Bump git hashes as used in nightly build of Mon Mar 28 08:20:32 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 611
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/611
Signed-off-by: ci.toradex <cicd@toradex.com>
Bump git hashes as used in nightly build of Tue Mar 1 10:08:20 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 288
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/288
Bump git hashes as used in nightly build of Mon Jan 31 10:14:13 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 559
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/559
Bump git hashes as used in nightly build of Tue Jan 4 16:29:29 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 235
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/235
Bump git hashes as used in nightly build of Tue Jan 4 09:17:08 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 534
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/534
Bump git hashes as used in nightly build of Wed Dec 1 09:58:45 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 502
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/502
Bump git hashes as used in nightly build of Tue Nov 2 13:38:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 470
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/470
Bump git hashes as used in nightly build of Fri Oct 1 11:28:21 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 141
Matrix Build Status: FAILURE
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/141
Change-Id: I3d18765296d850954d1406d8894244fc1469721c
Bump git hashes as used in nightly build of Thu Sep 16 19:04:27 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 128
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/128
Change-Id: Ic5ba890ed9d5f1ebcbae087abdc50090906cffa7
Related-to: ELB-4127
This commit moves the manifest for building tezi from internal
toradex-tezi-platform to toradex-manifest, so we can make use of the pinned
BSP hashes.
This commit updates the hashes from toradex-tezi-platform as follows:
meta-toradex-bsp-common
9f07b468d6cecb6fcda469866c305d37fb20f230 ->
276a8e076225332b336e41eb2c62375ddc6989bf
meta-toradex-nxp
91233079b4167fe0be7e1f37af67c261ef9afb78 ->
4a074b05bad21ac438a398bb036ec0e8da41513c
meta-toradex-tegra
f58026172d3c32a9c8026287370ae813d9f14fc5 ->
d4ef0a4584e04b14a6ba368b8cdf8592af43d3bb
meta-toradex-tezi
6a58e5cd2d5a84357686fe7c6b08e4033ca065dd ->
e1d825219d627b5ded55e347ca4e9d4c78e41673
hashes of integration.xml and next.xml are the same if any are present there.
