Environment offset was set to block 6 (0xC0000), which is still
inside the U-Boot partition. Since U-Boot is small enouth to fit
in the first 5 blocks, it usually is not an issue, however if
one of this 5 blocks is bad, then the environment overwrites part
of the boot loader. This fix sets the environment to erase block 12
(0x180000).
Increase boot delay to one second again as otherwise one is not able to enter
into the interactive U-Boot console when recovering U-Boot via UART (e.g. doing
./update.sh -d /dev/ttyUSB0).
Change to a Toradex email address.
Properly handle malloc return value.
Re-implement memory kernel argument passing in order to properly use
all available memory even on our currently used kernel.
Re-integrate U-Boot board size limit checking.
Re-add CMD_ASKENV and CMD_EXT2 but disable CMD_FLASH and CMD_LOADB/S
again.
Get rid of spurious double CMD_BOOTZ define.
Enable VERSION_VARIABLE in order to be able to check U-Boot version
from our update scripts.
Change boot delay to zero and enable ZERO_BOOTDELAY_CHECK to be more
in-line with our other BSPs.
Re-integrate vidargs environment handling.
Added setupdate command introduced on Apalis iMX6 to ease update
procedure from SD card.
While at it ran it through checkpatch.pl and cleaned it up.
follow 10fda48779fc86e74e4482cbc7667431237cf60c
i.MX6DQ/DLS: replace pad names with their Linux kernel equivalents
follow 164d98466103a46b7c881149e92ec2a28a6375be
Move setup_sata to common part
follow commit 02824dc78642b3057cc8c1ab7dc32203f55a17fa
ARM: mx6: Update non-Freescale boards to include CPU errata.
follow commit b089d039b1971fc3abfe1d9bcebd0d35245fb110
i2c: update config using mxc driver to new subsystem
follow commit a79854a90f7297ddfda2114c867fd62643fa6e3a
2014.04-colibri_vf
boards.cfg
Move load address to the beginning of RAM to maximize available
RAM for filesystem images.
Use UBI root partition according to MTD partition name.
Use default environment which boots from UBI. Add commands to boot
from NFS or MMC as available on other Toradex modules.
Also configure default IP address and command prompt.
Detect Colibri VF50 modules by read L2 cache configuration of the
running CPU. Colibri VF50 modules come without L2 cache. Configure
CPU clock accordingly.
Add support for Toardex specific config block. This data structure
is available on NAND and written at production time. Get MAC
address as well as serial number and board revision from this
structure.
This enables NAND for Colibri VF61/VF50. The environment is now
taken from NAND. The first block, the boot control block, is
definied as a seperate partition in order for easier erasing.
This adds initial support for Colibri VF61 based on Freescale
Vybrid Tower System TWR-VF65GS10:
- New Machine ID
- Default UART_A on SCI0
- FEC1
- Enabled command line editing
- PLL5 based RMII clocking (e.g. no external crystal)
- UART_A and UART_C I/O muxing
- Boot from OCRAM gfxRAM
Tested on Colibri VF61 V1.1 booting using serial loader over
UART.
Add an additional target which prepends the u-boot.imx image with
0x400 padding bytes. On Vybrid, this is required for NAND boot
devices. The configuration CONFIG_IMX_NAND enables this image
for a board.
Add writebcb command which creates a NAND Boot Configuration Block
at the beginning of the active flash device. The offset of the
boot firmware are specified using arguments, at least one location
is mandatory.
Currently only the FCB (Firmware Configuration Block) is supported,
the DBBT (Discovered Bad Block Table) is optional and is not
used currently.
The firmware, e.g. U-Boot (along with the IVT header and a 0x400
long prefix) need to be written to NAND seperatly.
This adds initial support for Freescale NFC (NAND Flash Controller).
The IP is used in ARM based Vybrid SoCs as well as on some PowerPC
devices. This driver is only tested on Vybrid.
Add pin mux for NAND Flash Controller.
Add NFC (NAND Flash Controller) clock support and enable them
at board initialization time.
The i.MX V2 headers total size is 0x7fc. The header is placed
in front of the U-Boot binary which of course is aligned to
text base. Hence the header starting point is not page
aligned (e.g. at 0x3f400404). This is still a valid header,
which boots fine using serial loader. However, the image
fails to boot from NAND (tested on a VF61x SoC).
