We must enable the external 32kHz oscillator in order to work
around a known clock drift issue with the internal 32kHz oscillator.
This fixes the Linux kernel system clock drift.
Signed-off-by: Anthony Huereca <B04178@freescale.com>
Signed-off-by: Jiri Kotzian <B36968@freescale.com>
Signed-off-by: Justin Waters <justin.waters@timesys.com>
When enable the hardware ecc in kernel, there are crc errors
for JFFS2 filesystem after write to the filesystem.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
On some platform, such as vybrid, there is no scr register,
but the dis-order excution may wrongly excute the register write.
The barrier used to prevent this.
Without the fix, flash_write_cfibuffer will terminate the erased
status check once an all-0xFF word has been found instead of
continuing the erased status check utill the first non-0xFF word.
Signed-off-by: Tao Hou <hotforest@gmail.com>
Cc: Stefan Roese <sr@denx.de>
This patch adds FAT and ext2 command support for marvell gplugD
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
This patch adds support for USB commands and USB storage device for
Marvell gplugD
This patch adds support for USB EHCI driver for Armada100 SOCs.
This patch adds USB host controller's UTMI PHY interface driver for
Armada100 SOCs.
The dev->req_config flag was indicating that the forwarded
request needs to perform the usb gadget delayed status.
This is however not needed anymore, so it can be removed.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
While receiving packets from FIFO sometimes the buffer provided was
nonaligned. Fix this by taking a temporary aligned buffer and then
copying the content to nonaligned buffer.
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
This patch adds the support for usb device high speed for designware peripheral.
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
This patch fixes a few bugs in USB device controller driver.
The fixes are as follows
1. Adding error condition checks eg. NULL return
2. Endpoint other than endpoint 0 (control endpoint) are initialized
only if usb state machine reaches STATE_ADDRESSED or above
3. Zero length packet handling corrected
4. Dead code removed
5. Bulk out endpoint returns after servicing 1 interrupt and returns
back to service if more interrupts are pending
The earlier usb device controller driver was specific to spear platforms. This
patch implements the usb device controller driver as a generic controller which
can be reused by other platforms using this peripheral.
Common code has a mdelay() func, so use that instead of the usb-specific
wait_ms() func. This also fixes the build errors:
ohci-hcd.c: In function 'submit_common_msg':
/usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available
ohci-hcd.c:1519:9: sorry, unimplemented: called from here
ohci-hcd.c:1816:10: sorry, unimplemented: called from here
ohci-hcd.c:1827:10: sorry, unimplemented: called from here
ohci-hcd.c:1844:10: sorry, unimplemented: called from here
ohci-hcd.c:1563:11: sorry, unimplemented: called from here
ohci-hcd.c:1583:9: sorry, unimplemented: called from here
make[1]: *** [ohci-hcd.o] Error 1
musb_hcd.c: In function 'musb_submit_rh_msg':
musb_hcd.c:827:2: warning: format '%d' expects type 'int',
but argument 3 has type 'long unsigned int'
Add calls to bootstage before and after relocation, and just
before jumping to the OS.
The idea here is you can call bootstage_report() to get a report.
Additionally, if you define CONFIG_BOOTSTAGE_REPORT then a report is
printed automatically by U-Boot just before jumping to the kernel.
This inserts bootstage calls into tftp, usb start and bootm. We
could go further, but this is a reasonable start to illustrate
the concept.
This defines the basics of a new boot time measurement feature. This allows
logging of very accurate time measurements as the boot proceeds, by using
an available microsecond counter.
To enable the feature, define CONFIG_BOOTSTAGE in your board config file.
Also available is CONFIG_BOOTSTAGE_REPORT which will cause a report to be
printed just before handing off to the OS.
Most IDs are not named at this stage. For that I would first like to
renumber them all.
