2015-11-04 | libusbg: enable USB Gadgets after Connman to avoid interference | Stefan Agner | |
It seems that Connman disables ALL interfaces on startup, even if they are listed in NetworkInterfaceBlacklist. This leads to the following situation: networkd starts... usb0 gets created... networkd sets the device up (event triggered) connman starts... and sets the device down! networkd does not restart the device in this situation. To avoid the situation, create the USB Gadget functions after connman. It seems that if connman is up and running, it does not touch the device anymore. | |||
2015-05-12 | libusbg: add updated version of USB gadget library | Stefan Agner | |
Add updated version of USB gadget library. Also add a systemd start- script which loads the default schema located at /etc/usbg/g1.schema. |