Most parts of the header have a length of a multiply of 16
bytes.The rest of the header is filled with 8 bytes long DCD
data. Only the boot data header is 3 word long (12 bytes).
This patch makes sure the whole image is exactly 0x800 by
adding one padding word after the boot data header. Since
the individual data structures are referenced by pointers,
this still results in a valid i.MX V2 header while
maintaining page alignment.
Set DDR_SEL_PAD_CONTR register explicitly to DDR3 which solves DDR3
issues with newer silicon (1.1). This register was added in revision
4 of the Vybrid Reference Manual.
Add CONFIG_SYS_GENERIC_BOARD to use common/board_[fr].c for kzm9g.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Acked-by: Heiko Schocher <hs@denx.de>
This is regression of commit 2035d77d i2c: sh_i2c: Update to new CONFIG_SYS_I2C framework
Before commit 2035d77d, i2c probe command works properly on kzm9g board.
KZM-A9-GT# i2c probe
Valid chip addresses: 0C 12 1D 32 39 3D 40 60
After commit 2035d77d, i2c probe command does not work.
Valid chip addresses: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F
sh_i2c_probe() calls sh_i2c_read(), but read length is 0. So acutally it does not read device at all. This patch prepares dummy buffer and read data into it.
Commit d016dc42cedbf6102e100fa9ecb58462edfb14f8 changed the layout of BCH8 SW
on omap3 boards. We need to adopt the ecc layout for the nand_spl_simle
driver to avoid wrong ecc errors.
Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
Cc: Thomas Weber <thomas.weber@corscience.de>
Commit 890880583d84607e36b52a785a96b167728bbf73 introduced EEPROM parsing and
board detection but faild to return a valid tricorder_eeprom struct for backup
case. When pressing S200 while reading EEPROM we ignore the value. We
returned falsely a tricorder_eeprom struct with uninitialized data which is
just garbage.
Initialize it by zeroing the whole structure.
During switch to device tree, commit 1ecab0f has removed this code.
INFORM4 and INFORM5 registers are used by TRATS2 first stage bootloader for
providing recovery. For normal operation, those two must be cleared out.
This error emerges when one force reset from u-boot's command line for
three times.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
In some use cases, SPL linker script was not updated even when
it should be.
For instance,
$ make tricoder_config all
[ build complete ]
... modify include/configs/tricoder.h
$ make
spl/u-boot-spl.lds should be updated in this case, but it wasn't.
To fix this problem, linker scripts generation should be handled
by $(call if_changed_dep,...) rather than by $(call if_changed,...).
Reported-by: Andreas Bießmann <andreas.devel@googlemail.com>
Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
include/configs/trats.h
include/configs/trats2.h
include/mmc.h
This patch add gicv3 support to uboot armv8 platform.
Changes for v2:
- rename arm/cpu/armv8/gic.S with arm/lib/gic_64.S
- move smp_kick_all_cpus() from gic.S to start.S, it would be
implementation dependent.
- Each core initialize it's own ReDistributor instead of master
initializeing all ReDistributors. This is advised by arnab.basu
<arnab.basu@freescale.com>.
Signed-off-by: David Feng <fenghua@phytium.com.cn>
The conditional is using a variable that is not defined.
Signed-off-by: Rommel G Custodio <sessyargc+u-boot@gmail.com>
When flush the d$ with set/way instruction, it need calculate the way's
offset = log2(Associativity); but in current uboot's code, it use below
formula to calculate the offset: log2(Associativity * 2 - 1), so finally
it cannot flush data cache properly.
Signed-off-by: Leo Yan <leoy@marvell.com>
For ARMv8, U-boot has been running at EL3 with cache and MMU enabled.
Without proper setup for EL2, cache and MMU are both disabled (out of
reset). Before switching, we need to flush the dcache to make sure the
data is in the main memory.