Timer summary in microseconds:
Mark Elapsed Stage
0 0 reset
205,000 205,000 board_init_f
6,053,000 5,848,000 bootm_start
6,053,000 0 id=1
6,058,000 5,000 id=101
6,058,000 0 id=100
6,061,000 3,000 id=103
6,064,000 3,000 id=104
6,093,000 29,000 id=107
6,093,000 0 id=106
6,093,000 0 id=105
6,093,000 0 id=108
7,089,000 996,000 id=7
7,089,000 0 id=15
7,089,000 0 id=8
7,097,000 8,000 start_kernel
These calls should not be made directly any more, since bootstage
will call the show_boot_...() functions as needed.
Define timer_get_boot_us() which returns the number of microseconds
since boot. If undefined then we use get_timer() * 1000.
We can fit this in a 32-bit register which keeps everyone happy on
the efficiency side. It will wrap around after about an hour. If we
are still looking at it after an hour then we had better not be
timing the boot.
This changes over all the FIT image progress numbers to use enums
from bootstage.h.
This changes over the network-related progress numbers to use enums
from bootstage.h.
This changes over the NAND progress numbers to use enums from
bootstage.h.
This changes over the IDE progress numbers to use enums from bootstage.h.
Rather than the caller negating our progress numbers to indicate an
error has occurred, which seems hacky, add a function to indicate this.
This changes the number 15 as used in boot_stage_progress() to use the
new name provided for it. This is a separate patch because it touches
so many files.
At present boot_stage_progress() is called with various magic numbers. The
new bootstage.h header will be used to turn these into symbolic names
throughout the code.
The intent is not that these numbers are passed to Linux. In fact by using
an enum to track them we should eventually be able to remove the explict
numbers and just have the stages count up from 0.
This patch clear and disable the data cache for vxWorks.
The entry point sysInit(int) intended by Windriver to be called from
the vxWorks bootrom, a very small vxWorks system.
The routine is called by the go() handler in the bootrom, that clears
the cache from start of image to end of usable memory.
The PowerPC implementations only invalidates and disable the cache,
the ARM implementations also flush it.
U-Boot will be on the safe side, if it disables the data cache before
calling vxWorks sysInit(int).
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
A few subsystems are using the same define "NAMESIZE". This has been
working so far because they define it to the same number. However, I
want to change the size of eth_device's NAMESIZE, so rather than tweak
the define names, simply drop references to it. Almost no one does,
and the handful that do can easily be changed to a sizeof().
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750.
As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3,
the device must be swapped.
* 'master' of git://git.denx.de/u-boot-avr32:
atmel_mci.h: remove outdated register macros
doc/git-mailrc: add <me> to avr32 alias
ATMEL: remove old atmel_mci driver
ATMEL: use generic mmc framework
* 'sandbox' of git://git.denx.de/u-boot-blackfin:
sandbox: mark os_exit as noreturn
sandbox: add getopt support
sandbox: allow processing before main loop
sandbox: add concept of sandbox state
sandbox: disable fortification
sandbox: u-boot.lds: tweak style
sandbox: add get_{tbclk,ticks}
sandbox: enable GPIO driver
sandbox: gpio: add basic driver for simulating GPIOs
sandbox: add flags for open() call
sandbox: config: enable fdt and snprintf() options
sandbox: fdt: add support for CONFIG_OF_CONTROL
sandbox: add lseek helper
sandbox: add ifdef protection to os.h
sandbox: add required header to os.c
sandbox: sort header files in os.c
* 'master' of git://git.denx.de/u-boot-sh:
sh: timer: Remove unnecessary variable 'ticks'
sh: Fix sh7264 clock speed and related serial setting
net: sh_eth: Remove unnecessary return
net: sh_eth: Collect up EDMR_INIT_CNT to TIMEOUT_CNT
net: sh_eth: Remove SH_ETH_PHY_DELAY
sh: ecovec: Add support PHY of SMSC
sh: sh_eth: Add support SH7724
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
New gen_atmel_mci driver does not use the outated register access macros. Since
the old atmel_mci driver is deleted these macros are no longer necessary.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
All boards are using the gen_atmel_mci driver now, so no need
to carry the old driver around.
Signed-off-by: Sven Schnelle <svens@stackframe.org>
gen_atmel_mci works on AVR32 as well, so no need to use the legacy
mmc driver. This also has the nice side effect of being able to use
SDHC cards an those boards.
