Related-to: TOR-2125
Signed-off-by: Rogerio Guerra Borin <rogerio.borin@toradex.com>
Bump git hashes as used in nightly build of Mon Jan 31 10:14:13 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 559
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/559
Signed-off-by: ci.toradex <cicd@toradex.com>
Related-to: TOR-2156
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
Related-to: TOR-2099
Bump git hashes as used in nightly build of Tue Jan 4 09:17:08 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 534
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/534
Related-to: TOR-2079
Bump git hashes as used in nightly build of Wed Dec 1 09:58:45 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 502
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/502
Bump git hashes as used in extint build of Sat Nov 27 12:50:08 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 60
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/60
Related-to: TOR-2040
Related-to: TOR-2061
Bump git hashes as used in nightly build of Tue Nov 2 13:38:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 470
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/470
Bump git hashes as used in nightly build of Fri Oct 1 11:28:21 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 141
Matrix Build Status: FAILURE
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/141
Bump git hashes as used in nightly build of Thu Sep 16 19:04:27 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 128
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/128
Change-Id: Ic5ba890ed9d5f1ebcbae087abdc50090906cffa7
Related-to: TOR-1965
Bump git hashes as used in nightly build of Tue Aug 31 00:11:14 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 408
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/408
Bump git hashes as used in extint build of Sat Aug 7 13:35:46 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 43
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/43
Bump git hashes as used in nightly build of Wed Aug 4 08:36:36 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 369
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/369
With amended hashes of due to the recipe git hash bumps in bsp-common, nxp, tegra layers.
Change-Id: I36655527635684a86cc0f5898d6543f612e01429
Bump git hashes as used in extint build of Tue Aug 3 12:33:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 65
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/65
Related-to: TOR-1902
Bump git hashes as used in nightly build of Wed Jun 30 02:40:46 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 338
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/338
Added use-head-next hash updates done on Wed Jun 30 2021.
Change-Id: I5477a15c465d89f7238917e9819f9e135afc434c
Include a fix for podman-compose build.
Related-to: TOR-1844
Bump git hashes as used in nightly build of Sat May 29 04:20:05 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 311
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/311
Change-Id: Iab89f8242187ef43c3a24160bc0d5a3eaef84e70
To support signed distros, we need bump meta-security to include a bunch
of IMA related fixes.
Related-to: TOR-1704
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Related-to: TOR-1754
Change-Id: If1451be3d5d0d6bea957dd050a6685a1b6c4c208
Related-to: TOR-1686
Related-to: TOR-1635
Bump git hashes as used in nightly build of Tue Feb 2 09:26:09 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 205
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/205
Bump git hashes as used in extint build of Sat Jan 30 14:52:47 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 32
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/32
Bump git hashes as used in extint build of Sat Dec 5 12:31:32 UTC 2020
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 24
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/24
Bump git hashes as used in nightly build of Wed Dec 30 21:42:42 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 176
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/176
Related-to: TOR-1523
Add remote alias to all manifests of torizoncore. This change is required
by the Toradex CI process. The ci srcrev bumping scripts expect the
remote being called "repo" in order to push to the remotes.
Signed-off-by: samuel.bissig <samuel.bissig@toradex.com>
Bump git hashes as used in nightly build of Mon Nov 30 03:26:32 UTC 2020
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 138
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/138
Change-Id: I2642b35a0a939dc93af5e96738c57dc85bc23e25
To involve in two fixes from meta-updater:
e5325ff5: ostree-kernel-initramfs: add back initramfs fit workaround
75518b1f: image_types_ostree: fix chmod
Also some CVE fixes from meta-security layer.
Related-to: TOR-1551
To involve in a following fix:
u-boot: drop u-boot.inc
The u-boot.inc file has been removed in meta-toradex-nxp dunfell then
we could remove it from here.
Now only the u-boot.inc file from OE would be used.
This fixes a issue that .cfg files were never applied when UBOOT_CONFIG
is set, which has been fixed in OE by commit 4fc38627:
[ u-boot: fix condition to allow use of *.cfg ]
or else the rollback is failing for apalis-imx6/colibri-imx6 machines.
Related-to: TOR-1519
Related-to: TOR-1461
Bump TorizonCore specific hashes for the 5.0.0-devel-202010 monthly
release.
Related-to: TOR-1359
The BSP created the dunfell-5.x.y branches at HEAD of current master.
Reflect that in the manifest.
While at it set the hashes to current HEAD for the BSP layers.
Related-to: ELB-2812
Change-Id: I251919cec7c1367d224b47b3f34abbc124deae31
HEAD of master is no longer compatible with the HEAD of the dunfell
branches of the other layers.
Fixes the ext integration test builds.
Change-Id: I0a59a44bde1b60e40fb5c75e9c3b2c4179f29bc4
To involve in the following commits from meta-updater dunfell:
bd0a055 sota: introduce OSTREE_MULTI_DEVICETREE_SUPPORT
79dc91f aktualizr: Upgrade to 2020.9 release.
ec3afd4 image_repo_manifest.bbclass: fix build when there is no repo on host
918dab0 image_repo_manifest.bbclass: explicitly call python3
2d882d6 Inherit python3native instead of using HOSTTOOLS.
a753c24 qemucommand: Restore custom booloader parameter.
Related-to: TOR-1370
Update external layers for 5.0.0-devel-202009 Monthly Release.
Related-to: TOR-1257
Change-Id: Ie645e6a49de93653110ec60ddf66572cc5c6c85a
To involve in some fixes from external layers, basically for:
meta-updater:
8371f4c aktualizr: Bump to latest and install headers in dev package.
3fec6c0 nfs-utils: don't add nfs-home-mount.service without sota enabled
50a0abd nfs-utils: fix nfs systemd daemons runtime issues
Related-to: TOR-1283
Related-to: TOR-1239
