Bump git hashes as used in nightly build of Wed Dec 1 09:58:45 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 502
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/502
Signed-off-by: ci.toradex <cicd@toradex.com>
Bump git hashes as used in nightly build of Tue Nov 2 13:38:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 470
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/470
Bump git hashes as used in nightly build of Thu Sep 16 19:04:27 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 128
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/128
Change-Id: Ic5ba890ed9d5f1ebcbae087abdc50090906cffa7
Bump git hashes as used in nightly build of Tue Aug 31 00:11:14 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 408
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/408
Bump git hashes as used in nightly build of Wed Aug 4 08:36:36 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 369
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/369
With amended hashes of due to the recipe git hash bumps in bsp-common, nxp, tegra layers.
Change-Id: I36655527635684a86cc0f5898d6543f612e01429
Bump git hashes as used in nightly build of Wed Jun 30 02:40:46 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 338
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/338
Added use-head-next hash updates done on Wed Jun 30 2021.
Change-Id: I5477a15c465d89f7238917e9819f9e135afc434c
Bump git hashes as used in nightly build of Sat May 29 04:20:05 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 311
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/311
Change-Id: Iab89f8242187ef43c3a24160bc0d5a3eaef84e70
Change-Id: If1451be3d5d0d6bea957dd050a6685a1b6c4c208
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 257
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/257
Bump git hashes as used in extint build of Sat Mar 27 23:40:06 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 45
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/45
Plus update to latest openembedded-core.
Change-Id: Ieb14742a67dd4b4a1ae662cba1a2a4e55a8abcf4
Bump git hashes as used in nightly build of Tue Feb 2 09:26:09 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 205
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/205
Bump git hashes as used in nightly build of Wed Dec 30 21:42:42 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 176
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/176
Bump git hashes as used in nightly build of Tue Dec 1 04:22:34 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 145
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/145
Bump git hashes as used in nightly build of Mon Nov 30 03:26:32 UTC 2020
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 138
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/138
Change-Id: I2642b35a0a939dc93af5e96738c57dc85bc23e25
Bump git hashes as used in extint build of Sun Nov 29 04:53:03 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 26
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/26
Bumps all external and bsp layers.
This synchronizes the state of the linux-firmware packages which were upstreamed.
Change-Id: I4d7bb7c5339c307e362c73a2b110c37ce45049ee
Bump git hashes as used in extint build of Wed Nov 11
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 23
Change-Id: I91ef6364a624a61b4dab223dcd623de0f25bd45d
Related-to: ELB-3196
Prepare for BSP monthly 5.1.0-devel-202011.
Change-Id: I8f46322dfc7a157bd0bdb179ccb8a9cfc776ad88
With BSP updates in meta-freescale the pinned external layers against
latest meta-toradex-* became incompatible and did through build errors.
Change-Id: I5e8f951393460a4fd66327f133182717f2707ebb
The BSP created the dunfell-5.x.y branches at HEAD of current master.
Reflect that in the manifest.
While at it set the hashes to current HEAD for the BSP layers.
Related-to: ELB-2812
Change-Id: I251919cec7c1367d224b47b3f34abbc124deae31
Change-Id: Ie645e6a49de93653110ec60ddf66572cc5c6c85a
Related-to: TOR-1239
Signed-off-by: Ming Liu <ming.liu@toradex.com>
meta-qt5 layer got added and recipe names changed. Bump the hash
so builds are not failing due to missing bblayers.conf.
Related-to: ELB-2838
Change-Id: I431086ea9818e34cd51fee1c5bfdfe87ffa0c58f
This unifies and replaces the following manifests
starting from version 5.x.y:
http://git.toradex.com/toradex-bsp-platform.git
https://github.com/toradex/toradex-torizon-manifest.git
Related-to: ELB-2755
