Bump git hashes as used in nightly build of Tue May 31 19:16:25 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 371
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/371
Signed-off-by: ci.toradex <cicd@toradex.com>
Bump git hashes as used in extint build of Sun May 29 23:33:05 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 111
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/111
Bump git hashes as used in nightly build of Mon May 2 14:29:21 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 342
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/342
Bump git hashes as used in extint build of Sat Apr 30 12:16:13 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 107
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/107
Bump git hashes as used in nightly build of Mon Mar 28 15:26:38 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 612
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/612
Bump git hashes as used in nightly build of Mon Mar 28 08:20:32 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 611
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/611
Bump git hashes as used in nightly build of Tue Mar 1 10:08:20 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 288
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/288
Bump git hashes as used in extint build of Sat Feb 26 23:11:03 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 97
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/98
Bump git hashes as used in nightly build of Mon Jan 31 10:14:13 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 559
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/559
Bump git hashes as used in extint build of Sun Jan 23 04:40:38 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 93
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/93
Bump git hashes as used in nightly build of Tue Jan 4 09:17:08 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 534
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/534
Bump git hashes as used in nightly build of Wed Dec 1 09:58:45 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 502
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/502
Bump git hashes as used in extint build of Sat Nov 27 12:50:08 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 60
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/60
Bump openembedded-core/bitbake/meta-yocto and meta-toradex-bsp-common.
This prevents a clash of our update to linux-firmware vs. the backported
update in openembedded-core.
Bump git hashes as used in nightly build of Thu Nov 4 08:23:32 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 473
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/473
Bump git hashes as used in nightly build of Tue Nov 2 13:38:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 470
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/470
Bump git hashes as used in extint build of Sun Oct 24 07:28:22 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 78
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/78
Change-Id: I3d18765296d850954d1406d8894244fc1469721c
Bump git hashes as used in nightly build of Thu Sep 16 19:04:27 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 128
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/128
Change-Id: Ic5ba890ed9d5f1ebcbae087abdc50090906cffa7
The kernel RT patch got moved. Adjusts the path accordingly.
Change-Id: I523b36e966e12fcd11476d799ef35e110199b832
Bump git hashes as used in nightly build of Tue Aug 31 00:11:14 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 408
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/408
Bump git hashes as used in nightly build of Wed Aug 4 08:36:36 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 369
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/369
With amended hashes of due to the recipe git hash bumps in bsp-common, nxp, tegra layers.
Change-Id: I36655527635684a86cc0f5898d6543f612e01429
Bump git hashes as used in extint build of Tue Aug 3 12:33:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 65
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/65
Change-Id: I05fe149ff7f74ff7fc913aefa993e8d968196ac3
Bump git hashes as used in nightly build of Wed Jun 30 02:40:46 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 338
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/338
Added use-head-next hash updates done on Wed Jun 30 2021.
Change-Id: I5477a15c465d89f7238917e9819f9e135afc434c
Bump git hashes as used in nightly build of Sat May 29 04:20:05 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 311
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/311
Bump git hashes as used in extint build of Sat May 29 18:13:20 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 54
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/54
Change-Id: Iab89f8242187ef43c3a24160bc0d5a3eaef84e70
Change-Id: I583ee5a230232d8669d7d5b9c6fc9ad887d3cb15
Related-to: ELB-3931
Change-Id: Ib0db4810462c1076e821b83ba2b62d5b403e2a21
Change-Id: If1451be3d5d0d6bea957dd050a6685a1b6c4c208
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 257
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/257
Bump git hashes as used in extint build of Sat Mar 27 23:40:06 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 45
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/45
Plus update to latest openembedded-core.
Change-Id: Ieb14742a67dd4b4a1ae662cba1a2a4e55a8abcf4
Change-Id: I6293b5603bddce5cb11d6acee2209b37436e2c8f
Related-to: ELB-3342
Change-Id: I343d35c91cbb1b06c117fa1a374bd72735889492
Bump git hashes as used in extint build of Sun Feb 28 02:50:56 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 40
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/40
Bump git hashes as used in extint build of Mon Feb 22 19:46:35 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 39
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/39
Change-Id: I19cf1cc74884923529052bf17eb7e9dcbda438f0
Bump git hashes as used in nightly build of Tue Feb 2 09:26:09 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 205
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/205
Bump git hashes as used in extint build of Sat Jan 30 14:52:47 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 32
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/32
Bump git hashes as used in extint build of Sat Dec 5 12:31:32 UTC 2020
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 24
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/24
Bump git hashes as used in nightly build of Wed Dec 30 21:42:42 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 176
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/176
Change-Id: I1529a109566b350717ddc3012363793c5cae5839
Bump git hashes as used in nightly build of Tue Dec 1 04:22:34 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 145
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/145
Bump git hashes as used in nightly build of Mon Nov 30 03:26:32 UTC 2020
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 138
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/138
Change-Id: I2642b35a0a939dc93af5e96738c57dc85bc23e25
Bump git hashes as used in extint build of Sun Nov 29 04:53:03 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 26
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/26
Bumps all external and bsp layers.
This synchronizes the state of the linux-firmware packages which were upstreamed.
Change-Id: I4d7bb7c5339c307e362c73a2b110c37ce45049ee
Bump git hashes as used in extint build of Wed Nov 11
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 23
Change-Id: I91ef6364a624a61b4dab223dcd623de0f25bd45d
Related-to: ELB-3196
Prepare for BSP monthly 5.1.0-devel-202011.
Change-Id: I8f46322dfc7a157bd0bdb179ccb8a9cfc776ad88
With BSP updates in meta-freescale the pinned external layers against
latest meta-toradex-* became incompatible and did through build errors.
Change-Id: I5e8f951393460a4fd66327f133182717f2707ebb
This bump has only one change in it. It enforces the new tezi config
format that was made to make sure the right u-boot environment gets
written when installing this image.
This is necessary because older tezi releases do break u-boot
environment leading to non-booting BSP 5.0.0 images.
