Related-to: TOR-2219
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
Bump git hashes as used in nightly build of Tue May 31 19:16:25 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 371
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/371
Signed-off-by: ci.toradex <cicd@toradex.com>
Completes commit e7d2316 ("torizoncore: update external hashes")
Related-to: TOR-2213
Bump git hashes as used in extint build of Sun May 29 23:33:05 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 111
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/111
Reduce SD speed on Apalis iMX6 and fix linux-toradex-mainline build
issues.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Also move meta-updater to the Uptane space on GitHub.
Related-to: TOR-2217
Signed-off-by: Rogerio Guerra Borin <rogerio.borin@toradex.com>
Related-to: TOR-2247
TorizonCore does not use meta-lmp anymore, so let's remove it.
Bump git hashes as used in nightly build of Mon May 2 14:29:21 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 342
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/342
Bump git hashes as used in extint build of Sat Apr 30 12:16:13 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 107
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/107
Add the Yocto layers for the tester control image to the tester
manifest. The tester control image is meant for the Apalis T30 based
tester hardware.
Related-to: TOR-2151
Bump git hashes as used in nightly build of Mon Mar 28 15:26:38 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 612
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/612
Bump git hashes as used in nightly build of Mon Mar 28 08:20:32 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 611
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/611
Related-to: TOR-2150
Related-to: TOR-2160
Bump git hashes as used in nightly build of Tue Mar 1 10:08:20 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 288
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/288
Bump git hashes as used in extint build of Sat Feb 26 23:11:03 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 97
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/98
Related-to: TOR-2125
Bump git hashes as used in nightly build of Mon Jan 31 10:14:13 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 559
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/559
Bump git hashes as used in extint build of Sun Jan 23 04:40:38 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 93
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/93
Related-to: TOR-2156
Related-to: TOR-2099
Bump git hashes as used in nightly build of Tue Jan 4 16:29:29 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 235
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/235
Bump git hashes as used in nightly build of Tue Jan 4 09:17:08 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 534
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/534
Related-to: TOR-2079
Bump git hashes as used in nightly build of Wed Dec 1 09:58:45 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 502
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/502
Bump git hashes as used in extint build of Sat Nov 27 12:50:08 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 60
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/60
Related-to: TOR-2040
Bump openembedded-core/bitbake/meta-yocto and meta-toradex-bsp-common.
This prevents a clash of our update to linux-firmware vs. the backported
update in openembedded-core.
Bump git hashes as used in nightly build of Thu Nov 4 08:23:32 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 473
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/473
Related-to: TOR-2061
Bump git hashes as used in nightly build of Tue Nov 2 13:38:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 470
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/470
Bump git hashes as used in extint build of Sun Oct 24 07:28:22 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 78
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/78
This adds the changes needed for Wi-Fi testing.
- use one of our regular containers. (with a fixup for /usr/bin/python missing)
- keep the artefacts inside the checked out git repo
Bump git hashes as used in nightly build of Fri Oct 1 11:28:21 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 141
Matrix Build Status: FAILURE
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/141
Change-Id: I3d18765296d850954d1406d8894244fc1469721c
Bump git hashes as used in nightly build of Thu Sep 16 19:04:27 UTC 2021
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 128
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/128
Change-Id: Ic5ba890ed9d5f1ebcbae087abdc50090906cffa7
Related-to: ELB-4127
This commit moves the manifest for building tezi from internal
toradex-tezi-platform to toradex-manifest, so we can make use of the pinned
BSP hashes.
This commit updates the hashes from toradex-tezi-platform as follows:
9f07b468d6cecb6fcda469866c305d37fb20f230 ->
276a8e076225332b336e41eb2c62375ddc6989bf
meta-toradex-nxp
91233079b4167fe0be7e1f37af67c261ef9afb78 ->
4a074b05bad21ac438a398bb036ec0e8da41513c
meta-toradex-tegra
f58026172d3c32a9c8026287370ae813d9f14fc5 ->
d4ef0a4584e04b14a6ba368b8cdf8592af43d3bb
meta-toradex-tezi
6a58e5cd2d5a84357686fe7c6b08e4033ca065dd ->
e1d825219d627b5ded55e347ca4e9d4c78e41673
hashes of integration.xml and next.xml are the same if any are present there.
The kernel RT patch got moved. Adjusts the path accordingly.
Change-Id: I523b36e966e12fcd11476d799ef35e110199b832
Related-to: TOR-1965
Bump git hashes as used in nightly build of Tue Aug 31 00:11:14 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 408
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/408
Bump git hashes as used in extint build of Sat Aug 7 13:35:46 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-extint-matrix 43
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-extint-matrix/43
Bump git hashes as used in nightly build of Wed Aug 4 08:36:36 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 369
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/369
With amended hashes of due to the recipe git hash bumps in bsp-common, nxp, tegra layers.
Change-Id: I36655527635684a86cc0f5898d6543f612e01429
Bump git hashes as used in extint build of Tue Aug 3 12:33:39 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-extint-matrix 65
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-extint-matrix/65
