Currently, "nand scrub" runs chip->scan_bbt at the end of
nand_erase_opts() even if NAND_SKIP_BBTSCAN flag is set.
It violates the intention of NAND_SKIP_BBTSCAN.
Move NAND_SKIP_BBTSCAN flag check to nand_block_checkbad() so that
chip->scan_bbt() is never run if NAND_SKIP_BBTSCAN is set.
Also, unset NAND_BBT_SCANNED flag instead of running chip->scan_bbt()
right after scrub. We can be lazier here because the BBT is scanned
at the next call of nand_block_checkbad().
Cc: Scott Wood <scottwood@freescale.com>
Commit 35c204d8a9d0 (nand: reinstate lazy bad block scanning)
broke NAND_BBT_USE_FLASH feature.
Its git-log claimed that it reinstated the change as by commit
fb49454b1b6c ("nand: reinstate lazy bad block scanning"), but it moved
"chip->options |= NAND_BBT_SCANNED" below "chip->scan_bbt(mtd);".
It causes recursion if scan_bbt does not find a flash based BBT
and tries to write one, and the attempt to erase the BBT area
causes a bad block check.
Reinstate commit ff49ea8977b5 (NAND: Mark the BBT as scanned prior to
calling scan_bbt.).
Cc: Rostislav Lisovy <lisovy@merica.cz>
Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14),
the "nand scrub" command has not been working.
Commit ff94bc40af3481d47546595ba73c136de6af6929
("mtd, ubi, ubifs: resync with Linux-3.14")
accidentally reverted part of the commit
13f0fd94e3cae6f8a0d9fba5d367e311edc8ebde
("NAND: Scan bad blocks lazily.").
Reinstate the change as by commit
fb49454b1b6c7c6e238ac3c0b1e302e73eb1a1ea
Signed-off-by: Rostislav Lisovy <lisovy@merica.cz>
Acked-by: Heiko Schocher <hs@denx.de>
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Inorder to use the pins as GPIO, apart from setting the alt-function,
pinmuxing need to be done, this patch adds pinmux entries of
few GPIOs.
Add GPIO support to Freescale VF610
Boot from SD-card (and probably also from NAND) was broken since
commit d6d07a9bec ("arm: vf610: add NAND support for vf610twr").
It looks like the increased size of U-Boot lead to a situation
where the boot ROM overwrote its own stack/heap while loading
U-Boot from the SD-card to the SRAM. However, U-Boot worked fine
when loaded through USB serial loader directly into SRAM. It
looks like loading from SD-card uses other stack/heap location
then the serial loader (or maybe no stack or heap at all).
This fix moves U-Boot to gfxRAM, which is 512kB in size and is not
used by the boot ROM nor the SD-card loader of it.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
http://lists.denx.de/pipermail/u-boot/2012-September/134347.html
allows for reading files in chunks from the shell.
When this feature is used to read past the end of a file an error
was returned instead of returning the bytes read up to the end of
file. Thus the following fails in the shell:
offset = 0
len = chunksize
do
read file, offset, len
write data
until bytes_read < len
The patch changes the behaviour to printing an informational
message and returning the actual read number of bytes.
(cherry picked from commit 4641b92713300089c5980259ba31e668657aa75d)
Add missing absolute /boot path for dtb file
in sddtbload variable.
Add consoleblank=0 to disable console blanking by default. To use
initramfs without the need of creating a U-Boot image using mkimage,
enable CONFIG_SUPPORT_RAW_INITRD too.
Add default environment variable allowing update of the on-board flash
using USB mass storage in addition to SD card.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
[merged with SD-card update script]
Allow bit flips in a empty page up to half of the recoverable
bits (strength / 2). Some flash show bit flips in empty pages
which are larger then the corrected bit count according to the
ECC controller. It is not yet clear how to solve this correctly,
discussion is ongoing:
http://thread.gmane.org/gmane.linux.ports.arm.kernel/295424
Since we habe a 24-bit correction, this allows up to 12 bit
flips on a empty page before reporting it as page with ECC
errors.
Set USB vendor and product ID of the module when using DFU. This
allows to identify the module over USB and act accordingly if
necessary (e.g. flash different version or root filesystem or
similar use cases).
