2017-01-12 | manifest: update to morty | Max Krummenacher | |
Change-Id: Iad1e866b68848cf373b9c483a86ebe77ea74e5ad Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-11-22 | manifest: update to latest jethroApalis_TK1_LinuxImageV2.6.1Beta2_20161122 | Max Krummenacher | |
Change-Id: I8129d4fc8c5b83948357ffd2aa656626ad4efd4b Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-10-01 | manifest: update to latest jethroColibri_iMX7_LinuxImageV2.6.1Beta1_20160929Colibri_iMX6_LinuxImageV2.6.1Beta1_20160929Colibri_VF_LinuxImageV2.6.1Beta1_20161001Colibri_T30_LinuxImageV2.6.1Beta1_20160929Colibri_T20_LinuxImageV2.6.1Beta1_20160929Apalis_iMX6_LinuxImageV2.6.1Beta1_20160929Apalis_TK1_LinuxImageV2.6.1Beta1_20160929Apalis_T30_LinuxImageV2.6.1Beta1_20160929 | Max Krummenacher | |
Change-Id: If915ef9bada09e173de7e1c2e0fe9dd24b865254 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-09-05 | default.xml: oe-layers: rename the parent directory from stuff to layers | Max Krummenacher | |
Have all oe meta data layers in a directory called layers rather than stuff Change-Id: Ibb4a383830c528de12c389aa6bbf70606dc637ae Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-08-26 | add the split meta-toradex-xxx layers | Max Krummenacher | |
Change-Id: I6acf15dd9fdb6f5cda897a5c57feb1943d7d69f5 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-07-01 | manifest: update to latest jethroColibri_iMX7_LinuxImageV2.6Beta2_20160701Colibri_iMX6_LinuxImageV2.6Beta2_20160701Colibri_VF_LinuxImageV2.6Beta2_20160701Colibri_T30_LinuxImageV2.6Beta2_20160701Colibri_T20_LinuxImageV2.6Beta2_20160701Apalis_iMX6_LinuxImageV2.6Beta2_20160701Apalis_TK1_LinuxImageV2.6Beta2_20160701Apalis_T30_LinuxImageV2.6Beta2_20160701 | Max Krummenacher | |
Change-Id: I29b04f65475befb8d2b6917ed025a390ed071c7c Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-03-31 | manifest: update to latest jethroColibri_iMX6_LinuxImageV2.6Beta1_20160331Colibri_VF_LinuxImageV2.6Beta1_20160331Colibri_T30_LinuxImageV2.6Beta1_20160331Colibri_T20_LinuxImageV2.6Beta1_20160331Apalis_iMX6_LinuxImageV2.6Beta1_20160331Apalis_T30_LinuxImageV2.6Beta1_20160331 | Max Krummenacher | |
Change-Id: I729f51ea709fc8e571f781cf5750f2cd4ce753fc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-03-15 | manifest: update to jethroColibri_iMX7_LinuxImageV2.6Alpha1_20160315 | Max Krummenacher | |
Change-Id: Iebb4a2f8ec462c06b2edd790fcba69565c999ee3 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-12 | default.xml: move oe URL to github | Max Krummenacher | |
http://www.openembedded.org/wiki/Mirrors Change-Id: Iee8b2d5d3a6b6b4e9f6c4a6b01cbfd331178c987 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-12 | default.xml: shorten project names | Max Krummenacher | |
Move common URL name parts from <project> to <remote> Change-Id: I8c4122e1cb8d043a947ce5de9e466f56575a90a1 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-12 | default.xml: set all remote names to repo | Max Krummenacher | |
this allows to fetch all git repos with one command. repo forall -c git fetch repo Change-Id: I74894fe5c6c438f1ceaa40b5683bcbc00f4ec6af Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-12-15 | manifest: update to latest fidoColibri_iMX6_LinuxImageV2.5Beta3_20151215Colibri_VF_LinuxImageV2.5Beta3_20151215Colibri_T30_LinuxImageV2.5Beta3_20151215Colibri_T20_LinuxImageV2.5Beta3_20151215Apalis_iMX6_LinuxImageV2.5Beta3_20151215Apalis_T30_LinuxImageV2.5Beta3_20151215LinuxImageV2.5 | Max Krummenacher | |
