define the load address in all commands.
2014-10-23colibri_vf: extend environmentStefan Agner
Newer UBI implementation do not allow small UBI partitions since the amount of bad blocks is now calculated by the size of the MTD partition (instead volume size). On small partitions, this leads to UBI partitions only consisting of reserved blocks. Therefor we now use only one volume, which also allows better wear leveling and bad block management. Since it is needed to attach the whole UBI partition, mounting the UBI filesystem would be a good option. Measurement showed that the overhead reading from UBI filesystem compared to read from a UBI volume is minimal (below 100ms). Furthermore, this also adds support to load device trees for newer, device tree based kernels. By setting the variable fdt_board, the scripts read the FDT file and try to pass this to the kernel. The FDT file will be concatinated: ${soc}-colibri-{fdt_board}.dtb E.g. when fdt_board is set to "eval-v3", the scripts will load the device tree file "vf610-colibri-eval-v3.dtb" on a Colibri VF61.
2014-10-23arm: vf610: add SoC detectionStefan Agner
Vybrid product family consists of several rather similar SoC which can be determined by softare during boot time. This allows to use the variable ${soc} for Linux device tree files.
2014-10-23arm: vf610: enable cachesStefan Agner
Enables caches which provides a rather huge speedup of the boot loader. Also mark the on-chip RAM as cachable since this is the area U-Boot runs from.
2014-10-23colibri_vf: disable automatic boot when using recovery modeStefan Agner
Since we use the same UART to download U-Boot and get the U-Boot prompt, it is quite hard to switch between the download program and the terminal emulator within the boot delay. This patch disables the automatic boot by setting the bootdelay to -1 when using the recovery mode (serial downloader).
2014-10-23vf610: improve CPU type detectionStefan Agner
Detect VF5xx CPU's by reading the CPU count register. Also we can guess the second number of the CPU type (VF6x0) which indicates the presence of a L2 cache.
2014-10-23colibri vf50/61: detect bad blocks in U-Boot areaStefan Agner
The boot ROM was not able to detect bad blocks in the U-Boot area due to disabled "bad block marking swap" functionality. The description of this field is a bit unclear, but tests show that skipping bad blocks in U-Boot area only work if this field is set to 0.
2014-10-23vf610: enable external 32KHz oscillatorStefan Agner
Enable the SCSC (Slow Clock Source Controller) and select the external 32KHz oscillator. This improves accuracy of the RTC.
2014-10-17arm: vf610: initial integration for Colibri VF50/VF61Stefan Agner
This adds initial support for Colibri VF50/VF61 based on Freescale Vybrid SoC. The board support package is based on Freescale Tower board, with following differences: - CPU clocked at 500MHz - Use PLL2 as DDR3 clock (400MHz) - New Machine ID - Console on UART1 (Colibri UART_A) - Ethernet on FEC1 - Enabled command line editing - PLL5 based RMII clocking (e.g. no external crystal) - UART_A and UART_C I/O muxing - Boot from OCRAM gfxRAM - Boot from NAND by default Tested on Colibri VF50/VF61 booting using serial loader over UART.
2014-10-16imx: add u-boot-nand.imx targetStefan Agner
Add an additional target which prepends the u-boot.imx image with 0x400 padding bytes. On Vybrid, this is required for NAND boot devices. The configuration CONFIG_IMX_NAND enables this image for a board.
2014-10-16imx: add writebcb commandStefan Agner
Add writebcb command which creates a NAND Boot Configuration Block at the beginning of the active flash device. The offset of the boot firmware are specified using arguments, at least one location is mandatory. Currently only the FCB (Firmware Configuration Block) is supported, the DBBT (Discovered Bad Block Table) is optional and is not used currently. The firmware, e.g. U-Boot (along with the IVT header and a 0x400 long prefix) need to be written to NAND seperatly.
2014-10-16tools: make imxheader size align on page sizeStefan Agner
The i.MX V2 headers total size is 0x7fc. The header is placed in front of the U-Boot binary which of course is aligned to text base. Hence the header starting point is not page aligned (e.g. at 0x3f400404). This is still a valid header, which boots fine using serial loader. However, the image fails to boot from NAND (tested on a VF61x SoC). Most parts of the header have a length of a multiply of 16 bytes.The rest of the header is filled with 8 bytes long DCD data. Only the boot data header is 3 word long (12 bytes). This patch makes sure the whole image is exactly 0x800 by adding one padding word after the boot data header. Since the individual data structures are referenced by pointers, this still results in a valid i.MX V2 header while maintaining page alignment.
2014-10-16arm: vf610: move DDR initialization to imx-commonStefan Agner
In order to avoid code duplication move the DDR initialization to the common place under imx-common. Currently, only TREF, TRFC, COL_DIFF and ROW_DIFF can be choosen from board file.
2014-10-14Merge tag 'v2014.10' into 2014.10-toradex-nextMarcel Ziswiler
Prepare v2014.10
2014-10-14Prepare v2014.10v2014.10Tom Rini
2014-10-13sunxi: axp152: dcdc3 scale is 50mV / step not 25mV / stepHans de Goede
Currently uboot wrongly uses 25mV / step for dcdc3, this is a copy and paste error introduced when adding the axp152_mvolt_to_target during review of the axp152.c driver. This results in u-boot setting Vddr to 2.3V instead of 1.5V. This commit fixes this. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-13Makefile: drop "tools-only" from no-dot-config-targetsTom Rini
With the introduction of CONFIG_LOCALVERSION support we cannot build tools without having a config file (as we won't know our PLAIN_VERSION until then). Reported-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Tom Rini <trini@ti.com>
2014-10-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-10-11tegra: apalis_t30: enable gigabit ethernet over pcie supportMarcel Ziswiler
Now with everything in place actually enable i210/i211 aka gigabit Ethernet over PCIe support.
2014-10-11e1000: i210/i211 hackMarcel Ziswiler
Hack driver to avoid the following error for now e1000: e1000#0: ERROR: Hardware Initialization Failed
2014-10-11e1000: add i211 and unprogrammed i210/i211 supportMarcel Ziswiler
This patch adds support for i211 as well as unprogrammed aka tools only i210/i211 chip support. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2014-10-11net: rtl8169: Add support for RTL-8168/8111gThierry Reding
This network interface card in found on the NVIDIA Jetson TK1. Signed-off-by: Thierry Reding <treding@nvidia.com>