Also the serial number of the USB device is visible by using the
lsusb utility:
$ lsusb -d 1b67: -v
Bus 002 Device 092: ID 1b67:0018
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 2 Communications
bDeviceSubClass 2 Abstract (modem)
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1b67
idProduct 0x0018
bcdDevice 2.21
iManufacturer 1 Toradex
iProduct 2 USB download gadget
iSerial 3 4799890
Switch default console to ttyLP0 by default since future image
will use the mainline kernel which uses the lpuart driver.
Fix the DIV_SELECT definition for PLL3 and PLL7, but don't set
it in the PLL control registers since USB needs a clock multiplier
of 20 to get 480MHz.
Improve the evaluation of the reset source. Bit description according
to latest reference manual rev. 7.
Environment range is used to move the config block to the next block
in case the first erase block of the environment is marked as bad
block. The absence of this config made saving of the environment
impossible when the first block of the environment partition was
marked bad.
Fix usage of multiple USB controllers by setting returning ENODEV
for the respective controllers when trying to initialize them in
the non-standard mode (on USBH allows only host mode, on USBC allow
only device mode).
Enable clock and PLL's for USB
This patch disables subpage writes for vf610_nfc nand
driver. This is required as without this fix, writing
unaligned u-boot images with DFU results in a hang.
Switch to Thumb to builds which are considerable smaller:
415512 19. Nov 14:52 ../u-boot-toradex/u-boot.imx
vs.
313112 19. Nov 14:55 ../u-boot-toradex/u-boot.imx
Especially download time through serial loader is linearly
to size, hence download time is faster by 25% too.
Resynchronize memcpy/memset with kernel and build them explicitly
in Thumb2 mode (unified syntax). Those assembler files can be
built and linked in ARM mode too, however when calling them from
Thumb2 built code, the stack got corrupted and the copy did not
succeed (the exact details have not been traced back). Hoever,
the Linux kernel builds those files in Thumb2 mode. Hence U-Boot
should build them in Thumb2 mode too when CONFIG_SYS_THUMB_BUILD
is set.
Also add implicit-it=always to AFLAGS when building for Thumb2.
Furthermore add no-warn-deprecated option to AFLAGS to rid of
deprecated unified syntax:
arch/arm/lib/memcpy.S: Assembler messages:
arch/arm/lib/memcpy.S:153: Warning: conditional infixes are deprecated in unified syntax
arch/arm/lib/memcpy.S:154: Warning: conditional infixes are deprecated in unified syntax
Improve error handling in common configblock code. Also fixes a
warning when loading configblock from NAND (unused variable offset).
In order to support dual ethernet configurations, a second MAC
address is needed. Toradex assignes two addresses for each module,
one address is the serial number, and the second is the serial
number with an offset of 0x100000.
Without this, when CONFIG_ENV_VARS_UBOOT_CONFIG is active we get
a compile time error when doing 'make env'.
In file included from tools/env/fw_env.c:117:0:
include/env_default.h:110:11: error: expected ‘}’ before ‘CONFIG_SYS_ARCH’
When building U-Boot this is included indirectly by the compiler switch
-include
/home/trdx/git.toradex.com/u-boot-2014.10-toradex/include/linux/kconfig.h
This patch fixes operation of our on-board AX88772B chip without EEPROM
but with a ethaddr coming from the regular U-Boot environment. This is
a forward port of some remaining parts initially implemented by
Antmicro.
DDR leveling parameters are board specific, hence we should be able
to set them differently per board. Extract the leveling parameters
in a seperate struct to be able to set them per board.
With the new JEDEC standardized initialization parameter, the
initialization takes longer than 200us. Use the status bit to
determine whether the memory initialization was completed.
Also use recommended JEDEC defaults for t_INIT.
On VF50, we can use PLL1 as DDR clock since the CPU is clocked
with 400MHz as well. This saves some power (measured around ~10mW).
Add Toradex config block support using the new common config block
handling. Extend common config block handling to support reading
from NAND too.
