2014-12-19colibri_imx6.h: fix syntax in vidargsColibri_iMX6_LinuxImageV2.3Beta5_20141219Apalis_iMX6_LinuxImageV2.3Beta6_20150112Apalis_iMX6_LinuxImageV2.3Beta5_201412192014.04-toradexMax Krummenacher
2014-12-10colibri_imx6.h: default to VGA on parallel RGBMax Krummenacher
2014-12-10colibri-imx6: add board_rev to the U-Boot environmentMax Krummenacher
Unify code with Apalis iMX6 while not changing behaviour Add board_rev to the U-Boot environment. On V1.0A HW: 010a Add CONFIG_ENV_VARS_UBOOT_CONFIG
2014-12-10apalis-imx6: add HW revision detectionMax Krummenacher
- Default to DTE UART mode, as used on HW V1.1 but automatically fall back to use DCE UART on V1.0 HW. - If using the default device tree filename imx6q-apalis-eval.dtb, switch to the V1.0 devicetree on V1.0 HW. If device tree name is not the default leave it alone. - Add board_rev to the U-Boot environment. On V1.0A HW: 010a - Add CONFIG_ENV_VARS_UBOOT_CONFIG
2014-12-05apalis imx6: add inital configuration for ITMax Krummenacher
- Add a 2GB RAM configuration with quick and dirty DDR optimization values. - Make sure the device-tree is not relocated to high-memory. - Configure eMMC reset to GPIO with pullup. The boot ROM already did a pulse.
2014-12-05apalis-imx6: pf0100: enable needed voltages when unfusedMax Krummenacher
This is needed during production or Ethernet will not work. This partly reverts commit b5e9ee3bb9ac34d6073083e1ccb4fda3ef45426a. While at it fix coding style.
2014-12-05apalis-imx6: V1.1 HW changesMax Krummenacher
- use PWM 4 through a buffer for BL_PWM - use UARTs in DTE mode (Pinout change from V1.1 HW) - enable mtest
2014-12-05apalis_imx6: use _ in file nameMax Krummenacher
Be consistent with other Toradex products
2014-12-05colibri_imx6: use UART DTE mode unconditionallyMax Krummenacher
2014-12-05colibri_imx6: use _ in file nameMax Krummenacher
2014-10-30Colibri iMX6: use optimized DDR settingsColibri_iMX6_LinuxImageV2.3Beta4_20141113Apalis_iMX6_LinuxImageV2.3Beta3_20141031Max Krummenacher
2014-10-30colibri_imx6.c: enable USB host power consistentlyMax Krummenacher
2014-10-30apalis_imx6.c: enable USB host power consistentlyMax Krummenacher
2014-10-29apalis_imx6.c: divide enet reset from pinmuxingMax Krummenacher
2014-10-29apalis_imx6q.cfg: use correct boot deviceMax Krummenacher
2014-10-29apalis_imx6.c/colibri_imx6.c: use get_ram_size()Max Krummenacher
This gives a fast basic ram test. While at it clean up whitespace
2014-10-28Apalis/Colibri iMX6: cleanup configsMax Krummenacher
remove double defines remove unneeded environment remove usb nic driver move defines to were they logically belong move the (unused) ramdisk_addr_r out of the addresses used for the kernel
2014-10-28do_fuse: enable the fusingMax Krummenacher
2014-10-28apalis_imx6: fix error msg, Apalis vs. ColibriMax Krummenacher
2014-09-18apalis-imx6.h: fix LVDS panel name in environmentMax Krummenacher
2014-09-18colibri-imx6.h: add vidargs example for HDMIMax Krummenacher
2014-09-18colibri-imx6: pf0100.c: fix pin assignment for VPGM enMax Krummenacher
2014-09-10colibri-imx6.h: adapt vidargs for i.MX6S/DLMax Krummenacher
2014-09-10colibri-imx6.h: set module parameter galcoreMax Krummenacher
Without this X does not start on a Colibri iMX6S for lack of RAM. galcore.contiguousSize=50331648 (48MB)
2014-09-04colibri_imx6.c: add patch_ddr_size cmdMax Krummenacher
Adds the patch_ddr_size cmd which patches the DCD data structure settings for the DDR memory controller optimized for the module. Currently this is only the bus width which is changed from 32bit to 64bit on DL modules. This allows to use a unified U-Boot for S and DL modules. Right after flashing the U-Boot to eMMC this cmd will be run to complete the update.
2014-09-04colibri_imx6.c: get the RAM size from the MMDC's configMax Krummenacher
2014-09-04fs/fs.c: read up to EOF when len would read past EOFMax Krummenacher
http://lists.denx.de/pipermail/u-boot/2012-September/134347.html allows for reading files in chunks from the shell. When this feature is used to read past the end of a file an error was returned instead of returning the bytes read up to the end of file. Thus the following fails in the shell: offset = 0 len = chunksize do read file, offset, len write data until bytes_read < len The patch changes the behaviour to printing an informational message and returning the actual read number of bytes.