Change-Id: I6d6e103d0c869bcd27fddb16ac68413b40db6b1e Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-12-09 | manifest: update to latest fido | Max Krummenacher | |
Change-Id: Ibc371e2d2a45e445675c58e5dc6410517f0ab225 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-12-09 | README: updated available machines | Max Krummenacher | |
Change-Id: I4a91d2163544a0ca321e267009a136262a4e2167 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-11-12 | manifest: update to meta-toradex latest | Max Krummenacher | |
Fixes build error of glibc when building a non arm image or meta-toolchain based recipes. Change-Id: I8fbcd01c915fd6b08ec9e4de3426fe949a65af37 | |||
2015-11-06 | manifest: update to meta-toradex latestColibri_iMX6_LinuxImageV2.5Beta2_20151106Colibri_VF_LinuxImageV2.5Beta2_20151106Colibri_T30_LinuxImageV2.5Beta2_20151106Colibri_T20_LinuxImageV2.5Beta2_20151106Apalis_iMX6_LinuxImageV2.5Beta2_20151106Apalis_T30_LinuxImageV2.5Beta2_20151106 | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2015-11-05 | manifest: update meta-toradex to latest | Max Krummenacher | |
Change-Id: I65d4164d91e19584fa4f67174cfcf13300ef8169 | |||
2015-11-04 | manifest: update meta-toradex to latest | Marcel Ziswiler | |
2015-11-03 | manifest: update meta-toradex to latest | Marcel Ziswiler | |
2015-11-03 | manifest: update to latest fido | Marcel Ziswiler | |
2015-10-12 | meta-toradex: bump to scrot, giblib: add fedora download mirror | Max Krummenacher | |
Change-Id: Ia51d2fbe0c15627da11b765ecfb288ce83f983c0 | |||
2015-08-18 | manifest: update meta-toradex to latestColibri_VF_LinuxImageV2.5Beta1_20150813 | Marcel Ziswiler | |
2015-08-17 | manifest: update to latest fido | Marcel Ziswiler | |
2015-05-29 | manifest: update meta-toradex to latest | Stefan Agner | |
Fix mcc-kmod build and makes sure mkimage gets built to create the U-Boot update scripts. | |||
2015-05-18 | openembedded-core: update to HEAD of dizzyColibri_iMX6_LinuxImageV2.4Beta1_20150518Colibri_VF_LinuxImageV2.4Beta1_20150518Colibri_T30_LinuxImageV2.4Beta1_20150518Colibri_T20_LinuxImageV2.4Beta1_20150518Apalis_iMX6_LinuxImageV2.4Beta1_20150518Apalis_T30_LinuxImageV2.4Beta1_20150518 | Max Krummenacher | |
Change-Id: I67b1def412ce74828012244c3fa20d6ca15861ad | |||
2015-05-18 | manifest: use HEAD of dizzy branches | Max Krummenacher | |
Change-Id: I50faae547591edc5ebf2dc1d7907509495235cf4 | |||
2015-04-08 | manifest: update meta-toradex and fix branch name | Max Krummenacher | |
Change-Id: Id96c7deef8c8b6c5e433aac3b85898b0f0c8a93c | |||
2015-04-08 | manifest: add revisions for dizzy | Max Krummenacher | |
Change-Id: Ie323368ad1ec75d846c7b90990168c99c2455925 | |||
2015-03-19 | manifest: use HEAD of dizzy branches | Max Krummenacher | |
Change-Id: Ifb026d0d54f0ec88b9e405ea4e94233ce4b51298 | |||
2015-02-04 | manifest: update meta-toradex to latestColibri_VF_LinuxImageV2.3Beta7_20150203Colibri_T20_LinuxImageV2.3Beta7_20150203 | Stefan Agner | |
2015-01-20 | manifest: update meta-toradex to latest | Max Krummenacher | |
Change-Id: Ia56953caffde8e22e612334f58a5f30f2daf0ba6 | |||
2015-01-14 | manifest: update meta-toradex to latest | Max Krummenacher | |
Change-Id: I5b82c9b5e2652ea197d2a061b56a4980386ac7ce | |||
2015-01-13 | manifest: update meta-toradex to latestApalis_iMX6_LinuxImageV2.3Beta6_20150112 | Max Krummenacher | |
