2014-08-04 | colibri-vf: update kernel to latest, port recipe for use with daisy | Max Krummenacher | |
2014-08-04 | linux-toradex-fsl: remove linux-toradex-fsl.inc usage | Max Krummenacher | |
2014-08-04 | mcc/m4: use recipes from meta-fsl-arm | Max Krummenacher | |
deleted: recipes-bsp/libmcc/libmcc_1.04.bb deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb | |||
2014-05-20 | colibri-vf: switch back to latest git on colibri_vf branch | Marcel Ziswiler | |
This commit switches Colibri VF machine back to use the colibri_vf branch and use the latest Linux kernel. | |||
2014-05-07 | linux-toradex: rename linux.inc to avoid layer order dependency | Stefan Agner | |
The include files (such as linux.inc) are not resolved by priority but on layer order instead. This can lead to build errors in case the layers in BBLAYERS are ordered differently. | |||
2014-04-30 | colibri-vf: switch to U-Boot 2014.04 and latest git | Stefan Agner | |
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location. | |||
2014-04-05 | linux-toradex-fsl_git: fix parsing | Max Krummenacher | |
Make the bitbake parser not fail when this recipe is parsed for a machine for which this recipe is not a COMPATIBLE_MACHINE. | |||
2014-04-03 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-02 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-01 | kernel: add Apalis iMX6 and Colibri VF recipe | Max Krummenacher | |
2014-04-01 | colibri-vf: use meta-fsl* layer for BSP files | Max Krummenacher | |
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra | |||
2014-03-18 | kernel vybrid: update to latest | Max Krummenacher | |
2014-03-18 | kernel Txx: update to latest | Max Krummenacher | |
2014-03-17 | kernel/u-boot: update to latest git revision | Stefan Agner | |
2014-03-17 | vybrid: backport Cortex-M utilites from meta-fsl | Stefan Agner | |
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core | |||
2014-02-10 | kernel/u-boot: update to latest gitColibri_T30_LinuxImageV2.1Beta2_20140206Colibri_T20_LinuxImageV2.1Beta2_20140207Apalis_T30_LinuxImageV2.1Beta2_20140206 | Stefan Agner | |
2013-12-02 | kernel: update to latest git | Max Krummenacher | |
2013-11-21 | kernel: colibri-vf: use the unified kernel 50/60 | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-11-05 | Use double-quotes to make script work using dash (debian/ubuntu default) | Stefan Agner | |
2013-10-23 | linux: update to latest git versions | Max Krummenacher | |
2013-10-16 | kernel: update to latest git revision | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-07 | kernel: fix hash for colibri-t30 | Max Krummenacher | |
2013-09-22 | kernel: update to latest in git | Max Krummenacher | |
2013-09-22 | linux-firmware_git: remove bbappend, recipe now more granular | Max Krummenacher | |
2013-09-22 | kernel: hack, CFLAGS should not require contradicting soft and hard float | Max Krummenacher | |
2013-08-19 | kernel: update to latest git version | Max Krummenacher | |
2013-06-26 | kernel: update to latest git revision for T30 kernelsT30_LinuxImageV2.0Beta2_20130626Apalis_T30_LinuxImageV2.0Beta1_20130626 | Max Krummenacher | |
2013-06-26 | kernel: update to latest git revision for T30 kernels | Max Krummenacher | |
2013-05-01 | kernel: change pxa git version | Max Krummenacher | |
2013-03-20 | kernel: update to latest apalis kernel | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-03-04 | T30 kernel: next image will be beta1 | Max Krummenacher | |
2013-03-04 | kernel: update Apalis kernel, comments to full-hd & camera config | Max Krummenacher | |
2013-03-04 | full-hd.patch: fixup patch to work with latest resolution array | Max Krummenacher | |
2013-02-06 | kernel: example patch to change to Full HD resolution | Max Krummenacher | |
- patch not added to recipe, so default remains VGA resolution - changes colibri-t20, colibri-t30, apalis-t30 | |||
2013-01-29 | kernel: update to latest git | Max Krummenacher | |
2013-01-29 | kernel: unified the recipes for all toradex kernels | Max Krummenacher | |
2013-01-22 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-12-18 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-07 | kernel: remove all fiddeling with the defconfig, compile the kernel as it is ↵ | Max Krummenacher | |
in git | |||
2012-11-19 | linux-firmware: split the Ralink firmware into its own package | Max Krummenacher | |
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-10-18 | kernel: use latest from git | Max Krummenacher | |
2012-10-18 | update to latest colibri kernel | Max Krummenacher | |
2012-10-18 | kernel tools breaks the build | Max Krummenacher | |
2012-10-18 | merge with L4T R16 kernel | Max Krummenacher | |