Signed-off-by: York Sun <yorksun@freescale.com>
Acked-by: David.Feng <fenghua@phytium.com.cn>
Get rid of double VF610_PAD_DDR_A15__DDR_A_15 iomux configuration.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This patch contains several changes required for second Ethernet
(enet1/RMII1) port on vf610
- ANADIG PLL5 control definitions required for Ethernet RMII1 clock
- Secondary Ethernet (enet1) MAC RMII1 base address definition
- RMII1 iomux definitions
- VF610_PAD_PTA6__RMII0_CLKOUT iomux definition required for
internal (e.g. crystal-less) Ethernet clocking.
[stefan@agner.ch: regrouped patch]
Signed-off-by: Stefan Agner <stefan@agner.ch>
Add CCM_CCGR0_UART0_CTRL_MASK clock definition and add TX/RX iomux
definitions for UART0 (aka. SCI0).
The anadig_reg structure started at the wrong offset (fixed by adding
reserved_0x000[4]), was missing some reserved field required for
alignment purpose (reserved_0x094[3] between pll4_denom and pll6_ctrl)
and further contained a too short reserved field causing further miss-
alignment (reserved_0x0C4[7]). Also, rename all the reserved fields
and using a memory offset based scheme for.
Discovered and tested by temporarily putting the following debug
instrumentation into board_init():
struct anadig_reg *anadig = (struct anadig_reg *)ANADIG_BASE_ADDR;
printf("&anadig->pll3_ctrl=0x%p\n", &anadig->pll3_ctrl);
printf("&anadig->pll5_ctrl=0x%p\n", &anadig->pll5_ctrl);
After Kbuild introduction, the CROSS_COMPILE environment variable has been
set to some default value (prefix arm-linux-).
This shall be removed since it breaks building u-boot for native arm target
(like qemu ARM).
Moreover not all compilers have arm-linux- prefix.
Additionally the u-boot cross compiles with CROSS_COMPILE= set explicitly-
e.g.:
CROSS_COMPILE=/ .... /arm-v7a-linux-gnueabi- make
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Since MX6 is Cortex-A9 r2p10, enable software workaround
for errata 794072 and 761320.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
Full cache line writes to the same memory region from at least two
processors might deadlock the processor. Exists on r1, r2, r3
revisions.
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
A short loop including a DMB instruction might cause a denial of
service on another processor which executes a CP15 broadcast operation.
Exists on r1, r2, r3, r4 revisions.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
When SoC first boots up, we should invalidate the cache but not flush it.
We can use the same function for invalid and flush mostly, with a wrapper.
Invalidating large cache can ben slow on emulator, so we postpone doing
so until I-cache is enabled, and before enabling D-cache.
CC: David Feng <fenghua@phytium.com.cn>
If D-cache is enabled, we need to flush it, and invalidate i-cache before
jumping to the new location. This should be done right after relocation.
Move setting for MAIR and TCR to cache_v8.c, to avoid conflict with
sub-architecture.
Avoids "could not find output section .gnu.hash" ld.bfd errors on openSUSE.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Andreas Färber <afaerber@suse.de>
Clock Manager driver will be called to reconfigure all the
clocks setting based on user input. The input are passed to
Preloader through handoff files
Signed-off-by: Chin Liang See <clsee@altera.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
We've run into a non-trivial conversion to CONFIG_SYS_GENERIC_BOARD so
we'll postpone this notice until right after v2014.04 is out.
This reverts commit 36c4b1d98059244c34ec3327d9cc9f3c552fd01b.
This patch adds the groundwork for generating signed BootStream, which
can be used by the HAB library in i.MX28. We are adding a new target,
u-boot-signed.sb , since the process for generating regular non-signed
BootStream is much easier. Moreover, the signed bootstream depends on
external _proprietary_ _binary-only_ tool from Freescale called 'cst',
which is available only under NDA.
To make things even uglier, the CST or HAB mandates a kind-of circular
dependency. The problem is, unlike the regular IVT, which is generated
by mxsimage, the IVT for signed boot must be generated by hand here due
to special demands of the CST. The U-Boot binary (or SPL binary) and IVT
are then signed by the CST as a one block. But here is the problem. The
size of the entire image (U-Boot, IVT, CST blocks) must be appended at
the end of IVT. But the size of the entire image is not known until the
CST has finished signing the U-Boot and IVT. We solve this by expecting
the CST block to be always 3904B (which it is in case two files, U-Boot
and the hand-made IVT, are signed in the CST block).