Change-Id: I57fda66d818a5b8213c67d556aa127601093a702 | |||
2014-12-19 | manifest: update meta-toradex to latestColibri_iMX6_LinuxImageV2.3Beta5_20141219Colibri_VF_LinuxImageV2.3Beta5_20141219Colibri_T30_LinuxImageV2.3Beta5_20141219Colibri_T20_LinuxImageV2.3Beta5_20141219Apalis_iMX6_LinuxImageV2.3Beta5_20141219Apalis_T30_LinuxImageV2.3Beta5_20141219 | Marcel Ziswiler | |
2014-12-18 | manifests: update all layers to latest | Marcel Ziswiler | |
2014-11-13 | manifest: update meta-toradexColibri_iMX6_LinuxImageV2.3Beta4_20141113 | Marcel Ziswiler | |
2014-10-31 | manifest: update meta-toradexColibri_VF_LinuxImageV2.3Beta3_20141031Colibri_T30_LinuxImageV2.3Beta3_20141031Colibri_T20_LinuxImageV2.3Beta3_20141031Apalis_iMX6_LinuxImageV2.3Beta3_20141031Apalis_T30_LinuxImageV2.3Beta3_20141031 | Max Krummenacher | |
Change-Id: I955efa9483501fbec7b6f290a06f811ad6981f4c | |||
2014-10-30 | manifest: meta-toradex: fix imx6 arch | Max Krummenacher | |
Change-Id: Ifcf2e10e21be697d2f2f9d456ff9ac516e7d6747 | |||
2014-10-30 | manifests: update all layers to latest | Max Krummenacher | |
Change-Id: Ibca32b530520d4701114b151df99d3087977d525 | |||
2014-10-06 | manifest: update meta-toradex, meta-angstrom to fix Qt5 builds | Max Krummenacher | |
Change-Id: Ib768775cad03ab30fa9767eb14a8185d680ddf5a | |||
2014-10-01 | manifest: update meta-lxde, obconf: add git mirror | Max Krummenacher | |
Change-Id: I6737fa6b90572f0e610d24967f3a93dd433cb053 | |||
2014-09-03 | manifest: update meta-toradex, Apalis T30 PCIe issuesApalis_T30_LinuxImageV2.3Beta2_20140903 | Max Krummenacher | |
Change-Id: I2d71fc77af370074cc3329523f8ff63cea24562d | |||
2014-09-03 | manifest: update meta-toradex, imlib2: use git | Max Krummenacher | |
Change-Id: I4e449c33dc00e8424b199a8cb5374986cf43bace | |||
2014-08-04 | manifest: update meta-toradexColibri_VF_LinuxImageV2.3Beta1_20140804Colibri_T30_LinuxImageV2.3Beta1_20140804Colibri_T20_LinuxImageV2.3Beta1_20140804Apalis_iMX6_LinuxImageV2.3Beta1_20140804Apalis_T30_LinuxImageV2.3Beta1_20140804 | Max Krummenacher | |
Change-Id: Idc73be976e97e43e09dc012ef07edcc86f42c718 | |||
2014-08-04 | manifest: update to use daisy branches | Max Krummenacher | |
Change-Id: Icfd6a7f904cd380227df2d8e1dbd8f07a0c78a52 | |||
2014-08-04 | README: add comment for generation of default.xml | Max Krummenacher | |
Change-Id: Idcebc033f1118967bd84f419eb16c6d0bf1fec54 | |||
2014-06-10 | manifest: update to dora branch commits used for VFxx V2.2 Beta 1Colibri_VF_LinuxImageV2.2Beta1_20140603LinuxImageV2.2 | Stefan Agner | |
Update all layers to latest dora branch commits which were used for Colibri VFxx V2.2 Beta 1 release. | |||
2014-05-26 | manifest: update meta-toradex | Marcel Ziswiler | |
Update meta-toradex with latest burnflash scripts. | |||
2014-05-24 | manifest: update meta-toradex | Marcel Ziswiler | |
Update meta-toradex with latest U-Boot and burnflash scripts. Update scripts now allow migrating existing Colibri VF50/VF61 modules to the new flash layout. | |||
2014-05-20 | manifest: update meta-lxde and meta-toradex | Marcel Ziswiler | |
Update meta-lxde as well as meta-toradex to make colibri-vf machine buildable again. Please be careful updating existing Colibri VF50/VF61 modules though as we changed the flash layout. Update script taking care of this is yet to be written and tested. |