2014-09-04colibri-imx6.cfg: fix config variable nameMax Krummenacher
2014-09-01colibri-imx6: initial support for dual-lightMax Krummenacher
2014-09-01apalis-imx6: pf0100: remove settings now fusedMax Krummenacher
2014-09-01apalis-imx6: access GPIO with symbolic namesMax Krummenacher
2014-09-01apalis-imx6: move cfg to board/toradexMax Krummenacher
Prepare for additional SKU's
2014-08-19arm: vf610: lpuart: disable FIFO on initializatonStefan Agner
UART does not use the UART FIFO, but we should also not rely that the UART FIFO is diabled by default. For instance, when loading U-Boot using the boot ROMs serial downloader protocol over UART, FIFO is enabled at U-Boot start time. This patch disables the RX and TX FIFO, sets back their thresholds and flushes them.
2014-08-19arm: vf610: lpuart: correct status register handlingStefan Agner
The status register 1 (S1) is not writeable, hence we should not write it. In order to clear the RDRF flag we only need to read the data register. Also, when stressing U-Boot a lot with serial input, an overflow can occur which asserts the S1_OR flag (while not asserting the S1_RDRF flag). To clear this flag we again just need to read the data register, hence add this flag to the abort conditions for the while loop. Insert a compiler barrier to make sure reading the data register gets executed after reading the status register.
2014-07-24colibri_vf: disable automatic boot when using recovery modeColibri_VF_LinuxImageV2.3Beta1_20140804Apalis_iMX6_LinuxImageV2.3Beta1_20140804Stefan Agner
Since we use the same UART to download U-Boot and get the U-Boot prompt, it is quite hard to switch between the download program and the terminal emulator within the boot delay. This patch disables the automatic boot by setting the bootdelay to -1 when using the recovery mode (serial downloader).
2014-07-24vf610: improve CPU type detectionStefan Agner
Detect VF5xx CPU's by reading the CPU count register. Also we can guess the second number of the CPU type (VF6x0) which indicates the presence of a L2 cache.
2014-07-23colibri vf50/61: detect bad blocks in U-Boot areaStefan Agner
The boot ROM was not able to detect bad blocks in the U-Boot area due to disabled "bad block marking swap" functionality. The description of this field is a bit unclear, but tests show that skipping bad blocks in U-Boot area only work if this field is set to 0.
2014-07-22colibri vf50/61: use PLL2 as DRAM clock sourceStefan Agner
On migration from 2011.11 to 2014.04 U-Boot the initialization code also switched the source of the DRAM clock to system clock. However, since Colibri VF61 runs on 500MHz system clock, we should use PLL2 as DRAM clock. This also broke suspend on resume: The system switches to 24MHz FIRC as system clock when entering suspend mode while still running from DRAM. However, DRAM seems not to work on 24MHz, which then lead to a system freeze during entering suspend mode.
2014-07-21colibri vf50/61: update env config for environmentStefan Agner
Define the environment partition r/w in order to write the environment from Linux. Also define ENV_RANGE to make use of the whole parittion in case the partition contains bad blocks.
2014-07-21Merge branch '2014.04-toradex-next' into 2014.04-toradexMax Krummenacher
2014-07-21apalis-imx6.h: add LVDS vidargs env. variable sampleMax Krummenacher
additionally fix missing whitespace in LCD sample
2014-07-17vf610: enable external 32KHz oscillatorStefan Agner
Enable the SCSC (Slow Clock Source Controller) and select the external 32KHz oscillator. This improves accuracy of the RTC.
2014-07-16apalis-imx6.h: add device tree bootingMax Krummenacher
while at it - clean up environment variables and names - make setupdate work with both SD/MMC slots - add example for VDAC video out
2014-07-16apalis-imx6.h: cleanupMax Krummenacher
2014-07-16boards: add Apalis iMX6 maintainerMax Krummenacher
2014-07-16fs: fat: Fix cache align error message in fatwriteNobuhiro Iwamatsu
Use of malloc of do_fat_write() causes cache error on ARM v7 platforms. Perhaps, the same problem will occur at any other CPUs. This replaces malloc with memalign to fix cache buffer alignment. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Yoshiyuki Ito <yoshiyuki.ito.ub@renesas.com> Tested-by: Hector Palacios <hector.palacios@digi.com> (cherry picked from commit 8abd053cf07a1e4264d59c671e05a602fc7a31ad)
2014-07-15apalis-imx6: use DCE UARTs for nowMax Krummenacher
Apalis iMX6+ 1GB V1.0A V1.0B are wired for DCE, now that the code is prepared for DTE switch back to DCE.
2014-07-15apalis_imx6: update config to changed USB stackMax Krummenacher
2014-07-15apalis-imx6: Enable VERSION_VARIABLEMax Krummenacher
Enable VERSION_VARIABLE in order to be able to check U-Boot version from update scripts.
2014-07-15apalis-imx6: use UARTs in DCE modeMax Krummenacher
The Apalis standart uses the UART in DTE mode. This commit uses UART1 in DTE mode for the U-Boot console and configures all used UARTs to start in DTE mode. Note that for this to work module version V1.0A requires TXD/RXD to be crossed between the Apalis iMX6 and the RS232 transceiver.
