path: root/tester
2022-05-18tester: bump tester layerStefan Eichenberger
Reduce SD speed on Apalis iMX6 and fix linux-toradex-mainline build issues. Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2022-04-20tester: add layers for tester control imageStefan Eichenberger
Add the Yocto layers for the tester control image to the tester manifest. The tester control image is meant for the Apalis T30 based tester hardware.
2021-10-21tester: bump tester layer5.4.1Max Krummenacher
This adds the changes needed for Wi-Fi testing.
2021-10-20gitlab-ci: add the internal testerMax Krummenacher