Migrate Apalis/Colibri T30 to U-Boot 2014.10 and integrate new update
concept based on Apalis/Colibri iMX6 and Colibri VF50/VF61.
Add common confg block hanlding. The config block is a Toradex
specific data structure containing manufacturing data and static
module information such as ethernet address.
Now that the FW/SW synchronisation is fixed we can reduce the hack
introduced by the following commit:
02bf24ad4a7c882e25771f656b973d5458695cf0
e1000: i210/i211 hack
Note that we leave one final hack for now required for unprogrammed
i210 operation.
I finally had a look at the datasheet and spotted an additional
register address difference between regular E1000 and i210/i211 chips.
This patch fixes this and now successfully works on programmed
i210/i211 as well as unprogrammed i211.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Commit 951860634fdb557bbb58e0f99215391bc0c29779 may have changed
the logic unintentially from "if (!(swfw_sync & (fwmask | swmask)))"
to "if ((swfw_sync & swmask) && !(swfw_sync & fwmask))". This change
breaks some e1000 NIC with a message "ERROR: Unable to read EEPROM!".
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Marek Vasut <marex@denx.de>
CC: Tim Harvey <tharvey@gateworks.com>
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting
slower. With mainline Linux I noticed about a 1 to 2 second increase
while booting downstream L4T takes 10 to 15 seconds longer!
This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813.
drivers/serial/Makefile
Synchronize environment with i.MX6 U-boot. Load device tree
unconditionally, but set parameter to device tree file only when
loading succeeded. Also load the device tree when using SD or NFS
boot.
Switch to zImage for SD and NFS-Boot. Explicitly define the load
address in all commands.
Newer UBI implementation do not allow small UBI partitions since
the amount of bad blocks is now calculated by the size of the MTD
partition (instead volume size). On small partitions, this leads
to UBI partitions only consisting of reserved blocks. Therefor we
now use only one volume, which also allows better wear leveling
and bad block management.
Since it is needed to attach the whole UBI partition, mounting
the UBI filesystem would be a good option. Measurement showed that
the overhead reading from UBI filesystem compared to read from
a UBI volume is minimal (below 100ms).
Furthermore, this also adds support to load device trees for newer,
device tree based kernels. By setting the variable fdt_board, the
scripts read the FDT file and try to pass this to the kernel. The
FDT file will be concatinated:
${soc}-colibri-{fdt_board}.dtb
E.g. when fdt_board is set to "eval-v3", the scripts will load the
device tree file "vf610-colibri-eval-v3.dtb" on a Colibri VF61.
Vybrid product family consists of several rather similar SoC which
can be determined by softare during boot time. This allows to use
the variable ${soc} for Linux device tree files.
Enables caches which provides a rather huge speedup of the boot
loader. Also mark the on-chip RAM as cachable since this is the
area U-Boot runs from.
Since we use the same UART to download U-Boot and get the U-Boot
prompt, it is quite hard to switch between the download program
and the terminal emulator within the boot delay. This patch
disables the automatic boot by setting the bootdelay to -1 when
using the recovery mode (serial downloader).
Detect VF5xx CPU's by reading the CPU count register. Also we can
guess the second number of the CPU type (VF6x0) which indicates the
presence of a L2 cache.
The boot ROM was not able to detect bad blocks in the U-Boot area
due to disabled "bad block marking swap" functionality. The
description of this field is a bit unclear, but tests show that
skipping bad blocks in U-Boot area only work if this field is set
to 0.
Enable the SCSC (Slow Clock Source Controller) and select the
external 32KHz oscillator. This improves accuracy of the RTC.
This adds initial support for Colibri VF50/VF61 based on Freescale
Vybrid SoC. The board support package is based on Freescale Tower
board, with following differences:
- CPU clocked at 500MHz
- Use PLL2 as DDR3 clock (400MHz)
- New Machine ID
- Console on UART1 (Colibri UART_A)
- Ethernet on FEC1
- Enabled command line editing
- PLL5 based RMII clocking (e.g. no external crystal)
- UART_A and UART_C I/O muxing
- Boot from OCRAM gfxRAM
- Boot from NAND by default
Tested on Colibri VF50/VF61 booting using serial loader over UART.
