2016-08-17 | updated release notes | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-06-30 | i.MX 7: mention FreeRTOS issue in release notes | Stefan Agner | |
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-06-24 | i.MX 6: add gstreamer issue to release note | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-06-24 | Updated release notes. | Marcel Ziswiler | |
2016-03-30 | Colibri_iMX7: add initial release notes | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-14 | Apalis_iMX6_LinuxReleaseNotesV2.x.txt: document update_it bug | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2015-12-17 | Updated release notes.V2.5 | Marcel Ziswiler | |
2015-12-15 | Colibri iMX6: updated release notes | Max Krummenacher | |
2015-11-09 | Apalis/Colibri iMX6: updated release notes | Max Krummenacher | |
2015-11-06 | Updated release notes. | Marcel Ziswiler | |
2015-08-17 | colibri-vf: updated release notes | Marcel Ziswiler | |
2015-08-14 | colibri-vf: updated release notes | Marcel Ziswiler | |
2015-07-09 | updated release notes | Stefan Agner | |
Add USB mass storage mishap. | |||
2015-05-29 | Clean-up Colibri T20 release notes after recent pull/rename. | Marcel Ziswiler | |
2015-05-29 | Actually rename Colibri T20 release notes meant for BSP V2.3. | Marcel Ziswiler | |
2015-05-29 | Pulled in Colibri T20 release notes from V2.3-next branch applicable | Marcel Ziswiler | |
for V2.3 stable image. | |||
2015-05-29 | Rename Colibri T20 release notes now valid from BSP V2.4 onwards. | Marcel Ziswiler | |
2015-05-22 | updated release notes | Marcel Ziswiler | |
2015-05-19 | updated release notesColibri_iMX6_LinuxImageV2.4Beta1_20150518Colibri_VF_LinuxImageV2.4Beta1_20150518Colibri_T30_LinuxImageV2.4Beta1_20150518Colibri_T20_LinuxImageV2.4Beta1_20150518Apalis_iMX6_LinuxImageV2.4Beta1_20150518Apalis_T30_LinuxImageV2.4Beta1_20150518 | Marcel Ziswiler | |
2015-03-25 | Update release notes | Marcel Ziswiler | |
2015-02-12 | Update release notes | Marcel Ziswiler | |
2015-02-06 | Apalis/Colibri iMX6: Update release notes | Max Krummenacher | |
Add issue with getty also started on ttymxc1. | |||
2015-02-04 | Colibri VF50/VF61: Update release notes | Stefan Agner | |
2015-01-13 | Apalis iMX6: Update release notes for Beta6Apalis_iMX6_LinuxImageV2.3Beta6_20150112 | Max Krummenacher | |
2015-01-09 | Apalis iMX6: Update release notes | Max Krummenacher | |
2014-12-19 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-12-08 | Colibri iMX6: Update release notes | Max Krummenacher | |
Add update of single component U-Boot/Kernel/FDT Remove unavailable interfaces from the list of notworking Add correct git tag | |||
2014-12-08 | Release Notes: fix changed URL | Max Krummenacher | |
While at it remove supperseeded release note | |||
2014-12-08 | Colibri iMX6/T30: Add/Update release notes | Max Krummenacher | |
Add inital release notes for Colibri iMX6 Fix Colibri T30, EvalBoard MMC connector designator | |||
2014-12-08 | Apalis/Colibri T30: Update release notes | Max Krummenacher | |
Workaround for resize script | |||
2014-11-13 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-11-05 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-11-03 | Apalis/Colibri T30: Fixed release notes | Marcel Ziswiler | |
Got the U-Boot stuff mixed up. | |||
2014-11-03 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesColibri_VF_LinuxImageV2.3Beta3_20141031Colibri_T30_LinuxImageV2.3Beta3_20141031Colibri_T20_LinuxImageV2.3Beta3_20141031Apalis_iMX6_LinuxImageV2.3Beta3_20141031Apalis_T30_LinuxImageV2.3Beta3_20141031 | Marcel Ziswiler | |
2014-10-06 | apalis-imx6: Release notes: update from V2.2 on Ixora | Max Krummenacher | |
Conflicts: release-notes/Apalis_iMX6_LinuxReleaseNotesV2.x.txt | |||
2014-09-14 | apalis/colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-09-04 | Apalis T30: Update release notes | Marcel Ziswiler | |
2014-09-02 | apalis-imx6: Release notes: add notes for PCIe config | Max Krummenacher | |
2014-09-02 | apalis-imx6: Release notes: add saveenv to env update | Max Krummenacher | |
2014-09-02 | apalis-imx6: Release notes: Use webfriendly " char | Max Krummenacher | |
2014-08-05 | apalis/colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-06-12 | release notes: extend Colibri VF UART recovery notes | Stefan Agner | |
Add hint for non-fused modules, document recovery mode on Iris. | |||
2014-06-10 | release notes: update Colibri VF release notes | Stefan Agner | |
Update Colibri VFxx release notes to reflect latest release V2.2 Beta 1. | |||
2014-04-08 | Added note about Apalis iMX6 SSH password authentication being | Marcel Ziswiler | |
disabled by default. While at it line wrapped Apalis T30 release notes document. | |||
2014-04-04 | Apalis_iMX6: add initial rlease notesApalis_iMX6_LinuxImageV2.2Beta1_20140404 | Max Krummenacher | |
2014-03-20 | release notes: Colibri VF: add boot hang issue | Stefan Agner | |
Add boot hang issue to known bugs. | |||
2014-03-18 | release notes: apalis/colibri t20/t30 colibri vf v2.1 beta 3Colibri_VF_LinuxImageV2.1Beta3_20140318Colibri_T30_LinuxImageV2.1Beta3_20140318Colibri_T20_LinuxImageV2.1Beta3_20140318Apalis_T30_LinuxImageV2.1Beta3_20140318 | Max Krummenacher | |
2014-03-06 | release notes: vybrid beta 2 release notes | Stefan Agner | |
2014-02-13 | release notes: apalis t30 | Marcel Ziswiler | |
Add a note concerning suspend LP1 being untested resp. it currently failing due to igb/PCIe issues. | |||
2014-02-10 | release notes: apalis/colibri t20/t30 v2.1 beta 2 | Marcel Ziswiler | |
